ProSnippets Charts
Language:              C#
Subject:               Charts
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Charts
Create a simple scatter plot
//Note: QueuedTask is required to access the feature layer
    // For more information on the chart CIM specification:
    // https://github.com/Esri/cim-spec/blob/main/docs/v3/CIMCharts.md
    var lyrDefScatter = featureLayer.GetDefinition();
    // Define scatter plot CIM properties
    var scatterPlot = new CIMChart
      Name = "scatterPlot",
      GeneralProperties = new CIMChartGeneralProperties
        Title = $"{xField} vs. {yField}",
        UseAutomaticTitle = false
      Series =
          new CIMChartScatterSeries {
              UniqueName = "scatterPlotSeries",
              // Specify the X and Y field names
              Fields = new string[] { xField , yField },
              // Turn on trend line
              ShowTrendLine = true
    // Add new chart to layer's existing list of charts (if any exist)
    var newChartsScatter = new CIMChart[] { scatterPlot };
    var allChartsScatter = (lyrDefScatter == null) ? newChartsScatter : lyrDefScatter.Charts.Concat(newChartsScatter);
    // Add CIM chart to layer definition
    lyrDefScatter.Charts = allChartsScatter.ToArray();
    featureLayer.SetDefinition(lyrDefScatter);
Create a line chart with custom time binning and style
  // Note: QueuedTask is required to access the feature layer
    var lyrDefLine = featureLayer.GetDefinition();
    // Define line chart CIM properties
    var lineChart = new CIMChart
      Name = "lineChart",
        Title = $"Line chart for {dateField} summarized by {numericField}",
      Series =
            new CIMChartLineSeries {
              UniqueName = "lineChartSeries",
              Name = $"Sum({numericField})",
              // Specify date field and numeric field
              Fields = new string[] { dateField, numericField },
              // Specify aggregation type
              FieldAggregation = new string[] { string.Empty, "SUM" },
              // Specify custom time bin of 6 months
              TimeAggregationType = ChartTimeAggregationType.EqualIntervalsFromStartTime,
              TimeIntervalSize = 6.0,
              TimeIntervalUnits = esriTimeUnits.esriTimeUnitsMonths,
              // NOTE: When setting custom time binning, be sure to set CalculateAutomaticTimeInterval = false
              CalculateAutomaticTimeInterval = false,
              // Define custom line color
              ColorType = ChartColorType.CustomColor,
              LineSymbolProperties = new CIMChartLineSymbolProperties {
                  Style = ChartLineDashStyle.DashDot,
                  Color = new CIMRGBColor { R = 0, G = 150, B = 20 },
              MarkerSymbolProperties = new CIMChartMarkerSymbolProperties
    var newChartsLine = new CIMChart[] { lineChart };
    var allChartsLine = (lyrDefLine == null) ? newChartsLine : lyrDefLine.Charts.Concat(newChartsLine);
    lyrDefLine.Charts = allChartsLine.ToArray();
    featureLayer.SetDefinition(lyrDefLine);
Create a bar chart
    var layerDefinition = featureLayer.GetDefinition();
    string fieldXAxis = "textField";
    string fieldYAxis = "NumericField";
    var myBarChart = new CIMChart
      Name = "Bar chart",
        Title = $"{fieldXAxis} vs. {fieldYAxis}",
      Series =
          new CIMChartBarSeries
        Name = "Bar chart",
        UniqueName = "Bar chart",
        Fields = new string[] { fieldXAxis, fieldYAxis },
        //Create green fill symbols
        FillSymbolProperties = new CIMChartFillSymbolProperties
            Color = CIMColor.CreateRGBColor(38, 115, 0, 70)
    var newBarCharts = new CIMChart[] { myBarChart };
    var allChartsBar = (layerDefinition.Charts == null) ? newBarCharts : layerDefinition.Charts.Concat(newBarCharts);
    layerDefinition.Charts = allChartsBar.ToArray();
    featureLayer.SetDefinition(layerDefinition);
Create a histogram for every field of type Double
  var lyrDefHistogram = featureLayer.GetDefinition();
  // Get list names for fields of type Double
  var doubleFields = featureLayer.GetFieldDescriptions().Where(f => f.Type == FieldType.Double).Select(f => f.Name);
  // Create list that will contain all histograms
  var histograms = new List<CIMChart>();
  // Create histogram for each Double field
  foreach (var field in doubleFields)
    // Define histogram CIM properties
    var histogram = new CIMChart
      Name = $"histogram_{field}",
        Title = $"Histogram for {field}",
      Series =
              new CIMChartHistogramSeries {
                  UniqueName = "histogramSeries",
                  BinCount = 15,
                  // Specify the number field
                  Fields = new string[] { field },
    histograms.Add(histogram);
  var allChartsHistogram = (lyrDefHistogram == null) ? histograms : lyrDefHistogram.Charts.Concat(histograms);
  lyrDefHistogram.Charts = allChartsHistogram.ToArray();
  featureLayer.SetDefinition(lyrDefHistogram);
Create a multiseries bar chart
  var lyrDefBar = featureLayer.GetDefinition();
  // Get unique values for `splitByField`
  var values = new List<string>();
  using (RowCursor cursor = featureLayer.Search())
    while (cursor.MoveNext())
      var value = Convert.ToString(cursor.Current[splitByField]);
      values.Add(value);
  var uniqueValues = values.Distinct().ToList();
  // Define bar chart CIM properties
  var barChart = new CIMChart
    Name = "barChart",
      Title = $"{categoryField} grouped by {splitByField}",
  // Create list to store the info for each chart series
  var allSeries = new List<CIMChartSeries>();
  // Create a series for each unique category
  foreach (var value in uniqueValues)
    var series = new CIMChartBarSeries
      UniqueName = value,
      Name = value,
      // Specify the category field
      Fields = new string[] { categoryField, string.Empty },
      // Specify the WhereClause to filter a series by unique value
      WhereClause = $"{splitByField} = '{value}'",
      GroupFields = new[] { categoryField },
      FieldAggregation = new string[] { string.Empty, "COUNT" }
    allSeries.Add(series);
  barChart.Series = allSeries.ToArray();
  var newChartsBar = new CIMChart[] { barChart };
  var allBarCharts = (lyrDefBar == null) ? newChartsBar : lyrDefBar.Charts.Concat(newChartsBar);
  lyrDefBar.Charts = allBarCharts.ToArray();
  featureLayer.SetDefinition(lyrDefBar);
Create a pie chart with custom legend formatting
  var lyrDef = featureLayer.GetDefinition();
  // Define pie chart CIM properties
  var pieChart = new CIMChart
    Name = "pieChart",
      Title = "Pie chart with custom legend formatting",
      UseAutomaticTitle = true
    Legend = new CIMChartLegend
      LegendText = new CIMChartTextProperties
        FontFillColor = new CIMRGBColor { R = 0, G = 250, B = 20 }, // Specify new font color
        FontSize = 6.0, // Specify new font size
    Series = [
            new CIMChartPieSeries
               UniqueName = "pieSeries",
               Name = "pieSeries",
  var newCharts = new CIMChart[] { pieChart };
  var allCharts = (lyrDef?.Charts == null) ? newCharts : lyrDef.Charts.Concat(newCharts);
  lyrDef.Charts = allCharts.ToArray();
  featureLayer.SetDefinition(lyrDef);
