Language: C#
Subject: 3D Analyst Data
Contributor: ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization: Esri, http://www.esri.com
Date: 4/30/2026
ArcGIS Pro: 3.7
Visual Studio: 2026
TIN
Open a TIN Dataset
//Note: This snippet requires to be run on the MCT (Main CIM Thread)
string path = @"d:\Data\Tin";
var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.Tin);
using (FileSystemDatastore dataStore = new FileSystemDatastore(fileConnection))
// TIN is in a folder at d:\Data\Tin\TinDataset
string dsName = "TinDataset";
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(dsName))
//Do something with the dataset
Get a TIN Defintion
using (var def = dataStore.GetDefinition<ArcGIS.Core.Data.Analyst3D.TinDatasetDefinition>(dsName))
//Do something with the definition
Get Super Node Extent
var superNodeExtent = tinDataset.GetSuperNodeExtent();
Get Data Area
var dataArea = tinDataset.GetDataArea();
Element Counts
var nodeCount = tinDataset.GetNodeCount();
var outsideNodeCount = tinDataset.GetOutsideNodeCount();
var edgeCount = tinDataset.GetEdgeCount();
var outsideEdgecount = tinDataset.GetOutsideEdgeCount();
var triCount = tinDataset.GetTriangleCount();
var outsideTriCount = tinDataset.GetOutsideTriangleCount();
Tin Properties
var isEmpty = tinDataset.GetIsEmpty();
var hasHardEdges = tinDataset.HasHardEdges();
var hasSoftEdges = tinDataset.HasSoftEdges();
var isConstrainedDelaunay = tinDataset.UsesConstrainedDelaunay();
Access TIN Elements By Index
using (ArcGIS.Core.Data.Analyst3D.TinNode nodeFromIndex = tinDataset.GetNodeByIndex(23))
//Do something with the node
using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeFromIndex = tinDataset.GetEdgeByIndex(45))
//Do something with the edge
using (ArcGIS.Core.Data.Analyst3D.TinTriangle triangleFromIndex = tinDataset.GetTriangleByIndex(22))
//Do something with the triangle
Search for TIN Nodes
// search all nodes that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorsearch = tinDataset.SearchNodes(null))
while (nodeCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinNode nodeCurrent = nodeCursor.Current)
// do something with the node
// search within an extent
ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
nodeFilter.FilterEnvelope = envelope; //or use any other appropriate envelope
using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursorSearch = tinDataset.SearchNodes(nodeFilter))
// search all "inside" nodes
nodeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
// search for super nodes only
nodeFilter.FilterEnvelope = tinDataset.GetSuperNodeExtent();
nodeFilter.SuperNode = true;
Search for TIN Edges
// search all single edges that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(null))
while (edgeCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinEdge edgeCurrent = edgeCursor.Current)
// do something with the edge
ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
edgeFilter.FilterEnvelope = envelope;
using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinDataset.SearchEdges(edgeFilter))
// search all "inside" edges
edgeFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
// search for hard edges
edgeFilter.FilterByEdgeType = true;
edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
Search for TIN Triangles
// search all triangles that intersect the data extent
using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(null))
while (triangleCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.TinTriangle triangleCurrent = triangleCursor.Current)
ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
triangleFilter.FilterEnvelope = envelope;
using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleSearchCursor = tinDataset.SearchTriangles(triangleFilter))
// search all "inside" triangles
triangleFilter.FilterType = ArcGIS.Core.Data.Analyst3D.TinFilterType.InsideDataArea;
Access TIN Elements by MapPoint
// "identify" the closest node, edge, triangle
using (var nearestNode = tinDataset.GetNearestNode(mapPoint))
using (var nearestEdge = tinDataset.GetNearestEdge(mapPoint))
using (var triangleByPoint = tinDataset.GetTriangleByPoint(mapPoint))
// do something with the triangle
// get the set of natural neighbors
// (set of nodes that "mapPoint" would connect with to form triangles if it was added to the TIN)
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> naturalNeighbors = tinDataset.GetNaturalNeighbors(mapPoint);
// get the set of triangles whose circumscribed circle contains "mapPoint"
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = tinDataset.GetTriangleNeighborhood(mapPoint);
TIN Nodes
// is the node "inside"
var isInsideNode = node.IsInsideDataArea;
// get all other nodes connected to "node"
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinNode> adjNodes = node.GetAdjacentNodes();
// get all edges that share "node" as a from node.
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinEdge> edges = node.GetIncidentEdges();
// get all triangles that share "node"
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TinTriangle> triangles = node.GetIncidentTriangles();
TIN Edges
// nodes of the edge
var nodes = edge.Nodes;
// edge geometry
polyline = edge.ToPolyline();
// edge length
var length = edge.Length;
// is the edge "inside"
var isInsideEdge = edge.IsInsideDataArea;
// edge type - regular/hard/soft
var edgeType = edge.EdgeType;
// get next (clockwise) edge in the triangle
var nextEdge = edge.GetNextEdgeInTriangle();
// get previous (anti-clockwise) edge in the triangle
var prevEdge = edge.GetPreviousEdgeInTriangle();
// get opposite edge
var oppEdge = edge.GetNeighbor();
// get left triangle
var leftTriangle = edge.LeftTriangle;
// get right triangle
var rightTriangle = edge.RightTriangle;
TIN Triangles
// nodes, edges of the triangle
var triNnodes = triangle.Nodes;
var triEdges = triangle.Edges;
// triangle geometry
polygon = triangle.ToPolygon();
// triangle length
var triLength = triangle.Length;
// triangle area
var triArea = triangle.Area;
// is the triangle "inside"
var isInsideTriangle = triangle.IsInsideDataArea;
// triangle aspect and slope (radians)
var aspect = triangle.Aspect;
var slope = triangle.Slope;
// get centroid
var centroid = triangle.GetCentroid();
// get normal
var normal = triangle.GetNormal();
// get adjacent triangles
var adjTriangles = triangle.GetAdjacentTriangles();
// get area of triangle that falls between the z values
double minZ = 1.0;
double maxZ = 3.0;
IReadOnlyList<Coordinate3D> coords = triangle.GetPointsBetweenZs(minZ, maxZ);
var fields = featureClass.GetDefinition().GetFields();
// Use the z-values from the geometries as the height field
ArcGIS.Core.Data.Field heightField = fields.First(f => f.FieldType == FieldType.Geometry);
// Set the vertices from the geometries as TIN nodes
TinEditor tinEditorFromFC = TinEditor.CreateFromFeatureClass(featureClass, null, heightField, null, TinSurfaceType.MassPoint);
bool isInEditMode = tinEditorFromFC.IsInEditMode; // isInEditMode = true
// Use the object ids as tag values
ArcGIS.Core.Data.Field tagField = fields.First(f => f.FieldType == FieldType.OID);
// Set the lines from the geometries as TIN edges
var tinEditorFromFCEdges = TinEditor.CreateFromFeatureClass(featureClass, null, heightField, tagField, TinSurfaceType.HardLine);
isInEditMode = tinEditorFromFCEdges.IsInEditMode; // isInEditMode = true
// Only use certain geometries in the TIN
ArcGIS.Core.Data.QueryFilter filter = new ArcGIS.Core.Data.QueryFilter()
ObjectIDs = new List<long> { 2, 6, 7, 8, 9, 10, 14, 17, 21, 22 }
tinEditor = TinEditor.CreateFromFeatureClass(featureClass, filter, heightField, tagField, TinSurfaceType.HardLine);
isInEditMode = tinEditor.IsInEditMode; // isInEditMode = true
Add geometries from feature class
//Get TinEditor in various ways as shown above before using it here
tinEditor.AddFromFeatureClass(featureClass, null, heightField, null, TinSurfaceType.MassPoint);
tinEditor.AddFromFeatureClass(featureClass, null, heightField, tagField, TinSurfaceType.HardLine);
QueryFilter filter = new QueryFilter()
tinEditor.AddFromFeatureClass(featureClass, filter, heightField, tagField, TinSurfaceType.HardLine);
Add a geometry
// Add a point as a node with no tag value at height = 10. Points and multipoints can only be added as mass points.
tinEditor.AddGeometry(mapPoint, TinSurfaceType.MassPoint, 0, 10);
// Add a z-aware multipoint as a nodes with tag value = 12 at height equal to the z-values of the points. Points and multipoints can only be added as mass points.
tinEditor.AddGeometryZ(multipointZ, TinSurfaceType.MassPoint, 12);
// Add a polyline as hard lines with tag value = 42 and height = 17.
tinEditor.AddGeometry(polyline, TinSurfaceType.HardLine, 42, 17);
// Add a z-aware polygon as an erase polygon with no tag value and height equal to the z-values of the vertices.
Polygon polygonZ = PolygonBuilderEx.CreatePolygon(pointsForPolygon); //Define a z-aware polygon
tinEditor.AddGeometryZ(polygonZ, TinSurfaceType.HardErase, 0);
Add mass points
// Add points with no tag value and height = 17.
// The points have the same spatial reference as the tin editor, so there is no need to provide it.
tinEditor.AddMassPoints(points, 0, 17);
Coordinate3D[] coordinate3Ds = new Coordinate3D[] //Define some coordinates
new Coordinate3D(0,0,5),
new Coordinate3D(1,1,6),
new Coordinate3D(2,1,7)
// Add coordinates as nodes with tag value = 42. The height will come from the z-values of the coordinates.
tinEditor.AddMassPointsZ(coordinate3Ds, 42);
// Add z-aware points with tag value = 21. The height will come from the z-values of the points.
// The points are in a different spatial reference than the tin editor, so we provide the spatial
// reference of the points. The points will be projected to the spatial reference of the tin editor.
tinEditor.AddMassPointsZ(pointsZ, 21, SpatialReferenceBuilder.CreateSpatialReference(54004));
Add z-aware point
// Add a z-aware point with tag value = 56
tinEditor.AddPointZ(pointZ, 56);
Add polygons
// Add polygons with tagValue = 42 and height = 12.
// The polygons are in a different spatial reference than the tin editor, so we provide the spatial
// reference of the polygons. The polygons will be projected to the spatial reference of the tin editor.
Polygon[] polygons = new Polygon[] //Define some polygons
PolygonBuilderEx.CreatePolygon(new List<Coordinate2D>
new Coordinate2D(0,0),
new Coordinate2D(20,20),
tinEditor.AddPolygons(polygons, TinSurfaceType.ZLessSoftLine, 42, 12, SpatialReferenceBuilder.CreateSpatialReference(54004));
// Add z-aware polygons with no tag value. The height comes from the z-values of the vertices.
// The polygons are in the same spatial reference as the tin editor, so there is no need to provide it.
Polygon[] polygonsZ = new Polygon[] //Define some z-aware polygons
PolygonBuilderEx.CreatePolygon(new List<Coordinate3D>
new Coordinate3D(20,20,15),
tinEditor.AddPolygonsZ(polygonsZ, TinSurfaceType.HardLine, 0);
Add polylines
// Add polylines with tagValue = 42 and height = 12.
// The polylines are in a different spatial reference than the tin editor, so we provide the spatial
// reference of the polylines. The polylines will be projected to the spatial reference of the tin editor.
Polyline[] polylines = new Polyline[] //Define some polylines
PolylineBuilderEx.CreatePolyline(new List<Coordinate2D>
tinEditor.AddPolylines(polylines, TinSurfaceType.ZLessSoftLine, 42, 12, SpatialReferenceBuilder.CreateSpatialReference(54004));
// Add z-aware polylines with no tag value. The height comes from the z-values of the vertices.
// The polylines are in the same spatial reference as the tin editor, so there is no need to provide it.
Polyline[] polylinesZ = new Polyline[] //Define some z-aware polylines
PolylineBuilderEx.CreatePolyline(new List<Coordinate3D>
tinEditor.AddPolylinesZ(polylinesZ, TinSurfaceType.HardLine, 0);
Delete tag values
// Delete all edge tags
tinEditor.DeleteEdgeTagValues();
// Delete all node tags
tinEditor.DeleteNodeTagValues();
// Delete all triangle tags
tinEditor.DeleteTriangleTagValues();
Set tag values
// Set the tag value for edge #6
tinEditor.SetEdgeTagValue(6, 42);
// Set the tag value for node #8
tinEditor.SetNodeTagValue(8, 93);
// Set the tag value for triangle #9
tinEditor.SetTriangleTagValue(9, 17);
Delete node
// Delete node by index
tinEditor.DeleteNode(7);
// Node indices start at 1.
try
tinEditor.DeleteNode(0);
catch (ArgumentException)
// Handle the exception
// Can't delete a super node (indices 1 - 4)
try
tinEditor.DeleteNode(2);
catch (TinException)
Delete nodes outside of data area
// Delete all data nodes that are outside the data area. Does not delete super nodes.
tinEditor.DeleteNodesOutsideDataArea();
Set edge type
// Set the type of edge #8
tinEditor.SetEdgeType(8, TinEdgeType.SoftEdge);
Set z-value of a node
// Set the z-value of node #10
tinEditor.SetNodeZ(10, 12.5);
Set the spatial reference
// Set the spatial reference
tinEditor.SetSpatialReference(SpatialReferenceBuilder.CreateSpatialReference(54004));
Set to constrained Delaunay
// Set the triangulation method to constrained Delaunay from this point forward
tinEditor.SetToConstrainedDelaunay();
Set triangle in/out of data area
// Set triangle #7 to be inside the data area
tinEditor.SetTriangleInsideDataArea(7);
// Set triangle #9 to be outside the data area
tinEditor.SetTriangleInsideDataArea(9);
Create a new TIN and save edits
// Create a new TIN
tinEditor = new TinEditor(MapView.Active.Extent); // or use any envelope
tinEditor.AddMassPoints(points, 42, 13.7);
// Since the TIN doesn't exist on disk, you can't call SaveEdits.
// You must call SaveAs first.
try
tinEditor.SaveEdits();
// Since the TIN doesn't exist on disk, you can't call StopEditing(true).
try
tinEditor.StopEditing(true);
// Now save the newly created TIN to disk
tinEditor.SaveAs("C:\\Tin1", false);
// Delete a node
// Since the TIN now exists on disk you can call SaveEdits
// Delete another node
tinEditor.DeleteNode(11);
// Since the TIN now exists on disk, you can call StopEditing(true).
// The edits will be saved and the tin editor will be taken out of edit mode.
bool isInEditMode = tinEditor.IsInEditMode; // isInEditMode = false
// Now if you try to make an edit, an exception is thrown because the editor is not in edit mode.
try
tinEditor.AddPointZ(pointZ, 0);
// Put the editor into edit mode.
tinEditor.StartEditing();
// Now you can add the point
// Oops, you didn't really want to add the point. You want to stop editing and discard the unsaved edits
// since the last time the editor was put into edit mode. All previous saved edits remain.
tinEditor.StopEditing(false);
Edit an existing TIN
string tinPath = "C:\\Tin"; //original TIN path
// Create an instance of TinEditor from an existing TinDataset
tinEditor = new TinEditor(tinDataset);
int numNodes = tinDataset.GetNodeCount(); // numNodes = 10
tinEditor.AddPointZ(pointZ, 7);
// Calling SaveEdits modifies the existing TIN
numNodes = tinDataset.GetNodeCount(); // numNodes = 11
// Adding twenty points
tinEditor.AddMassPoints(points, 10, 112.5);
// Calling SaveAs creates a new TIN on disk, and
// the tin editor points to the new TIN.
string tinPath2 = "C:\\Tin2";
tinEditor.SaveAs(tinPath2, true);
var connection = new FileSystemConnectionPath(new Uri(Path.GetDirectoryName(tinPath2)), FileSystemDatastoreType.Tin);
using (FileSystemDatastore dataStore = new FileSystemDatastore(connection))
// See https://github.com/esri/arcgis-pro-sdk/wiki/ProConcepts-3D-Analyst-Data#working-with-tin-data
TinDataset tinDataset2 = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(Path.GetFileName(tinPath2));
numNodes = tinDataset2.GetNodeCount(); // numNodes = 31
// The edits still show up in the original TIN while it is in memory, but if you open it
// again you will see that it only has the edits that were saved before SaveAs was called.
numNodes = tinDataset.GetNodeCount(); // numNodes = 31
var connection2 = new FileSystemConnectionPath(new Uri(Path.GetDirectoryName(tinPath)), FileSystemDatastoreType.Tin);
tinDataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.TinDataset>(Path.GetFileName(tinPath));
Terrain
Open a Terrain
//Note: Use QueuedTask.Run to run on the MCT
string path = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb";
var fileConnection = new FileGeodatabaseConnectionPath(new Uri(path));
using (Geodatabase dataStore = new Geodatabase(fileConnection))
string dsName = "nameOfTerrain";
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.Terrain>(dsName))
Get a Terrain Definition
using (var terrainDefinition = dataStore.GetDefinition<ArcGIS.Core.Data.Analyst3D.TerrainDefinition>(dsName))
// get the feature class names that are used in the terrain
var fcNames = terrainDefinition.GetFeatureClassNames();
Get datasources from a Terrain
var dsCount = terrainDataset.GetDataSourceCount();
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TerrainDataSource> dataSources = terrainDataset.GetDataSources();
foreach (var ds in dataSources)
var dsName = ds.DataSourceName;
var surfaceType = ds.SurfaceType;
var maxResolution = ds.MaximumResolution;
var minResolution = ds.MinimumResolution;
Get Pyramid Level Information from a Terrain
var levelCount = terrainDataset.GetPyramidLevelCount();
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.TerrainPyramidLevel> pyramidLevels = terrainDataset.GetPyramidLevels();
foreach (var pyramidLevel in pyramidLevels)
var resolution = pyramidLevel.Resolution;
var maxScale = pyramidLevel.MaximumScale;
Get Tile Information from a Terrain
var tileInfo = terrainDataset.GetTileProperties();
var colCount = tileInfo.ColumnCount;
var rowCount = tileInfo.RowCount;
var tileSize = tileInfo.TileSize;
var tileCount = tileInfo.TileCount;
Get Pyramid Information from a TerrainDefinition
var pyramidType = terrainDef.GetPyramidType();
var pyramidProps = terrainDef.GetPyramidWindowSizeProperties();
var method = pyramidProps.Method;
var threshold = pyramidProps.ZThreshold;
var strategy = pyramidProps.ZThresholdStrategy;
LAS Dataset
Open a LAS Dataset
string path = @"d:\Data\LASDataset";
var fileConnection = new FileSystemConnectionPath(new Uri(path), FileSystemDatastoreType.LasDataset);
string name = "utrecht_tile.lasd"; // can specify with or without the .lasd extension
using (var dataset = dataStore.OpenDataset<ArcGIS.Core.Data.Analyst3D.LasDataset>(name))
Get a LAS Dataset Defintion
using (var dataset = dataStore.GetDefinition<ArcGIS.Core.Data.Analyst3D.LasDatasetDefinition>(name))
//Use the dataset
Get Individual File Information from a LAS Dataset
var (lasFileCount, zLasFileCount) = lasDataset.GetFileCounts();
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.LasFile> fileInfo = lasDataset.GetFiles();
foreach (var file in fileInfo)
var pathFile = file.FilePath;
var name = file.FileName;
var ptCount = file.PointCount;
var zMin = file.ZMin;
var zMax = file.ZMax;
Get Surface Constraint information from a LAS Dataset
var constraintCount = lasDataset.GetSurfaceConstraintCount();
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.SurfaceConstraint> constraints = lasDataset.GetSurfaceConstraints();
foreach (var constraint in constraints)
var dsName = constraint.DataSourceName;
var wksPath = constraint.WorkspacePath;
var heightField = constraint.HeightField;
var surfaceType = constraint.SurfaceType;
Get classification codes / Returns from a LAS Dataset
var classCodes = lasDataset.GetUniqueClassCodes();
var returns = lasDataset.GetUniqueReturns();
Access LAS Points by ID
// access by ID
IReadOnlyList<ArcGIS.Core.Data.Analyst3D.LasPoint> pts = lasDataset.GetPointByID(123456);
pts = lasDataset.GetPointByID(123456, envelope);
ArcGIS.Core.Data.Analyst3D.LasPoint pt = pts.FirstOrDefault();
var coordsLasPoint = pt.Coordinate3D;
var mapPointLas = pt.ToMapPoint();
Search LAS Points
ArcGIS.Core.Data.Analyst3D.LasPointFilter pointFilter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
pointFilter.FilterGeometry = envelope;
using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(pointFilter))
while (ptCursor.MoveNext())
using (ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current)
// search within an extent and limited to specific classification codes
pointFilter.ClassCodes = new List<int> { 4, 5 };
Search using pre initialized arrays
// search all points
using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(null))
int count;
Coordinate3D[] lasPointsRetrieved = new Coordinate3D[10000];
while (ptCursor.MoveNextArray(lasPointsRetrieved, null, null, null, out count))
var pointsLas = lasPointsRetrieved.ToList();
// use MoveNextArray retrieving coordinates, fileIndex and pointIds
ArcGIS.Core.Data.Analyst3D.LasPointFilter filter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
filter.FilterGeometry = envelope;
using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDataset.SearchPoints(filter))
int count;
Coordinate3D[] lasPointsRetrieved = new Coordinate3D[50000];
int[] fileIndexes = new int[50000];
double[] pointIds = new double[50000];
while (ptCursor.MoveNextArray(lasPointsRetrieved, null, fileIndexes, pointIds, out count))
