ProSnippets Geoprocessing
Language:              C#
Subject:               Geoprocessing
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
General
How to execute a Model tool
// get the model tool's parameter syntax from the model's help
  var args = Geoprocessing.MakeValueArray(input_roads, buff_dist_field, input_vegetation, output_data);
  var result = Geoprocessing.ExecuteToolAsync(tool_path, args);
  // use the result as needed
Set Geoprocessing extent environment
var parameters = Geoprocessing.MakeValueArray(@"C:\data\data.gdb\HighwaysUTM11", @"C:\data\data.gdb\Highways_extent");
  var ext = Geoprocessing.MakeEnvironmentArray(extent: "460532 3773964 525111 3827494");
  var result = Geoprocessing.ExecuteToolAsync("management.CopyFeatures", parameters, ext);
Open a script tool dialog in Geoprocessing pane
// use defaults for other parameters - no need to pass any value
  var arguments = Geoprocessing.MakeValueArray(input_data, out_pdf, field_name);
  string toolpath = @"C:\data\WorkflowTools.tbx\MakeHistogram";
  Geoprocessing.OpenToolDialog(toolpath, arguments);
Open the Geoprocessing Tool Pane for a specific Tool
// For a System toolbox, to identify the specific tool to show, use
  // either:
  // o "ToolboxName.ToolName" - eg "analysis.Buffer"
  // o "Fullpath to Toolbox.tbx\Toolname" - eg:
  //       "C:\ArcGIS\Resources\ArcToolBox\Toolboxes\Analysis Tools.tbx\Buffer"
  // note:
  // For legacy purposes, the convention "ToolName_ToolBox" is also supported so,
  // o "Buffer_analysis" would also work
  // For a custom toolbox, the full path must be provided. So, for example,
  // given the custom toolbox "DeepThought.tbx" containing a python script tool
  // called "Answer", installed at "C:\Data\DeepThought-ProAddin\Toolboxes\toolboxes",
  // the full path would be:
  // o "C:\Data\DeepThought-ProAddin\Toolboxes\toolboxes\DeepThought.tbx\Answer"
  //Open the Buffer Tool GP Dialog - use either the full path or just
  //use "ToolboxName.ToolName"
  var path = @"C:\ArcGIS\Resources\ArcToolBox\Toolboxes\Analysis Tools.tbx";
  var full_tool_name = System.IO.Path.Combine(path, "Buffer");
  var short_tool_name = "analysis.Buffer";
  var tool_name = short_tool_name;//or full_tool_name
  var extent = MapView.Active.Extent;
  IReadOnlyList<string> val_array = null;
  // Note: Needs QueuedTask to run
    var rect = GeometryEngine.Instance.Scale(extent, extent.Center, 0.25, 0.25) as Envelope;
    var poly = PolygonBuilderEx.CreatePolygon(rect, rect.SpatialReference);
    var geom = new List<object>() { poly };
    val_array = Geoprocessing.MakeValueArray(geom, null, @"1000 Meters");
  //Call OpenToolDialog on the UI thread!
  Geoprocessing.OpenToolDialog(tool_name, val_array, null, false);
Get Geoprocessing project items
var gpItems = CoreModule.CurrentProject.Items.OfType<GeoprocessingProjectItem>();
  // go through all the available toolboxes
  foreach (var gpItem in gpItems)
    var itemsInsideToolBox = gpItem.GetItems();
    // then for each toolbox list the tools inside
    foreach (var toolItem in itemsInsideToolBox)
      string newTool = string.Join(";", [toolItem.Path, toolItem.Name]);
      // do something with the newTool
      // for example, add to a list to track or use them later
Stop a feature class created with GP from automatically adding to the map
// However, settings in Pro App's Geoprocessing Options will override option set in code
  // for example, in Pro App's Options > Geoprocessing dialog, if you check 'Add output datasets to an open map'
  // then the output WILL BE added to history overriding settings in code
  var CopyfeaturesParams = Geoprocessing.MakeValueArray("C:\\data\\Input.gdb\\PlanA_Roads", "C:\\data\\Input.gdb\\Roads_copy");
  IGPResult gpResult = Geoprocessing.ExecuteToolAsync("management.CopyFeatures", CopyfeaturesParams, null, null, null, GPExecuteToolFlags.None).Result;
GPExecuteToolFlags.AddToHistory will add the execution messages to History
  // for example, if in Options > Geoprocessing dialog, if you uncheck 'Write geoprocessing operations to Geoprocessing History'
  // then the output will not be added to history.
  var args = Geoprocessing.MakeValueArray("C:\\data\\Vegetation.shp", "NewField", "TEXT");
  var result = Geoprocessing.ExecuteToolAsync("management.AddField", args, null, null, null, GPExecuteToolFlags.AddToHistory);
Multi Ring Buffer
//The data referenced in this snippet can be downloaded from the arcgis-pro-sdk-community-samples repo
  //https://github.com/Esri/arcgis-pro-sdk-community-samples
    var paramsArray = Geoprocessing.MakeValueArray(currentTemplate.MapMember.Name,
                @"C:\Data\FeatureTest\FeatureTest.gdb\Points_MultipleRingBuffer",
                new List<string> { "1000", "2000" }, "Meters", "Distance",
                "ALL", "FULL");
    IGPResult gpResult = Geoprocessing.ExecuteToolAsync("Analysis.MultipleRingBuffer", paramsArray).Result;
    var messages = string.IsNullOrEmpty(gpResult.ReturnValue)
            ? $@"Error in Geoprocessing tool: {gpResult.ErrorMessages}"
            : $@"Ok: {gpResult.ReturnValue}";
    // use the messages and the result as needed
Non-blocking execution of a Geoprocessing tool
  string in_data = @"C:\tools\data.gdb\cities";
  string cities_buff = @"E:\data\data.gdb\cities_2km";
  var valueArray = Geoprocessing.MakeValueArray(in_data, cities_buff, "2000 Meters");
  // to let the GP tool run asynchronously without blocking the main thread
  // use the GPThread option of GPExecuteToolFlags
  GPExecuteToolFlags flags = GPExecuteToolFlags.GPThread;  // instruct the tool run non-blocking GPThread
  IGPResult bufferResult = Geoprocessing.ExecuteToolAsync("Analysis.Buffer", valueArray, null, null, null, flags).Result;
How to pass parameter with multiple or complex input values
var environments = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
  string toolName = "Snap_edit";  // or use edit.Snap
  // Snap tool takes multiple inputs each of which has
  // Three (3) parts: a feature class or layer, a string value and a distance
  // Each part is separated by a semicolon - you can get example of sytax from the tool documentation page
  var snapEnv = @"'C:/SnapProject/fgdb.gdb/line_1' END '2 Meters';'C:/SnapProject/fgdb.gdb/points_1' VERTEX '1 Meters';'C:/SnapProject/fgdb.gdb/otherline_1' END '20 Meters'";
  var infc = @"C:/SnapProject/fgdb.gdb/poly_1";
  var snapParams = Geoprocessing.MakeValueArray(infc, snapEnv);
  GPExecuteToolFlags tokens = GPExecuteToolFlags.RefreshProjectItems | GPExecuteToolFlags.GPThread | GPExecuteToolFlags.AddToHistory;
  IGPResult snapResult = Geoprocessing.ExecuteToolAsync(toolName, snapParams, environments, null, null, tokens).Result;
How to pass native objects as parameter values to run geoprocessing tool
string tool2 = "analysis.Buffer";
  List<MapPoint> list =
    MapPointBuilderEx.CreateMapPoint(1.0, 1.0),
    MapPointBuilderEx.CreateMapPoint(1.0, 2.0),
    MapPointBuilderEx.CreateMapPoint(2.0, 2.0),
    MapPointBuilderEx.CreateMapPoint(2.0, 1.0),
  Multipoint multiPoint = MultipointBuilderEx.CreateMultipoint(list);
  var spatial_ref = SpatialReferenceBuilder.CreateSpatialReference(3857);
  var args3 = Geoprocessing.MakeValueArray(multiPoint, "memory\\Buffers", "800 meters");
  var env1 = Geoprocessing.MakeEnvironmentArray(outputCoordinateSystem: spatial_ref);
  var messages = new List<string>(); // list to collect all output messages
  var cts = new CancellationTokenSource();
  Geoprocessing.ExecuteToolAsync(tool2, args3, env1, cts.Token);
How to access Geoprocessing History
string openProjectPath = @"D\DATA\IGPHistoryItemTestProject\IGPHistoryItemTestProject.aprx";
  Project.OpenAsync(openProjectPath);
  MapProjectItem mapProjItem = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(item => item.Name.Equals("Map", StringComparison.CurrentCultureIgnoreCase));
  var map = mapProjItem.GetMap();
  var ftrLayer = map.Layers[0] as FeatureLayer;
  string tool1 = "management.GetCount";
  var args1 = Geoprocessing.MakeValueArray(ftrLayer);
  var env = Geoprocessing.MakeEnvironmentArray(overwriteoutput: true);
  GPExecuteToolFlags executeFlags = GPExecuteToolFlags.AddToHistory;
  var t = Geoprocessing.ExecuteToolAsync(tool1, args1, env, null, null, executeFlags);
  IEnumerable<IGPHistoryItem> hisItems = Project.Current.GetProjectItemContainer(Geoprocessing.HistoryContainerKey) as IEnumerable<IGPHistoryItem>;
  string hitemID = "";
  string hitemToolPath = "";
  IGPResult hitemGPResult = null;
  DateTime hitemTimeStamp;
  foreach (var hitem in hisItems)
    // common IGPHistoryItem and Item properties
    hitemID = (hitem as Item).ID;
    hitemToolPath = hitem.ToolPath;
    hitemGPResult = hitem.GPResult;
    hitemTimeStamp = hitem.TimeStamp;
    // use the properties as needed
How to use Geoprocessing public event
ArcGIS.Desktop.Core.Events.GPExecuteToolEvent.Subscribe(e =>
          // Handle the event
          string id = e.ID;           // Same as history ID
          if (e.IsStarting == false)  // Execute completed
            _ = e.GPResult.ReturnValue;
          System.Windows.MessageBox.Show("event triggered.");
  Geoprocessing.ExecuteToolAsync("management.GetCount", Geoprocessing.MakeValueArray(@"c:\shape_file.shp"));
Parameter Value Array
Add Geometry via MakeValueArray to GP Tool parameter lists
var tool_name = "analysis.Clip";
  var sel_layer = MapView.Active.Map.GetLayersAsFlattenedList()
                    .OfType<FeatureLayer>().FirstOrDefault(l => l.Name == "GreatLakes");
  if (sel_layer == null) return;
  var gdb = Project.Current.DefaultGeodatabasePath;
  var out_fc = System.IO.Path.Combine(gdb, "clipped_lakes_out");
  var rect = GeometryEngine.Instance.Scale(extent, extent.Center, 0.5, 0.5) as Envelope;
  var clip_poly = PolygonBuilderEx.CreatePolygon(rect, rect.SpatialReference);
  //Add the geometry to a list before calling MakeValueArray
  //Envelope and Geometry types are supported
  var geom = new List<object>() { clip_poly };
  var val_array = Geoprocessing.MakeValueArray([sel_layer, geom, out_fc]);
  Geoprocessing.ExecuteToolAsync(tool_name, val_array,
  null, null, null, GPExecuteToolFlags.InheritGPOptions);
Get GeoprocessingOptions
//These options are for behavior of interactive GP tools _only_.
  var overwrite_gp = ApplicationOptions.GeoprocessingOptions.OverwriteExistingDatasets;
  var remove_gp = ApplicationOptions.GeoprocessingOptions.RemoveOverwrittenLayers;
  var addoutput_gp = ApplicationOptions.GeoprocessingOptions.AddOutputDatasetsToOpenMap;
  var history_gp = ApplicationOptions.GeoprocessingOptions.WriteGPOperationsToHistory;
Set GeoprocessingOptions
//Note: changing these options modifies behavior of interactive GP tools _only_.
  //Use the ArcGIS.Desktop.Core.Geoprocessing.GPExecuteToolFlags enum parameter
  //to modify the behavior of Geoprocessing.ExecuteToolAsync(...)
  //Note: Needs QueuedTask to run
    ApplicationOptions.GeoprocessingOptions.SetOverwriteExistingDatasets(true);
    ApplicationOptions.GeoprocessingOptions.SetRemoveOverwrittenLayers(false);
    ApplicationOptions.GeoprocessingOptions.SetAddOutputDatasetsToOpenMap(true);
    ApplicationOptions.GeoprocessingOptions.SetWriteGPOperationsToHistory(false);
