ProSnippets Browse Dialog Filters
Language:      C#
Subject:       Framework
Contributor:   ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:  Esri, https://www.esri.com
Date:          4/30/2026
ArcGIS Pro:    3.7
Visual Studio: 2022
The code snippet below creates a "BrowseProjectFilter" that can be used in Open and Save item dialogs. "esri_browseDialogFilters_2dVector_files" is the ID of an existing ArcGIS Pro filter and "2D Vector Files(EMF, SVG)" is its caption. Use the available ArcGIS Pro filter IDs and captions listed in the table below to create your own "Browse Project Filters".
var bpf = new BrowseProjectFilter("esri_browse_dialog_filter_exceptions_file_types");
bpf.Name = "Exceptions file";
var openItemDialog = new OpenItemDialog { BrowseFilter = bpf };
Name: S-57 Cells (000)
Name: 2D Vector Files (EMF, SVG)
Name: 3D Model Files (3DS, DAE, FLT, OBJ, glTF, GLB))
Name: 3D Studio File (3DS)
Name: Gaussian Splat Layer
Name: 3D Tiles (All Types)
Name: 3D Tiles Dataset
Name: 3D Tiles Archive Files (3TZ)
Name: Cloud Storage Connections
Name: ArcGIS Server Connections
Name: AI Service Connection Files (.ais)
Name: Tables and Raster Catalogs
Name: All supported
Name: All Supported Types
Name: All Server Connections
Name: STAC Connections
Name: Windows Batch Files (BAT)
Name: BIM File Workspaces
Name: CAD Data (All Types)
Name: CAD Annotation Feature Classes
Name: CAD DGN Files
Name: CAD DWG Files
Name: CAD DXF Files
Name: CAD Line Feature Classes
Name: CAD Multi Patch Feature Classes
Name: CAD Multipoint Feature Classes
Name: CAD Point Feature Classes
Name: CAD Point and Multipoint Feature Classes (All Types)
Name: CAD Polygon Feature Classes
Name: World Files (WLD)
Name: Calculate Field Expression (CAL)
Name: UAV/UAS Camera Files (CAM)
Name: Graphics Files (SVG, PNG, JPG)
Name: Esri Classifier Definition files (ECD)
Name: Colormap Files (CLR)
Name: Windows Command Script (CMD)
Name: MS-DOS Command Files (COM)
Name: Graphics Files (All)
Name: Collada File (DAE)
Name: Dictionary Files (DIC)
Name: Deep Learning Model files (dlpk, emd)
Name: CAD DWG Files
Name: Exploratory Analysis Tools (EAT)
Name: Enhanced MetaFile Files (EMF)
Name: ENVI Spectral Library Files (SLI)
Name: Excel Worksheets (XLS, XLSX)
Name: Executable Files (EXE)
Name: FBX Files (FBX)
Name: FDP Files (FDP)
Name: 3D Object Feature Layers
Name: Feature Classes (All Types)
Name: Annotation Feature Classes (All Types)
Name: Feature Classes and Data Store Items (All Types)
Name: Line Feature Classes and Data Store Items (All Types)
Name: Point Feature Classes and Data Store Items (All Types)
Name: Polygon Feature Classes and Data Store Items (All Types)
Name: Dimension Feature Classes (All Types)
Name: Point Feature Classes (local)
Name: Line Feature Classes (All Types)
Name: Multipatch Feature Classes (All Types)
Name: Multipoint Feature Classes (All Types)
Name: Point Feature Classes (All Types)
Name: Point and Multipoint Feature Classes (All Types)
Name: Polygon Feature Classes (All Types)
Name: Feature Datasets (All Types)
Name: Feed Files (FEED)
Name: File or Enterprise Geodatabases
Name: File Knowledge Graph
Name: Open Flight File (FLT)
Name: FME Workbench Files (FMW)
Name: Parcel Fabrics for ArcMap
Name: Geodatabase Feature Classes
Name: Geodatabase Feature Datasets
Name: Geodatabase Mosaic Datasets
Name: Geodatabase Raster Catalogs
Name: Geodatabase Raster Datasets
Name: Geodatabase Toolboxes
Name: Geodatabase Trajectory Datasets
Name: Enterprise Geodatabases
Name: Database Connection Files
Name: File Geodatabases
Name: Mobile Geodatabases
Name: GeoPackage and SQLite Databases
Name: Geodata Services and Geodatabases
Name: GeoJSON File (GeoJSON)
Name: glTF Binary File (GLB)
Name: glTF JSON File (GLTF)
Name: CityGML Files (GML)
Name: Script Tool Files (PY, R)
Name: Tables and Attribute Tables (All Types)
Name: All supported
Name: GPS Exchange Format File (GPX)
Name: GRIB Tables (TAB, TXT)
Name: Spatial Analyst Signature File (GSG)
Name: Hypertext Markup Language File (HTML)
Name: Huff Model Calibration
Name: Industry Foundation Classes File (IFC)
Name: Esri Classification Schema (ECS)
Name: Web Imagery Layers
Name: Inspection Schema (Feature Classes, JSON)
Name: JavaScript Object Notation File (JSON)
Name: Keyhole Markup Language Files (KML, KMZ)
Name: Keyhole Markup Language Files (KML)
Name: Keyhole Markup Language Zipped Files (KMZ)
Name: Data model design
Name: Filtered find paths configuration
Name: Knowledge Graph Item
Name: Data Loading Configuration
Name: LAS Files (LAS)
Name: Layer Files and Packages (All Types)
Name: Layer Packages (LPK)
Name: Layer Packages (LPKX)
Name: Layer Files (LYR)
Name: Layer Files (LYRX)
Name: Layout Files (PAGX)
Name: LAZ Files (LAZ)
Name: Map Files (MAPX)
Name: Presentation Files (PRSX)
Name: Report Files (RPTX)
Name: Label Expression File (LXP)
Name: Globe Documents (3DD)
Name: Maps (All Types)
Name: ArcMap, ArcGlobe, ArcScene Documents (MXD, 3DD, SXD)
Name: Map Documents (MXD)
Name: Scene Documents (SXD)
Name: Multifile Feature Connections
Name: Mosaic Datasets and Image Services
Name: NetCDF File (NC)
Name: Wavefront Object File (OBJ)
Name: OGC API Server Connections
Name: Oriented Imagery Catalog
Name: Oriented Imagery Datasets
Name: Ortho Mapping Workspaces
Name: OpenSceneGraph Binary File (OSGB)
Name: ArcGIS Desktop Packages (All Types)
Name: Geoprocessing Packages (GPK, GPKX)
Name: Geoprocessing Packages (GPK)
Name: Geoprocessing Packages (GPKX)
Name: Map Packages (MPK, MMPK, MPKX, MSPK)
Name: Locator Packages (GCPK)
Name: Mobile Map Packages (MMPK, MSPK)
Name: Map Packages (MPK)
Name: Map Packages (MPKX)
Name: Mobile Scene Packages (MSPK)
Name: Project Packages (PPKX)
Name: Rule Packages (RPK)
Name: Tile Packages (TPK, TPKX)
Name: Vector Tile Packages (VTPK)
Name: Parquet Files (Parquet)
Name: Adobe Portable Document Format Files (PDF)
Name: Point Cloud Training Datasets
Name: Pop-up Configuration Files (POP)
Name: Esri WKT (.prj)
Name: Project Templates (APTX)
Name: Projects (APRX, PPKX)
Name: Projects (APRX, Portal)
Name: Projects (APRX, PPKX, Portal)
Name: Projects (PPKX, Portal)
Name: Python Script Files (PY)
Name: Script Tool Files (BAT, CMD, EXE, PY)
Name: Query Expression (EXP)
Name: R Script Files (R)
Name: Raster Functions
Name: Raster Products (All Local Types)
Name: Rasters (All Local Types)
Name: Raster Layers (All Types)
Name: Spatial Analysis GeoDatasets (All Types)
Name: Rasters And Image Services
Name: Reality Mapping Workspaces
Name: Random Forest Classification (RFM)
Name: ASCII Remap Files (RMP)
Name: Topology Rule Sets (RUL)
Name: S-101 Cells (000)
Name: Spatial Analyst Comparison Models
Name: Spatial Analyst Model Containers
Name: Spatial Analyst Models
Name: Scene Service Layer
Name: Scene Layer Packages (SLPK)
Name: 3DObject I3S layerType
Name: IntegratedMesh I3S layerType
Name: Point I3S layerType
Name: Statistical Data Collections
Name: Service Definition Files (SD)
Name: Web Layers and Services
Name: Elevation Services (All Types)
Name: Feature Layers and Services
Name: CDW Web Feature Layers / Map Image Layers
Name: DocDb Web Feature Layers / Map Image Layers
Name: Web Feature Layers / Map Image Layers
Name: Web Toolboxes
Name: Globe Layers and Services
Name: Web Scene Layers
Name: Web Tile Layers
Name: Web Vector Tile Layers
Name: Imagery Layers and Services
Name: Indoor Positioning Data Service
Name: Map Dynamic Layers and Services
Name: Map Image Layers / Web Imagery Layers
Name: Web Tile Layer / Image Service
Name: Web Tile Layer / Image Service / Elevation Service
Name: Vector Tile Layer
Name: WCS Dynamic Layers and Services
Name: WFS Dynamic Layers and Services
Name: WMS Dynamic Layers and Services
Name: WMTS Tile Layers and Services
Name: Segmentation Target Group
Name: SketchUp File (SKP)
Name: Scene Layer Package (SLPK)
Name: Esri Spectral Library Files (ESL)
Name: Scene Package (SPK)
Name: Spatial Datasets (All Types)
Name: SQlite Databases
Name: Styles (STYLX, WEBSTYLE)
Name: Elevation Surfaces (All Types)
Name: Scalable Vector Graphic (SVG)
Name: Spatial Weights Matrix Files (SWM)
Name: Tables (All Types)
Name: dBASE Tables (DBF)
Name: Tables for Geocode File
Name: Task Files (ESRITASKS)
Name: Text Files (TXT, CSV, TAB)
Name: Text Files (CSV)
Name: Text Files (TAB)
Name: Text Files (TXT)
Name: Toolboxes (All Types)
Name: Python Toolboxes (PYT)
Name: Camera Files (CAM, CSV, TXT)
Name: Universal Scene Description Files (USDC)
Name: Universal Scene Description Files (USDZ)
Name: Video Files (All Types)
Name: Video Files (AVI)
Name: Video Files (MOV)
Name: Video Files and Services
Name: WCS Server Connections
Name: WFS Server Connections
Name: World File 3D
Name: WMS Server Connections
Name: WMTS Server Connections
Name: Workspaces (All Types)
Name: World Files (WLD3/WLD)
Name: World 3D Files (WLD3)
Name: Virtual Reality Modeling Language File (WRL)
Name: XML Files (XML)
Name: XSLT Files (XSL, XSLT)
Name: ZIP Files (ZIP, Z)
Name: ZLAS Files (ZLAS)
