ProSnippets 3D Analyst Layers
Language:              C#
Subject:               3D Analyst Layers
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Layer Methods for TIN, Terrain, LasDataset
Retrieve layers
// find the first TIN layer
  tinLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
  // find the first Terrain layer
  terrainLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<TerrainLayer>().FirstOrDefault();
  // find the first LAS dataset layer
  lasDatasetLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<LasDatasetLayer>().FirstOrDefault();
  // find the first surface layer
  surfaceLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<SurfaceLayer>().FirstOrDefault();
Retrieve dataset objects
//Note: Needs QueuedTask to run
    using (var tin = tinLayer.GetTinDataset())
      using var tinDef = tin.GetDefinition();
      Envelope extent = tinDef.GetExtent();
      SpatialReference sr = tinDef.GetSpatialReference();
    using (terrain = terrainLayer.GetTerrain())
      using var terrainDef = terrain.GetDefinition();
      Envelope extent = terrainDef.GetExtent();
      SpatialReference sr = terrainDef.GetSpatialReference();
    using (lasDataset = lasDatasetLayer.GetLasDataset())
      using var lasDatasetDef = lasDataset.GetDefinition();
      Envelope extent = lasDatasetDef.GetExtent();
      SpatialReference sr = lasDatasetDef.GetSpatialReference();
Create a TinLayer
string tinPath = @"d:\Data\Tin\TinDataset";
  var tinURI = new Uri(tinPath);
  var tinCP = new TinLayerCreationParams(tinURI);
  tinCP.Name = "My TIN Layer";
  tinCP.IsVisible = false;
  // Note: Needs QueuedTask to run
    //Create the layer to the TIN
    tinLayer = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP, map);
Create a TinLayer from a dataset
var tinCP_ds = new TinLayerCreationParams(tinDataset);
  tinCP_ds.Name = "My TIN Layer";
  tinCP_ds.IsVisible = false;
    var tinLayer_ds = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_ds, map);
Create a TinLayer with renderers
var tinCP_renderers = new TinLayerCreationParams(tinDataset)
    Name = "My TIN layer",
    IsVisible = true
  // define the node renderer - use defaults
  var node_rd = new TinNodeRendererDefinition();
  // define the face/surface renderer
  var face_rd = new TinFaceClassBreaksRendererDefinition();
  face_rd.ClassificationMethod = ClassificationMethod.NaturalBreaks;
  // accept default color ramp, breakCount
  // set up the renderer dictionary
  var rendererDict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>
  { SurfaceRendererTarget.Points, node_rd },
  { SurfaceRendererTarget.Surface, face_rd }
  // assign the dictionary to the creation params
  tinCP_renderers.RendererDefinitions = rendererDict;
    // create the layer
    var tinLayer_rd = LayerFactory.Instance.CreateLayer<TinLayer>(tinCP_renderers, MapView.Active.Map);
Create a TerrainLayer
    string terrainPath = @"d:\Data\Terrain\filegdb_Containing_A_Terrain.gdb\FeatureDataset\Terrain_name";
    var terrainURI = new Uri(terrainPath);
    var terrainCP = new TerrainLayerCreationParams(terrainURI);
    terrainCP.Name = "My Terrain Layer";
    terrainCP.IsVisible = false;
      //Create the layer to the terrain
      terrainLayer = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP, map);
Create a TerrainLayer from a dataset
var terrainCP_ds = new TerrainLayerCreationParams(terrain);
  terrainCP_ds.Name = "My Terrain Layer";
  terrainCP_ds.IsVisible = true;
    var terrainLayer_ds = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_ds, map);
Create a TerrainLayer with renderers
var terrainCP_renderers = new TerrainLayerCreationParams(terrain);
  terrainCP_renderers.Name = "My LAS Layer";
  terrainCP_renderers.IsVisible = true;
  // define the edge type renderer - use defaults
  var edgeRD = new TinBreaklineRendererDefinition();
  var faceRD = new TinFaceClassBreaksRendererDefinition();
  faceRD.ClassificationMethod = ClassificationMethod.NaturalBreaks;
  // define the dirty area renderer - use defaults
  var dirtyAreaRD = new TerrainDirtyAreaRendererDefinition();
  // add renderers to dictionary
  var t_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
  t_dict.Add(SurfaceRendererTarget.Edges, edgeRD);
  t_dict.Add(SurfaceRendererTarget.Surface, faceRD);
  t_dict.Add(SurfaceRendererTarget.DirtyArea, dirtyAreaRD);
  // assign dictionary to creation params
  terrainCP_renderers.RendererDefinitions = t_dict;
    var terrainLayer_rd = LayerFactory.Instance.CreateLayer<TerrainLayer>(terrainCP_renderers, map);
Create a LasDatasetLayer
string lasPath = @"d:\Data\LASDataset.lasd";
  var lasURI = new Uri(lasPath);
  var lasCP = new LasDatasetLayerCreationParams(lasURI);
  lasCP.Name = "My LAS Layer";
  lasCP.IsVisible = false;
    //Create the layer to the LAS dataset
    lasDatasetLayer = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP, map);
Create a LasDatasetLayer from a LasDataset
if (lasDataset == null)
    throw new ArgumentNullException(nameof(lasDataset));
  var lasCP_ds = new LasDatasetLayerCreationParams(lasDataset);
  lasCP_ds.Name = "My LAS Layer";
  lasCP_ds.IsVisible = false;
    var lasDatasetLayer_ds = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_ds, map);
Create a LasDatasetLayer with renderers
var lasCP_renderers = new LasDatasetLayerCreationParams(lasDataset);
  lasCP_renderers.Name = "My LAS Layer";
  lasCP_renderers.IsVisible = false;
  // create a point elevation renderer
  var ptR = new LasStretchRendererDefinition();
  // accept all defaults
  // create a simple edge renderer
  var edgeR = new TinEdgeRendererDefintion();
  var l_dict = new Dictionary<SurfaceRendererTarget, TinRendererDefinition>();
  l_dict.Add(SurfaceRendererTarget.Points, ptR);
  l_dict.Add(SurfaceRendererTarget.Edges, edgeR);
  lasCP_renderers.RendererDefinitions = l_dict;
    var lasDatasetLayer_rd = LayerFactory.Instance.CreateLayer<LasDatasetLayer>(lasCP_renderers, map);
Renderers for TinLayer, TerrainLayer, LasDatasetLayer
Get Renderers
    // get the list of renderers
    IReadOnlyList<CIMTinRenderer> renderers = surfaceLayer.GetRenderers();
    // get the renderers as a dictionary
    Dictionary<SurfaceRendererTarget, CIMTinRenderer> dict = surfaceLayer.GetRenderersAsDictionary();
Simple Node Renderer
// applies to TIN layers only
  var nodeRendererDef = new TinNodeRendererDefinition();
  nodeRendererDef.Description = "Nodes";
  nodeRendererDef.Label = "Nodes";
  nodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
    if (tinLayer.CanCreateRenderer(nodeRendererDef))
      CIMTinRenderer renderer = tinLayer.CreateRenderer(nodeRendererDef);
      if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
        tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
Elevation Node Renderer - Equal Breaks
  var equalBreaksNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
  equalBreaksNodeRendererDef.BreakCount = 7;
    if (tinLayer.CanCreateRenderer(equalBreaksNodeRendererDef))
      CIMTinRenderer renderer = tinLayer.CreateRenderer(equalBreaksNodeRendererDef);
      if (tinLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
        tinLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
Elevation Node Renderer - Defined Interval
  var defiendIntervalNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
  defiendIntervalNodeRendererDef.ClassificationMethod = ClassificationMethod.DefinedInterval;
  defiendIntervalNodeRendererDef.IntervalSize = 4;
  defiendIntervalNodeRendererDef.SymbolTemplate = nodeSymbol.MakeSymbolReference();
    if (tinLayer.CanCreateRenderer(defiendIntervalNodeRendererDef))
      CIMTinRenderer renderer = tinLayer.CreateRenderer(defiendIntervalNodeRendererDef);
Elevation Node Renderer - Standard Deviation
  var stdDevNodeRendererDef = new TinNodeClassBreaksRendererDefinition();
  stdDevNodeRendererDef.ClassificationMethod = ClassificationMethod.StandardDeviation;
  stdDevNodeRendererDef.DeviationInterval = StandardDeviationInterval.OneHalf;
  stdDevNodeRendererDef.ColorRamp = ColorFactory.Instance.GetColorRamp("Cyan to Purple");
    if (tinLayer.CanCreateRenderer(stdDevNodeRendererDef))
      CIMTinRenderer renderer = tinLayer.CreateRenderer(stdDevNodeRendererDef);
Simple Edge Renderer
// applies to TIN or LAS dataset layers only
  var edgeRendererDef = new TinEdgeRendererDefintion();
  edgeRendererDef.Description = "Edges";
  edgeRendererDef.Label = "Edges";
  edgeRendererDef.SymbolTemplate = lineSymbol.MakeSymbolReference();
    if (surfaceLayer.CanCreateRenderer(edgeRendererDef))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(edgeRendererDef);
      if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Edges))
        surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Edges);
Edge Type Renderer
var breaklineRendererDef = new TinBreaklineRendererDefinition();
  // use default symbol for regular edge but specific symbols for hard,soft,outside
  breaklineRendererDef.HardEdgeSymbol = hardEdgeSymbol.MakeSymbolReference();
  breaklineRendererDef.SoftEdgeSymbol = softEdgeSymbol.MakeSymbolReference();
  breaklineRendererDef.OutsideEdgeSymbol = outsideEdgeSymbol.MakeSymbolReference();
    if (surfaceLayer.CanCreateRenderer(breaklineRendererDef))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(breaklineRendererDef);
Contour Renderer
var contourDef = new TinContourRendererDefinition();
  // now customize with a symbol
  contourDef.Label = "Contours";
  contourDef.SymbolTemplate = contourLineSymbol.MakeSymbolReference();
  contourDef.ContourInterval = 6;
  contourDef.IndexLabel = "Index Contours";
  contourDef.IndexSymbolTemplate = indexLineSymbol.MakeSymbolReference();
  contourDef.ContourFactor = 4;
  contourDef.ReferenceHeight = 7;
    if (surfaceLayer.CanCreateRenderer(contourDef))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(contourDef);
      if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Contours))
        surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Contours);
Simple Face Renderer
var simpleFaceRendererDef = new TinFaceRendererDefinition();
  simpleFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
    if (surfaceLayer.CanCreateRenderer(simpleFaceRendererDef))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(simpleFaceRendererDef);
      if (surfaceLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Surface))
        surfaceLayer.SetRenderer(renderer, SurfaceRendererTarget.Surface);
Aspect Face Renderer
var aspectFaceRendererDef = new TinFaceClassBreaksAspectRendererDefinition();
  aspectFaceRendererDef.SymbolTemplate = polySymbol.MakeSymbolReference();
    if (surfaceLayer.CanCreateRenderer(aspectFaceRendererDef))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(aspectFaceRendererDef);
Slope Face Renderer - Equal Interval
var slopeFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
  // accept default breakCount, symbolTemplate, color ramp
    if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksEqual))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksEqual);
Slope Face Renderer - Quantile
var slopeFaceClassBreaksQuantile = new TinFaceClassBreaksRendererDefinition(TerrainDrawCursorType.FaceSlope);
  slopeFaceClassBreaksQuantile.ClassificationMethod = ClassificationMethod.Quantile;
    if (surfaceLayer.CanCreateRenderer(slopeFaceClassBreaksQuantile))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(slopeFaceClassBreaksQuantile);
Elevation Face Renderer - Equal Interval
var elevFaceClassBreaksEqual = new TinFaceClassBreaksRendererDefinition();
    if (surfaceLayer.CanCreateRenderer(elevFaceClassBreaksEqual))
      CIMTinRenderer renderer = surfaceLayer.CreateRenderer(elevFaceClassBreaksEqual);
Dirty Area Renderer
var dirtyAreaRendererDef = new TerrainDirtyAreaRendererDefinition();
  // accept default labels, symbolTemplate
  if (terrainLayer == null)
    return;
    if (terrainLayer.CanCreateRenderer(dirtyAreaRendererDef))
      CIMTinRenderer renderer = terrainLayer.CreateRenderer(dirtyAreaRendererDef);
      if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.DirtyArea))
        terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.DirtyArea);
Terrain Point Class Breaks Renderer
var terrainPointClassBreaks = new TerrainPointClassBreaksRendererDefinition();
  // accept defaults
    if (terrainLayer.CanCreateRenderer(terrainPointClassBreaks))
      CIMTinRenderer renderer = terrainLayer.CreateRenderer(terrainPointClassBreaks);
      if (terrainLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
        terrainLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
LAS Points Classification Unique Value Renderer
var lasPointsClassificationRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.Classification);
  // accept the defaults for color ramp, symbolTemplate, symbol scale factor
  if (lasDatasetLayer == null)
    return;
    if (lasDatasetLayer.CanCreateRenderer(lasPointsClassificationRendererDef))
      CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassificationRendererDef);
      if (lasDatasetLayer.CanSetRenderer(renderer, SurfaceRendererTarget.Points))
        lasDatasetLayer.SetRenderer(renderer, SurfaceRendererTarget.Points);
LAS Points Returns Unique Value Renderer
var lasPointsReturnsRendererDef = new LasUniqueValueRendererDefinition(LasAttributeType.ReturnNumber);
  lasPointsReturnsRendererDef.ModulateUsingIntensity = true;
  lasPointsReturnsRendererDef.SymbolScaleFactor = 1.0;
    if (lasDatasetLayer.CanCreateRenderer(lasPointsReturnsRendererDef))
      CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsReturnsRendererDef);
LAS Points Elevation Stretch Renderer
var elevLasStretchRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
  // accept the defaults for color ramp, etc
  if (lasDatasetLayer.CanCreateRenderer(elevLasStretchRendererDef))
    CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchRendererDef);
  // OR use a stretch renderer with stretchType standard Deviations
  var elevLasStretchStdDevRendererDef = new LasStretchRendererDefinition(ArcGIS.Core.CIM.LASStretchAttribute.Elevation);
  elevLasStretchStdDevRendererDef.StretchType = LASStretchType.StandardDeviations;
  elevLasStretchStdDevRendererDef.NumberOfStandardDeviations = 2;
    if (lasDatasetLayer.CanCreateRenderer(elevLasStretchStdDevRendererDef))
      CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(elevLasStretchStdDevRendererDef);
LAS Points Classified Elevation Renderer
var lasPointsClassBreaksRendererDef = new LasPointClassBreaksRendererDefinition();
  lasPointsClassBreaksRendererDef.ClassificationMethod = ClassificationMethod.NaturalBreaks;
  lasPointsClassBreaksRendererDef.ModulateUsingIntensity = true;
  // increase the symbol size by a factor
  lasPointsClassBreaksRendererDef.SymbolScaleFactor = 1.0;
    if (lasDatasetLayer.CanCreateRenderer(lasPointsClassBreaksRendererDef))
      CIMTinRenderer renderer = lasDatasetLayer.CreateRenderer(lasPointsClassBreaksRendererDef);
Remove an edge renderer
    surfaceLayer.RemoveRenderer(SurfaceRendererTarget.Edges);
TIN Layer Searching
Search for TIN Nodes, Edges, Triangles
    // search all "inside" nodes
    using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(null))
      while (nodeCursor.MoveNext())
        using ArcGIS.Core.Data.Analyst3D.TinNode node = nodeCursor.Current;
        //Use the node
    // search "inside" nodes with an extent
    ArcGIS.Core.Data.Analyst3D.TinNodeFilter nodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
    nodeFilter.FilterEnvelope = envelope;
    using (ArcGIS.Core.Data.Analyst3D.TinNodeCursor nodeCursor = tinLayer.SearchNodes(nodeFilter))
        //use the node
    // search for super nodes only
    var supernodeFilter = new ArcGIS.Core.Data.Analyst3D.TinNodeFilter();
    supernodeFilter.FilterEnvelope = tinLayer.GetTinDataset().GetSuperNodeExtent();
    supernodeFilter.DataElementsOnly = false;
    supernodeFilter.SuperNode = true;
        //Use the node
    // search all edges within an extent
    //    this could include outside or edges attached to super nodes depending upon the extent
    ArcGIS.Core.Data.Analyst3D.TinEdgeFilter edgeFilterAll = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
    edgeFilterAll.FilterEnvelope = envelope;
    edgeFilterAll.DataElementsOnly = false;
    using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilterAll))
      while (edgeCursor.MoveNext())
        using ArcGIS.Core.Data.Analyst3D.TinEdge edge = edgeCursor.Current;
        //Use the edge
    // search for hard edges in the TIN
    var edgeFilter = new ArcGIS.Core.Data.Analyst3D.TinEdgeFilter();
    edgeFilter.FilterByEdgeType = true;
    edgeFilter.EdgeType = ArcGIS.Core.Data.Analyst3D.TinEdgeType.HardEdge;
    using (ArcGIS.Core.Data.Analyst3D.TinEdgeCursor edgeCursor = tinLayer.SearchEdges(edgeFilter))
        //Use the edge
    // search for "inside" triangles in an extent
    ArcGIS.Core.Data.Analyst3D.TinTriangleFilter triangleFilter = new ArcGIS.Core.Data.Analyst3D.TinTriangleFilter();
    triangleFilter.FilterEnvelope = envelope;
    triangleFilter.DataElementsOnly = true;
    using (ArcGIS.Core.Data.Analyst3D.TinTriangleCursor triangleCursor = tinLayer.SearchTriangles(triangleFilter))
      while (triangleCursor.MoveNext())
        using ArcGIS.Core.Data.Analyst3D.TinTriangle triangle = triangleCursor.Current;
        //use the triangle
LAS Dataset Layer Display Filter
Get and Set Display Filter
    // get the current display filter
    LasPointDisplayFilter ptFilter = lasDatasetLayer.GetDisplayFilter();
    // display only ground points
    lasDatasetLayer.SetDisplayFilter(LasPointDisplayFilterType.Ground);
    // display first return points
    lasDatasetLayer.SetDisplayFilter(LasPointDisplayFilterType.FirstReturnPoints);
    // set display filter to a set of classification codes
    List<int> classifications = new List<int>() { 4, 5, 7, 10 };
    lasDatasetLayer.SetDisplayFilter(classifications);
    // set display filter to a set of returns
    List<ArcGIS.Core.Data.Analyst3D.LasReturnType> returns = new List<ArcGIS.Core.Data.Analyst3D.LasReturnType>()
        { ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnFirstOfMany};
    lasDatasetLayer.SetDisplayFilter(returns);
    // set up a display filter
    var newDisplayFilter = new LasPointDisplayFilter();
    newDisplayFilter.Returns = new List<ArcGIS.Core.Data.Analyst3D.LasReturnType>()
        { ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnFirstOfMany, ArcGIS.Core.Data.Analyst3D.LasReturnType.ReturnLastOfMany};
    newDisplayFilter.ClassCodes = new List<int>() { 2, 4 };
    newDisplayFilter.KeyPoints = true;
    newDisplayFilter.WithheldPoints = false;
    newDisplayFilter.SyntheticPoints = false;
    newDisplayFilter.NotFlagged = false;
Active Surface Constraints
    var activeSurfaceConstraints = lasDatasetLayer.GetActiveSurfaceConstraints();
    // clear all surface constraints (i.e. none are active)
    lasDatasetLayer.SetActiveSurfaceConstraints(null);
    // set all surface constraints active
      var surfaceConstraints = lasDataset.GetSurfaceConstraints();
      var names = surfaceConstraints.Select(sc => sc.DataSourceName).ToList();
      lasDatasetLayer.SetActiveSurfaceConstraints(names);
LAS Dataset Layer Searching
Search for LAS Points
    // searching on the LasDatasetLayer will honor any LasPointDisplayFilter
    // search all points
    using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(null))
      while (ptCursor.MoveNext())
        using ArcGIS.Core.Data.Analyst3D.LasPoint point = ptCursor.Current;
        //Use the point
    // search within an extent
    ArcGIS.Core.Data.Analyst3D.LasPointFilter pointFilter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
    pointFilter.FilterGeometry = envelope;
    using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(pointFilter))
        //Use the point
    // search within an extent and limited to specific classification codes
    pointFilter.ClassCodes = new List<int> { 4, 5 };
        //Use the point
Search using pre initialized arrays
    // search all points and process with a set size of array retrieving only coordinates
      int count;
      Coordinate3D[] lasPointsRetrieved = new Coordinate3D[10000];
      while (ptCursor.MoveNextArray(lasPointsRetrieved, null, null, null, out count))
        var points = lasPointsRetrieved.ToList();
        // Use the points
    // use MoveNextArray retrieving coordinates, fileIndex and pointIds
    ArcGIS.Core.Data.Analyst3D.LasPointFilter filter = new ArcGIS.Core.Data.Analyst3D.LasPointFilter();
    filter.FilterGeometry = envelope;
    using (ArcGIS.Core.Data.Analyst3D.LasPointCursor ptCursor = lasDatasetLayer.SearchPoints(filter))
      int count;
      Coordinate3D[] lasPointsRetrieved = new Coordinate3D[50000];
      int[] fileIndexes = new int[50000];
      double[] pointIds = new double[50000];
      while (ptCursor.MoveNextArray(lasPointsRetrieved, null, fileIndexes, pointIds, out count))
        //Use the points
LAS Dataset Layer Eye Dome Lighting
Eye Dome Lighting
    // get current EDL settings
    bool isEnabled = lasDatasetLayer.IsEyeDomeLightingEnabled;
    var radius = lasDatasetLayer.EyeDomeLightingRadius;
    var strength = lasDatasetLayer.EyeDomeLightingStrength;
    // set EDL values
    lasDatasetLayer.SetEyeDomeLightingEnabled(true);
    lasDatasetLayer.SetEyeDomeLightingStrength(65.0);
    lasDatasetLayer.SetEyeDomeLightingRadius(2.0);
LAS Dataset Layer Selection
Selection Settings
// must be on MCT
  // configure the LAS selection settings
  // set visible points and a specific set of classification codes selectable
  lasDatasetLayer.SetSelectVisiblePoints(true);
  lasDatasetLayer.SetSelectableClassCodes(new List<int>() { 3, 4, 5 });
  // this example sets all classification codes selectable
  lasDatasetLayer.SetSelectableClassCodes(new List<int>());
  // get the current LAS selection settings
  var canSelectVisible = lasDatasetLayer.GetSelectVisiblePoints();
  var selectableClassCodes = lasDatasetLayer.GetSelectableClassCodes();
Select using LasPointSelectionFilter
// must be on MCT
  // create the filter
  var filter = new LasPointSelectionFilter();
  // set the filter geometry
  // don't set VisiblePoints, ClassCodes - use the existing layer values
  filter.FilterGeometry = polygon;
  // perform the selection
  var selCount = await lasDatasetLayer.SelectAsync(filter, SelectionCombinationMethod.New);
  // set up a second filter and configure the VisiblePoints, ClassCodes
  // note that the ClassCodes is using only (4,5)
  // whereas the layers setting is (3,4,5)
  var filter2 = new LasPointSelectionFilter();
  filter2.VisiblePoints = true;
  filter2.ClassCodes = new List<int>() { 4, 5 };
  filter2.FilterGeometry = polygon;
  selCount = await lasDatasetLayer.SelectAsync(filter2, SelectionCombinationMethod.New);
Select using LasPointClusterSelectionFilter
// must be on MCT
  var clusterFilter = new LasPointClusterSelectionFilter();
  clusterFilter.VisiblePoints = true;
  clusterFilter.ClassCodes = new List<int>();  // empty list means all classification codes
  clusterFilter.FilterGeometry = polygon;
  clusterFilter.SearchRadius = 0.5; // meters
  clusterFilter.MaximumNumberOfPoints = 500;
  var clusterSelCount = await lasDatasetLayer.SelectAsync(clusterFilter, SelectionCombinationMethod.New);
Select using LasPointPlaneSelectionFilter
// must be on MCT
  var planeFilter = new LasPointPlaneSelectionFilter();
  planeFilter.VisiblePoints = true;
  planeFilter.ClassCodes = new List<int>();  // empty list means all classification codes
  planeFilter.FilterGeometry = polygon;
  planeFilter.ClusteringDistance = 0.3; // meters
  planeFilter.MaximumDistance = 500;
  planeFilter.PlaneTolerance = 0.152; // meters
  var planeSelCount = await lasDatasetLayer.SelectAsync(planeFilter, SelectionCombinationMethod.New);
Select using LasPointRailSelectionFilter
// must be on MCT
  var railFilter = new LasPointRailSelectionFilter();
  railFilter.VisiblePoints = true;
  railFilter.ClassCodes = new List<int>();  // empty list means all classification codes
  railFilter.FilterGeometry = polygon;
  // configure a few of the properties and accept defaults for others
  railFilter.SearchRadius = 0.5; // meters
  railFilter.RailThickness = 0.2; // meters
  railFilter.MaximumLength = 225; // meters
  var railSelCount = await lasDatasetLayer.SelectAsync(railFilter, SelectionCombinationMethod.New);
Select using LasPointPipelineSelectionFilter
// must be on MCT
  var pipelineFilter = new LasPointPipelineSelectionFilter();
  pipelineFilter.VisiblePoints = true;
  pipelineFilter.ClassCodes = new List<int>();  // empty list means all classification codes
  pipelineFilter.FilterGeometry = polygon;
  pipelineFilter.ApplyWindCorrection = true;
  pipelineFilter.MinimumLength = 25;  // meters
  var pipelineSelCount = await lasDatasetLayer.SelectAsync(pipelineFilter, SelectionCombinationMethod.New);
Determine if Layer has selection
// get selection count
  var count = lasDatasetLayer.SelectionCount;
  // does the layer have a selection
  var hasSelection = lasDatasetLayer.HasSelection;
Clear Selection
// must be on MCT
  lasDatasetLayer.ClearSelection();
LAS Dataset Layer Classification
Classify LAS Points
// build the LasPointClassificationDescription
// assign a new classification code to be assigned to the selected LAS points
// don't alter any of the classification flags
var edits = new LasPointClassificationDescription();
edits.ClassCode = 6;
if (lasDatasetLayer.CanClassifyLasPoints(edits))
  lasDatasetLayer.ClassifyLasPoints(edits, true);
// alternatively set up the LasPointClassificationDescription to modify classification flags
var edits2 = new LasPointClassificationDescription();
edits2.KeyPoints = LasClassFlagEditType.Set;
edits2.SyntheticPoints = LasClassFlagEditType.Clear;
// don't change the OverlapPoints, WithheldPoints flags
// apply the edit
if (lasDatasetLayer.CanClassifyLasPoints(edits2))
  lasDatasetLayer.ClassifyLasPoints(edits2, true);
// or perform both a classification code and classification flag edit
var edits3 = new LasPointClassificationDescription();
edits3.ClassCode = 5;
edits3.KeyPoints = LasClassFlagEditType.Set;
edits3.SyntheticPoints = LasClassFlagEditType.Clear;
// be explicit about not changing the other flags
edits3.WithheldPoints = LasClassFlagEditType.NoChange;
edits3.OverlapPoints = LasClassFlagEditType.NoChange;
// apply the edit
if (lasDatasetLayer.CanClassifyLasPoints(edits3))
  lasDatasetLayer.ClassifyLasPoints(edits3, true);
Line of Sight
Get Line of Sight
tinLayer = null;
  MapPoint observerPoint = null;
  MapPoint targetPoint = null;
  CIMPointSymbol obstructionPointSymbol = null;
  CIMLineSymbol visibleLineSymbol = null;
  CIMLineSymbol invisibleLineSymbol = null;
  var losParams = new LineOfSightParams();
  losParams.ObserverPoint = observerPoint;
  losParams.TargetPoint = targetPoint;
  // add offsets if appropriate
  // losParams.ObserverHeightOffset = observerOffset;
  // losParams.TargetHeightOffset = targerOffset;
  // add obstruction feature class if appropriate (multipatch)
  //losParams.ObstructionsMultipatchFeatureClass = obsFeatureClass;
  // set output spatial reference
  losParams.OutputSpatialReference = MapView.Active.Map.SpatialReference;
  LineOfSightResult results = null;
  try
      if (tinLayer.CanGetLineOfSight(losParams))
        results = tinLayer.GetLineOfSight(losParams);
  catch (Exception)
    // handle exception
  if (results != null)
    bool targetIsVisibleFromObserverPoint = results.IsTargetVisibleFromObserverPoint;
    //These properties are not used. They will always be false
    // results.IsTargetVisibleFromVisibleLine;
    // results.IsTargetVisibleFromInvisibleLine;
    if (results.VisibleLine != null)
      MapView.Active.AddOverlay(results.VisibleLine, visibleLineSymbol.MakeSymbolReference());
    if (results.InvisibleLine != null)
      MapView.Active.AddOverlay(results.VisibleLine, invisibleLineSymbol.MakeSymbolReference());
    if (results.ObstructionPoint != null)
      MapView.Active.AddOverlay(results.ObstructionPoint, obstructionPointSymbol.MakeSymbolReference());
TIN Layer Functionalities
Get Elevation, Slope, Aspect from TIN layer at a location
    // get elevation, slope and aspect values
    SurfaceValues values = tinLayer.GetSurfaceValues(mapPoint);
    var elev = values.Elevation;
    var slopeRadians = values.Slope;
    var slopeDegrees = values.SlopeDegrees;
    var slopePercent = values.SlopePercent;
    var aspectRadians = values.Aspect;
    var aspectDegrees = values.AspectDegrees;
Get Z values from a TIN Layer
    if (tinLayer.CanGetZs())
      // get z value for a mapPoint
      var zResult = tinLayer.GetZs(mapPoint);
      if (zResult.Status == SurfaceZsResultStatus.Ok)
        // cast to a mapPoint
        var mapPointZ = zResult.Geometry as MapPoint;
        var z = mapPointZ.Z;
      // get z values for a polyline
      zResult = tinLayer.GetZs(polyline);
        // cast to a Polyline
        var polylineZ = zResult.Geometry as Polyline;
Interpolate Shape
  // Note: Needs 3d Analyst license to run
    ArcGIS.Core.Geometry.Geometry output = null;
    // interpolate z values for a geometry
    if (tinLayer.CanInterpolateShape(polyline))
      output = tinLayer.InterpolateShape(polyline, SurfaceInterpolationMethod.NaturalNeighbor);
    if (output != null)
      // process the output
    // densify the shape before interpolating
    if (tinLayer.CanInterpolateShape(polygon))
      output = tinLayer.InterpolateShape(polygon, SurfaceInterpolationMethod.Linear, 0.01, 0);
    if (output != null)
Interpolate Shape vertices
    // interpolate z values at the geometry vertices only
    Geometry output = tinLayer.InterpolateShapeVertices(polyline, SurfaceInterpolationMethod.NaturalNeighbor);
    if (output != null)
    // or use a different interpolation method
    output = tinLayer.InterpolateShapeVertices(polyline, SurfaceInterpolationMethod.Linear);
Interpolate Z at an x,y location
    // interpolate values at the specified x,y location
    double z = tinLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.NaturalNeighborZNearest);
    z = tinLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.Linear);
Get 3D length of multipart by interpolating heights
    // interpolate heights and calculate the sum of 3D distances between the vertices
    double length3d = tinLayer.GetSurfaceLength(polygon, SurfaceInterpolationMethod.NaturalNeighbor);
    length3d = tinLayer.GetSurfaceLength(polyline, SurfaceInterpolationMethod.NaturalNeighborZNearest);
    length3d = tinLayer.GetSurfaceLength(polygon, SurfaceInterpolationMethod.NaturalNeighbor, 0.01, 0);
Interpolate Polygon To Multipatch
    var multipatch = tinLayer.InterpolatePolygonToMultipatch(polygon, 1024);
    if (multipatch != null)
Terrain Layer Functionalities
Interpolate Shape
    if (terrainLayer.CanInterpolateShape(polyline))
      output = terrainLayer.InterpolateShape(polyline, SurfaceInterpolationMethod.NaturalNeighbor);
    if (output != null)
    if (terrainLayer.CanInterpolateShape(polygon))
      output = terrainLayer.InterpolateShape(polygon, SurfaceInterpolationMethod.Linear, 0.01, 0);
    if (output != null)
    Geometry output = terrainLayer.InterpolateShapeVertices(polyline, SurfaceInterpolationMethod.NaturalNeighbor, 0);
    if (output != null)
    output = terrainLayer.InterpolateShapeVertices(polyline, SurfaceInterpolationMethod.Linear, 0);
    double z = terrainLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.NaturalNeighborZNearest);
    z = terrainLayer.InterpolateZ(x, y, SurfaceInterpolationMethod.Linear);
    var multipatch = terrainLayer.InterpolatePolygonToMultipatch(polygon, 1024, 0);
