ProSnippets Geodatabase
Language:              C#
Subject:               GeoDatabase
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Geodatabases and Datastores
Opening a File Geodatabase given the path
await QueuedTask.Run(() =>
    // Opens a file geodatabase. This will open the geodatabase if the folder exists and contains a valid geodatabase.
    using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\Data\LocalGovernment.gdb"))))
      // Use the geodatabase.
Opening an Enterprise Geodatabase using connection properties
    // Opening a Non-Versioned SQL Server instance.
    DatabaseConnectionProperties connectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
      AuthenticationMode = AuthenticationMode.DBMS,
      // Where testMachine is the machine where the instance is running and testInstance is the name of the SqlServer instance.
      Instance = @"testMachine\testInstance",
      // Provided that a database called LocalGovernment has been created on the testInstance and geodatabase has been enabled on the database.
      Database = "LocalGovernment",
      // Provided that a login called gdb has been created and corresponding schema has been created with the required permissions.
      User = "gdb",
      Password = "password",
      Version = "dbo.DEFAULT"
    using (Geodatabase geodatabase = new Geodatabase(connectionProperties))
Opening an Enterprise Geodatabase using sde file path
      new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
Connecting to a Feature Service using a URL
//Url examples for (federated) feature services
  //(by "ref" online):
  var url =
      @"https://sampleserver6.arcgisonline.com/arcgis/rest/services/LocalGovernment/Recreation/FeatureServer";
  //(federated by ref on portal)
  //https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer
  //(federated by value - Hosted - on portal)
  //https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer
    var uri = new Uri(url, UriKind.Absolute);
    using (var fs_db =
        new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
      //Use the geodatabase
Connecting to Different Types of Feature Services
    Uri nonFederatedServerURL = new Uri(
    "https://arcgis.server.example.com:6443/arcgis/rest/services/FeatureServiceName/FeatureServer");
    // Note that for non-federated ArcGIS Server hosted feature services,
    // the username and password have to be specified always.
    ServiceConnectionProperties nonFederatedArcGISServer =
          new ServiceConnectionProperties(nonFederatedServerURL)
            User = "serverUser",
            Password = "serverPassword"
    using (Geodatabase nonFederatedServerFeatureService =
      new Geodatabase(nonFederatedArcGISServer))
      // Use the feature service geodatabase.
    //Hosted (or published "by value")
    Uri federatedServerURL = new Uri(
      "http://federated.with.portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer");
    //Published "by reference"
    //Uri federatedServerURL = new Uri(
    //"http://federated.with.portal.example.com/server/rest/services/FeatureServiceName/FeatureServer");
    // Note that for feature services hosted on ArcGIS Server federated with
    // ArcGIS Portal, the username and password cannot be specified through the API.
    // Even if the username and password were specified, they will be disregarded.
    // Instead the Portal authorization has to be configured by adding the Portal to
    // ArcGIS Pro with the user with which the connection should be established.
    // To connect to a Portal from a CoreHost application, use the
    // ArcGIS.Core.SystemCore.ArcGISSignOn class to authenticate with the Portal.
    ServiceConnectionProperties federatedArcGISServer =
      new ServiceConnectionProperties(federatedServerURL);
    using (Geodatabase federatedServerFeatureService =
      new Geodatabase(federatedArcGISServer))
    Uri arcgisOnlineURL = new Uri(
      "http://services1.arcgis.com/47GG2ga246DGaLwa/arcgis/rest/services/FeatureServiceName/FeatureServer");
    //or
    //https://sampleserver6.arcgisonline.com/arcgis/rest/services/LocalGovernment/Recreation/FeatureServer
    //etc
    // Similar to Federated Feature Services, note that for feature services
    // hosted on ArcGIS Online, the username and password cannot be specified through
    // the API. Even if the username and password were specified, they will be
    // disregarded. Instead the connection will be established based on the ArcGIS
    // Online user credentials used to login to ArcGIS Pro at startup.
    ServiceConnectionProperties arcGISOnline =
      new ServiceConnectionProperties(arcgisOnlineURL);
    using (Geodatabase arcGISOnlineFeatureService =
      new Geodatabase(arcGISOnline))
Get the Data Connection Properties from a Feature Service
    Layer selectedLayer = MapView.Active.GetSelectedLayers()[0];
    if (selectedLayer is FeatureLayer)
      FeatureLayer featureLayer = selectedLayer as FeatureLayer;
      using (Table table = featureLayer.GetTable())
      using (Datastore datastore = table.GetDatastore())
        ServiceConnectionProperties serviceConnectionProperties = datastore.GetConnector() as ServiceConnectionProperties;
        if (serviceConnectionProperties == null)
          return;
        Uri url = serviceConnectionProperties.URL;      // Will be the URL to the Feature Service.
        string user = serviceConnectionProperties.User;     // The username property will only be
                                                            // populated for feature service hosted
                                                            // on non-federated ArcGIS Server.
        string password = serviceConnectionProperties.Password; // Will always be empty.
Obtaining Geodatabase from Project Item
    IEnumerable<GDBProjectItem> gdbProjectItems = Project.Current.GetItems<GDBProjectItem>();
    foreach (GDBProjectItem gdbProjectItem in gdbProjectItems)
      using (Datastore datastore = gdbProjectItem.GetDatastore())
        //Unsupported datastores (non File GDB and non Enterprise GDB) will be of type UnknownDatastore
        if (datastore is UnknownDatastore)
          continue;
        Geodatabase geodatabase = datastore as Geodatabase;
Getting Database Connection Properties from a Connection File
DatabaseConnectionFile connectionFile =
    new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"));
    DatabaseClient.GetDatabaseConnectionProperties(connectionFile);
  // Now you could, for example, change the user name and password in the connection properties prior to use them to open a geodatabase
Obtaining Geodatabase from FeatureLayer
    IEnumerable<Layer> layers =
      MapView.Active.Map.Layers.Where(layer => layer is FeatureLayer);
    foreach (FeatureLayer featureLayer in layers)
          continue;
Executing SQL Statements
// Executes raw SQL on the underlying database management system.
  //  Any SQL is permitted (DDL or DML), but no results can be returned
  void ExecuteSQLOnGeodatabase(Geodatabase geodatabase, string statement)
    //Must be on QueuedTask.Run
    DatabaseClient.ExecuteStatement(geodatabase, statement);
Definitions
Obtaining Definition from Geodatabase
    using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file\\sdefile.sde"))))
      // Remember that for Enterprise databases you have to qualify your dataset names with the DatabaseName and UserName.
      TableDefinition enterpriseTableDefinition = geodatabase.GetDefinition<TableDefinition>("LocalGovernment.GDB.CitizenContactInfo");
      // It does not matter if the dataset is within a FeatureDataset or not.
      FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>("LocalGovernment.GDB.FireStation");
      // GetDefinition For a RelationshipClass.
      RelationshipClassDefinition relationshipClassDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>(
          "LocalGovernment.GDB.AddressPointHasSiteAddresses");
      // GetDefinition For a FeatureDataset.
      FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("LocalGovernment.GDB.Address");
Obtaining List of Definitions from Geodatabase
      IReadOnlyList<FeatureClassDefinition> enterpriseDefinitions = geodatabase.GetDefinitions<FeatureClassDefinition>();
      IEnumerable<Definition> featureClassesHavingGlobalID = enterpriseDefinitions.Where(definition => definition.HasGlobalID());
      IReadOnlyList<FeatureDatasetDefinition> featureDatasetDefinitions = geodatabase.GetDefinitions<FeatureDatasetDefinition>();
      bool electionRelatedFeatureDatasets = featureDatasetDefinitions.Any(definition => definition.GetName().Contains("Election"));
      IReadOnlyList<AttributedRelationshipClassDefinition> attributedRelationshipClassDefinitions = geodatabase.GetDefinitions<AttributedRelationshipClassDefinition>();
      IReadOnlyList<RelationshipClassDefinition> relationshipClassDefinitions = geodatabase.GetDefinitions<RelationshipClassDefinition>();
Obtaining Definitions from a Feature Service by Layer ID
  var url =
      @"https://sampleserver6.arcgisonline.com/arcgis/rest/services/SF311/FeatureServer";
  //https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer");
  //https://portal.example.com/server/rest/services/Hosted/FeatureServiceName/FeatureServer");
    using (var fs_db = new ArcGIS.Core.Data.Geodatabase(new ServiceConnectionProperties(uri)))
      //Assuming that id 0 is a FeatureClass for the given service
          fs_db.GetDefinition<FeatureClassDefinition>("0");
      string shapeField = featureClassDefinition.GetShapeField();
      IReadOnlyList<Field> fields = featureClassDefinition.GetFields();
      //Assuming that id 1 is a Table for the given service
      TableDefinition tableDefinition =
            fs_db.GetDefinition<TableDefinition>("1");
      string objectIDField = tableDefinition.GetObjectIDField();
      // Remember the qualification of DatabaseName. for the RelationshipClass.
      RelationshipClassDefinition enterpriseDefinition = geodatabase.GetDefinition<RelationshipClassDefinition>("LocalGovernment.GDB.AddressPointHasSiteAddresses");
      IReadOnlyList<Definition> enterpriseDefinitions = geodatabase.GetRelatedDefinitions(enterpriseDefinition,
          DefinitionRelationshipType.DatasetsRelatedThrough);
      FeatureClassDefinition enterpriseAddressPointDefinition = enterpriseDefinitions.First(defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint"))
          as FeatureClassDefinition;
      IReadOnlyList<Definition> datasetsInAddressDataset = geodatabase.GetRelatedDefinitions(featureDatasetDefinition,
          DefinitionRelationshipType.DatasetInFeatureDataset);
      FeatureClassDefinition addressPointInAddressDataset = datasetsInAddressDataset.First(defn => defn.GetName().Equals("LocalGovernment.GDB.AddressPoint"))
      RelationshipClassDefinition addressPointHasSiteAddressInAddressDataset = datasetsInAddressDataset.First(defn =>
            defn.GetName().Equals("LocalGovernment.GDB.AddressPointHasSiteAddresses"))
          as RelationshipClassDefinition;
Getting a Table Definition from a Layer
// GetDefinitionFromLayer - This code works even if the layer has a join to another table
  //Must be called within QueuedTask.Run()
  TableDefinition GetDefinitionFromLayer(FeatureLayer featureLayer)
    // Get feature class from the layer
    FeatureClass featureClass = featureLayer.GetFeatureClass();
    // Determine if feature class is a join
    if (featureClass.IsJoinedTable())
      // Get join from feature class
      Join join = featureClass.GetJoin();
      // Get origin table from join
      Table originTable = join.GetOriginTable();
      // Return feature class definition from the join's origin table
      return originTable.GetDefinition();
    return featureClass.GetDefinition();
Datasets
Opening datasets from Geodatabase
      using (Table table = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.EmployeeInfo"))
      // Open a featureClass (within a feature dataset or outside a feature dataset).
      using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.AddressPoint"))
      // Open a FeatureClass as a Table which will return the Table reference.
      using (Table featureClassAsTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.AddressPoint"))
        // But it is really a FeatureClass object.
        FeatureClass featureClassOpenedAsTable = featureClassAsTable as FeatureClass;
      // Open a FeatureDataset.
      using (FeatureDataset featureDataset = geodatabase.OpenDataset<FeatureDataset>("LocalGovernment.GDB.Address"))
      // Open a RelationshipClass.  Just as you can open a FeatureClass as a Table, you can also open an AttributedRelationshipClass as a RelationshipClass.
      using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.AddressPointHasSiteAddresses"))
Opening datasets from a Feature Service by Layer ID
  var url =
      @"https://portal.example.com/server/rest/services/FeatureServiceName/FeatureServer";
      using (FeatureClass featureClass = fs_db.OpenDataset<FeatureClass>("0"))
        // Use the feature class opened from layer ID 0.
      using (Table table = fs_db.OpenDataset<Table>("4"))
        // Use the table opened from layer ID 4.
      using (AttributedRelationshipClass attributedRelationshipClass =
          fs_db.OpenDataset<AttributedRelationshipClass>("5"))
        // Use the attributed relationship class opened from layer ID 5.
      try
        string idOfLayerWhichIsNotTable = "3";
        fs_db.OpenDataset<Table>(idOfLayerWhichIsNotTable);
      catch (InvalidOperationException)
        // Handle Exception.
Checking for the existence of a Table
//Must be called within QueuedTask.Run().
  bool TableExists(Geodatabase geodatabase, string tableName)
    try
      using TableDefinition tableDefinition =
        geodatabase.GetDefinition<TableDefinition>(tableName);
      return true;
    catch
      // GetDefinition throws an exception if the definition doesn't exist
      return false;
Checking for the existence of a Feature Class
  bool FeatureClassExists(Geodatabase geodatabase, string featureClassName)
    try
      using FeatureClassDefinition featureClassDefinition =
        geodatabase.GetDefinition<FeatureClassDefinition>(featureClassName);
      return true;
    catch
      return false;
Opening RelationshipClass between two Tables
// Must be called within QueuedTask.Run().
  // When used with file or enterprise geodatabases, this routine takes two table names.
  // When used with feature services, this routine takes layer IDs, or the names of the tables as they are exposed through the service (e.g., "L0States")
  IReadOnlyList<RelationshipClass> OpenRelationshipClassFeatureServices(
    Geodatabase geodatabase, string originClass, string destinationClass)
    return geodatabase.OpenRelationshipClasses(originClass, destinationClass);
      foreach (RelationshipClassDefinition relationshipClassDefinition in relationshipClassDefinitions)
        IReadOnlyList<Definition> definitions = geodatabase.GetRelatedDefinitions(relationshipClassDefinition, DefinitionRelationshipType.DatasetsRelatedThrough);
        foreach (Definition definition in definitions)
          Debug.WriteLine($"Feature class in the RelationshipClass is:{definition.GetName()}");
Opening a FeatureClass from a ShapeFile Datastore
    FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\shapefiles"),
        FileSystemDatastoreType.Shapefile);
    using (FileSystemDatastore shapefile = new FileSystemDatastore(fileConnection))
      FeatureClass taxLotsFeatureClass = shapefile.OpenDataset<FeatureClass>("TaxLots");
      // Can use the .shp extension, but its not needed.
      FeatureClass manHolesFeatureClass = shapefile.OpenDataset<FeatureClass>("ManHoles.shp");
      Table taxDetailsTableWithoutExtension = shapefile.OpenDataset<Table>("TaxDetails");
      Table taxDetailsTable = shapefile.OpenDataset<Table>("TaxDetails.dbf");
Opening a CAD Datastore
    FileSystemConnectionPath fileConnection = new FileSystemConnectionPath(new Uri("path\\to\\folder\\containing\\CAD"), FileSystemDatastoreType.Cad);
    using (FileSystemDatastore cadDatastore = new FileSystemDatastore(fileConnection))
      //Note: Extension is required
      FeatureClass cadDataset = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg");
      // Take note of the pattern for referencing a feature class.
      FeatureClass cadfeatureClass = cadDatastore.OpenDataset<FeatureClass>("hatchplayboundaries.dwg:Polyline");
      int numRows = 0;
      using (RowCursor cursor = cadfeatureClass.Search())
        while (cursor.MoveNext())
          numRows++;
Queries
Searching a Table using QueryFilter
    try
      using (Table table = geodatabase.OpenDataset<Table>("EmployeeInfo"))
        QueryFilter queryFilter = new QueryFilter
          WhereClause = "COSTCTRN = 'Information Technology'",
          SubFields = "KNOWNAS, OFFICE, LOCATION",
          PostfixClause = "ORDER BY OFFICE"
        using (RowCursor rowCursor = table.Search(queryFilter, false))
          while (rowCursor.MoveNext())
            using (Row row = rowCursor.Current)
              string location = Convert.ToString(row["LOCATION"]);
              string knownAs = Convert.ToString(row["KNOWNAS"]);
    catch (GeodatabaseFieldException fieldException)
      // One of the fields in the where clause might not exist. There are multiple ways this can be handled:
      // Handle error appropriately
Searching a Table for non-Latin characters
    using (Table table = geodatabase.OpenDataset<Table>("TableWithChineseCharacters"))
      // This will fail with many database systems that expect Latin characters by default
      string incorrectWhereClause = "颜色 = '绿'";
      // Correct solution is to prepend the 'National String Prefix' to the attribute value
      // For example, with SQL Server this value is 'N'
      // This value is obtained using the SQLSyntax class
      string nationalStringPrefix = "";
      SQLSyntax sqlSyntax = geodatabase.GetSQLSyntax();
      nationalStringPrefix = sqlSyntax.GetSupportedStrings(SQLStringType.NationalStringPrefix).First();
      // This Where clause will work
      QueryFilter queryFilter = new QueryFilter()
        WhereClause = "颜色 = " + nationalStringPrefix + "'绿'"
Searching a Table using a set of ObjectIDs
  RowCursor SearchingATable(Table table, IReadOnlyList<long> objectIDs)
      ObjectIDs = objectIDs
    return table.Search(queryFilter);
Searching a FeatureClass using SpatialQueryFilter
    using (FeatureClass schoolBoundaryFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.SchoolBoundary"))
      // Using a spatial query filter to find all features which have a certain district name and lying within a given Polygon.
      SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter
        WhereClause = "DISTRCTNAME = 'Indian Prairie School District 204'",
        FilterGeometry = new PolygonBuilderEx(new List<Coordinate2D>
          new Coordinate2D(1021880, 1867396),
          new Coordinate2D(1028223, 1870705),
          new Coordinate2D(1031165, 1866844),
          new Coordinate2D(1025373, 1860501),
          new Coordinate2D(1021788, 1863810)
        }).ToGeometry(),
        SpatialRelationship = SpatialRelationship.Within
      using (RowCursor indianPrairieCursor = schoolBoundaryFeatureClass.Search(spatialQueryFilter, false))
        while (indianPrairieCursor.MoveNext())
          using (Feature feature = (Feature)indianPrairieCursor.Current)
            // Process the feature. For example...
            Console.WriteLine(feature.GetObjectID());
Selecting Rows from a Table
    using (Table enterpriseTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.piCIPCost"))
      QueryFilter anotherQueryFilter = new QueryFilter { WhereClause = "FLOOR = 1 AND WING = 'E'" };
      // For Selecting all matching entries.
      using (Selection anotherSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Normal))
      // This can be used to get one record which matches the criteria. No assumptions can be made about which record satisfying the criteria is selected.
      using (Selection onlyOneSelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
      // This can be used to obtain a empty selection which can be used as a container to combine results from different selections.
      using (Selection emptySelection = enterpriseTable.Select(anotherQueryFilter, SelectionType.ObjectID, SelectionOption.Empty))
      // If you want to select all the records in a table.
      using (Selection allRecordSelection = enterpriseTable.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
Selecting Features from a FeatureClass
    using (FeatureClass enterpriseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.FacilitySite"))
      List<Coordinate2D> newCoordinates = new List<Coordinate2D>
        new Coordinate2D(1021570, 1880583),
        new Coordinate2D(1028730, 1880994),
        new Coordinate2D(1029718, 1875644),
        new Coordinate2D(1021405, 1875397)
      SpatialQueryFilter spatialFilter = new SpatialQueryFilter
        WhereClause = "FCODE = 'Park'",
        FilterGeometry = new PolygonBuilderEx(newCoordinates).ToGeometry(),
        SpatialRelationship = SpatialRelationship.Crosses
      using (Selection anotherSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Normal))
      // criteria is selected.
      using (Selection onlyOneSelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.OnlyOne))
      // This can be used to obtain an empty selction which can be used as a container to combine results from different selections.
      using (Selection emptySelection = enterpriseFeatureClass.Select(spatialFilter, SelectionType.ObjectID, SelectionOption.Empty))
      using (Selection allRecordSelection = enterpriseFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Normal))
Gets the count of a Table or FeatureClass
  void GetCount(FeatureLayer featureLayer)
    // Row count in a Table
    Table table = featureLayer.GetTable();
    long count = table.GetCount();
    // Feature count in a FeatureClass
    FeatureLayer lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
    FeatureClass featureClass = lyr.GetFeatureClass();
    count = featureClass.GetCount();
Sorting a Table
  RowCursor SortWorldCities(FeatureClass worldCitiesTable)
    using (FeatureClassDefinition featureClassDefinition = worldCitiesTable.GetDefinition())
      Field countryField = featureClassDefinition.GetFields()
        .First(x => x.Name.Equals("COUNTRY_NAME"));
      Field cityNameField = featureClassDefinition.GetFields()
        .First(x => x.Name.Equals("CITY_NAME"));
      // Create SortDescription for Country field
      SortDescription countrySortDescription = new SortDescription(countryField);
      countrySortDescription.CaseSensitivity = CaseSensitivity.Insensitive;
      countrySortDescription.SortOrder = SortOrder.Ascending;
      // Create SortDescription for City field
      SortDescription citySortDescription = new SortDescription(cityNameField);
      citySortDescription.CaseSensitivity = CaseSensitivity.Insensitive;
      citySortDescription.SortOrder = SortOrder.Ascending;
      // Create our TableSortDescription
      TableSortDescription tableSortDescription = new TableSortDescription(
        new List<SortDescription>() { countrySortDescription, citySortDescription });
      return worldCitiesTable.Sort(tableSortDescription);
Calculating Statistics on a Table
  // Calculate the Sum and Average of the Population_1990 and Population_2000 fields, grouped and ordered by Region
  void CalculateStatistics(FeatureClass countryFeatureClass)
    using (FeatureClassDefinition featureClassDefinition = countryFeatureClass.GetDefinition())
      // Get fields
      Field regionField = featureClassDefinition.GetFields()
        .First(x => x.Name.Equals("Region"));
      Field pop1990Field = featureClassDefinition.GetFields()
        .First(x => x.Name.Equals("Population_1990"));
      Field pop2000Field = featureClassDefinition.GetFields()
        .First(x => x.Name.Equals("Population_2000"));
      // Create StatisticsDescriptions
      StatisticsDescription pop1990StatisticsDescription = new StatisticsDescription(pop1990Field,
        new List<StatisticsFunction>()
          StatisticsFunction.Sum,
          StatisticsFunction.Average
      StatisticsDescription pop2000StatisticsDescription = new StatisticsDescription(pop2000Field,
      // Create TableStatisticsDescription
      TableStatisticsDescription tableStatisticsDescription = new TableStatisticsDescription(
        new List<StatisticsDescription>()
          pop1990StatisticsDescription, pop2000StatisticsDescription
      tableStatisticsDescription.GroupBy = new List<Field>() { regionField };
      tableStatisticsDescription.OrderBy = new List<SortDescription>() { new SortDescription(regionField) };
      // Calculate Statistics
      IReadOnlyList<TableStatisticsResult> tableStatisticsResults =
        countryFeatureClass.CalculateStatistics(tableStatisticsDescription);
      foreach (TableStatisticsResult tableStatisticsResult in tableStatisticsResults)
        // Get the Region name
        // If multiple fields had been passed into TableStatisticsDescription.GroupBy, there would be multiple values in TableStatisticsResult.GroupBy
        string regionName = tableStatisticsResult.GroupBy.First().Value.ToString();
        // Get the statistics results for the Population_1990 field
        StatisticsResult pop1990Statistics = tableStatisticsResult.StatisticsResults[0];
        double population1990Sum = pop1990Statistics.Sum;
        double population1990Average = pop1990Statistics.Average;
        // Get the statistics results for the Population_2000 field
        StatisticsResult pop2000Statistics = tableStatisticsResult.StatisticsResults[1];
        double population2000Sum = pop2000Statistics.Sum;
        double population2000Average = pop2000Statistics.Average;
        // Do something with the results here...
Evaluating a QueryDef on a single table
    using (Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri("path\\to\\sde\\file"))))
      QueryDef adaCompilantParksQueryDef = new QueryDef
        Tables = "Park",
        WhereClause = "ADACOMPLY = 'Yes'",
      using (RowCursor rowCursor = geodatabase.Evaluate(adaCompilantParksQueryDef, false))
            Feature feature = row as Feature;
            Geometry shape = feature.GetShape();
            String type = Convert.ToString(row["ADACOMPLY"]); // will be "Yes" for each row.
            try
              Table table = row.GetTable(); // Will always throw exception.
            catch (NotSupportedException exception)
              // Handle not supported exception.
Evaluating a QueryDef on a Join using WHERE Clause
      QueryDef municipalEmergencyFacilitiesQueryDef = new QueryDef
        SubFields = "EmergencyFacility.OBJECTID, EmergencyFacility.Shape, EmergencyFacility.FACILITYID, FacilitySite.FACILITYID, FacilitySite.FCODE",
        Tables = "EmergencyFacility, FacilitySite",
        WhereClause = "EmergencyFacility.FACNAME = FacilitySite.NAME AND EmergencyFacility.JURISDICT = 'Municipal'",
      using (RowCursor rowCursor = geodatabase.Evaluate(municipalEmergencyFacilitiesQueryDef, false))
            long objectID = Convert.ToInt64(row["EmergencyFacility.OBJECTID"]);
            String featureCode = Convert.ToString(row["FacilitySite.FCODE"]);
              fields = feature.GetFields(); //Contains one ArcGIS.Core.Data.Field objects for every subfield
Evaluating a QueryDef on a OUTER JOIN
      QueryDef queryDefWithLeftOuterJoin = new QueryDef
        Tables = "CommunityAddress LEFT OUTER JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
        SubFields = "CommunityAddress.OBJECTID, CommunityAddress.Shape, CommunityAddress.SITEADDID, CommunityAddress.ADDRNUM, CommunityAddress.FULLNAME, CommunityAddress.FULLADDR, CommunityAddress.MUNICIPALITY, MunicipalBoundary.Name, MunicipalBoundary.MUNITYP, MunicipalBoundary.LOCALFIPS",
      using (RowCursor rowCursor = geodatabase.Evaluate(queryDefWithLeftOuterJoin, false))
            int siteAddressId = Convert.ToInt32(row["CommunityAddress.SITEADDID"]);
            String stateName = Convert.ToString(row["MunicipalBoundary.name"]);
Evaluating a QueryDef on a INNER join
      QueryDef queryDef = new QueryDef()
        Tables = "People INNER JOIN States ON People.FK_STATE_ID = States.OBJECTID",
        SubFields = "People.OBJECTID, People.First_Name, People.Last_Name, People.City, States.State_Name"
      using (RowCursor cursor = geodatabase.Evaluate(queryDef))
          using (Row row = cursor.Current)
            // Handle row
Evaluating a QueryDef on a nested - INNER and OUTER join
        Tables = "((People INNER JOIN States ON People.FK_STATE_ID = States.OBJECTID) LEFT OUTER JOIN Homes ON People.OBJECTID = Homes.FK_People_ID)",
        SubFields = "People.OBJECTID, People.First_Name, People.Last_Name, States.State_Name, Homes.Address"
      using (RowCursor cursor = geodatabase.Evaluate(queryDef, false))
            // Handle row
Create Default QueryDescription for a Database table and obtain the ArcGIS.Core.Data.Table for the QueryDescription
    DatabaseConnectionProperties databaseConnectionProperties = new DatabaseConnectionProperties(EnterpriseDatabaseType.SQLServer)
      Instance = "instance",
      Database = "database",
      User = "user",
    using (Database database = new Database(databaseConnectionProperties))
      QueryDescription queryDescription = database.GetQueryDescription("CUSTOMERS");
      using (Table table = database.OpenTable(queryDescription))
        //use table
Create QueryDescription from a custom query for a Database table
      User = "user",
      QueryDescription queryDescription = database.GetQueryDescription("SELECT OBJECTID, Shape, FACILITYID FROM EmergencyFacility WHERE JURISDICT = 'Municipal'",
        "MunicipalEmergencyFacilities");
        // Use the table.
Create QueryDescription from a join query where there is no non-nullable unique id column
      User = "user",
      QueryDescription queryDescription = database.GetQueryDescription("SELECT BUSLINES.ID as BUSLINESID, BUSSTOPS.ID as BUSSTOPSID, BUSLINES.RTE_DESC, BUSLINES.DIR, BUSSTOPS.JURISDIC, BUSSTOPS.LOCATION, BUSSTOPS.ROUTE,BUSSTOPS.SHAPE from demosql.dbo.BUSSTOPS JOIN demosql.dbo.BUSLINES ON BUSSTOPS.ROUTE = BUSLINES.ROUTE",
        "BusInfo");
      queryDescription.SetObjectIDFields("BUSLINESID,BUSSTOPSID");
        // Use the table.
Create QueryDescription from a query for a Database table which has more than one shape type
      User = "user",
      QueryDescription pointQueryDescription = database.GetQueryDescription("select Description, SHAPE, UniqueID from MULTIGEOMETRYTEST",
          "MultiGeometryPoint");
      pointQueryDescription.SetShapeType(GeometryType.Point);
      using (Table pointTable = database.OpenTable(pointQueryDescription))
        //use pointTable
      QueryDescription polygonQueryDescription = database.GetQueryDescription("select Description, SHAPE, UniqueID from MULTIGEOMETRYTEST",
          "MultiGeometryPolygon");
      polygonQueryDescription.SetShapeType(GeometryType.Polygon);
      using (Table polygonTable = database.OpenTable(polygonQueryDescription))
        //use polygonTable
Create QueryDescription from a query for an SQLite Database table
    using (Database database = new Database(new SQLiteConnectionPath(new Uri("Path\\To\\Sqlite\\Database\\USA.sqlite"))))
      QueryDescription washingtonCitiesQueryDescription = database.GetQueryDescription("select OBJECTID, Shape, CITY_FIPS, CITY_NAME, STATE_FIPS, STATE_CITY, TYPE, CAPITAL from main.cities where STATE_NAME='Washington'",
        "WashingtonCities");
      using (Table washingtonTable = database.OpenTable(washingtonCitiesQueryDescription))
        // Use washingtonTable.
Using SQLSyntax to form platform agnostic queries
    using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("C:\\Data\\LocalGovernment.gdb"))))
    using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("FacilitySite"))
      string substringFunctionName = sqlSyntax.GetFunctionName(SQLFunction.Substring);
      string upperFunctionName = sqlSyntax.GetFunctionName(SQLFunction.Upper);
      string substringfunction = string.Format("{0}({1}(FCODE, 1, 6)) = 'SCHOOL'", upperFunctionName,
        substringFunctionName);
        WhereClause = substringfunction
      using (Selection selection =
             featureClass.Select(queryFilter, SelectionType.ObjectID, SelectionOption.Normal))
        // work with the selection.
Fulltext search query
    using (Table table = geodatabase.OpenDataset<Table>("WaterPipeInfo"))
    using (TableDefinition tableDefinition = table.GetDefinition())
      bool supportsFullText = geodatabase.GetDatastoreProperties().SupportsFullTextIndex;
      if (!supportsFullText)
        return;
      IReadOnlyList<Index> indexes = tableDefinition.GetIndexes();
      IReadOnlyList<Field> fieldsToSearch = indexes.First().GetFields();
      FullTextSearchTermExpression searchRepairStatus = new FullTextSearchTermExpression()
        SearchFields = fieldsToSearch[0].Name,
        SearchTerm = "Repaired",
        SearchType = FullTextSearchType.Simple
      FullTextSearchTermExpression searchPipeMaterial = new FullTextSearchTermExpression()
        SearchFields = fieldsToSearch[1].Name,
        SearchTerm = "Copper",
      FullTextOrExpression repairedOrCopperEx = new FullTextOrExpression(searchRepairStatus, searchPipeMaterial);
      QueryFilter queryfilter = new QueryFilter
        FullTextExpression = repairedOrCopperEx,
        Offset = 1,
        RowCount = 20,
        PostfixClause = "Order By Size"
      using (RowCursor rowCursor = table.Search(queryfilter, false))
        // Use row cursor ...
Joining a file geodatabase feature class to an Oracle database query layer feature class with a virtual relationship class
    using (Database database = new Database(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
      User = "user",
    using (FeatureClass leftFeatureClass = geodatabase.OpenDataset<FeatureClass>("Hospital"))
    using (Table rightTable = database.OpenTable(database.GetQueryDescription("FacilitySite")))
      Field originPrimaryKey = leftFeatureClass.GetDefinition().GetFields()
        .FirstOrDefault(field => field.Name.Equals("facilityId"));
      Field destinationForeignKey = rightTable.GetDefinition().GetFields()
        .FirstOrDefault(field => field.Name.Equals("hospitalID"));
      VirtualRelationshipClassDescription description = new VirtualRelationshipClassDescription(
        originPrimaryKey, destinationForeignKey, RelationshipCardinality.OneToOne);
      using (RelationshipClass relationshipClass = leftFeatureClass.RelateTo(rightTable, description))
        JoinDescription joinDescription = new JoinDescription(relationshipClass)
          JoinDirection = JoinDirection.Forward,
          JoinType = JoinType.LeftOuterJoin
        Join join = new Join(joinDescription);
        using (Table joinedTable = join.GetJoinedTable())
          // Perform operation on joined table.
Joining two tables from different geodatabases
    using (Geodatabase sourceGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("Path \\ to \\Geodatabase \\ one"))))
    using (Geodatabase destinationGeodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri("Path \\ to \\Geodatabase \\ two"))))
    using (Table sourceTable = sourceGeodatabase.OpenDataset<Table>("State"))
    using (Table destinationTable = destinationGeodatabase.OpenDataset<Table>("Cities"))
      Field primaryKeyField = sourceTable.GetDefinition().GetFields()
        .FirstOrDefault(field => field.Name.Equals("State.State_Abbreviation"));
      Field foreignKeyField = destinationTable.GetDefinition().GetFields()
        .FirstOrDefault(field => field.Name.Equals("Cities.State"));
      VirtualRelationshipClassDescription virtualRelationshipClassDescription = new VirtualRelationshipClassDescription(primaryKeyField, foreignKeyField,
          RelationshipCardinality.OneToMany);
      using (RelationshipClass relationshipClass = sourceTable.RelateTo(destinationTable, virtualRelationshipClassDescription))
          JoinType = JoinType.InnerJoin,
          TargetFields = sourceTable.GetDefinition().GetFields()
        using (Join join = new Join(joinDescription))
          Table joinedTable = join.GetJoinedTable();
          //Process the joined table. For example ..
          using (RowCursor cursor = joinedTable.Search())
                // Use Row
Creating a QueryTable using a query which joins two versioned tables in a geodatabase
      Tables = "CommunityAddress JOIN MunicipalBoundary on CommunityAddress.Municipality = MunicipalBoundary.Name",
    using (Geodatabase testVersion1Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
      User = "user",
      Version = "user.testVersion1"
      QueryTableDescription queryTableDescription = new QueryTableDescription(queryDef)
        Name = "CommunityAddrJounMunicipalBoundr",
        PrimaryKeys = testVersion1Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
      // Will be based on testVersion1.
      using (Table queryTable = testVersion1Geodatabase.OpenQueryTable(queryTableDescription))
        // Use queryTable.
    using (Geodatabase testVersion2Geodatabase = new Geodatabase(new DatabaseConnectionProperties(EnterpriseDatabaseType.Oracle)
      User = "user",
      Version = "user.testVersion2"
        PrimaryKeys = testVersion2Geodatabase.GetSQLSyntax().QualifyColumnName("CommunityAddress", "OBJECTID")
      // Will be based on testVersion2.
      using (Table queryTable = testVersion2Geodatabase.OpenQueryTable(queryTableDescription))
        // Use queryTable.
Checking a field value for null
  bool CheckColumnForNull(Row row, Field field)
    object val = row[field.Name];
    if (val is DBNull || val == null)
      return true;
    return false;
Get domain string from a field
  string GetDomainStringFromField(Row row, Field field)
    // Get the table and table definition from the Row
    using (Table table = row.GetTable())
      // Get name of subtype field
      string subtypeFieldName = tableDefinition.GetSubtypeField();
      // Get subtype, if any
      Subtype subtype = null;
      if (subtypeFieldName.Length != 0)
        // Get value of subtype field for this row
        object varSubtypeCode = row[subtypeFieldName];
        long subtypeCode = (long)varSubtypeCode;
        // Get subtype for this row
        subtype = tableDefinition.GetSubtypes().First(x => x.GetCode() == subtypeCode);
      // Get the coded value domain for this field
      CodedValueDomain domain = field.GetDomain(subtype) as CodedValueDomain;
      // Return the text string for this field
      if (domain != null)
        return domain.GetName(row[field.Name]);
      return row[field.Name].ToString();
Get datastore or workspace properties
  void GetDatastoreProperties(Datastore geodatabase)
    // Check if a data store supports datastore properties
    bool areDatastorePropertiesSupported = geodatabase.AreDatastorePropertiesSupported();
    if (areDatastorePropertiesSupported)
      DatastoreProperties datastoreProperties = geodatabase.GetDatastoreProperties();
      // Supports 64-bit integer field
      bool supportsBigInteger = datastoreProperties.SupportsBigInteger;
      // Supports pagination
      bool supportsQueryPagination = datastoreProperties.SupportsQueryPagination;
      // Supports datastore edit
      bool canEdit = datastoreProperties.CanEdit;
      // Supports 64-bit Object ID
      bool supportsBigObjectId = datastoreProperties.SupportsBigObjectID;
      // Supports DateOnly field
      bool supportsDateOnly = datastoreProperties.SupportsDateOnly;
      // Supports TimeOnly field
      bool supportsTimeOnly = datastoreProperties.SupportsTimeOnly;
      // Supports TimestampOffset field
      bool supportsTimestampOffset = datastoreProperties.SupportsTimestampOffset;
Pagination in QueryFilter
  void QueryFilterWithPagination(Table table, List<long> objectIDs)
    int rowsPerBatch = 100;
    int offset = 0;
    // Query filter
    // Some datastores support pagination only through an SQL postfix clause
      ObjectIDs = objectIDs,
      PostfixClause = "ORDER BY OBJECTID"
    // Fetch rows in a batch from a table
    for (int index = offset; index <= objectIDs.Count; index += rowsPerBatch)
      // Set number of rows to return from a table
      queryFilter.RowCount = rowsPerBatch;
      // Set positional offset to skip number of rows from a table
      queryFilter.Offset = index;
      using (RowCursor cursor = table.Search(queryFilter))
            Console.WriteLine(row.GetObjectID());
Illustrate version conflict information from a reconcile operation
  void GetVersionConflictsInfoInUpdateDeleteType(
    ServiceConnectionProperties featureServiceConnectionProperties,
    // To illustrate the conflict between versions,
    // the feature is updated in the child version and deleted in the parent version.
    long featureObjectIDForEdit = Int64.MinValue;
    // Get branch versioned service
    using (Geodatabase fsGeodatabase = new Geodatabase(featureServiceConnectionProperties))
    using (VersionManager versionManager = fsGeodatabase.GetVersionManager())
    using (Version defaultVersion = versionManager.GetDefaultVersion())
    using (Geodatabase defaultGeodatabase = defaultVersion.Connect())
    using (FeatureClass defaultFeatureClass = defaultGeodatabase.OpenDataset<FeatureClass>(featureClassName))
    using (FeatureClassDefinition defaultFeatureClassDefinition = defaultFeatureClass.GetDefinition())
      // Create a feature in the default version to edit in a branch
      defaultGeodatabase.ApplyEdits(() =>
        using (RowBuffer rowBuffer = defaultFeatureClass.CreateRowBuffer())
          rowBuffer["NAME"] = "Loblolly Pine";
          rowBuffer["TREEAGE"] = 1;
          rowBuffer[defaultFeatureClassDefinition.GetShapeField()] = new MapPointBuilderEx(new Coordinate2D(1, 1),
            SpatialReferenceBuilder.CreateSpatialReference(4152, 0)).ToGeometry();
          using (Feature feature = defaultFeatureClass.CreateRow(rowBuffer))
            featureObjectIDForEdit = feature.GetObjectID();
      // Add newly created feature in the filter
      QueryFilter queryFilter = new QueryFilter { ObjectIDs = new List<long> { featureObjectIDForEdit } };
      // Create a branch version
      VersionDescription versionDescription = new VersionDescription("UpdateDeleteConflictType",
        "Update-Delete version conflict type", VersionAccessType.Public);
      // Edit the feature in the branch
      using (Version editVersion = versionManager.CreateVersion(versionDescription))
      using (Geodatabase branchGeodatabase = editVersion.Connect())
      using (FeatureClass featureClass = branchGeodatabase.OpenDataset<FeatureClass>(featureClassName))
      using (RowCursor rowCursor = featureClass.Search(queryFilter, false))
        branchGeodatabase.ApplyEdits(() =>
              row["TREEAGE"] = 100;
              row["NAME"] = $"{row["Name"]}_EditInBranch";
              row.Store();
        // Delete the feature from the default version
          defaultFeatureClass.DeleteRows(queryFilter);
        // Reconcile options
        ReconcileOptions reconcileOptions = new ReconcileOptions(defaultVersion)
          ConflictResolutionType = ConflictResolutionType.FavorEditVersion,
          ConflictDetectionType = ConflictDetectionType.ByRow,
          ConflictResolutionMethod = ConflictResolutionMethod.Continue
        // Reconcile with default
        ReconcileResult reconcileResult = editVersion.Reconcile(reconcileOptions);
        // Check for conflicts
        bool hasConflictsReconcileResults = reconcileResult.HasConflicts;
        bool hasConflictsAfterReconcile = editVersion.HasConflicts();
        // Fetch conflicts
        IReadOnlyList<Conflict> conflictsAfterReconcile = editVersion.GetConflicts();
        // Iterate conflicts
        foreach (Conflict conflict in conflictsAfterReconcile)
          // Object ID of row where conflict occurs
          long objectId = conflict.ObjectID;
          ConflictType conflictType = conflict.ConflictType;
          IReadOnlyList<FieldValue> ancestorVersionValues = conflict.AncestorVersionValues;
          object nameAncestor = ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
          object treeAgeAncestor =
            ancestorVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
          IReadOnlyList<FieldValue> childVersionValues = conflict.ChildVersionValues;
          object nameChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("NAME")).Value;
          object treeAgeChild = childVersionValues.FirstOrDefault(f => f.FieldName.Contains("TREEAGE")).Value;
          IReadOnlyList<FieldValue> parentVersionValues = conflict.ParentVersionValues;
          IReadOnlyList<Field> originalFields = defaultFeatureClassDefinition.GetFields();
          string datasetName = conflict.DatasetName;
Explore contingent attribute values
  void ExploreContingentValues(Table table)
      IReadOnlyList<Contingency> contingencies = tableDefinition.GetContingencies();
      foreach (Contingency contingency in contingencies)
        // Field group
        FieldGroup filedGroup = contingency.FieldGroup;
        string fieldGroupName = filedGroup.Name;
        IReadOnlyList<string> fieldInFieldGroup = filedGroup.FieldNames;
        bool isEditRestriction = filedGroup.IsRestrictive;
        int contingencyId = contingency.ID;
        Subtype subtype = contingency.Subtype;
        bool isContingencyRetired = contingency.IsRetired;
        // Contingent values
        IReadOnlyDictionary<string, ContingentValue> contingentValuesByFieldName =
          contingency.GetContingentValues();
        foreach (KeyValuePair<string, ContingentValue> contingentValueKeyValuePair in contingentValuesByFieldName)
          string attributeFieldName = contingentValueKeyValuePair.Key;
          // Contingent value type associated with the attribute field
          ContingentValue contingentValue = contingentValueKeyValuePair.Value;
          switch (contingentValue)
            case ContingentCodedValue contingentCodedValue:
              string codedValueDomainName = contingentCodedValue.Name;
              object codedValueDomainValue = contingentCodedValue.CodedValue;
              break;
            case ContingentRangeValue contingentRangeValue:
              object rangeDomainMaxValue = contingentRangeValue.Max;
              object rangeDomainMinValue = contingentRangeValue.Min;
              break;
            case ContingentAnyValue contingentAnyValue:
              // Any value type
              break;
            case ContingentNullValue contingentNullValue:
              // Null value
              break;
Validate contingent attribute values
  void ValidateContingentValues(FeatureClass parcels, string zoningFieldName = "Zone", string taxCodeFieldName = "TaxCode")
    using (RowBuffer rowBuffer = parcels.CreateRowBuffer())
      // Insert values in a row buffer
      rowBuffer[zoningFieldName] = "Business";
      rowBuffer[taxCodeFieldName] = "TaxB";
      // Validate contingency values of the parcels' row
      ContingencyValidationResult contingencyValidationResult = parcels.ValidateContingencies(rowBuffer);
      // Valid contingencies
      IReadOnlyList<Contingency> matchedContingencies = contingencyValidationResult.Matches;
      if (matchedContingencies.Count > 0)
        // Create a row with valid contingency values
        parcels.CreateRow(rowBuffer);
      // Invalid contingencies
      IReadOnlyList<ContingencyViolation> violatedContingencies = contingencyValidationResult.Violations;
      foreach (ContingencyViolation contingencyViolation in violatedContingencies)
        ContingencyViolationType violationType = contingencyViolation.Type;
        Contingency violatedContingency = contingencyViolation.Contingency;
Get possible contingent values
  void GetPossibleContingentValues(FeatureClass parcels, string zoningFieldName = "Zone")
      IReadOnlyDictionary<FieldGroup, IReadOnlyList<ContingentValue>> possibleZonings = parcels.GetContingentValues(rowBuffer, zoningFieldName);
      IEnumerable<FieldGroup> possibleFieldGroups = possibleZonings.Keys;
      foreach (FieldGroup possibleFieldGroup in possibleFieldGroups)
        IReadOnlyList<ContingentValue> possibleZoningValues = possibleZonings[possibleFieldGroup];
        foreach (ContingentValue possibleZoningValue in possibleZoningValues)
          switch (possibleZoningValue)
            case ContingentCodedValue codedValue:
              string codedValueDomainName = codedValue.Name;
              object codedValueDomainValue = codedValue.CodedValue;
              break;
            case ContingentRangeValue rangeValue:
              object rangeDomainMaxValue = rangeValue.Max;
              object rangeDomainMinValue = rangeValue.Min;
              break;
              // Any value type
              break;
              // Null value
              break;
Editing
Creating a Row
    string message = String.Empty;
    bool creationResult = false;
    EditOperation editOperation = new EditOperation();
      // Declare the callback here. We are not executing it .yet.
      editOperation.Callback(context =>
        TableDefinition tableDefinition = enterpriseTable.GetDefinition();
        int assetNameIndex = tableDefinition.FindField("ASSETNA");
        using (RowBuffer rowBuffer = enterpriseTable.CreateRowBuffer())
          // Either the field index or the field name can be used in the indexer.
          rowBuffer[assetNameIndex] = "wMain";
          rowBuffer["COST"] = 700;
          rowBuffer["ACTION"] = "Open Cut";
          // subtype value for "Abandon".
          rowBuffer[tableDefinition.GetSubtypeField()] = 3;
          using (Row row = enterpriseTable.CreateRow(rowBuffer))
            // To Indicate that the attribute table has to be updated.
            context.Invalidate(row);
      }, enterpriseTable);
      try
        creationResult = editOperation.Execute();
        if (!creationResult) message = editOperation.ErrorMessage;
      catch (GeodatabaseException exObj)
        message = exObj.Message;
    if (!string.IsNullOrEmpty(message))
      Debug.WriteLine(message);
Creating a Feature
      //Declare the callback here. We are not executing it yet
        FeatureClassDefinition facilitySiteDefinition = enterpriseFeatureClass.GetDefinition();
        int facilityIdIndex = facilitySiteDefinition.FindField("FACILITYID");
        using (RowBuffer rowBuffer = enterpriseFeatureClass.CreateRowBuffer())
          rowBuffer[facilityIdIndex] = "wMain";
          rowBuffer["NAME"] = "Griffith Park";
          rowBuffer["OWNTYPE"] = "Municipal";
          rowBuffer["FCODE"] = "Park";
          // Add it to   Attractions Subtype.
          rowBuffer[facilitySiteDefinition.GetSubtypeField()] = 820;
          rowBuffer[facilitySiteDefinition.GetShapeField()] = new PolygonBuilderEx(newCoordinates).ToGeometry();
          using (Feature feature = enterpriseFeatureClass.CreateRow(rowBuffer))
            //To Indicate that the attribute table has to be updated
            context.Invalidate(feature);
      }, enterpriseFeatureClass);
      try
Modifying a Row
    bool modificationResult = false;
        QueryFilter openCutFilter = new QueryFilter { WhereClause = "ACTION = 'Open Cut'" };
        using (RowCursor rowCursor = enterpriseTable.Search(openCutFilter, false))
          int subtypeFieldIndex = tableDefinition.FindField(tableDefinition.GetSubtypeField());
              // In order to update the Map and/or the attribute table.
              // Has to be called before any changes are made to the row.
              row["ASSETNA"] = "wMainOpenCut";
              if (Convert.ToDouble(row["COST"]) > 700)
                // Abandon asset if cost is higher than 700 (if that is what you want to do).
                row["ACTION"] = "Open Cut Abandon";
                row[subtypeFieldIndex] = 3; //subtype value for "Abandon"
              //After all the changes are done, persist it.
              row.Store();
              // Has to be called after the store too.
      try
        modificationResult = editOperation.Execute();
        if (!modificationResult) message = editOperation.ErrorMessage;
Modifying a Feature
      int ownTypeIndex = facilitySiteDefinition.FindField("OWNTYPE");
      int areaIndex = facilitySiteDefinition.FindField(facilitySiteDefinition.GetAreaField());
        { WhereClause = "FCODE = 'Hazardous Materials Facility' AND OWNTYPE = ' '" };
        using (RowCursor rowCursor = enterpriseFeatureClass.Search(queryFilter, false))
            using (Feature feature = (Feature)rowCursor.Current)
              // Transfer all Hazardous Material Facilities to the City.
              feature[ownTypeIndex] = "Municipal";
              if (Convert.ToDouble(feature[areaIndex]) > 50000)
                // Set the Shape of the feature to whatever you need.
                feature.SetShape(new PolygonBuilderEx(newCoordinates).ToGeometry());
              feature.Store();
      try
Writing a value into a Guid column
  void WritingIntoGuidColumn(Row row, Field field, Guid guid)
    row[field.Name] = "{" + guid.ToString() + "}";
Deleting a Row/Feature
    bool deletionResult = false;
              // In order to update the Map and/or the attribute table. Has to be called before the delete.
              row.Delete();
      try
        deletionResult = editOperation.Execute();
        if (!deletionResult) message = editOperation.ErrorMessage;
Split a feature by geometry
  void SplitALineByPoint(FeatureClass lineFeatureClass, MapPoint xPoint)
           lineFeatureClass.Search(new QueryFilter() { ObjectIDs = new List<long>() { 1 } }))
      if (rowCursor.MoveNext())
        using (Feature feature = rowCursor.Current as Feature)
          // ObjectIDs of newly created lines
          IReadOnlyList<long> splits = feature.Split(xPoint);
Adding Attachments
    using (FeatureClass parkFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.Park"))
      QueryFilter filter = new QueryFilter { WhereClause = "NUMPARKING > 0" };
      using (RowCursor parkingCursor = parkFeatureClass.Search(filter, false))
        while (parkingCursor.MoveNext())
          using (MemoryStream stream = CreateMemoryStreamFromContentsOf("Sample.xml"))
            Attachment attachment = new Attachment("Sample.xml", "text/xml", stream);
            using (Row row = parkingCursor.Current)
              long attachmentId = row.AddAttachment(attachment);
  // Helper method to read a file into a memory stream
  MemoryStream CreateMemoryStreamFromContentsOf(String fileNameWithPath)
    MemoryStream memoryStream = new MemoryStream();
    using (FileStream file = new FileStream(fileNameWithPath, FileMode.Open, FileAccess.Read))
      byte[] bytes = new byte[file.Length];
      file.Read(bytes, 0, (int)file.Length);
      memoryStream.Write(bytes, 0, (int)file.Length);
    return memoryStream;
Updating Attachments
    using (FeatureClass landUseCaseFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.LandUseCase"))
      QueryFilter filter = new QueryFilter { WhereClause = "CASETYPE = 'Rezoning'" };
      using (RowCursor landUseCursor = landUseCaseFeatureClass.Search(filter, false))
        while (landUseCursor.MoveNext())
          using (Feature rezoningUseCase = (Feature)landUseCursor.Current)
            IReadOnlyList<Attachment> rezoningAttachments = rezoningUseCase.GetAttachments();
            IEnumerable<Attachment> filteredAttachments = rezoningAttachments.Where(attachment => !attachment.GetName().Contains("rezoning"));
            foreach (Attachment attachmentToUpdate in filteredAttachments)
              attachmentToUpdate.SetName(attachmentToUpdate.GetName().Replace(".pdf", "Rezoning.pdf"));
              rezoningUseCase.UpdateAttachment(attachmentToUpdate);
Deleting Attachments
    using (Table inspectionTable = geodatabase.OpenDataset<Table>("luCodeInspection"))
      QueryFilter queryFilter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
      using (RowCursor cursor = inspectionTable.Search(queryFilter, false))
          using (Row currentRow = cursor.Current)
            IReadOnlyList<Attachment> rowAttachments = currentRow.GetAttachments(null, true);
            IEnumerable<Attachment> attachments = rowAttachments.Where(attachment =>
              attachment.GetContentType().Equals("application/pdf"));
            IReadOnlyList<long> attachmentIDs =
              attachments.Select(attachment => attachment.GetAttachmentID()) as IReadOnlyList<long>;
            IReadOnlyDictionary<long, Exception> failures = currentRow.DeleteAttachments(attachmentIDs);
            if (failures.Count > 0)
              //process errors
Writing a Blob field
  void WriteBlobField(Table table, string blobFieldName, string imageFileName)
    // Read the image file into a MemoryStream
    using (FileStream imageFile = new FileStream(imageFileName, FileMode.Open, FileAccess.Read))
      imageFile.CopyTo(memoryStream);
    // Create a new row in the table, and write the Memory Stream into a blob fiele
    using (RowBuffer rowBuffer = table.CreateRowBuffer())
      rowBuffer[blobFieldName] = memoryStream;
      table.CreateRow(rowBuffer).Dispose();
Reading a Blob field
  void ReadBlobField(Table table, QueryFilter queryFilter, string blobFieldName)
    const string imageFileBaseName = "C:\\path\\to\\image\\directory\\Image";
    // For each row that satisfies the search criteria, write the blob field out to an image file
    using (RowCursor rowCursor = table.Search(queryFilter))
      int fileCount = 0;
          // Read the blob field into a MemoryStream
          MemoryStream memoryStream = row[blobFieldName] as MemoryStream;
          // Create a file
          using (FileStream outputFile = new FileStream(imageFileBaseName + fileCount.ToString(),
                   FileMode.Create, FileAccess.Write))
            // Write the MemoryStream into the file
            memoryStream.WriteTo(outputFile);
    using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.luCodeViolationHasInspections"))
    using (FeatureClass violationsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.luCodeViolation"))
    using (Table inspectionTable = geodatabase.OpenDataset<Table>("LocalGovernment.GDB.luCodeInspection"))
      List<Row> jeffersonAveViolations = new List<Row>();
      QueryFilter queryFilter = new QueryFilter { WhereClause = "LOCDESC LIKE '///%Jefferson///%'" };
      using (RowCursor rowCursor = violationsFeatureClass.Search(queryFilter, false))
          jeffersonAveViolations.Add(rowCursor.Current);
      IReadOnlyList<Row> relatedOriginRows = null;
      IReadOnlyList<Row> relatedDestinationRows = null;
      try
        QueryFilter filter = new QueryFilter { WhereClause = "ACTION = '1st Notice'" };
        using (Selection selection = inspectionTable.Select(filter, SelectionType.ObjectID, SelectionOption.Normal))
          relatedOriginRows = relationshipClass.GetRowsRelatedToDestinationRows(selection.GetObjectIDs());
        bool containsJeffersonAve = relatedOriginRows.Any(row => Convert.ToString(row["LOCDESC"]).Contains("Jefferson"));
        List<long> jeffersonAveViolationObjectIds = jeffersonAveViolations.Select(row => row.GetObjectID()).ToList();
        relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(jeffersonAveViolationObjectIds);
        bool hasFirstNoticeInspections = relatedDestinationRows.Any(row => Convert.ToString(row["ACTION"]).Contains("1st Notice"));
      finally
        Dispose(jeffersonAveViolations);
        Dispose(relatedOriginRows);
        Dispose(relatedDestinationRows);
  void Dispose(IEnumerable<Row> rows)
    foreach (Row row in rows)
      row.Dispose();
Creating a Relationship
    using (RelationshipClass relationshipClass = geodatabase.OpenDataset<RelationshipClass>("LocalGovernment.GDB.OverviewToProject"))
    using (FeatureClass projectsFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjects"))
    using (FeatureClass overviewFeatureClass = geodatabase.OpenDataset<FeatureClass>("LocalGovernment.GDB.CIPProjectsOverview"))
      // This will be PROJNAME. This can be used to get the field index or used directly as the field name.
      string originKeyField = relationshipClass.GetDefinition().GetOriginKeyField();
        // The rows are being added to illustrate adding relationships.
        // If one has existing rows, those can be used to add a relationship.
        using (RowBuffer projectsRowBuffer = projectsFeatureClass.CreateRowBuffer())
        using (RowBuffer overviewRowBuffer = overviewFeatureClass.CreateRowBuffer())
          projectsRowBuffer["TOTCOST"] = 500000;
          overviewRowBuffer[originKeyField] = "LibraryConstruction";
          overviewRowBuffer["PROJECTMAN"] = "John Doe";
          overviewRowBuffer["FUNDSOUR"] = " ";
          using (Row projectsRow = projectsFeatureClass.CreateRow(projectsRowBuffer))
          using (Row overviewRow = overviewFeatureClass.CreateRow(overviewRowBuffer))
            Relationship relationship = relationshipClass.CreateRelationship(overviewRow, projectsRow);
            //To Indicate that the Map has to draw this feature/row and/or the attribute table has to be updated
            context.Invalidate(projectsRow);
            context.Invalidate(overviewRow);
            context.Invalidate(relationshipClass);
      }, projectsFeatureClass, overviewFeatureClass);
      bool editResult = editOperation.Execute();
Deleting a Relationship
        if (!rowCursor.MoveNext())
          return;
        using (Row jeffersonAveViolation = rowCursor.Current)
          IReadOnlyList<Row> relatedDestinationRows = relationshipClass.GetRowsRelatedToOriginRows(new List<long>
              { jeffersonAveViolation.GetObjectID() });
          try
              foreach (Row relatedDestinationRow in relatedDestinationRows)
                try
                  relationshipClass.DeleteRelationship(jeffersonAveViolation, relatedDestinationRow);
                catch (GeodatabaseRelationshipClassException exception)
                  Console.WriteLine(exception);
            }, relationshipClass);
          finally
            foreach (Row row in relatedDestinationRows)
              row.Dispose();
Using an Insert Cursor
// Insert Cursors are intended for use in CoreHost applications, not Pro Add-ins
    using (Table citiesTable = geodatabase.OpenDataset<Table>("name\\of\\cities_table"))
      geodatabase.ApplyEdits(() =>
        using (InsertCursor insertCursor = citiesTable.CreateInsertCursor())
        using (RowBuffer rowBuffer = citiesTable.CreateRowBuffer())
          rowBuffer["State"] = "Colorado";
          rowBuffer["Name"] = "Fort Collins";
          rowBuffer["Population"] = 167830;
          insertCursor.Insert(rowBuffer);
          rowBuffer["Name"] = "Denver";
          rowBuffer["Population"] = 727211;
          // Insert more rows here
          // A more realistic example would be reading source data from a file
          insertCursor.Flush();
Creating a new Annotation Feature in an Annotation FeatureClass using a RowBuffer
  void CreatingAnAnnotationFeature(Geodatabase geodatabase)
    using (AnnotationFeatureClass annotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("Annotation // feature // class // name"))
    using (AnnotationFeatureClassDefinition annotationFeatureClassDefinition = annotationFeatureClass.GetDefinition())
    using (RowBuffer rowBuffer = annotationFeatureClass.CreateRowBuffer())
    using (AnnotationFeature annotationFeature = annotationFeatureClass.CreateRow(rowBuffer))
      annotationFeature.SetAnnotationClassID(0);
      annotationFeature.SetStatus(AnnotationStatus.Placed);
      // Get the annotation labels from the label collection
      IReadOnlyList<CIMLabelClass> labelClasses =
        annotationFeatureClassDefinition.GetLabelClassCollection();
      // Setup the symbol reference with the symbol id and the text symbol
      CIMSymbolReference cimSymbolReference = new CIMSymbolReference();
      cimSymbolReference.Symbol = labelClasses[0].TextSymbol.Symbol;
      cimSymbolReference.SymbolName = labelClasses[0].TextSymbol.SymbolName;
      // Setup the text graphic
      CIMTextGraphic cimTextGraphic = new CIMTextGraphic();
      cimTextGraphic.Text = "Charlotte, North Carolina";
      cimTextGraphic.Shape = new MapPointBuilderEx(new Coordinate2D(-80.843, 35.234), SpatialReferences.WGS84)
        .ToGeometry();
      cimTextGraphic.Symbol = cimSymbolReference;
      // Set the symbol reference on the graphic and store
      annotationFeature.SetGraphic(cimTextGraphic);
      annotationFeature.Store();
Versioning
Connecting to a Version
  Geodatabase ConnectToVersion(Geodatabase geodatabase, string versionName)
    Geodatabase connectedVersion = null;
    if (geodatabase.IsVersioningSupported())
      using (VersionManager versionManager = geodatabase.GetVersionManager())
      using (Version version = versionManager.GetVersion(versionName))
        connectedVersion = version.Connect();
    return connectedVersion;
Reconciling and Posting a Version with its Parent in separate edit sessions
  void ReconcileAndPost(Geodatabase geodatabase)
    // Get a reference to our version and our parent
      using (Version currentVersion = versionManager.GetCurrentVersion())
      using (Version parentVersion = currentVersion.GetParent())
        // Create a ReconcileOptions object
        ReconcileOptions reconcileOptions = new ReconcileOptions(parentVersion);
        reconcileOptions.ConflictResolutionMethod = ConflictResolutionMethod.Continue; // continue if conflicts are found
        reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByRow; //Default
        reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorTargetVersion; //or FavorEditVersion
        // Reconcile
        ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions);
        if (!reconcileResult.HasConflicts)
          //No conflicts, perform the post
          PostOptions postOptions = new PostOptions(parentVersion);
          //var postOptions = new PostOptions(); for default version
          postOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous; //Default
          // Post - Deprecated since Pro SDK 3.6 / Enterprise 12.0 . Use Reconcile(reconcileOptions, postOptions) instead.
          // currentVersion.Post(postOptions);
          currentVersion.Reconcile(reconcileOptions, postOptions);
Reconciling and Posting a Version with its Parent in the same edit session
  void ReconcileAndPost2(Geodatabase geodatabase)
        // Reconcile
        ReconcileResult reconcileResult = currentVersion.Reconcile(reconcileOptions, postOptions);
        if (reconcileResult.HasConflicts)
          //TODO resolve conflicts
Working with Versions
await QueuedTask.Run(() =>
      IReadOnlyList<string> versionNames = versionManager.GetVersionNames();
      Version defaultVersion = versionManager.GetDefaultVersion();
      string testVersionName = versionNames.First(v => v.Contains("Test"));
      Version testVersion = versionManager.GetVersion(testVersionName);
      Version qaVersion = defaultVersion.GetChildren().First(version => version.GetName().Contains("QA"));
      Geodatabase qaVersionGeodatabase = qaVersion.Connect();
      FeatureClass currentFeatureClass = geodatabase.OpenDataset<FeatureClass>("featureClassName");
      FeatureClass qaFeatureClass = qaVersionGeodatabase.OpenDataset<FeatureClass>("featureClassName");
Working with the Default Version
  Version FindDefaultVersion(Geodatabase geodatabase)
    if (!geodatabase.IsVersioningSupported()) return null;
      Version currentVersion = versionManager.GetCurrentVersion();
      Version defaultVersion = GetDefaultVersion(currentVersion);
      if (currentVersion != defaultVersion)
        currentVersion.Dispose(); // If we are not pointing to default, we want to dispose this Version object
      return defaultVersion;
    // Check to see if the current version is default.
    // Works with both branch and traditional versioning.
    bool IsDefaultVersion(Version version)
      Version parentVersion = version.GetParent();
      if (parentVersion == null)
        return true;
      parentVersion.Dispose();
      return false;
    // Gets the default version.
    // Note that this routine depends on IsDefaultVersion(), above.
    Version GetDefaultVersion(Version version)
      if (IsDefaultVersion(version))
        return version;
      Version parent = version.GetParent();
      Version ancestor = GetDefaultVersion(parent);
      if (parent != ancestor)
        parent.Dispose(); //If the versioning tree is more than 2 deep, we want to dispose any intermediary versions
      return ancestor;
Creating a Version
  Version CreateVersion(Geodatabase geodatabase, string versionName, string description, VersionAccessType versionAccessType)
        new VersionDescription(versionName, description, versionAccessType);
      return versionManager.CreateVersion(versionDescription);
Creating a Historical version
  HistoricalVersion CreateHistoricalVersion(Geodatabase geodatabase, string versionName)
      HistoricalVersionDescription historicalVersionDescription =
        new HistoricalVersionDescription(versionName, DateTime.Now);
      HistoricalVersion historicalVersion =
        versionManager.CreateHistoricalVersion(historicalVersionDescription);
      return historicalVersion;
Switching between versions
  void ChangeVersions(Geodatabase geodatabase, string toVersionName)
      VersionBaseType versionBaseType = versionManager.GetCurrentVersionBaseType();
      if (versionBaseType == VersionBaseType.Version)
        Version fromVersion = versionManager.GetCurrentVersion();
        Version toVersion = versionManager.GetVersion(toVersionName);
        // Switch between versions
        MapView.Active.Map.ChangeVersion(fromVersion, toVersion);
      if (versionBaseType == VersionBaseType.HistoricalVersion)
        HistoricalVersion fromHistoricalVersion = versionManager.GetCurrentHistoricalVersion();
        HistoricalVersion toHistoricalVersion = versionManager.GetHistoricalVersion(toVersionName);
        // Switch between historical versions
        MapView.Active.Map.ChangeVersion(fromHistoricalVersion, toHistoricalVersion);
      // Switch from HistoricalVersion to Version and vice-versa
      // MapView.Active.Map.ChangeVersion(fromHistoricalVersion, toVersion);
      // MapView.Active.Map.ChangeVersion(fromVersion, toHistoricalVersion);
Partial Posting
  void PartialPostingSnippet(Version designVersion, FeatureClass supportStructureFeatureClass, List<long> deletedSupportStructureObjectIDs)
    // Partial posting allows developers to post a subset of changes made in a version.
    // One sample use case is an electric utility that uses a version to design the facilities in
    // a new housing subdivision. At some point in the process, one block of new houses have been
    // completed, while the rest of the subdivision remains unbuilt.  Partial posting allows the user
    // to post the completed work, while leaving not yet constructed features in the version to be
    // posted later. Partial posting requires a branch-versioned feature service using ArcGIS
    // Enterprise 10.9 and higher
    // Specify a set of features that were constructed
    QueryFilter constructedFilter = new QueryFilter()
      WhereClause = "ConstructedStatus = 'True'"
    // This selection represents the inserts and updates to the support
    // structure feature class that we wish to post
    using (Selection constructedSupportStructures = supportStructureFeatureClass.Select(constructedFilter, SelectionType.ObjectID,
      // Specifying which feature deletions you wish to post is slightly trickier, since you cannot issue
      // a query to fetch a set of deleted features Instead, a list of ObjectIDs must be used
      using (Selection deletedSupportStructures = supportStructureFeatureClass.Select(null, SelectionType.ObjectID, SelectionOption.Empty))
        deletedSupportStructures.Add(deletedSupportStructureObjectIDs); //deletedSupportStructureObjectIDs is defined as List<long>
        // Perform the reconcile with partial post
        ReconcileOptions reconcileOptions = new ReconcileOptions(); // Reconcile against Default
        reconcileOptions.ConflictDetectionType = ConflictDetectionType.ByColumn;
        reconcileOptions.ConflictResolutionType = ConflictResolutionType.FavorEditVersion;
        PostOptions postOptions = new PostOptions();
        // PartialPostSelections - Deprecated since Pro SDK 3.7. Use PartialPostOptions instead.
        postOptions.PartialPostSelections = new List<Selection>()
            constructedSupportStructures, deletedSupportStructures
        PartialPostOptions partialPostOptions = new PartialPostOptions(); // Partial post against the Default
        partialPostOptions.Selections = new List<Selection>()
        partialPostOptions.ServiceSynchronizationType = ServiceSynchronizationType.Synchronous;
        ReconcileResult reconcileResult = designVersion.Reconcile(reconcileOptions, partialPostOptions);
        // Use the reconcileResult ...
Iterate datasets inside a feature dataset
  void IterateDatasetsFromAFeatureDataset(Geodatabase geodatabase, string featureDatasetName = "City", string featureClassInFeatureDataset = "Buildings")
    // Open a feature dataset
    using (FeatureDataset cityFeatureDataset = geodatabase.OpenDataset<FeatureDataset>(featureDatasetName))
      // Get a feature class definition from a feature dataset
      FeatureClassDefinition buildingsFeatureClassDefinition = cityFeatureDataset.GetDefinition<FeatureClassDefinition>(featureClassInFeatureDataset);
      // Iterate dataset definition
      IReadOnlyList<FeatureClassDefinition> cityFeatureClassDefinitions = cityFeatureDataset.GetDefinitions<FeatureClassDefinition>();
      foreach (FeatureClassDefinition cityFeatureClassDefinition in cityFeatureClassDefinitions)
        // Use feature class definition ...
Get attribute rules of a dataset
  void GetAttributeRules(Geodatabase geodatabase, string tableName)
    using (TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableName))
      // Get all attribute rule types
      IReadOnlyList<AttributeRuleDefinition> ruleDefinitions = tableDefinition.GetAttributeRules();
      // Iterate rule definitions
      foreach (AttributeRuleDefinition ruleDefinition in ruleDefinitions)
        AttributeRuleType ruleType = ruleDefinition.GetAttributeRuleType();
        string ruleDescription = ruleDefinition.GetDescription();
        bool isAttributeFieldEditable = ruleDefinition.GetIsFieldEditable();
        string arcadeVersionToSupportRule = ruleDefinition.GetMinimumArcadeVersion();
        int ruleEvaluationOrder = ruleDefinition.GetEvaluationOrder();
        AttributeRuleTriggers triggeringEvents = ruleDefinition.GetTriggeringEvents();
        string scriptExpression = ruleDefinition.GetScriptExpression();
        // More properties ...
Creating a row buffer from a template row
  void CreateRowBufferFromARow(Table table)
    using (RowCursor rowCursor = table.Search())
        using (Row templateRow = rowCursor.Current)
          RowBuffer rowBuffer = table.CreateRowBuffer(templateRow);
          // Manipulate row buffer
          // Doesn't allow copying values of ObjectID and GlobalID
          // rowBuffer["Field"] = "Update";
          // Create a new row
          table.CreateRow(rowBuffer);
Extension Ids
Table Extension Ids
  void ExtensionIds1(Table table)
    // Add an extension id to a table
    // Check documentation for restrictions on backward compatibility - backward
    // compatibility is limited to ArcGIS Pro 3.1 if an extension id is added.
    // Note: This is an extension method. It is for use in addins only and not CoreHost.
    string extension_id_string = "52d8f3be-b73d-4140-beaf-23d4f9b697ea";
    Guid extension_id = Guid.Parse(extension_id_string);
    // Note: Must be within the lambda of   QueuedTask.Run()
    // Register the extension id with the relevant table
    table.AddActivationExtension(extension_id);
    // Remove an extension id from a table
    // Restores backward compatibility assuming no other compatibility limitations are in place.
    table.RemoveActivationExtension(extension_id);
    // Check if a given extension id  is registered with a particular table.
    if (table.GetHasActivationExtension(extension_id))
      //Implement custom logic relevant to presence of extension_id ...
    // Enumerate all extension ids on a given table.
    foreach (Guid ext_id in table.GetActivationExtensions())
      // Logic based on extension ids ...
DDL
64-bit Integer field
FieldDescription bigIntegerFieldDescription =
    new FieldDescription("BigInteger_64", FieldType.BigInteger);
ObjectID field
// 64-bit
  FieldDescription oidFieldDescription_64 =
    new FieldDescription("ObjectID_64", FieldType.OID)
      Length = 8
  // 32-bit
  FieldDescription oidFieldDescription_32 =
    new FieldDescription("ObjectID_32", FieldType.OID)
      Length = 4
DateOnly, TimeOnly, and TimestampOffset field
// Earthquake occurrences date and time
  // 9/28/2014 (DateOnly)
  FieldDescription earthquakeDateOnlyFieldDescription =
    new FieldDescription("Earthquake_DateOnly", FieldType.DateOnly);
  // 1:16:42 AM (TimeOnly)
  FieldDescription earthquakeTimeOnlyFieldDescription =
    new FieldDescription("Earthquake_TimeOnly", FieldType.TimeOnly);
  // 9/28/2014 1:16:42.000 AM -09:00 (Timestamp with Offset)
  FieldDescription earthquakeTimestampOffsetFieldDescription =
    new FieldDescription("Earthquake_TimestampOffset_Local", FieldType.TimestampOffset);
  // 9/28/2014 1:16:42 AM (DateTime)
  FieldDescription earthquakeDateFieldDescription =
    new FieldDescription("Earthquake_Date", FieldType.Date);
Creating a Table
  void CreateTableSnippet(Geodatabase geodatabase, CodedValueDomain inspectionResultsDomain)
    // Create a PoleInspection table with the following fields
    // GlobalID
    // ObjectID
    // InspectionDate (date)
    // InspectionResults (pre-existing InspectionResults coded value domain)
    // InspectionNotes (string)
    // This helper routine creates a FieldDescription for a GlobalID field with default values
    FieldDescription globalIDFieldDescription = FieldDescription.CreateGlobalIDField();
    // This helper routine creates a FieldDescription for an ObjectID field with default values
    FieldDescription objectIDFieldDescription = FieldDescription.CreateObjectIDField();
    // Create a FieldDescription for the InspectionDate field
    FieldDescription inspectionDateFieldDescription = new FieldDescription("InspectionDate", FieldType.Date)
      AliasName = "Inspection Date"
    // This helper routine creates a FieldDescription for a Domain field (from a pre-existing domain)
    FieldDescription inspectionResultsFieldDescription = FieldDescription.CreateDomainField("InspectionResults",
      new CodedValueDomainDescription(inspectionResultsDomain));
    inspectionResultsFieldDescription.AliasName = "Inspection Results";
    // This helper routine creates a FieldDescription for a string field
    FieldDescription inspectionNotesFieldDescription =
      FieldDescription.CreateStringField("InspectionNotes", 512);
    inspectionNotesFieldDescription.AliasName = "Inspection Notes";
    // Assemble a list of all of our field descriptions
    List<FieldDescription> fieldDescriptions = new List<FieldDescription>()
        globalIDFieldDescription, objectIDFieldDescription, inspectionDateFieldDescription,
        inspectionResultsFieldDescription, inspectionNotesFieldDescription
    // Create a TableDescription object to describe the table to create
    TableDescription tableDescription = new TableDescription("PoleInspection", fieldDescriptions);
    // Create a SchemaBuilder object
    SchemaBuilder schemaBuilder = new SchemaBuilder(geodatabase);
    // Add the creation of PoleInspection to our list of DDL tasks
    schemaBuilder.Create(tableDescription);
    // Execute the DDL
    bool success = schemaBuilder.Build();
    // Inspect error messages
    if (!success)
      IReadOnlyList<string> errorMessages = schemaBuilder.ErrorMessages;
      //etc.
Creating a feature class
// Must be called within QueuedTask.Run
  void CreateFeatureClassSnippet(Geodatabase geodatabase, FeatureClass existingFeatureClass,
    SpatialReference spatialReference)
    // Create a Cities feature class with the following fields
    // GlobalID
    // ObjectID
    // Name (string)
    // Population (integer)
    FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 255);
    // This helper routine creates a FieldDescription for an integer field
    FieldDescription populationFieldDescription = FieldDescription.CreateIntegerField("Population");
        { globalIDFieldDescription, objectIDFieldDescription, nameFieldDescription, populationFieldDescription };
    // Create a ShapeDescription object
    ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Point, spatialReference);
    // Alternatively, ShapeDescriptions can be created from another feature class.  In this case, the new feature class will inherit the same shape properties of the existing class
    ShapeDescription alternativeShapeDescription = new ShapeDescription(existingFeatureClass.GetDefinition());
    // Enable support for measure (M) value, if needed
    // shapeDescription.HasM = true;
    // Enable support for the vertical coordinate system (Z), if needed
    // shapeDescription.HasZ = true;
    // Create a FeatureClassDescription object to describe the feature class to create
    FeatureClassDescription featureClassDescription =
      new FeatureClassDescription("Cities", fieldDescriptions, shapeDescription);
    // Add the creation of the Cities feature class to our list of DDL tasks
    schemaBuilder.Create(featureClassDescription);
    // Execute the DDL
    if (!success)
      //etc.
Deleting a Table
  void DeleteTableSnippet(Geodatabase geodatabase, Table table)
    TableDescription tableDescription = new TableDescription(table.GetDefinition());
    // Add the deletion of the table to our list of DDL tasks
    schemaBuilder.Delete(tableDescription);
    // Execute the DDL
Deleting a Feature Class
  void DeleteFeatureClassSnippet(Geodatabase geodatabase, FeatureClass featureClass)
    FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClass.GetDefinition());
    // Add the deletion fo the feature class to our list of DDL tasks
    schemaBuilder.Delete(featureClassDescription);
    // Execute the DDL
Opens a memory geodatabase
    // Connects to the default memory geodatabase, if exists otherwise throws exception
    MemoryConnectionProperties memoryConnectionProperties = new MemoryConnectionProperties();
    // Alternatively, connects to memory geodatabase named as 'InterimMemoryGeodatabase'
    // MemoryConnectionProperties memoryConnectionProperties = new MemoryConnectionProperties("InterimMemoryGeodatabase");
    // Opens the memory geodatabase
    using (Geodatabase geodatabase = new Geodatabase(memoryConnectionProperties))
      // Use memory geodatabase
Creating a memory Geodatabase
    // Create the memory connection properties to connect to  default memory geodatabase
    // Alternatively create the memory connection properties to connect to memory geodatabase named as 'InterimMemoryGeodatabase'
    // Creates the new memory geodatabase if it does not exist or connects to an existing one if it already exists
      // Create additional schema here
Deleting a memory Geodatabase
    // Delete the memory geodatabase
    SchemaBuilder.DeleteGeodatabase(memoryConnectionProperties);
Creating a File Geodatabase
    // Create a FileGeodatabaseConnectionPath with the name of the file geodatabase you wish to create
    FileGeodatabaseConnectionPath fileGeodatabaseConnectionPath =
      new FileGeodatabaseConnectionPath(new Uri(@"C:\Path-To-File-Geodatabase\YourName.gdb"));
    // Create and use the file geodatabase
           SchemaBuilder.CreateGeodatabase(fileGeodatabaseConnectionPath))
Deleting a File Geodatabase
    // Create a FileGeodatabaseConnectionPath with the name of the file geodatabase you wish to delete
    // Delete the file geodatabase
    SchemaBuilder.DeleteGeodatabase(fileGeodatabaseConnectionPath);
Creating a Mobile Geodatabase
    // Create a MobileGeodatabaseConnectionPath with the name of the mobile geodatabase you wish to create
    MobileGeodatabaseConnectionPath mobileGeodatabaseConnectionPath =
      new MobileGeodatabaseConnectionPath(new Uri(@"C:\Path-To-Mobile-Geodatabase\YourName.geodatabase"));
    // Create and use the mobile geodatabase
    using (Geodatabase geodatabase = SchemaBuilder.CreateGeodatabase(mobileGeodatabaseConnectionPath))
Deleting a Mobile Geodatabase
    // Create a MobileGeodatabaseConnectionPath with the name of the mobile geodatabase you wish to delete
    // Delete the mobile geodatabase
    SchemaBuilder.DeleteGeodatabase(mobileGeodatabaseConnectionPath);
Creating a Range domain
  void CreateRangeDomainSnippet(Geodatabase geodatabase)
    // Create a range description with minimum value = 0 and maximum value = 1000
    RangeDomainDescription rangeDomainDescriptionMinMax = new RangeDomainDescription("RangeDomain_0_1000",
        FieldType.Integer, 0, 1000)
    { Description = "Domain value ranges from 0 to 1000" };
    // Create  a range domain
    schemaBuilder.Create(rangeDomainDescriptionMinMax);
Creating a CodedValue domain
  void CreateCodedDomainSnippet(Geodatabase geodatabase)
    // Create a CodedValueDomain description for water pipes
    CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription("WaterPipeTypes",
      FieldType.String, new SortedList<object, string> { { "C_1", "Copper" }, { "S_2", "Steel" } })
      SplitPolicy = SplitPolicy.Duplicate,
      MergePolicy = MergePolicy.DefaultValue
    // Create a coded value domain
    CodedValueDomainToken codedValueDomainToken = schemaBuilder.Create(codedValueDomainDescription);
Creating a FeatureDataset
  void CreateFeatureDatasetSnippet(Geodatabase geodatabase)
    // Creating a FeatureDataset named as 'Parcel_Information'
    // Create a FeatureDataset named as 'Parcel Information'
    FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription("Parcel_Information", SpatialReferences.WGS84);
    schemaBuilder.Create(featureDatasetDescription);
    // Build status
    bool buildStatus = schemaBuilder.Build();
    // Build errors
    if (!buildStatus)
      IReadOnlyList<string> errors = schemaBuilder.ErrorMessages;
Deleting a FeatureDataset
  void DeleteFeatureDatasetSnippet(Geodatabase geodatabase)
    // Deleting a FeatureDataset named as 'Parcel_Information'
    FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>("Parcel_Information");
    FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetDefinition);
    // Delete an existing feature dataset named as 'Parcel_Information'
    schemaBuilder.Delete(featureDatasetDescription);
Renaming a FeatureDataset
  void RenameFeatureDatasetSnippet(Geodatabase geodatabase)
    // Renaming a FeatureDataset from 'Parcel_Information' to 'Parcel_Information_With_Tax_Jurisdiction'
    string originalDatasetName = "Parcel_Information";
    string datasetRenameAs = "Parcel_Information_With_Tax_Jurisdiction";
    FeatureDatasetDefinition originalDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>(originalDatasetName);
    FeatureDatasetDescription originalFeatureDatasetDescription = new FeatureDatasetDescription(originalDatasetDefinition);
    // Rename the existing FeatureDataset, 'Parcel_Information' to 'Parcel_Information_With_Tax_Jurisdiction'
    schemaBuilder.Rename(originalFeatureDatasetDescription, datasetRenameAs);
Creating a FeatureDataset with a FeatureClass in one operation
  void CreateFeatureDatasetWithFeatureClassSnippet(Geodatabase geodatabase)
    // Creating a FeatureDataset named as 'Parcel_Information' and a FeatureClass with name 'Parcels' in one operation
    string featureDatasetName = "Parcel_Information";
    string featureClassName = "Parcels";
    // Create a FeatureDataset token
    FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, SpatialReferences.WGS84);
    FeatureDatasetToken featureDatasetToken = schemaBuilder.Create(featureDatasetDescription);
    // Create a FeatureClass description
    FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassName,
          new FieldDescription("Id", FieldType.Integer),
          new FieldDescription("Address", FieldType.String)
      new ShapeDescription(GeometryType.Point, SpatialReferences.WGS84));
    // Create a FeatureClass inside a FeatureDataset
    FeatureClassToken featureClassToken = schemaBuilder.Create(
      new FeatureDatasetDescription(featureDatasetToken),
    // Build status
    // Build errors
    if (!buildStatus)
Creating a FeatureClass in existing FeatureDataset
  void CreateFeatureClassInsideFeatureDatasetSnippet(Geodatabase geodatabase)
    // Creating a FeatureClass named as 'Tax_Jurisdiction' in existing FeatureDataset with name 'Parcels_Information'
    string featureDatasetName = "Parcels_Information";
    string featureClassName = "Tax_Jurisdiction";
          new FieldDescription("Tax_Id", FieldType.Integer),
    FeatureDatasetDefinition featureDatasetDefinition = geodatabase.GetDefinition<FeatureDatasetDefinition>(featureDatasetName);
    // Create a FeatureClass inside a FeatureDataset using a FeatureDatasetDefinition
    schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetDefinition), featureClassDescription);
    // Build status
    // Build errors
    if (!buildStatus)
Adding a FeatureClass to a FeatureDataset
  void AddFeatureClassToFeatureDatasetSnippet(Geodatabase geodatabase)
    // Adding a FeatureClass with name 'Tax_Jurisdiction' into a FeatureDataset named as 'Parcels_Information'
    string featureClassNameToAdd = "Tax_Jurisdiction";
    FeatureClassDefinition featureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>(featureClassNameToAdd);
    FeatureClassDescription featureClassDescription = new FeatureClassDescription(featureClassDefinition);
    // Add the 'Tax_Jurisdiction' FeatureClass to the 'Parcels_Information' FeatureDataset
    schemaBuilder.AddFeatureClass(featureDatasetDescription, featureClassDescription);
    bool addStatus = schemaBuilder.Build();
    if (!addStatus)
Renaming a Table
  void RenameTableSnippet(Geodatabase geodatabase)
    // Renaming a table from 'Original_Table' to 'Renamed_Table'
    string tableToBeRenamed = "Original_Table";
    string tableRenameAs = "Renamed_Table";
    TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableToBeRenamed);
    // Table rename
    schemaBuilder.Rename(new TableDescription(tableDefinition), tableRenameAs);
Adding fields to a FeatureClass
  void AddFieldsInFeatureClassSnippet(Geodatabase geodatabase)
    // Adding following fields to the 'Parcels' FeatureClass
    // Global ID
    // Parcel_ID
    // Tax_Code
    // Parcel_Address
    // The FeatureClass to add fields
    FeatureClassDefinition originalFeatureClassDefinition = geodatabase.GetDefinition<FeatureClassDefinition>(featureClassName);
    FeatureClassDescription originalFeatureClassDescription = new FeatureClassDescription(originalFeatureClassDefinition);
    // The four new fields to add on the 'Parcels' FeatureClass
    FieldDescription globalIdField = FieldDescription.CreateGlobalIDField();
    FieldDescription parcelIdDescription = new FieldDescription("Parcel_ID", FieldType.GUID);
    FieldDescription taxCodeDescription = FieldDescription.CreateIntegerField("Tax_Code");
    FieldDescription addressDescription = FieldDescription.CreateStringField("Parcel_Address", 150);
    List<FieldDescription> fieldsToAdd = new List<FieldDescription>
        globalIdField, parcelIdDescription,
        taxCodeDescription, addressDescription
    // Add new fields on the new FieldDescription list
    List<FieldDescription> modifiedFieldDescriptions = new List<FieldDescription>(originalFeatureClassDescription.FieldDescriptions);
    modifiedFieldDescriptions.AddRange(fieldsToAdd);
    // The new FeatureClassDescription with additional fields
    FeatureClassDescription modifiedFeatureClassDescription = new FeatureClassDescription(originalFeatureClassDescription.Name,
      modifiedFieldDescriptions, originalFeatureClassDescription.ShapeDescription);
    // Update the 'Parcels' FeatureClass with newly added fields
    schemaBuilder.Modify(modifiedFeatureClassDescription);
    bool modifyStatus = schemaBuilder.Build();
    if (!modifyStatus)
Adding a Field that uses a domain
  void AddFieldWithDomainSnippet(Geodatabase geodatabase)
    //The FeatureClass to add field
    string featureClassName = "Pipes";
    CodedValueDomainDescription pipeDomainDescription = new CodedValueDomainDescription("WaterPipeTypes",
          { "S_2", "Steel" }
    // Create a coded value domain token
    CodedValueDomainToken codedValueDomainToken = schemaBuilder.Create(pipeDomainDescription);
    // Create a new description from domain token
    CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomainToken);
    // Create a field named as 'PipeType' using a domain description
    FieldDescription domainFieldDescription = new FieldDescription("PipeType", FieldType.String);
    domainFieldDescription.SetDomainDescription(codedValueDomainDescription);
    //Retrieve existing information for 'Pipes' FeatureClass
    // Add domain field on existing fields
    // Adding a field,'PipeType', which uses the coded value domain to the 'Pipes' FeatureClass
      { domainFieldDescription };
    // Create a new description with updated fields for 'Pipes' FeatureClass
    FeatureClassDescription featureClassDescription = new FeatureClassDescription(originalFeatureClassDescription.Name, modifiedFieldDescriptions,
    // Update the 'Pipes' FeatureClass with domain field
    schemaBuilder.Modify(featureClassDescription);
    // Build status
    // Build errors
    if (!buildStatus)
Removing fields from a Table
  void RemoveFieldTableSnippet(Geodatabase geodatabase)
    // Removing all fields from 'Parcels' table except following
    // Tax_Code
    // Parcel_Address
    // The table to remove fields
    string tableName = "Parcels";
    TableDefinition tableDefinition = geodatabase.GetDefinition<TableDefinition>(tableName);
    IReadOnlyList<Field> fields = tableDefinition.GetFields();
    // Existing fields from 'Parcels' table
    Field taxCodeField = fields.First(f => f.Name.Equals("Tax_Code"));
    Field parcelAddressField = fields.First(f => f.Name.Equals("Parcel_Address"));
    FieldDescription taxFieldDescription = new FieldDescription(taxCodeField);
    FieldDescription parcelAddressFieldDescription = new FieldDescription(parcelAddressField);
    // Fields to retain in modified table
    List<FieldDescription> fieldsToBeRetained = new List<FieldDescription>()
        taxFieldDescription, parcelAddressFieldDescription
    // New description of the 'Parcels' table with the 'Tax_Code' and 'Parcel_Address' fields
    TableDescription modifiedTableDescription = new TableDescription(tableName, fieldsToBeRetained);
    // Remove all fields except the 'Tax_Code' and 'Parcel_Address' fields
    schemaBuilder.Modify(modifiedTableDescription);
Creating an annotation feature class
  void CreateStandAloneAnnotationFeatureClass(
    Geodatabase geodatabase, SpatialReference spatialReference)
    // Creating a Cities annotation feature class
    // with following user defined fields
    // Name
    // GlobalID
    // Annotation feature class name
    string annotationFeatureClassName = "CitiesAnnotation";
    // Create user defined attribute fields for annotation feature class
    // Create a list of all field descriptions
        { globalIDFieldDescription, nameFieldDescription };
    ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polygon, spatialReference);
    // Create general placement properties for Maplex engine
    CIMMaplexGeneralPlacementProperties generalPlacementProperties =
      new CIMMaplexGeneralPlacementProperties
        AllowBorderOverlap = true,
        PlacementQuality = MaplexQualityType.High,
        DrawUnplacedLabels = true,
        InvertedLabelTolerance = 1.0,
        RotateLabelWithDisplay = true,
        UnplacedLabelColor = new CIMRGBColor
          R = 0,
          G = 255,
          B = 0,
          Alpha = 0.5f // Green
    // Create general placement properties for Standard engine
    //CIMStandardGeneralPlacementProperties generalPlacementProperties =
    //  new CIMStandardGeneralPlacementProperties
    //    DrawUnplacedLabels = true,
    //    InvertedLabelTolerance = 3.0,
    //    RotateLabelWithDisplay = true,
    //    UnplacedLabelColor = new CIMRGBColor
    //      R = 255, G = 0, B = 0, Alpha = 0.5f // Red
    // Create annotation  label classes
    // Green label
    CIMLabelClass greenLabelClass = new CIMLabelClass
      Name = "Green",
      ExpressionTitle = "Expression-Green",
      ExpressionEngine = LabelExpressionEngine.Arcade,
      Expression = "$feature.OBJECTID",
      ID = 1,
      Priority = 0,
      Visibility = true,
      TextSymbol = new CIMSymbolReference
        Symbol = new CIMTextSymbol()
          Angle = 45,
          FontType = FontType.Type1,
          FontFamilyName = "Tahoma",
          FontEffects = FontEffects.Normal,
          HaloSize = 2.0,
          Symbol = new CIMPolygonSymbol
            SymbolLayers = new CIMSymbolLayer[]
                new CIMSolidFill
                  Color = CIMColor.CreateRGBColor(0, 255, 0)
            UseRealWorldSymbolSizes = true
        MaxScale = 0,
        MinScale = 0,
        SymbolName = "TextSymbol-Green"
      StandardLabelPlacementProperties = new CIMStandardLabelPlacementProperties
        AllowOverlappingLabels = true,
        LineOffset = 1.0
      MaplexLabelPlacementProperties = new CIMMaplexLabelPlacementProperties
        AlignLabelToLineDirection = true,
        AvoidPolygonHoles = true
    // Blue label
    CIMLabelClass blueLabelClass = new CIMLabelClass
      Name = "Blue",
      ExpressionTitle = "Expression-Blue",
      ID = 2,
      Priority = 0,
      Visibility = true,
          Angle = 45,
          FontFamilyName = "Consolas",
          HaloSize = 2.0,
                new CIMSolidFill
                  Color = CIMColor.CreateRGBColor(0, 0, 255)
        MaxScale = 0,
        MinScale = 0,
        SymbolName = "TextSymbol-Blue"
        LineOffset = 1.0
    // Create a list of labels
    List<CIMLabelClass> labelClasses = new List<CIMLabelClass> { greenLabelClass, blueLabelClass };
    // Create an annotation feature class description object to describe the feature class to create
    AnnotationFeatureClassDescription annotationFeatureClassDescription =
      new AnnotationFeatureClassDescription(annotationFeatureClassName, fieldDescriptions, shapeDescription,
        generalPlacementProperties, labelClasses)
        IsAutoCreate = true,
        IsSymbolIDRequired = false,
        IsUpdatedOnShapeChange = true
    // Add the creation of the Cities annotation feature class to the list of DDL tasks
    schemaBuilder.Create(annotationFeatureClassDescription);
    // Execute the DDL
    if (!success)
      //etc.
Creating a feature-linked annotation feature class
  void CreateFeatureLinkedAnnotationFeatureClass(Geodatabase geodatabase,
    // Creating a feature-linked annotation feature class between water pipe and valve in water distribution network
    // PipeName
    // GlobalID
    string annotationFeatureClassName = "WaterPipeAnnotation";
    FieldDescription pipeGlobalID = FieldDescription.CreateGlobalIDField();
        { pipeGlobalID, nameFieldDescription };
    CIMMaplexGeneralPlacementProperties generalPlacementProperties = new CIMMaplexGeneralPlacementProperties
        R = 255,
        G = 0,
        B = 0,
        Alpha = 0.5f
    // Green label
      Name = "Green",
      ID = 1,
      Priority = 0,
      Visibility = true,
          Angle = 45,
          HaloSize = 2.0,
                new CIMSolidFill
        MaxScale = 0,
        MinScale = 0,
        LineOffset = 1.0
    // Blue label
      Name = "Blue",
      ID = 2,
      Priority = 0,
      Visibility = true,
          Angle = 45,
          HaloSize = 2.0,
                new CIMSolidFill
        MaxScale = 0,
        MinScale = 0,
        LineOffset = 1.0
    // Create linked feature description
    // Linked feature class name
    string linkedFeatureClassName = "WaterPipe";
    // Create fields for water pipe
    FieldDescription waterPipeGlobalID = FieldDescription.CreateGlobalIDField();
    FieldDescription pipeName = FieldDescription.CreateStringField("PipeName", 255);
    // Create a list of water pipe field descriptions
    List<FieldDescription> pipeFieldDescriptions = new List<FieldDescription> { waterPipeGlobalID, pipeName };
    // Create a linked feature class description
    FeatureClassDescription linkedFeatureClassDescription = new FeatureClassDescription(linkedFeatureClassName,
      pipeFieldDescriptions,
      new ShapeDescription(GeometryType.Polyline, spatialReference));
    // Add the creation of the linked feature class to the list of DDL tasks
    FeatureClassToken linkedFeatureClassToken = schemaBuilder.Create(linkedFeatureClassDescription);
        generalPlacementProperties, labelClasses, new FeatureClassDescription(linkedFeatureClassToken))
    // Add the creation of the annotation feature class to the list of DDL tasks
    // Execute the DDL
    if (!success)
      //etc.
Creating an annotation feature class inside feature dataset
  void CreateAnnotationFeatureClassUsingExistingAnnotationFeatureClassInDataset(
    // Create a Cities annotation feature class inside Places feature dataset using existing annotation feature class
    // Feature dataset name
    string featureDatasetName = "Places";
    // Open existing annotation feature class name
    using (AnnotationFeatureClass existingAnnotationFeatureClass = geodatabase.OpenDataset<AnnotationFeatureClass>("ExistingAnnotationFeatureClass"))
      // Create Feature dataset description
      FeatureDatasetDescription featureDatasetDescription = new FeatureDatasetDescription(featureDatasetName, existingAnnotationFeatureClass.GetDefinition().GetSpatialReference());
      // Add the creation of the Places dataset to DDL task
      // Create an annotation feature class description using existing annotation feature class
      AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassName,
          existingAnnotationFeatureClass.GetDefinition())
      // Add the creation of the Cities annotation feature class inside Places feature dataset
      schemaBuilder.Create(new FeatureDatasetDescription(featureDatasetToken),
      // Execute the DDL
      if (!success)
        //etc.
Creating a dimension feature class
  void CreateDimensionFeatureClass(Geodatabase geodatabase)
    // Dimension feature class name
    string dimensionFeatureClassName = "LineInfo";
    // Create user defined attribute fields for dimension feature class
    FieldDescription nameFieldDescription = new FieldDescription("Name", FieldType.String);
    FieldDescription distanceFieldDescription = new FieldDescription("DistanceMeasure", FieldType.Double);
    FieldDescription measurementDateFieldDescription = new FieldDescription("MeasurementDate", FieldType.Date);
        { nameFieldDescription, distanceFieldDescription, measurementDateFieldDescription };
    ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84);
    // Create DimensionFeatureClassDescription object
    DimensionFeatureClassDescription dimensionFeatureClassDescription = new DimensionFeatureClassDescription(
      dimensionFeatureClassName, fieldDescriptions,
      shapeDescription, GetCIMDimensionStyles());
    // Token
    DimensionFeatureClassToken dimensionFeatureClassToken =
      schemaBuilder.Create(dimensionFeatureClassDescription);
    // Execute the DDL
    if (!success)
      //etc.
    List<CIMDimensionStyle> GetCIMDimensionStyles()
      CIMColor color = CIMColor.CreateRGBColor(10, 20, 30);
      CIMPointSymbol beginMarkerSymbol = GetMarkerSymbol(color);
      CIMPointSymbol endMarkerSymbol = GetMarkerSymbol(color);
      CIMLineSymbol dimensionLineSymbol = GetLineSymbol(color, 0.5);
      CIMLineSymbol extensionLineSymbol = GetLineSymbol(color, 0.5);
      CIMTextSymbol textSymbol = GetDefaultTextSymbol(10);
      textSymbol.Symbol = GetPolygonSymbol(color, color, 0);
      textSymbol.HorizontalAlignment = HorizontalAlignment.Center;
      CIMDimensionStyle cimDimensionStyle = new CIMDimensionStyle()
        Name = "Style 1",
        ID = 0,
        Align = true,
        DisplayUnits = null,
        DisplayPrecision = 0,
        BeginMarkerSymbol = beginMarkerSymbol,
        EndMarkerSymbol = endMarkerSymbol,
        MarkerOption = DimensionPartOptions.Both,
        MarkerFit = DimensionMarkerFit.Text,
        DimensionLineSymbol = dimensionLineSymbol,
        DimensionLineOption = DimensionPartOptions.Both,
        DrawLineOnFit = false,
        ExtendLineOnFit = true,
        BaselineHeight = 0.0,
        ExtensionLineSymbol = extensionLineSymbol,
        ExtensionLineOption = DimensionPartOptions.Both,
        ExtensionLineOvershot = 0.0,
        ExtensionLineOffset = 0.0,
        Expression = "",
        ExpressionParserName = "Arcade",
        TextSymbol = textSymbol,
        TextOption = DimensionTextOption.Only,
        TextFit = DimensionTextFit.MoveBegin,
      List<CIMDimensionStyle> cimDimensionStyles = [cimDimensionStyle];
      return cimDimensionStyles;
    CIMFill DefaultFill(CIMColor color)
      return new CIMSolidFill()
        Enable = true,
        Name = "Fill_" + Guid.NewGuid().ToString(),
        ColorLocked = false,
        Color = color
    CIMStroke DefaultStroke(CIMColor color, double width = 1)
      return new CIMSolidStroke()
        Color = color,
        Name = "Stroke_" + Guid.NewGuid().ToString(),
        CapStyle = LineCapStyle.Round,
        JoinStyle = LineJoinStyle.Round,
        CloseCaps3D = false,
        LineStyle3D = Simple3DLineStyle.Strip,
        MiterLimit = 4,
        Width = width,
        Enable = true,
    CIMPolygonSymbol GetPolygonSymbol(CIMColor fillColor, CIMColor outlineColor, double outlineWidth)
      if ((outlineColor == null) || (outlineWidth <= 0))
        return new CIMPolygonSymbol() { SymbolLayers = new CIMSymbolLayer[1] { DefaultFill(fillColor) } };
        SymbolLayers = new CIMSymbolLayer[2]
          { DefaultStroke(outlineColor, outlineWidth), DefaultFill(fillColor) }
    CIMLineSymbol GetLineSymbol(CIMColor color, double width)
      CIMStroke stroke = DefaultStroke(color, width);
      return new CIMLineSymbol() { SymbolLayers = new CIMSymbolLayer[1] { stroke } };
    Polygon CreateArrowGeometry()
      double x = 2.39;
      double y = 1.20;
      double xMod = 0.3;
      Coordinate2D pt1 = new Coordinate2D() { X = -x + xMod, Y = -y };
      Coordinate2D pt2 = new Coordinate2D() { X = x + xMod, Y = 0 };
      Coordinate2D pt3 = new Coordinate2D() { X = -x + xMod, Y = y };
      List<Coordinate2D> coords = new List<Coordinate2D>() { pt1, pt2, pt3 };
      Polygon polygon = PolygonBuilderEx.CreatePolygon(coords);
      return polygon;
    CIMPointSymbol GetMarkerSymbol(CIMColor color)
      CIMMarkerGraphic graphic = new CIMMarkerGraphic()
        Geometry = CreateArrowGeometry(),
        Symbol = new CIMPolygonSymbol()
              new CIMSolidFill()
                Enable = true,
                Color = color,
          UseRealWorldSymbolSizes = false
      CIMSymbolLayer symbolLayer = new CIMVectorMarker()
        Enable = true,
        Size = 12,
        Frame = new EnvelopeBuilderEx() { XMin = -5, YMin = -3, XMax = 5, YMax = 3 }.ToGeometry() as Envelope,
        MarkerGraphics = new CIMMarkerGraphic[1] { graphic },
        ScaleSymbolsProportionally = true,
        RespectFrame = true
      return new CIMPointSymbol()
        SymbolLayers = new CIMSymbolLayer[1] { symbolLayer },
        HaloSize = 1,
        ScaleX = 1,
        AngleAlignment = AngleAlignment.Map,
    CIMTextSymbol GetDefaultTextSymbol(double height)
      return new CIMTextSymbol()
        DrawGlyphsAsGeometry = false,
        DrawSoftHyphen = false,
        ExtrapolateBaselines = true,
        FlipAngle = 0.0,
        IndentAfter = 0.0,
        IndentBefore = 0.0,
        IndentFirstLine = 0.0,
        Kerning = true,
        LetterSpacing = 0.0,
        LetterWidth = 100.0,
        Ligatures = true,
        LineGap = 0.0,
        LineGapType = LineGapType.ExtraLeading,
        Underline = false,
        Strikethrough = false,
        OffsetX = 0.0,
        OffsetY = 0.0,
        FontStyleName = "Regular",
        WordSpacing = 100.0,
        Height = height
Creating the memory geodatabase
    // Creates the default memory geodatabase if not exist or connects to an existing one if already exists
    Geodatabase memoryGeodatabase = new Geodatabase(new MemoryConnectionProperties());
    // Creates schema
    SchemaBuilder schemaBuilder = new SchemaBuilder(memoryGeodatabase);
    schemaBuilder.Create(new TableDescription("MyTable", new List<FieldDescription>()));
    return memoryGeodatabase;
Spatial query filter with DE9-IM spatial relationships
  void FindSpatiallyRelatedFeaturesUsingDE9IMPredicate(Geodatabase geodatabase, FeatureClass polygonFeatureClass, FeatureClass polylineFeatureClass)
    using (RowCursor polygonRowCursor = polygonFeatureClass.Search(new QueryFilter()))
      if (polygonRowCursor.MoveNext())
        using (Feature polygonFeature = polygonRowCursor.Current as Feature)
          // DE9IM predicate string to find overlapping features
          string overlappingDE9IM = "1*T***T**";
          SpatialQueryFilter spatialQueryFilter = new SpatialQueryFilter()
            FilterGeometry = polygonFeature.GetShape(),
            SpatialRelationship = SpatialRelationship.Relation,
            SpatialRelationshipDescription = overlappingDE9IM
          using (RowCursor overlappingPolyline = polylineFeatureClass.Search(spatialQueryFilter))
            while (overlappingPolyline.MoveNext())
              // Overlapping polylines on the polygon
Check if table is versioned
  bool IsTableVersioned(Geodatabase geodatabase, string tableName)
    using (Table table = geodatabase.OpenDataset<Table>(tableName))
      // Check table version type
      RegistrationType registrationType = table.GetRegistrationType();
      if (registrationType == RegistrationType.Versioned)
        return true;
    return false;
Creating a table with index from scratch
  void CreatingTableWithIndex(SchemaBuilder schemaBuilder)
    FieldDescription nameFieldDescription = FieldDescription.CreateStringField("Name", 50);
    FieldDescription addressFieldDescription = FieldDescription.CreateStringField("Address", 200);
    // Creating a feature class, 'Buildings' with two fields
    TableDescription tableDescription = new TableDescription("Buildings",
      new List<FieldDescription>() { nameFieldDescription, addressFieldDescription });
    // Enqueue DDL operation to create a table
    TableToken tableToken = schemaBuilder.Create(tableDescription);
    // Creating an attribute index named as 'Idx'
    AttributeIndexDescription attributeIndexDescription = new AttributeIndexDescription("Idx", new TableDescription(tableToken),
      new List<string> { nameFieldDescription.Name, addressFieldDescription.Name });
    // Enqueue DDL operation to create an attribute index
    schemaBuilder.Create(attributeIndexDescription);
    // Execute build indexes operation
    bool isBuildSuccess = schemaBuilder.Build();
Adding indexes in pre-existing dataset
  void AddingIndexes(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
    // Field names to add in the attribute index
    string fieldName = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Name")).Name;
    string fieldAddress = featureClassDefinition.GetFields().First(f => f.AliasName.Contains("Address")).Name;
    // Creating an attribute index with index name 'Idx' and two participating fields' name
      new TableDescription(featureClassDefinition), new List<string> { fieldName, fieldAddress });
    // Enqueue DDL operation for an attribute index creation
    // Creating the spatial index
    SpatialIndexDescription spatialIndexDescription = new SpatialIndexDescription(new FeatureClassDescription(featureClassDefinition));
    // Enqueue DDL operation for the spatial index creation
    schemaBuilder.Create(spatialIndexDescription);
    if (!isBuildSuccess)
      // Iterate and handle errors
Removing attribute index
  void RemoveAttributeIndex(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition, string attributeIndexName)
    // Find a index to be removed
    ArcGIS.Core.Data.Index indexToRemove = featureClassDefinition.GetIndexes().First(f => f.GetName().Equals(attributeIndexName));
    // Index description of the index to be removed
    AttributeIndexDescription indexDescriptionToRemove = new AttributeIndexDescription(indexToRemove, new TableDescription(featureClassDefinition));
    // Enqueue the DDL operation to remove index
    schemaBuilder.Delete(indexDescriptionToRemove);
    // Execute the delete index operation
    bool isDeleteIndexSuccess = schemaBuilder.Build();
Removing spatial index
  void RemoveSpatialIndex(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
    // Create a spatial description
    schemaBuilder.Delete(spatialIndexDescription);
Modifying domain
  void ModifyDomain(Geodatabase geodatabase, string codedValueDomainName = "Pipe")
    CodedValueDomain codedValueDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(codedValueDomainName)) as CodedValueDomain;
    CodedValueDomainDescription codedValueDomainDescription = new CodedValueDomainDescription(codedValueDomain);
    // Update domain description
    codedValueDomainDescription.Description = "Water Pipe Domain";
    // Adding code/value pair
    codedValueDomainDescription.CodedValuePairs.Add("C", "Copper");
    schemaBuilder.Modify(codedValueDomainDescription);
    // To modify the orders of coded value domain
    // schemaBuilder.Modify(codedValueDomainDescription,SortBy.Name,SortOrder.Ascending);
Rename domain
  void RenameDomain(Geodatabase geodatabase, string rangeDomainOldName = "PipeDiameter", string rangeDomainNewName = "PipeDiam")
    RangeDomain rangeDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(rangeDomainOldName)) as RangeDomain;
    // Renaming a domain
    schemaBuilder.Rename(new RangeDomainDescription(rangeDomain), rangeDomainNewName);
Delete domain
  void DeleteDomain(Geodatabase geodatabase, string domainNameToBeDeleted = "PipeMaterial")
    CodedValueDomain codedValueDomain = geodatabase.GetDomains().First(f => f.GetName().Equals(domainNameToBeDeleted)) as CodedValueDomain;
    // Deleting a coded value domain
    schemaBuilder.Delete(codedValueDomainDescription);
Creating table with subtypes
  void CreateTableWithSubtypes(SchemaBuilder schemaBuilder)
    // Creating a 'Building' table with the subtype field 'BuildingType'
    FieldDescription buildingType = new FieldDescription("BuildingType", FieldType.Integer);
    FieldDescription buildingName = new FieldDescription("Name", FieldType.String);
    TableDescription tableDescription = new TableDescription("Building", new List<FieldDescription> { buildingName, buildingType });
    // Add the building type subtype with three subtypes - Business, Marketing, Security
    tableDescription.SubtypeFieldDescription = new SubtypeFieldDescription(buildingType.Name,
      new Dictionary<int, string> { { 1, "Business" }, { 2, "Marketing" }, { 3, "Security" } })
      DefaultSubtypeCode = 3 // Assigning 'Security' building type as the default subtype
Removing subtype field designation
  void DeleteSubtypeField(SchemaBuilder schemaBuilder, FeatureClassDefinition featureClassDefinition)
    // Set subtype field to null to remove the subtype field designation
    featureClassDescription.SubtypeFieldDescription = null;
Modifying subtypes
  void ModifySubtypes(SchemaBuilder schemaBuilder, TableDefinition tableDefinition)
    TableDescription tableDescription = new TableDescription(tableDefinition);
    // Remove the first subtype from the table
    IReadOnlyList<Subtype> subtypes = tableDefinition.GetSubtypes();
    tableDescription.SubtypeFieldDescription.Subtypes.Remove(subtypes.First().GetCode());
    // Adding a new subtype, 'Utility', in the existing table
    tableDescription.SubtypeFieldDescription.Subtypes.Add(4, "Utility");
    // Assigning 'Utility' subtype as the default subtype
    tableDescription.SubtypeFieldDescription.DefaultSubtypeCode = 4;
    schemaBuilder.Modify(tableDescription);
Creating relationship class
  void CreateRelationshipWithRelationshipRules(SchemaBuilder schemaBuilder)
    // Creating a 'BuildingType' table with two fields - BuildingType and BuildingTypeDescription
    FieldDescription buildingType = FieldDescription.CreateIntegerField("BuildingType");
    FieldDescription buildingTypeeDescription = FieldDescription.CreateStringField("BuildingTypeDescription", 100);
    TableDescription buildingTypeDescription = new TableDescription("BuildingType",
      new List<FieldDescription>() { buildingType, buildingTypeeDescription });
    TableToken buildingtypeToken = schemaBuilder.Create(buildingTypeDescription);
    // Creating a 'Building' feature class with three fields - BuildingId, Address, and BuildingType
    FieldDescription buildingId = FieldDescription.CreateIntegerField("BuildingId");
    FieldDescription buildingAddress = FieldDescription.CreateStringField("Address", 100);
    FieldDescription usageSubType = FieldDescription.CreateIntegerField("UsageSubtype");
    FeatureClassDescription featureClassDescription = new FeatureClassDescription("Building",
      new List<FieldDescription> { buildingId, buildingAddress, buildingType, usageSubType },
      new ShapeDescription(GeometryType.Polygon, SpatialReferences.WGS84));
    // Set subtype details (optional)
    featureClassDescription.SubtypeFieldDescription = new SubtypeFieldDescription(usageSubType.Name,
      new Dictionary<int, string> { { 1, "Marketing" }, { 2, "Utility" } });
    FeatureClassToken buildingToken = schemaBuilder.Create(featureClassDescription);
    // Creating a 1:M relationship between the 'Building' feature class and 'BuildingType' table
    RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(
      "BuildingToBuildingType", new FeatureClassDescription(buildingToken), new TableDescription(buildingtypeToken),
      RelationshipCardinality.OneToMany, buildingType.Name, buildingType.Name)
      RelationshipType = RelationshipType.Composite
    // Adding relationship rules for the 'Marketing' subtype
    relationshipClassDescription.RelationshipRuleDescriptions.Add(new RelationshipRuleDescription(1, null));
    schemaBuilder.Create(relationshipClassDescription);
Creating attributed relationship class
  void CreateAttributedRelationship(SchemaBuilder schemaBuilder)
      new List<FieldDescription> { buildingId, buildingAddress, buildingType },
    // Creating M:M relationship between the 'Building' feature class and 'BuildingType' table
    AttributedRelationshipClassDescription attributedRelationshipClassDescription =
      new AttributedRelationshipClassDescription("BuildingToBuildingType",
        new TableDescription(buildingtypeToken), RelationshipCardinality.ManyToMany, "OBJECTID", "BuildingID",
        "OBJECTID", "BuildingTypeID");
    // Adding optional attribute field in the intermediate table - 'OwnershipPercentage' field
    attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("OwnershipPercentage"));
    schemaBuilder.Create(attributedRelationshipClassDescription);
Add relationship rules to a relationship class
  void ModifyRelationshipClass(SchemaBuilder schemaBuilder, AttributedRelationshipClassDefinition attributedRelationshipClassDefinition)
    AttributedRelationshipClassDescription attributedRelationshipClassDescription = new AttributedRelationshipClassDescription(attributedRelationshipClassDefinition);
    // Update the relationship split policy
    attributedRelationshipClassDescription.RelationshipSplitPolicy = RelationshipSplitPolicy.UseDefault;
    // Add field in the intermediate table
    attributedRelationshipClassDescription.FieldDescriptions.Add(FieldDescription.CreateIntegerField("RelationshipStatus"));
    // Add relationship rules based on subtypes,if available
    // Assuming origin class has subtype with code 1
    attributedRelationshipClassDescription.RelationshipRuleDescriptions.Add(
    // Enqueue modify operation
    schemaBuilder.Modify(attributedRelationshipClassDescription);
    // Execute modify DDL operation
Deleting a relationship class
  void DeleteRelationshipClass(SchemaBuilder schemaBuilder, RelationshipClassDefinition relationshipClassDefinition)
    schemaBuilder.Delete(new RelationshipClassDescription(relationshipClassDefinition));
Adding/Removing Relationship class in/out of a feature dataset
  void MoveRelationshipClass(SchemaBuilder schemaBuilder, FeatureDatasetDefinition featureDatasetDefinition, RelationshipClassDefinition relationshipClassDefinition)
    RelationshipClassDescription relationshipClassDescription = new RelationshipClassDescription(relationshipClassDefinition);
    // Remove relationship class from the feature dataset
    schemaBuilder.RemoveRelationshipClass(featureDatasetDescription, relationshipClassDescription);
    // Add relationship class inside the feature dataset
    // schemaBuilder.AddRelationshipClass(featureDatasetDescription, relationshipClassDescription);
Modifying annotation labels and symbols
  void ModifyAnnotationLabelAndSymbols(SchemaBuilder schemaBuilder, AnnotationFeatureClassDefinition annotationFeatureClassDefinition)
    AnnotationFeatureClassDescription annotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassDefinition);
    IReadOnlyList<CIMLabelClass> labelClasses = annotationFeatureClassDescription.LabelClasses;
    // Adding a new annotation label class
    List<CIMLabelClass> modifiedLabelClasses = new List<CIMLabelClass>(labelClasses);
    modifiedLabelClasses.Add(new CIMLabelClass()
      Name = "RedSymbol",
          Angle = 45,
          FontFamilyName = "Arial",
          HaloSize = 2.0,
              { new CIMSolidFill { Color = CIMColor.CreateRGBColor(255, 0, 0) } },
        MaxScale = 0,
        MinScale = 0,
        SymbolName = "TextSymbol-RED"
    // Adding a  new symbol
    annotationFeatureClassDescription.Symbols.Add(new CIMSymbolIdentifier()
      ID = 1001,
      Name = "ID_10001",
        Angle = 43,
        FontEffects = FontEffects.Subscript,
        FontType = FontType.TTOpenType,
        TextCase = TextCase.Allcaps
    // Modify annotation feature class
    AnnotationFeatureClassDescription modifiedAnnotationFeatureClassDescription = new AnnotationFeatureClassDescription(annotationFeatureClassDescription.Name,
        annotationFeatureClassDescription.FieldDescriptions, annotationFeatureClassDescription.ShapeDescription,
        annotationFeatureClassDescription.GeneralPlacementProperties, modifiedLabelClasses);
    // Enqueue modify
    schemaBuilder.Modify(modifiedAnnotationFeatureClassDescription);
    // DDL execute
Rename annotation feature class
  void Rename(SchemaBuilder schemaBuilder, AnnotationFeatureClassDefinition annotationFeatureClassDefinition, string featureClassNewName)
    // Enqueue rename operation
    schemaBuilder.Rename(annotationFeatureClassDescription, featureClassNewName);
    // Execute DDL
Modifying an existing field
  void ModifyExistingField(SchemaBuilder schemaBuilder, TableDefinition tableDefinition, string fieldNameToBeModified = "PropertyAddress")
    Field field = tableDefinition.GetFields().FirstOrDefault(f => f.Name.Contains(fieldNameToBeModified));
    // Update field's alias name and length
    FieldDescription fieldDescription = new FieldDescription(field)
      AliasName = "Physical Property Address",
      Length = 50
    // Update the default value
    fieldDescription.SetDefaultValue("123 Main St");
    schemaBuilder.Modify(new TableDescription(tableDefinition), field.Name, fieldDescription);
    // Execute DDL
