var oid = 1;
// See "Change Annotation Text Graphic" for an alternative if TEXTSTRING is missing from the schema
// Note: QueuedTask is required to access the Inspector
// use the inspector methodology
var insp = new Inspector();
insp.Load(annotationLayer, oid);
// make sure TextString attribute exists.
//It is not guaranteed to be in the schema
ArcGIS.Desktop.Editing.Attributes.Attribute att = insp.FirstOrDefault(a => a.FieldName == "TEXTSTRING");
if (att != null)
insp["TEXTSTRING"] = "Hello World";
//create and execute the edit operation
EditOperation op = new EditOperation();
op.Name = "Update annotation";
op.Modify(insp);
//OR using a Dictionary - again TEXTSTRING has to exist in the schema
//Dictionary<string, object> newAtts = new Dictionary<string, object>();
//newAtts.Add("TEXTSTRING", "hello world");
//op.Modify(annotationLayer, oid, newAtts);
op.Execute();
Rotate or Move the Annotation
var oid = 1; //ObjectID of the annotation feature to modify
// Note: QueuedTask is required to access the AnnotationFeature
//Don't use 'Shape'....Shape is the bounding box of the annotation text. This is NOT what you want...
//var insp = new Inspector();
//insp.Load(annotationLayer, oid);
//var shape = insp["SHAPE"] as Polygon;
//...wrong shape...
//Instead, we must get the TextGraphic from the anno feature.
//The TextGraphic shape will be the anno baseline...
QueryFilter qf = new QueryFilter()
WhereClause = "OBJECTID = 1"
//annotationLayer is ~your~ Annotation layer
using var rowCursor = annotationLayer.Search(qf);
if (rowCursor.MoveNext())
using (var annoFeature = rowCursor.Current as
ArcGIS.Core.Data.Mapping.AnnotationFeature)
var graphic = annoFeature.GetGraphic();
var textGraphic = graphic as CIMTextGraphic;
var textLine = textGraphic.Shape as Polyline;
// rotate the shape 90 degrees
var origin = GeometryEngine.Instance.Centroid(textLine);
Geometry rotatedPolyline = GeometryEngine.Instance.Rotate(textLine, origin, System.Math.PI / 2);
//Move the line 5 "units" in the x and y direction
//GeometryEngine.Instance.Move(textLine, 5, 5);
op.Name = "Change annotation angle";
op.Modify(annotationLayer, oid, rotatedPolyline);
op.Execute();
Get the Annotation Text Graphic
using var table = annotationLayer.GetTable();
using var rc = table.Search();
rc.MoveNext();
using var af = rc.Current as AnnotationFeature;
var graphic = af.GetGraphic();
//Note:
//var outline_geom = af.GetGraphicOutline();
//gets the anno text outline geometry...
Get the Outline Geometry for an Annotation
//get the first annotation feature...
//...assuming at least one feature gets selected
using var fc = annotationLayer.GetFeatureClass();
using var rc = fc.Search();
rc.MoveNext();
//TODO - use the outline...
//Note:
//var graphic = annoFeature.GetGraphic();
//gets the CIMTextGraphic...
Get the Mask Geometry for an Annotation
var mv = MapView.Active;
rc.MoveNext();
using var row = rc.Current;
var oid = row.GetObjectID();
//Use DrawingOutlineType.BoundingEnvelope to retrieve a generalized
//mask geometry or "Box". The mask will be in the same SpatRef as the map.
//The mask will be constructed using the anno class reference scale
var mask_geom = annotationLayer.GetDrawingOutline(oid, mv, DrawingOutlineType.Exact);
Create Annotation Construction Tool
public class AnnoConstructionTool : MapTool
//In your config.daml...set the categoryRefID
//<tool id="..." categoryRefID="esri_editing_construction_annotation" caption="Create Anno" ...>
//Sketch type Point or Line or BezierLine in the constructor...
public AnnoConstructionTool()
IsSketchTool = true;
UseSnapping = true;
SketchType = SketchGeometryType.Point;
/// <summary>
/// Callback when the sketch operation is complete.
/// </summary>
/// <param name="geometry">The geometry resulting from the sketch operation. Must not be <see langword="null"/>.</param>
/// <returns>A task that represents the asynchronous operation. The task result is <see langword="true"/> if the feature
/// creation operation succeeds; otherwise, <see langword="false"/>.</returns>
protected async override Task<bool> OnSketchCompleteAsync(ArcGIS.Core.Geometry.Geometry geometry)
if (CurrentTemplate == null || geometry == null)
return false;
// Create an edit operation
var createOperation = new EditOperation();
createOperation.Name = string.Format("Create {0}", CurrentTemplate.Layer.Name);
createOperation.SelectNewFeatures = true;
// update the geometry point into a 2 point line
//annotation needs at minimum a 2 point line for the text to be placed
double tol = 0.01;
var polyline = await CreatePolylineFromPointAsync((MapPoint)geometry, tol);
// Queue feature creation
createOperation.Create(CurrentTemplate, polyline);
// Execute the operation
return await createOperation.ExecuteAsync();
/// <summary>
/// Creates a polyline starting from the specified map point, with an additional point offset by the given tolerance.
/// </summary>
/// <param name="pt">The starting <see cref="MapPoint"/> for the polyline.</param>
/// <param name="tolerance">The distance, in the same spatial reference units as <paramref name="pt"/>, used to calculate the offset for the
/// second point.</param>
/// <returns>A <see cref="Task{Polyline}"/> representing the asynchronous operation. The result contains the constructed
/// polyline.</returns>
public Task<Polyline> CreatePolylineFromPointAsync(MapPoint pt, double tolerance)
return QueuedTask.Run(() =>
// create a polyline from a starting point
//use a tolerance to construct the second point
MapPoint pt2 = MapPointBuilderEx.CreateMapPoint(pt.X + tolerance, pt.Y, pt.SpatialReference);
return PolylineBuilderEx.CreatePolyline(new List<MapPoint>() { pt, pt2 });
