ProSnippets CoreHost
Language:              C#
Subject:               CoreHost
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Initializing Core Host
The main entry point for the application, responsible for initializing the ArcGIS Core Host.
//[STAThread] must be present on the Application entry point
[STAThread]
static void Main(string[] args)
  //Call Host.Initialize before constructing any objects from ArcGIS.Core
  try
    Host.Initialize();
  catch (Exception e)
    // Error (missing installation, no license, 64 bit mismatch, etc.)
    Console.WriteLine(string.Format("Initialization failed: {0}", e.Message));
    return;
  //if we are here, ArcGIS.Core is successfully initialized
  Geodatabase gdb = new(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\SDK\GDB\MySampleData.gdb")));
  IReadOnlyList<TableDefinition> definitions = gdb.GetDefinitions<FeatureClassDefinition>();
  foreach (var fdsDef in definitions)
    Console.WriteLine(TableString(fdsDef as TableDefinition));
  Console.Read();
private static string TableString(TableDefinition table)
  string alias = table.GetAliasName();
  string name = table.GetName();
  return string.Format("{0} ({1})", alias.Length > 0 ? alias : name, name);
