ProSnippets KnowledgeGraph
Language:              C#
Subject:               KnowledgeGraph
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
KnowledgeGraph Datastore
Opening a Connection to a KnowledgeGraph
await QueuedTask.Run(() =>
    //Create a connection properties
    var kg_props =
        new KnowledgeGraphConnectionProperties(new Uri(url));
    try
      //Open a connection
      using (var kg = new KnowledgeGraph(kg_props))
        //TODO...use the KnowledgeGraph
    catch (GeodatabaseNotFoundOrOpenedException ex)
      System.Diagnostics.Debug.WriteLine(ex.ToString());
Opening a Connection to a File KnowledgeGraph
    //Starting at 3.7, users can connect to a _file_ knowledge graph
    //The extension for a file kg is ".knowledgegraph"
    // Any path you want
    string kgPath = @"C:\Data\KG\Filebased_KG";
    string kgFileName = @"Test_File_KG.knowledgegraph";
    var kg_full_path = System.IO.Path.Combine(kgPath, kgFileName);
    var kg_props = new KnowledgeGraphConnectionProperties(new Uri(kg_full_path));
    try
      //Open a connection
        //TODO...use the File KnowledgeGraph
        var i = 0;
        //Get the featureclass definitions from the KG datastore
        var fc_defs = kg.GetDefinitions<FeatureClassDefinition>();
        //For each feature class definition, get the corresponding
        //feature class. Note: The name of the feature class will match
        //the name of its corresponding KnowledgeGraph named object type
        //in the KnowledgeGraph graph data model
        foreach (var fc_def in fc_defs)
          var fc_name = fc_def.GetName();
          System.Diagnostics.Debug.WriteLine($"FeatureClass[{i++}] {fc_name}");
Getting a Connection from a KnowledgeGraphLayer
//var kgLayer = MapView.Active.Map.GetLayersAsFlattenedList()
  //            .OfType<KnowledgeGraphLayer>().FirstOrDefault();
    // use the layer directly
    KnowledgeGraph datastore = kgLayer.GetDatastore();
    // or you can use any of the sub items since
    //KnowledgeGraphLayer is a composite layer - get the first
    // child feature layer or standalone table
    var featlayer = kgLayer?.GetLayersAsFlattenedList()?
                    .OfType<FeatureLayer>()?.FirstOrDefault();
    KnowledgeGraph kg = null;
    if (featlayer != null)
      using (var fc = featlayer.GetFeatureClass())
        kg = fc.GetDatastore() as KnowledgeGraph;
      //TODO use KnowledgeGraph
    else
      //try standalone table
      var stbl = kgLayer?.GetStandaloneTablesAsFlattenedList()?
                      .FirstOrDefault();
      if (stbl != null)
        using (var tbl = stbl.GetTable())
          kg = tbl.GetDatastore() as KnowledgeGraph;
Retrieving GDB FeatureClasses and Definitions
    var kg_props =
    //Connect to the KnowledgeGraph datastore
    //KnowledgeGraph datastores contain tables and feature classes
        using (var fc = kg.OpenDataset<FeatureClass>(fc_name))
          //TODO - use the feature class
Retrieving GDB Tables and Definitions
    var kg_props =
      //Get the table definitions from the KG datastore
      var tbl_defs = kg.GetDefinitions<TableDefinition>();
      //For each table definition, get the corresponding
      //table. Note: The name of the table will match the name
      //of its corresponding KnowledgeGraph named object type in
      //the KnowledgeGraph graph data model
      foreach (var tbl_def in tbl_defs)
        var tbl_name = tbl_def.GetName();
        using (var fc = kg.OpenDataset<Table>(tbl_name))
          //TODO - use the table
Get service Uri from KG datastore
    var kg_props =
      var connector = kg.GetConnector() as KnowledgeGraphConnectionProperties;
      var uri = connector.PathOrURL;
      var serviceUri = uri.AbsoluteUri;
Transform a set of objectIDs to IDs for an entity
    var kg_props =
      string entityName = "Name-of-the-entity";
      var oidList = new List<long>() { 260294, 678, 3523, 3, 669, 93754 };
      var idList = kg.TransformToIDs(entityName, oidList);
Transform a set of IDs to objectIDs for an entity
    var idList = new List<object>() { "{CA2EF786-A10E-4B40-9737-9BDDDEA127B0}",
                                 "{14B5AD65-890D-4062-90A7-C42C23B0066E}",
                                 "{A428D1F6-CB00-4559-AAFD-40885A4F2340}"};
    var kg_props =
      var oidList = kg.TransformToObjectIDs(entityName, idList);
KnowledgeGraph Graph Data Model
Retrieving the Data Model
    var kg_props =
      //Get the KnowledgeGraph Data Model
      using (var kg_dm = kg.GetDataModel())
        //TODO use KG data model...
Get Data Model Properties
    var kg_props =
        var kg_name = System.IO.Path.GetFileName(
                 System.IO.Path.GetDirectoryName(kg_props.PathOrURL.ToString()));
          $"\r\n'{kg_name}' Datamodel:\r\n-----------------");
        var time_stamp = kg_dm.GetTimestamp();
        var sr = kg_dm.GetSpatialReference();
        System.Diagnostics.Debug.WriteLine($"Timestamp: {time_stamp}");
        System.Diagnostics.Debug.WriteLine($"Sref: {sr.Wkid}");
          $"IsStrict: {kg_dm.GetIsStrict()}");
          $"OIDPropertyName: {kg_dm.GetOIDPropertyName()}");
          $"IsArcGISManaged: {kg_dm.GetIsArcGISManaged()}");
Get Data Model Identifier Info
    var kg_props =
        var kg_id_info = kg_dm.GetIdentifierInfo();
        var kg_id_gen = kg_id_info.GetIdentifierGeneration();
        if (kg_id_info is KnowledgeGraphNativeIdentifier kg_ni)
            $"IdentifierInfo: KnowledgeGraphNativeIdentifier");
        else if (kg_id_info is KnowledgeGraphUniformIdentifier kg_ui)
            $"IdentifierInfo: KnowledgeGraphUniformIdentifier");
            $"IdentifierName: '{kg_ui.GetIdentifierName()}'");
          $"Identifier MethodHint: {kg_id_gen.GetMethodHint()}");
Get Data Model MetaEntityTypes/Provenance
//Provenance entity type is stored as a MetaEntityType
    var kg_props =
        var dict_types = kg_dm.GetMetaEntityTypes();
        //If there is no provenance then MetaEntityTypes will be
        //an empty collection
        foreach (var kvp in dict_types)
          var meta_entity_type = kvp.Value;
          if (meta_entity_type.GetRole() ==
              KnowledgeGraphNamedObjectTypeRole.Provenance)
            //TODO - use the provenance entity type
            var name = meta_entity_type.GetName();
Get KnowledgeGraph Entity Types
    var kg_props =
        var dict_types = kg_dm.GetEntityTypes();
          var entity_type = kvp.Value;
          var role = entity_type.GetRole();
          //note "name" will be the same name as the corresponding
          //feature class or table in the KG's relational gdb model
          var name = entity_type.GetName();
          var alias = entity_type.GetAliasName();
          var objectIDPropertyName = entity_type.GetObjectIDPropertyName();
          //etc
Get the KG Provenance using KnowledgeGraphPropertyInfo
    var kg_props =
      // use the KnowledgeGraphPropertyInfo
      var propInfo = kg.GetPropertyNameInfo();
      var supportsProvenance = propInfo.SupportsProvenance;
      var provenanceType = propInfo.ProvenanceTypeName;
      var provenanceInfo = propInfo.ProvenancePropertyInfo;
Get Whether KG Supports Provenance
string GetProvenanceEntityTypeName(KnowledgeGraphDataModel kg_dm)
  var entity_types = kg_dm.GetMetaEntityTypes();
  foreach (var entity_type in entity_types)
    if (entity_type.Value.GetRole() == KnowledgeGraphNamedObjectTypeRole.Provenance)
      return entity_type.Value.GetName();
  return "";
bool KnowledgeGraphSupportsProvenance(KnowledgeGraph kg)
  //if there is a provenance entity type then the KnowledgeGraph
  //supports provenance
  return !string.IsNullOrEmpty(
    GetProvenanceEntityTypeName(kg.GetDataModel()));
  // OR use the KnowledgeGraphPropertyInfo
  return propInfo.SupportsProvenance;
Get the KG Document info using KnowledgeGraphPropertyInfo
    var kg_props =
      var supportsDocs = propInfo.SupportsDocuments;
      var documentType = propInfo.DocumentTypeName;
      var hasDocumentType = propInfo.HasDocumentTypeName; // available at Pro 3.6 only
      var documentInfo = propInfo.DocumentPropertyInfo;
Get Whether KG Has a Document Type
string GetDocumentEntityTypeName(KnowledgeGraphDataModel kg_dm)
  var entity_types = kg_dm.GetEntityTypes();
    var role = entity_type.Value.GetRole();
    if (role == KnowledgeGraphNamedObjectTypeRole.Document)
  return "";//Unusual - probably Neo4j user-managed
bool KnowledgeGraphHasDocumentType(KnowledgeGraph kg)
  //uncommon for there not to be a document type
    GetDocumentEntityTypeName(kg.GetDataModel()));
  return propInfo.SupportsDocuments;
Check Whether A KG Entity Is a Document
//Use GetDocumentEntityTypeName(KnowledgeGraphDataModel kg_dm) from
//the 'Get Whether KG Has a Document Type' snippet to
//get the documentNameType parameter
bool GetEntityIsDocument(KnowledgeGraphEntityValue entity,
  string documentNameType = "")
  if (string.IsNullOrEmpty(documentNameType))
    return false;
  return entity.GetTypeName() == documentNameType;
Check Whether A Graph Type has a Spatial Property
bool HasGeometry(KnowledgeGraphNamedObjectType kg_named_obj)
  var props = kg_named_obj.GetProperties();
  return props.Any(prop => prop.FieldType == FieldType.Geometry);
Get KnowledgeGraph Relationship Types
    var kg_props =
        var dict_types = kg_dm.GetRelationshipTypes();
          var rel_type = kvp.Value;
          var role = rel_type.GetRole();
          var name = rel_type.GetName();
          //etc.
          //Get relationship end points
          var end_points = rel_type.GetEndPoints();
          foreach (var end_point in end_points)
              $"Origin: '{end_point.GetOriginEntityTypeName()}', " +
              $"Destination: '{end_point.GetDestinationEntityTypeName()}'");
Get All KnowledgeGraph Graph Types
    var kg_props =
      using (var kg_datamodel = kg.GetDataModel())
        var entities = kg_datamodel.GetEntityTypes();
        var relationships = kg_datamodel.GetRelationshipTypes();
        var provenance = kg_datamodel.GetMetaEntityTypes();
        var all_graph_types = new List<KnowledgeGraphNamedObjectType>();
        all_graph_types.AddRange(entities.Values);
        all_graph_types.AddRange(relationships.Values);
        all_graph_types.AddRange(provenance.Values);
        System.Diagnostics.Debug.WriteLine("\r\nGraph Types");
        int c = 0;
        foreach (var graph_type in all_graph_types)
          var type_name = graph_type.GetName();
          var role = graph_type.GetRole().ToString();
          //equivalent to:
          //var fields = featClassDef.GetFields().Select(f => f.Name).ToList();
          //var field_names = string.Join(",", fields);
          var props = graph_type.GetProperties().Select(p => p.Name).ToList();
          var prop_names = string.Join(",", props);
          System.Diagnostics.Debug.WriteLine($"[{c++}]: " +
              $"{type_name}, {role}, {prop_names}");
KnowledgeGraph Investigations
Create an Investigation
    var investigation = KnowledgeGraphInvestigationFactory.Instance.CreateInvestigation(url, "myInvestigation");
    //TODO - use the investigation
Create and open an investigation pane
    ProApp.Panes.CreateInvestigationPaneAsync(investigation);
Open an existing investigation
// open an existing investigation
  var investigationProjectItems = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>();
  var investigationProjectItem = investigationProjectItems.FirstOrDefault(ipi => ipi.Name.Equals("myInvestigation"));
    KnowledgeGraphInvestigation investigation = investigationProjectItem.GetInvestigation();
    // or
    investigation.OpenViewAsync();
  // or
  investigationProjectItem.OpenInvestigationPaneAsync();
Get the Knowlege Graph Investigation container
var containerPath = "KnowledgeGraph";
  // find the first container with the correct path (key)
  var invContainer =
     Project.Current.ProjectItemContainers.FirstOrDefault(c => c.Path == containerPath);
Select an investigation in the catalog pane
var investigationContainer = Project.Current.GetProjectItemContainer("KnowledgeGraph");
  var item = Project.Current.GetItems<KnowledgeGraphInvestigationProjectItem>().FirstOrDefault();
  //Select the fc
  if (item != null)
    var projectWindow = Project.GetCatalogPane();
    await projectWindow.SelectItemAsync(item, true, true, investigationContainer);
Get the panes for an investigation
    var panes = investigation.GetInvestigationPanes();
    foreach (var pane in panes)
      KnowledgeGraphInvestigationView kgView = pane.InvestigationView;
      // if it's the active investigation view
      if (kgView == KnowledgeGraphInvestigationView.Active)
        // do something
Get the KnowledgeGraph from a KnowledgeGraphInvestigationProjectItem
// get an existing investigation
    // get the datasore
    using (var kg = investigationProjectItem.GetDatastore())
      // do something
Retrieve Investigation Query Definitions
// access the currently active knowledge graph investigation view
  KnowledgeGraphInvestigationView activeView = KnowledgeGraphInvestigationView.Active;
  KnowledgeGraphInvestigation investigation = activeView?.Investigation;
  if (investigation != null)
      // get all the query defintiions
      var queries = investigation.GetAllQueryDefinitions();
      // get a specific query definition
      var myQuery = investigation.GetQueryDefinition("Query1");
Add Query Definition
var newQueryDefinition = new CIMKnowledgeGraphQueryDefinition();
  newQueryDefinition.Name = "Query1";
  newQueryDefinition.ProvenanceBehavior = ProvenanceBehavior.Include;
  newQueryDefinition.OpenCypherQuery = "MATCH (n) RETURN n LIMIT 10\"";     // return the first 10 entities
      // add the new query defintiion
      investigation.AddQueryDefinition(newQueryDefinition);
Update Query Definition
      // return the first 20 entities
      var newOpenCypherQuery = "MATCH (n) RETURN n LIMIT 20\"";
      // update the open cypher query for a query definition
      investigation.UpdateQueryDefinition("Query1", newOpenCypherQuery);
      // or update other properties
      if (myQuery != null)
        myQuery.ProvenanceBehavior = ProvenanceBehavior.Exclude;
        myQuery.OpenCypherQuery = "MATCH (n) RETURN n LIMIT 30\"";
        investigation.UpdateQueryDefinition(myQuery);
Rename a Query Definition
      // rename the query definition
      investigation.RenameQueryDefinition("Query1", "EntityQuery");
Delete a Query Definition
      // delete the query definition
      investigation.DeleteQueryDefinition("Query1");
Retrieve Investigation Filtered Find Paths Configurations
      // get all the configurations
      var configurations = investigation.GetAllFilteredFindPathsConfigurations();
      // get a specific FFP configuration
      var myConfiguration = investigation.GetFilteredFindPathsConfiguration("FFPConfig1");
Add Filtered Find Paths Configuration
var newFFPConfig = new CIMFilteredFindPathsConfiguration();
  newFFPConfig.Name = "FFPConfig1";
  //Limit the set of origin entities to all entities of type POI and Supplier
  var poi_entity = new CIMFilteredFindPathsEntity();
  poi_entity.EntityTypeName = "POI";
  var supp_entity = new CIMFilteredFindPathsEntity();
  supp_entity.EntityTypeName = "Supplier";
  var originEntities = new List<CIMFilteredFindPathsEntity>();
  originEntities.Add(poi_entity);
  originEntities.Add(supp_entity);
  //Apply to the configuration origin entities filter
  newFFPConfig.OriginEntities = originEntities.ToArray();
      // add the new FFPConfig
      investigation.AddFilteredFindPathsConfiguration(newFFPConfig);
Update Filtered Find Paths Configuration
      // update FFPConfig properties
      var myFFPConig = investigation.GetFilteredFindPathsConfiguration("FFPConfig1");
      if (myFFPConig != null)
        //Limit the set of origin entities to just a specific POI entity
        poi_entity.ID = "{EC2A2D91-B09C-4CF6-93A3-51D6527CF51E}";//upper case guid with "{}"s
        myFFPConig.OriginEntities = originEntities.ToArray();
        investigation.UpdateFilteredFindPathsConfiguration(myFFPConig);
Rename a Filtered Find Paths Configuration
      // rename the FFPConfig
      investigation.RenameFilteredFindPathsConfiguration("FFPConfig1", "FFPConfig_POI");
Delete a Filtered Find Paths Configuration
      // delete the FFPConfig
      investigation.DeleteFilteredFindPathsConfiguration("FFPConfig1");
Import a Filtered Find Paths Configuration
    string pathName = @"d:\data\EntityFFPConfig.ffpcfg";
    // import from ffpcfg
    var ffpConfig = await investigation.ImportFilteredFindPathsConfiguration(pathName);
Export a Filtered Find Paths Configuration
        // export from ffpcfg
        investigation.ExportFilteredFindPathsConfiguration(myFFPConig, pathName, true);
Get the active KnowledgeGraphInvestigationView, KnowledgeGraphInvestigation
    // perform some action
Activate an existing investigation view
//Confirm if investigation exists as a project item
  KnowledgeGraphInvestigationProjectItem investigationItem =
                                                        item => item.Name.Equals("myInvestigation"));
  if (investigationItem != null)
       await QueuedTask.Run(() => investigationItem.GetInvestigation());
    // see if a view is already open that references the same investigation
    foreach (var investigationPane in ProApp.Panes.OfType<IKnowledgeGraphInvestigationPane>())
      //if there is a match, activate the view
      if (investigationPane.InvestigationView.Investigation == investigation)
        (investigationPane as Pane).Activate();
        return;
Select entity, relationship types in an investigation view
// get the active investigation view
  var iv = KnowledgeGraphInvestigationView.Active;
  // clear any TOC selection
  iv.ClearTOCSelection();
  // select entities
  List<string> entities = new List<string>();
  entities.Add("Person");
  entities.Add("Org");
  iv.SelectEntities(entities);
  // or select relationships
  List<string> relationships = new List<string>();
  relationships.Add("HasEmployee");
  iv.SelectRelationships(relationships);
  // or select a combination
  List<string> namedObjectTypes = new List<string>();
  namedObjectTypes.Add("Person");
  namedObjectTypes.Add("Org");
  namedObjectTypes.Add("HasEmployee");
  iv.SelectNamedObjectTypes(namedObjectTypes);
Select records in an investigation view
  var serviceUri = iv.Investigation.ServiceUri;
  // build a dictionary of records
  string some_entity = "Entity_Type_Name";
  var dict = new Dictionary<string, List<long>>();
  //Each entry consists of the type name and corresponding lists of ids
  dict.Add(some_entity, new List<long>() { 1, 5, 18, 36, 78 });
  //Create the id set...
  var idSet = KnowledgeGraphLayerIDSet.FromDictionary(new Uri(serviceUri), dict);
  // select the records on the investigation view
  iv.SetSelectedRecords(idSet, SelectionCombinationMethod.New);
Clear selected records in an investigation view
  // clear the selected records
  iv.ClearSelectedRecords();
    // get the investigation
    var inv = iv.Investigation;
    // get the set of selected records
    var idSet = iv.GetSelectedRecords();
    // view these records in a link chart
    var map = MapFactory.Instance.CreateLinkChart("myLinkChart", new Uri(inv.ServiceUri), idSet);
    ProApp.Panes.CreateMapPaneAsync(map);
KnowledgeGraphLayer Creation with Maps
Create a KG Layer containing all Entity and Relate types
    //With a connection to a KG established or source uri available...
    //Create a KnowledgeGraphLayerCreationParams
    var kg_params = new KnowledgeGraphLayerCreationParams(kg)
      Name = "KG_With_All_Types",
      IsVisible = false
    //Or
    var kg_params2 = new KnowledgeGraphLayerCreationParams(new Uri(url))
      IsVisible = false
    //Call layer factory with map or group layer container.
    //A KG layer containing a feature layer and/or standalone table per
    //entity and relate type (except provenance) is created
    var kg_layer = LayerFactory.Instance.CreateLayer<KnowledgeGraphLayer>(
        kg_params, map);
Create a KG Layer containing a subset of Entity and Relate types
    //To create a KG layer (on a map or link chart) with a subset of
    //entities and relates, you must create an "id set". The workflow
    //is very similar to how you would create a SelectionSet.
    //First, create a dictionary containing the names of the types to be
    //added plus a corresponding list of ids (just like with a selection set).
    //Note: null or an empty list means add all records for "that" type..
    var kg_datamodel = kg.GetDataModel();
    //Arbitrarily get the name of the first entity and relate type
    var first_entity = kg_datamodel.GetEntityTypes().Keys.First();
    var first_relate = kg_datamodel.GetRelationshipTypes().Keys.First();
    //Make entries in the dictionary for each
    dict.Add(first_entity, new List<long>());//Empty list means all records
    dict.Add(first_relate, null);//null list means all records
                                 //or specific records - however the ids are obtained
                                 //dict.Add(entity_or_relate_name, new List<long>() { 1, 5, 18, 36, 78});
    var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict);
    //Create the layer params and assign the id set
      Name = "KG_With_ID_Set",
      IsVisible = false,
      IDSet = idSet
    //A KG layer containing just the feature layer(s) and/or standalone table(s)
    //for the entity and/or relate types + associated records will be created
        kg_params, map);
Using LayerFactory.Instance.CanCreateLayer with KG Create Layer Params
    //Feature class and/or standalone tables representing KG entity and
    //relate types can only be added to a map (or link chart) as a child
    //of a KnowledgeGraph layer....
    //For example:
    var fc = kg.OpenDataset<FeatureClass>("Some_Entity_Or_Relate_Name");
    try
      //Attempting to create a feature layer containing the returned fc
      //is NOT ALLOWED - can only be a child of a KG layer
      var fl_params_w_kg = new FeatureLayerCreationParams(fc);
      //CanCreateLayer will return false
      if (!(LayerFactory.Instance.CanCreateLayer<FeatureLayer>(
        fl_params_w_kg, map)))
          $"Cannot create a feature layer for {fc.GetName()}");
        return;
      //This will throw an exception
      LayerFactory.Instance.CreateLayer<FeatureLayer>(fl_params_w_kg, map);
    catch (Exception ex)
    //Can only be added as a child of a parent KG
    dict.Add(fc.GetName(), new List<long>());
      Name = $"KG_With_Just_{fc.GetName()}",
      IsVisible = false,
      IDSet = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict)
      kg_params, map);
ProSnippet Group: KnowledgeGraph Layer
Get and Set a KG Layer IDSet
var kg_layer = MapView.Active.Map.GetLayersAsFlattenedList()
  if (kg_layer == null)
    return;
    //Get the existing kg layer id set and convert to a dictionary
    var layer_id_set = kg_layer.GetIDSet();
    var dict = layer_id_set.ToOIDDictionary();//Empty list means all records
    //Create an id set from a dictionary
    var dict2 = new Dictionary<string, List<long>>();
    dict2.Add("Enity_Or_Relate_Type_Name1", null);//Null means all records
    dict2.Add("Enity_Or_Relate_Type_Name2", new List<long>());//Empty list means all records
    dict2.Add("Enity_Or_Relate_Type_Name3",
      new List<long>() { 3, 5, 9, 101, 34 });//Explicit list of ids
                                             //dict2.Add("Enity_Or_Relate_Type_Name4",
                                             // new List<long>() { etc, etc });
    //Create the id set
    var idset = KnowledgeGraphLayerIDSet.FromDictionary(kg, dict2);
    //Can be used to create a layer, link chart, append to link chart, etc...
Is a dataset part of a Knowledge Graph
var featureLyer = MapView.Active.Map.GetLayersAsFlattenedList()
                  .OfType<FeatureLayer>().FirstOrDefault();
  if (featureLyer == null)
    return;
    //Get the feature class
    var fc = featureLyer.GetFeatureClass();
    // is it part of a KnowledgeGraph?
    var isPartOfKG = fc.GetIsKnowledgeGraphDataset();
Get KG Datastore
    return;
    // get the datastore
    var kg = kg_layer.GetDatastore();
    // now submit a search or a query
    // kg.SubmitSearch
    // kg.SubmitQuery
Get KG Service uri
//will be a path for a file-based kg otherwise it will be a service uri
  kgLayer.GetPathOrServiceUri();
SubLayers of a KnowledgeGraph Layer
var kg_layer = map.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().FirstOrDefault();
    return;
  if (map.MapType == MapType.LinkChart)
    // if map is of MapType.LinkChart then the first level
    // children of the kg_layer are of type LinkChartFeatureLayer
    var childLayers = kg_layer.Layers;
    foreach (var childLayer in childLayers)
      if (childLayer is LinkChartFeatureLayer lcFeatureLayer)
        var isEntity = lcFeatureLayer.IsEntity;
        var isRel = lcFeatureLayer.IsRelationship;
        // TODO - continue processing
  else if (map.MapType == MapType.Map)
    // if map is of MapType.Map then the children of the
    // kg_layer are the standard Featurelayer and StandAloneTable
    var chidlren = kg_layer.GetMapMembersAsFlattenedList();
    foreach (var child in chidlren)
      if (child is FeatureLayer fl)
        // TODO - process the feature layer
      else if (child is StandaloneTable st)
        // TODO - process the standalone table
Create a LinkChart from a subset of an existing LinkChart IDSet
//var map = ...
  if (map.MapType != MapType.LinkChart)
    return;
  // find the KG layer
  //var kgLayer = map.GetLayersAsFlattenedList()
  // find the first LinkChartFeatureLayer in the KG layer
  var lcFeatureLayer = kgLayer.GetLayersAsFlattenedList().OfType<LinkChartFeatureLayer>().FirstOrDefault();
  if (lcFeatureLayer != null)
    return;
    // get the ID set of the KG layer
    var idSet = kgLayer.GetIDSet();
    // get the named object type in the KG that the LinkChartFeatureLayer represents
    var typeName = lcFeatureLayer.GetTypeName();
    // if there are items in the ID Set for this type
    if (idSet.Contains(typeName))
      // build a new ID set containing only these records
      var dict = idSet.ToOIDDictionary();
      var oids = dict[typeName];
      var newDict = new Dictionary<string, List<long>>();
      newDict.Add(typeName, oids);
      var newIDSet = KnowledgeGraphLayerIDSet.FromDictionary(kgLayer.GetDatastore(), newDict);
      // now create a new link chart using just this subset of records
      MapFactory.Instance.CreateLinkChart("subset LinkChart", kgLayer.GetDatastore(), newIDSet);
Submit a Graph Query
await QueuedTask.Run(async () =>
    //and assuming you have established a connection to a knowledge graph
    //Construct an openCypher query - return the first 10 entities (whatever
    //they are...)
    var query = "MATCH (n) RETURN n LIMIT 10";//default limit is 100 if not specified
                                              //other examples...
                                              //query = "MATCH (a:Person) RETURN [a.name, a.age] ORDER BY a.age DESC LIMIT 50";
                                              //query = "MATCH (b:Person) RETURN { Xperson: { Xname: b.name, Xage: b.age } } ORDER BY b.name DESC";
                                              //query = "MATCH p = (c:Person)-[:HasCar]-() RETURN p ORDER BY c.name DESC";
    //Create a query filter
    //Note: OutputSpatialReference is currently ignored
    var kg_qf = new KnowledgeGraphQueryFilter()
      QueryText = query
    //Optionally - u can choose to include provenance in the results
    //(_if_ the KG has provenance - otherwise the query will fail)
    bool includeProvenanceIfPresent = KnowledgeGraphSupportsProvenance(kg);
    if (includeProvenanceIfPresent)
      //Only include if the KG has provenance
      kg_qf.ProvenanceBehavior =
          KnowledgeGraphProvenanceBehavior.Include;//default is exclude
    //submit the query - returns a KnowledgeGraphCursor
    using (var kg_rc = kg.SubmitQuery(kg_qf))
      //wait for rows to be returned from the server
      //note the "await"...
      while (await kg_rc.WaitForRowsAsync())
        //Rows have been retrieved - process this "batch"...
        while (kg_rc.MoveNext())
          //Get the current KnowledgeGraphRow
          using (var graph_row = kg_rc.Current)
            //Graph row is an array, process all returned values...
            var val_count = (int)graph_row.GetCount();
            for (int i = 0; i < val_count; i++)
              var retval = graph_row[i];
              //Process row value (note: recursive)
              //See "Process a KnowledgeGraphRow Value" snippet
              ProcessKnowledgeGraphRowValue(retval);
      }//WaitForRowsAsync
    }//SubmitQuery
    //Construct a KG search filter. Search text uses Apache Lucene Query Parser
    //syntax - https://lucene.apache.org/core/2_9_4/queryparsersyntax.html
    var kg_sf = new KnowledgeGraphSearchFilter()
      SearchTarget = KnowledgeGraphNamedTypeCategory.Entity,
      SearchText = "Acme Electric Co.",
      ReturnSearchContext = true,
      MaxRowCount = 10 //Default is 100 if not specified
    //submit the search - returns a KnowledgeGraphCursor
    var e = 0;
    using (var kg_rc = kg.SubmitSearch(kg_sf))
            //We are returning entities from this search
            var entity = graph_row[0] as KnowledgeGraphEntityValue;
            var entity_type = entity.GetTypeName();
            var record = new List<string>();
            //discover keys(aka "fields") dynamically via GetKeys
            foreach (var prop_name in entity.GetKeys())
              var obj_val = entity[prop_name] ?? "null";
              record.Add(obj_val.ToString());
              $"{entity_type}[{e++}] " + string.Join(", ", record));
            //or use "Process a KnowledgeGraphRow Value" snippet
            //ProcessKnowledgeGraphRowValue(entity);
      }//WaitForRowsAsync
    }//SubmitSearch
Convert an Open Cypher Query Result to a Selection
    //Given an open-cypher qry against an entity or relationship type
    var qry = @"MATCH (p:PhoneNumber) RETURN p LIMIT 10";
    //create a KG query filter
    var kg_qry_filter = new KnowledgeGraphQueryFilter()
      QueryText = qry
    //save a list of the ids
    var oids = new List<long>();
    using (var kgRowCursor = kg.SubmitQuery(kg_qry_filter))
      //wait for rows to be returned asynchronously from the server
      while (await kgRowCursor.WaitForRowsAsync())
        //get the rows using "standard" move next
        while (kgRowCursor.MoveNext())
          //current row is accessible via ".Current" prop of the cursor
          using (var graphRow = kgRowCursor.Current)
            var cell_phone = graphRow[0] as KnowledgeGraphEntityValue;
            //note: some user-managed graphs do not have objectids
            oids.Add(cell_phone.GetObjectID());
    //create a query filter using the oids
    if (oids.Count > 0)
      //select them on the layer
      var qf = new ArcGIS.Core.Data.QueryFilter()
        ObjectIDs = oids //apply the oids to the ObjectIds property
      //select the child feature layer or standalone table representing
      //the given entity or relate type whose records are to be selected
      var phone_number_fl = kgLayer.GetLayersAsFlattenedList()
          .OfType<FeatureLayer>().First(l => l.Name == "PhoneNumber");
      //perform the selection
      phone_number_fl.Select(qf);
Use Bind Parameters with an Open Cypher Query
    //assume we have, in this case, a list of ids (perhaps retrieved
    //via a selection, hardcoded (like here), etc.
    var oids = new List<long>() { 3,4,7,8,9,11,12,14,15,19,21,25,29,
   31,32,36,37,51,53,54,55,56,59,63,75,78,80,84,86,88,96,97,98,101,
   103,106};
    //In the query, we refer to the "bind parameter" with the
    //"$" and a variable name - '$object_ids' in this example
    var qry = @"MATCH (p:PhoneNumber) " +
              @" WHERE p.objectid IN $object_ids " +
              @"RETURN p";
    //we provide the values to be substituted for the variable via the
    //KnowledgeGraphQueryFilter BindParameter property...
      QueryText = qry
    //the bind parameter added to the query filter must refer to
    //the variable name used in the query string (without the "$")
    //Note:
    //Collections must be converted to a KnowledgeGraphArrayValue before
    //being assigned to a BindParameter
    var kg_oid_array = new KnowledgeGraphArrayValue();
    kg_oid_array.AddRange(oids);
    oids.Clear();
    kg_qry_filter.BindParameters["object_ids"] = kg_oid_array;
    //submit the query
            var oid = cell_phone.GetObjectID();
            var name = (string)cell_phone["FULL_NAME"];
            var ph_number = (string)cell_phone["PHONE_NUMBER"];
              $"[{oid}] {name}, {ph_number}");
Use Bind Parameters with an Open Cypher Query2
   103,106};
    //"$" and a variable name - '$object_ids' and '$sel_geom'
    //in this example
                @"WHERE p.objectid IN $object_ids AND " +
                @"esri.graph.ST_Intersects($sel_geom, p.shape) " +
                @"RETURN p";
      QueryText = qry
    //Note:
    //Create a polygon based on current map extent
    var extent = MapView.Active.Extent;
    var poly = PolygonBuilder.CreatePolygon(extent.Expand(0.25, 0.25, true));
    kg_qry_filter.BindParameters["sel_geom"] = poly;
    oids.Clear();
    //submit the query
            #region Process Row
Call WaitForRowsAsync With Cancellation
//On the QueuedTask...
  //submit query or search to return a KnowledgeGraphCursor
  //using (var kgRowCursor = kg.SubmitQuery(kg_qf)) {
  //using (var kgRowCursor = kg.SubmitSearch(kg_sf)) {
  //"auto-cancel" after 20 seconds
  var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
  //catch TaskCanceledException
  try
    while (await kgRowCursor.WaitForRowsAsync(cancel.Token))
      //check for row events
        using (var graph_row = kgRowCursor.Current)
  //Timeout expired
  catch (TaskCanceledException tce)
    //Handle cancellation as needed
  cancel.Dispose();
void ProcessGraphNamedObjectValue(
  KnowledgeGraphNamedObjectValue kg_named_obj_val)
  if (kg_named_obj_val is KnowledgeGraphEntityValue kg_entity)
    var label = kg_entity.GetLabel();
    //TODO - use label
  else if (kg_named_obj_val is KnowledgeGraphRelationshipValue kg_rel)
    var has_entity_ids = kg_rel.GetHasRelatedEntityIDs();
    if (kg_rel.GetHasRelatedEntityIDs())
      var origin_id = kg_rel.GetOriginID();
      var dest_id = kg_rel.GetDestinationID();
      //TODO - use ids
  var id = kg_named_obj_val.GetID();
  var oid = kg_named_obj_val.GetObjectID();
  //Note: Typename corresponds to the name of the feature class or table
  //in the relational gdb model -and- to the name of the KnowledgeGraphNamedObjectType
  //in the knowledge graph data model
  var type_name = kg_named_obj_val.GetTypeName();
  //TODO use id, object id, etc.
//Object values include entities, relationships, and anonymous objects
void ProcessGraphObjectValue(KnowledgeGraphObjectValue kg_obj_val)
  switch (kg_obj_val)
    case KnowledgeGraphEntityValue kg_entity:
      ProcessGraphNamedObjectValue(kg_entity);
      break;
    case KnowledgeGraphRelationshipValue kg_rel:
      ProcessGraphNamedObjectValue(kg_rel);
      break;
    default:
      //Anonymous objects
      break;
  //graph object values have a set of properties (equivalent
  //to a collection of key/value pairs)
  var keys = kg_obj_val.GetKeys();
  foreach (var key in keys)
    ProcessKnowledgeGraphRowValue(kg_obj_val[key]);//Recurse
//Process a KnowledgeGraphValue from a query or search
void ProcessGraphValue(KnowledgeGraphValue kg_val)
  switch (kg_val)
    case KnowledgeGraphPrimitiveValue kg_prim:
      //KnowledgeGraphPrimitiveValue not currently used in
      //query and search
      ProcessKnowledgeGraphRowValue(kg_prim.GetValue());//Recurse
      return;
    case KnowledgeGraphArrayValue kg_array:
      var count = kg_array.GetSize();
      //Recursively process each value in the array
      for (ulong i = 0; i < count; i++)
        ProcessKnowledgeGraphRowValue(kg_array[i]);//Recurse
      return;
    case KnowledgeGraphPathValue kg_path:
      //Entities
      var entity_count = kg_path.GetEntityCount();
      //Recursively process each entity value in the path
      for (ulong i = 0; i < entity_count; i++)
        ProcessGraphObjectValue(kg_path.GetEntity(i));//Recurse
      //Recursively process each relationship value in the path
      var relate_count = kg_path.GetRelationshipCount();
      for (ulong i = 0; i < relate_count; i++)
        ProcessGraphObjectValue(kg_path.GetRelationship(i));//Recurse
      return;
    case KnowledgeGraphObjectValue kg_object:
      ProcessGraphObjectValue(kg_object);//Recurse
      return;
    default:
      var type_string = kg_val.GetType().ToString();
        $"Unknown: '{type_string}'");
      return;
//Process each value from the KnowledgeGraphRow array
void ProcessKnowledgeGraphRowValue(object value)
  switch (value)
    //Graph value?
    case KnowledgeGraphValue kg_val:
      var kg_type = kg_val.KnowledgeGraphValueType.ToString();
        $"KnowledgeGraphValue: '{kg_type}'");
      ProcessGraphValue(kg_val);//Recurse
      return;
    //Primitive types...add additional logic as needed
    case System.DBNull dbn:
      System.Diagnostics.Debug.WriteLine("DBNull.Value");
      return;
    case string str:
      System.Diagnostics.Debug.WriteLine($"'{str}' (string)");
      return;
    case long l_val:
      System.Diagnostics.Debug.WriteLine($"{l_val} (long)");
      return;
    case int i_val:
      System.Diagnostics.Debug.WriteLine($"{i_val} (int)");
      return;
    case short s_val:
      System.Diagnostics.Debug.WriteLine($"{s_val} (short)");
      return;
    case double d_val:
      System.Diagnostics.Debug.WriteLine($"{d_val} (double)");
      return;
    case float f_val:
      System.Diagnostics.Debug.WriteLine($"{f_val} (float)");
      return;
    case DateTime dt_val:
      System.Diagnostics.Debug.WriteLine($"{dt_val} (DateTime)");
      return;
    case DateOnly dt_only_val:
      System.Diagnostics.Debug.WriteLine($"{dt_only_val} (DateOnly)");
      return;
    case TimeOnly tm_only_val:
      System.Diagnostics.Debug.WriteLine($"{tm_only_val} (TimeOnly)");
      return;
    case DateTimeOffset dt_tm_offset_val:
        $"{dt_tm_offset_val} (DateTimeOffset)");
      return;
    case System.Guid guid_val:
      var guid_string = guid_val.ToString("B");
      System.Diagnostics.Debug.WriteLine($"'{guid_string}' (Guid)");
      return;
    case ArcGIS.Core.Geometry.Geometry geom_val:
      var geom_type = geom_val.GeometryType.ToString();
      var is_empty = geom_val.IsEmpty;
      var wkid = geom_val.SpatialReference?.Wkid ?? 0;
        $"geometry: {geom_type}, empty: {is_empty}, sr_wkid {wkid} (shape)");
      return;
    default:
      //Blob? Others?
      var type_str = value.GetType().ToString();
      System.Diagnostics.Debug.WriteLine($"Primitive: {type_str}");
      return;
// ...submit query or search
//  ...wait for rows ...
//  while (await kgRowCursor.WaitForRowsAsync()) {
//   ...rows have been retrieved
//   while (kgRowCursor.MoveNext()) {
//     ...get the current KnowledgeGraphRow
//     using (var graph_row = kgRowCursor.Current) {
//        var val_count = (int)graph_row.GetCount();
//        for (int i = 0; i<val_count; i++)
//           ProcessKnowledgeGraphRowValue(graph_row[i]);
// find all the link chart project items
  var linkChartItems = Project.Current.GetItems<MapProjectItem>()
                              .Where(pi => pi.MapType == MapType.LinkChart);
  // find a link chart project item by name
  var linkChartItem =
        .FirstOrDefault(pi => pi.Name == "Acme Link Chart");
var projectItem = Project.Current.GetItems<MapProjectItem>()
  var linkChartMap = projectItem?.GetMap();
var mv = MapView.Active;
  // check the view
  var isLinkChartView = mv.IsLinkChartView;
  // or alternatively get the map and check that
  //var map = MapView.Active.Map;
  // check the MapType to determine if it's a link chart map
  var isLinkChart = map.MapType == MapType.LinkChart;
  // or you could use the following
  // var isLinkChart = map.IsLinkChart;
var mapPanes = FrameworkApplication.Panes.OfType<IMapPane>().ToList();
  var mapPane = mapPanes.FirstOrDefault(
      mp => mp.MapView.IsLinkChartView && mp.MapView.Map.Name == "Acme Link Chart");
  var lcMap = mapPane.MapView.Map;
  // a MapView can encapsulate a link chart IF it's map
  // is of type MapType.LinkChart
  // or use the following
    if (isLinkChart)
      // get the layout algorithm
      var layoutAlgorithm = mv.GetLinkChartLayout();
      // toggle the value
      if (layoutAlgorithm == KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard)
        layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Organic_Standard;
      else
        layoutAlgorithm = KnowledgeLinkChartLayoutAlgorithm.Geographic_Organic_Standard;
      // set it
      mv.SetLinkChartLayoutAsync(layoutAlgorithm);
      // OR set it and force a redraw / update
      // await mv.SetLinkChartLayoutAsync(layoutAlgorithm, true);
    //Create the link chart and show it
    //build the IDSet using KnowledgeGraphFilterType.AllNamedObjects
    var idSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraph(
      kg, KnowledgeGraphFilterType.AllNamedObjects);
    var linkChart = MapFactory.Instance.CreateLinkChart(
                      "KG Link Chart", kg, idSet);
    FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
    //Create the link chart with a -null- id set
    //This will create a KG Layer with empty sub-layers
    //(Note: you cannot create an empty KG layer on a map - only on a link chart)
                      "KG Link Chart", kg, null);
    using (var kg_for_lc = new KnowledgeGraph(
      new KnowledgeGraphConnectionProperties(new Uri(url))))
        kg_for_lc, KnowledgeGraphFilterType.AllEntities);
      var newLinkChart = MapFactory.Instance.CreateLinkChart(
        "All_Entities link chart", kg_for_lc, idSet);
//use the results of a query to create an idset. Create the link chart
  //containing just records corresponding to the query results
  var qry = @"MATCH (p1:PhoneNumber)-[r1:MADE_CALL|RECEIVED_CALL]->(c1:PhoneCall)<-" +
            @"[r2:MADE_CALL|RECEIVED_CALL]-(p2:PhoneNumber)-[r3:MADE_CALL|RECEIVED_CALL]" +
            @"->(c2:PhoneCall)<-[r4:MADE_CALL|RECEIVED_CALL]-(p3:PhoneNumber) " +
            @"WHERE p1.FULL_NAME = ""Robert Johnson"" AND " +
            @"p3.FULL_NAME= ""Dan Brown"" AND " +
            @"p1.globalid <> p2.globalid AND " +
            @"p2.globalid <> p3.globalid " +
            @"RETURN p1, r1, c1, r2, p2, r3, c2, r4, p3";
    using (var kg_for_lc = kgLayer.GetDatastore())
      var graphQuery = new KnowledgeGraphQueryFilter()
        QueryText = qry
      using (var kg_rc = kg_for_lc.SubmitQuery(graphQuery))
            using (var graphRow = kg_rc.Current)
              // process the row
              var cnt_val = (int)graphRow.GetCount();
              for (int v = 0; v < cnt_val; v++)
                var obj_val = graphRow[v] as KnowledgeGraphNamedObjectValue;
                var type_name = obj_val.GetTypeName();
                var oid = (long)obj_val.GetObjectID();
                if (!dict.ContainsKey(type_name))
                  dict[type_name] = new List<long>();
                if (!dict[type_name].Contains(oid))
                  dict[type_name].Add(oid);
      //make an ID Set to create the LinkChart
      var idSet = KnowledgeGraphLayerIDSet.FromDictionary(kg_for_lc, dict);
                        "KG With ID Set", kg_for_lc, idSet);
// note that the template link chart MUST use the same KG server
    // find the existing link chart by name
    if (linkChartMap == null)
      return;
    var kg_props2 =
    try
      //Open a connection
      using (var kg_for_lc = new KnowledgeGraph(kg_props2))
        //Add all entities to the link chart
        //Create the new link chart and show it
                          "KG from Template", kg_for_lc, idSet, linkChartMap.URI);
        FrameworkApplication.Panes.CreateMapPaneAsync(newLinkChart);
Checking KnowledgeGraphLayerException
// running on QueuedTask
  dict.Add("person", new List<long>());  //Empty list means all records
  dict.Add("made_call", null);  //null list means all records
  // or specific records - however the ids are obtained
  dict.Add("phone_call", new List<long>() { 1, 5, 18, 36, 78 });
  // make the id set
  try
                      "KG With ID Set", kg, idSet);
  catch (KnowledgeGraphLayerException e)
    // get the invalid named types
    //   remember that the named types are case-sensitive
    var invalidNamedTypes = e.InvalidNamedTypes;
    // do something with the invalid named types
    // for example - log or return to caller to show message to user
//We create an id set to contain the records to be appended
  dict["Suspects"] = new List<long>();
  //In this case, via results from a query...
  var qry2 = "MATCH (s:Suspects) RETURN s";
        QueryText = qry2
              var obj_val = graphRow[0] as KnowledgeGraphNamedObjectValue;
              dict["Suspects"].Add(oid);
      //make an ID Set to append to the LinkChart
      //Get the relevant link chart to which records will be
      //appended...in this case, from an open map pane in the
      //Pro application...
      var mapPane = mapPanes.First(
      var linkChartMap = mapPane.MapView.Map;
      //or get the link chart from an item in the catalog...etc.,etc.
      //var projectItem = Project.Current.GetItems<MapProjectItem>()
      //      .FirstOrDefault(pi => pi.Name == "Acme Link Chart");
      //var linkChartMap = projectItem?.GetMap();
      //Call AppendToLinkChart with the id set
      if (linkChartMap.CanAppendToLinkChart(idSet))
        linkChartMap.AppendToLinkChart(idSet);
    //Get the link chart to be cleared of content
    //Clear all content from the link chart
    if (linkChartMap.CanClearLinkChartContent())
      linkChartMap.ClearLinkChartContent();
if (!MapView.Active?.Map?.IsLinkChart == true)
    return;
    var sel_set = map.GetSelection();
    if (sel_set.Count > 0)
      var kg_layer_id_set = KnowledgeGraphLayerIDSet.FromSelectionSet(sel_set);
      //IDSetCombinationMethod can be New, Add, or Subtract
      if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.New))
        map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.New);
    return;
  //Assume we have a set of features in an entity type 'Species' and an entity
  //type 'Observation' that we want to append to an existing link chart...
  //Create a dictionary containing the entity uids to be added...
  var dict = new Dictionary<string, List<object>>();
  dict["Species"] = new List<object>();
  dict["Observation"] = new List<object>();
  dict["Species"].Add("{4478D960-A4D6-4930-A151-51A2C6140509}");
  dict["Species"].Add("{97E011A0-C140-4EA9-84E6-19413F6FCEE3}");
  dict["Observation"].Add("{18E1DB21-9F61-4CBE-A488-71AC8B24B605}");
  dict["Observation"].Add("{E378F1B1-FF5E-4EDD-808A-1C395A4857AD}");
    //Get the knowledge graph layer from the link chart
    var kg_layer = MapView.Active?.Map?.GetLayersAsFlattenedList()?
                              .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>()?
                              .First();
    //arbitrarily get the first feature layer that is a child of the kg layer
    var fl = kg_layer?.GetLayersAsFlattenedList()?
                .OfType<FeatureLayer>()?.First();
    //Get the kg from the kg layer
    using (var kg = kg_layer.GetDatastore())
      //Create a kg layer id set
      var id_set = KnowledgeGraphIDSet.FromDictionary(kg, dict);
      var kg_layer_id_set = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(id_set);
      //set the content of the link chart using the id set and the Add combination method
      if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Add))
        map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Add);
        //Set the newly added records selected...
        map.SetSelection(SelectionSet.FromKnowledgeGraphLayerIDSet(map, kg_layer_id_set));
    return;
      if (map.CanSetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Subtract))
        map.SetLinkChartContent(kg_layer_id_set, IDSetCombinationMethod.Subtract);
ID Sets
Get the ID Set of a KG layer
  // is the set empty?
  var isEmpty = idSet.IsEmpty;
  // get the count of named object types
  var countNamedObjects = idSet.NamedObjectTypeCount;
  // does it contain the entity "Species";
  var contains = idSet.Contains("Species");
  // get the idSet as a dictionary of namedObjectType and oids
  var oidDict = idSet.ToOIDDictionary();
  var speciesOIDs = oidDict["Species"];
  // alternatively get the idSet as a dictionary of
  // namedObjectTypes and uuids
  var uuidDict = idSet.ToUIDDictionary();
  var speciesUuids = uuidDict["Species"];
Create an ID set from a SelectionSet
    // get the selection set
    var sSet = map.GetSelection();
    // translate to an KnowledgeGraphLayerIDSet
    //  if the selectionset does not contain any KG entity or relationship records
    //    then idSet will be null
    var idSet = KnowledgeGraphLayerIDSet.FromSelectionSet(sSet);
    if (idSet == null)
      return;
    // you can use the idSet to create a new linkChart
    //   (using MapFactory.Instance.CreateLinkChart)
Root Nodes
Toggle Root Node Display
var val = MapView.Active.GetShowRootNodes();
    MapView.Active.SetShowRootNodes(!val);
Get records that are set as Root Nodes
    MapMemberIDSet rootNodes = MapView.Active.GetRootNodes();
    var rootNodeDict = rootNodes.ToDictionary();
    // rootNodeDict is a Dictionary<MapMember, List<long>>
    // access a particular mapMember in the Dictionary
    if (rootNodeDict.ContainsKey(mapMember))
      var oids = rootNodeDict[mapMember];
    // OR iterate through the dictionary
    foreach (var (mm, oids) in rootNodeDict)
      // do something
Assign a set of records as Root Nodes
    var dict = new Dictionary<MapMember, List<long>>();
    dict.Add(entityLayer, oids);
    MapMemberIDSet mmIDSet = MapMemberIDSet.FromDictionary(dict);
    MapView.Active.SetRootNodes(mmIDSet);
Assign a selection as Root Nodes
    var mapSel = MapView.Active.Map.GetSelection();
    MapView.Active.SetRootNodes(mapSel);
Select the records that are Root Node
    var mapSel = MapView.Active.SelectAllRootNodes();
    // this is the same as
    SelectionSet selSet = SelectionSet.FromMapMemberIDSet(rootNodes);
    MapView.Active.Map.SetSelection(selSet);
Define and select a set of records as Root Nodes
    dict.Add(entityLayer2, oids2);
    MapView.Active.SelectRootNodes(mmIDSet);
Clear Root Nodes
    //Assuming mapview is a link chart view
    MapView.Active.ClearRootNodes();
PrSnippet Group: Non Spatial Data
Non spatial data
    // display non spatial data
    MapView.Active.SetShowNonSpatialData(true);
    // select the current set of non spatial data
    var selNonSpatial = MapView.Active.SelectNonSpatialData();
    // select the current set of spatial data
    var selSpatial = MapView.Active.SelectSpatialData();
    // perform some other action
Editing
Create a new Entity
    //Instantiate an operation for the Create
    var edit_op = new EditOperation()
      Name = "Create a new organization",
      SelectNewFeatures = true
    //Use datasets or feature layer(s) or standalone table(s)
    //Get a reference to the KnowledgeGraph
    //var kg = ... ;
    //Open the feature class or Table to be edited
    var org_fc = kg.OpenDataset<FeatureClass>("Organization");
    //Alternatively, use the feature layer for 'Organization' if your context is a map
    //Get the parent KnowledgeGraphLayer
    var kg_layer = mv.Map.GetLayersAsFlattenedList()?
                  .OfType<ArcGIS.Desktop.Mapping.KnowledgeGraphLayer>().First();
    //From the KG Layer get the relevant child feature layer
    var org_fl = kg_layer.GetLayersAsFlattenedList().OfType<FeatureLayer>()
                    .First(child_layer => child_layer.Name == "Organization");
    //Define attributes
    var attribs = new Dictionary<string, object>();
    attribs["Name"] = "Acme Ltd.";
    attribs["Description"] = "Specializes in household items";
    attribs["SHAPE"] = mv.Extent.Center;//whatever is its location
    //Add it to the operation via the dataset...
    edit_op.Create(org_fc, attribs);
    //or use the feature layer/stand alone table if preferred and available
    //edit_op.Create(org_fl, attribs);
    if (edit_op.Execute())
      //TODO: Operation succeeded
Create a new Relationship from Existing Entities 1
var create_rel = await QueuedTask.Run(() =>
      Name = "Create a new relationship record",
    //var kg = ... ;
    //We will use a relate called 'HasEmployee' to relate an Organization w/ a Person
    //Use either tables or map members to get the rows to be related...
    var person_tbl = kg.OpenDataset<Table>("Person");
    //Get the relationship dataset
    //We can use either a table or standalone table
    var emp_tbl = kg.OpenDataset<Table>("HasEmployee");
    //we need the names of the origin and destination relationship properties
    var kg_prop_info = kg.GetPropertyNameInfo();
    //Arbitrarily use the first record from the two entity datasets "to be" related
    //Entities are always related by Global ID. Origin to Destination specifies the
    //direction (of the relate).
    //Populate the attributes for the relationship
    using (var rc = org_fc.Search())
      if (rc.MoveNext())
        //Use the KnowledgeGraphPropertyInfo to avoid hardcoding...
        attribs[kg_prop_info.OriginIDPropertyName] = rc.Current.GetGlobalID();
    using (var rc = person_tbl.Search())
      if (rc.MoveNext())
        attribs[kg_prop_info.DestinationIDPropertyName] = rc.Current.GetGlobalID();
    //Add any extra attribute information for the relation as needed
    attribs["StartDate"] = new DateTimeOffset(DateTime.Now);
    //Add a create for the relationship to the operation
    edit_op.Create(emp_tbl, attribs);
    //Do the create
    return edit_op.Execute();
Create a new Relationship from Existing Entities 2
var create_rel2 = await QueuedTask.Run(() =>
    //var kg = ... ;
    // get the origin, destination records
    Guid guidOrigin = Guid.Empty;
    Guid guidDestination = Guid.Empty;
      if (rc.MoveNext())
        guidOrigin = rc.Current.GetGlobalID();
      if (rc.MoveNext())
        guidDestination = rc.Current.GetGlobalID();
    var rd = new KnowledgeGraphRelationshipDescription(guidOrigin, guidDestination, attribs);
    edit_op.Create(emp_tbl, rd);
    //Do the create
Create a new Relationship and New Entities 1
  var create_rel1 = await QueuedTask.Run(() =>
    //This example uses a chained edit operation
      Name = "Create entities and a relationship",
    //We are just going to use the GDB objects in this one but
    //we could equally use feature layers/standalone tables
    //using Feature Class/Tables (works within Investigation or map)
    //Relationship table
    //New Organization
    //Add it to the operation - we need the rowtoken
    var rowtoken = edit_op.Create(org_fc, attribs);
    attribs.Clear();//we are going to re-use the dictionary
    //New Person
    attribs["Name"] = "Bob";
    attribs["Age"] = "41";
    attribs["Skills"] = "Plumbing, Framing, Flooring";
    var rowtoken2 = edit_op.Create(person_tbl, attribs);
    attribs.Clear();
    //At this point we must execute the create of the entities
      //if we are here, the create of the entities was successful
      //Next, "chain" a second create for the relationship - this ensures that
      //Both creates (entities _and_ relation) will be -undone- together if needed
      //....in other words they will behave as if they are a -single- transaction
      var edit_op_rel = edit_op.CreateChainedOperation();
      //we need the names of the origin and destination relation properties
      //use the row tokens we held on to from the entity creates
      attribs[kg_prop_info.OriginIDPropertyName] = rowtoken.GlobalID;
      attribs[kg_prop_info.DestinationIDPropertyName] = rowtoken2.GlobalID;
      //Do the create of the relate
      edit_op_rel.Create(emp_tbl, attribs);
      return edit_op_rel.Execute();
    return false;//Create of entities failed
Create a new Relationship and New Entities 2
  var createRel = await QueuedTask.Run(() =>
    //This example uses a KnowledgeGraphRelationshipDescription
      Name = "Create entities and a relationship using a KG relate desc",
    //We are just going to use mapmembers in this example
    //we could equally use feature classes/tables
    //From the KG Layer get the relevant child feature layer(s) and/or standalone
    //table(s)
    var person_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                    .First(child_layer => child_layer.Name == "Person");
    var rel_stbl = kg_layer.GetStandaloneTablesAsFlattenedList()
                    .First(child_layer => child_layer.Name == "HasEmployee");
    //New Organization
    var rowtoken_org = edit_op.Create(org_fl, attribs);
    //New Person
    var rowtoken_person = edit_op.Create(person_stbl, attribs);
    attribs.Clear();
    //Create the new relationship using a KnowledgeGraphRelationshipDescription
    //Row handles act as the placeholders for the TO BE created new entities that will
    //be related
    var src_row_handle = new RowHandle(rowtoken_org);
    var dest_row_handle = new RowHandle(rowtoken_person);
    var rel_desc = new KnowledgeGraphRelationshipDescription(
                                src_row_handle, dest_row_handle, attribs);
    //Add the relate description to the edit operation
    edit_op.Create(rel_stbl, rel_desc);
    //Execute the create of the entities and relationship
Create a Provenance Record
      Name = "Create a new provenance record",
    //lets get the provenance table (provenance is not added to the
    //map TOC)
    var provenance_tbl = kg.OpenDataset<Table>("Provenance");
    if (provenance_tbl == null)
      return;
    //we will add a row to the provenance for person entity
    //Arbitrarily retrieve the first "person" row
    var instance_id = Guid.Empty;
      if (!rc.MoveNext())
        return;
      instance_id = rc.Current.GetGlobalID();//Get the global id
    //Define the provenance attributes - we need the names
    //of the provenance properties from the KG ProvenancePropertyInfo
    var ppi = kg_prop_info.ProvenancePropertyInfo;
    attribs[ppi.ProvenanceTypeNamePropertyName] =
        person_tbl.GetDefinition().GetName();//entity type name
    attribs[ppi.ProvenanceFieldNamePropertyName] = "name";//Must be a property/field on the entity
    attribs[ppi.ProvenanceSourceNamePropertyName] = "Annual Review 2024";//can be anything - can be null
        //note: Source type is controlled by the CodedValueDomain "esri__provenanceSourceType"
    attribs[ppi.ProvenanceSourceTypePropertyName] = "Document";//one of ["Document", "String", "URL"].
    attribs[ppi.ProvenanceSourcePropertyName] = "HR records";//can be anything, not null
    attribs[ppi.ProvenanceCommentPropertyName] = "Rock star";//can be anything - can be null
    //Add in the id of the provenance owner - our "person" in this case
    attribs[ppi.ProvenanceInstanceIDPropertyName] = instance_id;
    //Specify any additional custom attributes added to the provenance
    //schema by the user as needed....
    //attribs["custom_attrib"] = "Foo";
    //attribs["custom_attrib2"] = "Bar";
    //Create the provenance row
    edit_op.Create(provenance_tbl, attribs);
Create a Provenance Record 2
    // check if provenance supported
    if (!propInfo.SupportsProvenance)
      return;
    var provName = propInfo.ProvenanceTypeName;
      if (!rc.MoveNext())
        return;
    var originHandle = new RowHandle(person_tbl, instance_id);
    var pd = new KnowledgeGraphProvenanceDescription(
      originHandle, "name", KnowledgeGraphSourceType.Document,
      "Annual Review 2024", "HR records", "Rock star");
    edit_op.Create(pd);
Create an Entity, a Document, a HasDocument and a Provenance record
      Name = "Create a records",
    // create the entity
    var personToken = edit_op.Create(personLayer, personAtts);
    // create the document
    var kgDocDesc = new KnowledgeGraphDocumentDescription(
      @"D:\Data\BirthCertificate.jpg");
    var docToken = edit_op.Create(docLayer, kgDocDesc);
    // create RowHandles from the returned RowTokens
    var personHandle = new RowHandle(personToken);
    var docHandle = new RowHandle(docToken);
    // create the "hasDocument" relationship
    var rd = new KnowledgeGraphRelationshipDescription(personHandle, docHandle);
    edit_op.Create(docLayer, rd);
    // create the provenance record for the person entity using the document entity
    // provenance record is on the "name" field
      personHandle, "name", docHandle, "", "comments");
    edit_op.Create(pd);
    // execute - create all the entities and relationship rows _together_
    edit_op.Execute();
Create a Document Record 1
var ok = await QueuedTask.Run(() =>
    using (var kg_for_doc = kgLayer.GetDatastore())
        Name = "Create Document Example",
      var doc_entity_name = GetDocumentTypeName(kg_for_doc.GetDataModel());
      if (string.IsNullOrEmpty(doc_entity_name))
        return false;
      var hasdoc_rel_name = GetHasDocumentTypeName(kg_for_doc.GetDataModel());
      if (string.IsNullOrEmpty(hasdoc_rel_name))
        return false;
      //Document can also be FeatureClass
      var doc_tbl = kg_for_doc.OpenDataset<Table>(doc_entity_name);
      var doc_rel_tbl = kg_for_doc.OpenDataset<Table>(hasdoc_rel_name);
      //This is the document to be added...file, image, resource, etc.
      var doc_url = @"E:\Data\Temp\HelloWorld.txt";
      var text = System.IO.File.ReadAllText(url);
      //Set document properties
      attribs["contentType"] = @"text/plain";
      attribs["name"] = System.IO.Path.GetFileName(url);
      attribs["url"] = doc_url;
      //Add geometry if relevant
      //attribs["Shape"] = doc_location;
      //optional
      attribs["fileExtension"] = System.IO.Path.GetExtension(doc_url);
      attribs["text"] = System.IO.File.ReadAllText(doc_url);
      //optional and arbitrary - your choice
      attribs["title"] = System.IO.Path.GetFileNameWithoutExtension(doc_url);
      attribs["keywords"] = @"text,file,example";
      attribs["metadata"] = "";
      //Specify any additional custom attributes added to the document
      //Get the entity whose document this is...
      var org_fc = kg_for_doc.OpenDataset<FeatureClass>("Organization");
        WhereClause = "name = 'Acme'",
        SubFields = "*"
      var origin_org_id = Guid.Empty;
      using (var rc = org_fc.Search(qf))
        if (!rc.MoveNext())
          return false;
        origin_org_id = rc.Current.GetGlobalID();//For the relate
      //Create the document row/feature
      var rowtoken = edit_op.Create(doc_tbl, attribs);
        //Create the relationship row
        attribs.Clear();
        var kg_prop_info = kg_for_doc.GetPropertyNameInfo();
        //Specify the origin entity (i.e. the document 'owner') and
        //the document being related to (i.e. the document 'itself')
        attribs[kg_prop_info.OriginIDPropertyName] = origin_org_id;//entity
        attribs[kg_prop_info.DestinationIDPropertyName] = rowtoken.GlobalID;//document
        //Specify any custom attributes added to the has document
        //"Chain" a second create for the relationship - this ensures that
        //Both creates (doc _and_ "has doc" relation) will be -undone- together if needed
        edit_op_rel.Create(doc_rel_tbl, attribs);
      return false;
string GetDocumentTypeName(KnowledgeGraphDataModel kg_dm)
  return "";
string GetHasDocumentTypeName(KnowledgeGraphDataModel kg_dm)
  var rel_types = kg_dm.GetRelationshipTypes();
  foreach (var rel_type in rel_types)
    var role = rel_type.Value.GetRole();
      return rel_type.Value.GetName();
  return "";
Create a Document Record 2
      var propInfo = kg_for_doc.GetPropertyNameInfo();
      if (!propInfo.SupportsDocuments)
        return false;
      var doc_entity_name = propInfo.DocumentTypeName;
      var hasdoc_rel_name = GetHasDocumentTypeName(kg.GetDataModel());
      // create the KnowledgeGraphDocumentDescription
      var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url);
      // if there is a geometry use the following ctor
      // var kgDocDesc = new KnowledgeGraphDocumentDescription(doc_url, doc_location);
      // if you have additional custom attributes
      //var customDocAtts = new Dictionary<string, object>();
      //customDocAtts.Add("custom_attrib", "Foo");
      //customDocAtts.Add("custom_attrib2", "Bar");
      //var kgDocDesc = new KnowledgeGraphDocumentDescription(url, null, customDocAtts);
      // add additional properties if required
      kgDocDesc.Keywords = @"text,file,example";
      // The Create method will auto-populate the Url, Name, FileExtension and contentType fields of the document row
      // from the path supplied.
      var rowToken = edit_op.Create(doc_tbl, kgDocDesc);
        SubFields = "*"
        if (!rc.MoveNext())
          return false;
      // set up the row handles
      var originHandle = new RowHandle(org_fc, origin_org_id);    // entity
      var destinationHandle = new RowHandle(rowToken);            // document
      // create the KnowledgeGraphRelationshipDescription
      var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle);
      // if you have additional custom attributes for the "HasDocument" relationship
      //var customHasDocAtts = new Dictionary<string, object>();
      //customHasDocAtts.Add("custom_attrib", "Foo");
      //customHasDocAtts.Add("custom_attrib2", "Bar");
      //var rd = new KnowledgeGraphRelationshipDescription(originHandle, destinationHandle, customHasDocAtts);
      // create the relate record using the same edit operation
      edit_op.Create(doc_rel_tbl, rd);
      //Call execute to create all the entities and relationship rows _together_
Modify an Entity and Relationship record
      Name = "Modify an Entity and Relationship record",
      SelectModifiedFeatures = true
    //We are  going to use mapmembers in this example
    //Entity
    //and/or Relationship
    //Get the entity feature to modify
    long org_oid = -1;
    var org_gid = Guid.Empty;
      SubFields = "*"
    using (var rc = org_fl.Search(qf))
      if (!rc.MoveNext())
        return;
      org_oid = rc.Current.GetObjectID();
      org_gid = rc.Current.GetGlobalID();
    if (org_oid == -1)
      return; //nothing to modify
    //Specify attributes to be updated
    //Add to the edit operation
    edit_op.Modify(org_fl, org_oid, attribs);
    //Get the relationship record (if a relate is being updated)
    //we need the name of the origin id property
    var sql = $"{kg_prop_info.OriginIDPropertyName} = ";
    sql += "'" + org_gid.ToString("B").ToUpper() + "'";
      WhereClause = sql,
      SubFields = "*"
    long rel_oid = -1;
    using (var rc = rel_stbl.Search(qf))
      if (!rc.MoveNext())
        return;
      rel_oid = rc.Current.GetObjectID();
    if (rel_oid > -1)
      //add the relate row updates to the edit operation
      edit_op.Modify(rel_stbl, rel_oid, attribs);
    //do the update(s)
Delete an Entity record
      Name = "Delete an Entity record"
    //Entity
    //Get the entity feature(s) to delete
    long org_oid = -1;
      SubFields = "*"
      if (!rc.MoveNext())
        return;//nothing to delete
    edit_op.Delete(org_fl, org_oid);
    edit_op.Execute();//Do the delete
Delete a Relationship record 1
      Name = "Delete a Relationship record"
    //Relationship
    //Get the relation row to delete
    long rel_oid = -1;
    using (var rc = rel_stbl.Search())
      if (!rc.MoveNext())
        return;
      //arbitrarily, in this example, get the first row
    edit_op.Delete(rel_stbl, rel_oid);
Delete a Relationship record 2
    //entities
    var entityOrg = kg_layer.GetStandaloneTablesAsFlattenedList()
    var entityPerson = kg_layer.GetStandaloneTablesAsFlattenedList()
    //Relationship
    using (var rc = entityOrg.Search())
      if (rc.MoveNext())
    using (var rc = entityPerson.Search())
      if (rc.MoveNext())
    var rd = new KnowledgeGraphRelationshipDescription(guidOrigin, guidDestination);
    edit_op.Delete(rel_stbl, rd);
Schema Edits
Create a File Knowledge Graph with SchemaBuilder
  //Starting at 3.7, users can use _file_ knowledge graphs
  //The extension for a file kg is ".knowledgegraph"
  string kgPath = @"C:\Data\KG\Filebased_KG";
  string kgFileName = @"Test_File_KG.knowledgegraph";
  //The file knowledge graph must NOT already exist or a GeodatabaseWorkspaceException
  //exception will be thrown
  string finalFileName = string.Empty;
  // ensure new file name is unique
  string baseFileName = System.IO.Path.GetFileNameWithoutExtension(kgFileName);
  int extraCount = 0;
  string extraFileName = string.Empty;
  string fullPath = string.Empty;
  do
    fullPath = System.IO.Path.Combine(
          kgPath, baseFileName + extraFileName + ".knowledgegraph");
    ++extraCount;
    extraFileName = $"({extraCount})";
  while (System.IO.File.Exists(fullPath));
  System.Diagnostics.Debug.WriteLine($"Creating {System.IO.Path.GetFileName(fullPath)}");
  var kgConnProps = new KnowledgeGraphConnectionProperties(
                                            new Uri(fullPath));
  try
    using (var kg = SchemaBuilder.CreateFileKnowledgeGraph(kgConnProps))
//TODO - use the new KG
    System.Diagnostics.Debug.WriteLine(ex.ToString());
Create Entity and Relationship Types with SchemaBuilder
  using (var kg = GetKnowledgeGraph(url))
    var entity_name = "PhoneCall";
    var relate_name = "WhoCalledWho";
    //Entity Fields
    var descs1 =
  new List<KnowledgeGraphPropertyDescription>();
    descs1.Add(
new KnowledgeGraphPropertyDescription("PhoneOwner", FieldType.String));
    descs1.Add(
new KnowledgeGraphPropertyDescription("PhoneNumber", FieldType.String));
    descs1.Add(
new KnowledgeGraphPropertyDescription("LocationID", FieldType.BigInteger));
    descs1.Add(
new KnowledgeGraphPropertyDescription("DateAndTime", FieldType.Date));
    //Relate Fields
    var descs2 =
    descs2.Add(
new KnowledgeGraphPropertyDescription("Foo", FieldType.String));
    descs2.Add(
new KnowledgeGraphPropertyDescription("Bar", FieldType.String));
    var includeShape = true;//change to false to omit the shape column
    var hasZ = false;
    var hasM = false;
    KnowledgeGraphEntityTypeDescription entityDesc = null;
    KnowledgeGraphRelationshipTypeDescription relateDesc = null;
    if (includeShape)
var sr = kg.GetSpatialReference();
var shp_desc = new ShapeDescription(GeometryType.Point, sr)
  HasM = hasM,
  HasZ = hasZ
entityDesc = new KnowledgeGraphEntityTypeDescription(
  entity_name, descs1, shp_desc);
relateDesc = new KnowledgeGraphRelationshipTypeDescription(
  relate_name, descs2, shp_desc);
    else
  entity_name, descs1);
  relate_name, descs2);
    //Run the schema builder
    try
SchemaBuilder sb = new(kg);
sb.Create(entityDesc);
sb.Create(relateDesc);
//Use the KnowledgeGraph extension method 'ApplySchemaEdits(...)'
//to refresh the Pro UI
if (!kg.ApplySchemaEdits(sb))
  var err_msg = string.Join(",", sb.ErrorMessages.ToArray());
  System.Diagnostics.Debug.WriteLine($"Entity/Relate Create error: {err_msg}");
Delete Entity and Relationship Types with SchemaBuilder
      var entityDesc = new KnowledgeGraphEntityTypeDescription(entity_name);
      var relateDesc = new KnowledgeGraphRelationshipTypeDescription(relate_name);
      try
        sb.Delete(entityDesc);
        sb.Delete(relateDesc);
          System.Diagnostics.Debug.WriteLine($"Entity/Relate Delete error: {err_msg}");
Modify Entity and Relationship Type Schemas with SchemaBuilder
      var kvp_entity = kg.GetDataModel().GetEntityTypes()
           .First(r => r.Key == entity_name);
      var kvp_relate = kg.GetDataModel().GetRelationshipTypes()
                     .First(r => r.Key == relate_name);
      //Let's delete one field and add a new one from each
      //A field gets deleted implicitly if it is not included in the list of
      //fields - or "properties" in this case....so we will remove the last
      //property from the list
      var entity_props = kvp_entity.Value.GetProperties().Reverse().Skip(1).Reverse();
      var prop_descs = new List<KnowledgeGraphPropertyDescription>();
      foreach (var prop in entity_props)
        if (prop.FieldType == FieldType.Geometry)
          continue;//skip shape
        var prop_desc = new KnowledgeGraphPropertyDescription(prop);
        prop_descs.Add(prop_desc);
      //deal with shape - we need to keep it
      //SchemaBuilder deletes any field not included in the "modify" list
      ShapeDescription shape_desc = null;
      if (kvp_entity.Value.GetIsSpatial())
        var geom_def = kvp_entity.Value.GetShapeDefinition();
        var shape_name = kvp_entity.Value.GetShapeField();
        shape_desc = new ShapeDescription(
          shape_name, geom_def.geometryType, geom_def.sr);
      //add the new entity property
      prop_descs.Add(
        KnowledgeGraphPropertyDescription.CreateStringProperty("foo", 10));
      //make a description for the entity type - ok if shape_desc is null
        entity_name, prop_descs, shape_desc);
      //Add the entity type description to the schema builder using 'Modify'
      sb.Modify(entityDesc);
      //Repeat for the relationship - assuming we have at least one custom attribute field
      //that can be deleted on our relationship schema...
      var rel_props = kvp_relate.Value.GetProperties().Reverse().Skip(1).Reverse();
      var rel_prop_descs = new List<KnowledgeGraphPropertyDescription>();
      foreach (var prop in rel_props)
        rel_prop_descs.Add(prop_desc);
      ShapeDescription shape_desc_rel = null;
      if (kvp_relate.Value.GetIsSpatial())
        var geom_def = kvp_relate.Value.GetShapeDefinition();
        var shape_name = kvp_relate.Value.GetShapeField();
        shape_desc_rel = new ShapeDescription(
      //add a new relationship property
      rel_prop_descs.Add(
        KnowledgeGraphPropertyDescription.CreateStringProperty("bar", 10));
      //make a description for the relationship type - ok if shape_desc is null
      var relDesc = new KnowledgeGraphRelationshipTypeDescription(
        relate_name, rel_prop_descs, shape_desc_rel);
      //Add the relationship type description to the schema builder using 'Modify'
      sb.Modify(relDesc);
      try
          System.Diagnostics.Debug.WriteLine($"Entity/Relate Modify error: {err_msg}");
Create Attribute Indexes on KG Schemas with SchemaBuilder
      //indexes are managed on the GDB objects...
      var entity_table_def = kg.GetDefinition<TableDefinition>(entity_name);
      var entity_table_desc = new TableDescription(entity_table_def);
      var entity_table_flds = entity_table_def.GetFields();
      AttributeIndexDescription attr_index1 = null;
      AttributeIndexDescription attr_index2 = null;
      foreach (var fld in entity_table_flds)
        //index the first string field
        if (fld.FieldType == FieldType.String && attr_index1 == null)
          if (fld.Name == "ESRI__ID")//special case
            continue;
          //Index _must_ be ascending for KG
          attr_index1 = new AttributeIndexDescription(
            "Index1", entity_table_desc, new List<string> { fld.Name })
            IsAscending = true
        //index the first numeric field (if there is one)
        if ((fld.FieldType == FieldType.BigInteger ||
             fld.FieldType == FieldType.Integer ||
             fld.FieldType == FieldType.Single ||
             fld.FieldType == FieldType.SmallInteger ||
             fld.FieldType == FieldType.Double) && attr_index2 == null)
          attr_index2 = new AttributeIndexDescription(
            "Index2", entity_table_desc, new List<string> { fld.Name })
            IsAscending = true,
            IsUnique = true //optional - unique if all values are to be unique in the index
        if (attr_index1 != null && attr_index2 != null) break;
      if (attr_index1 == null && attr_index2 == null)
        return; //nothing to index
      try
        if (attr_index1 != null)
          sb.Create(attr_index1);
        if (attr_index2 != null)
          sb.Create(attr_index2);
          System.Diagnostics.Debug.WriteLine($"Create index error: {err_msg}");
Delete Attribute Indexes on KG Schemas with SchemaBuilder
      var indexes = entity_table_def.GetIndexes();
      foreach (var idx in indexes)
        System.Diagnostics.Debug.WriteLine($"Index {idx.GetName()}");
      var idx1 = indexes.FirstOrDefault(
        idx => idx.GetName().ToLower() == "Index1".ToLower());
      var idx2 = indexes.FirstOrDefault(
        idx => idx.GetName().ToLower() == "Index2".ToLower());
      if (idx1 == null && idx2 == null)
        return;
      try
        if (idx1 != null)
          var idx_attr = new AttributeIndexDescription(idx1, entity_table_desc);
          sb.Delete(idx_attr);
        if (idx2 != null)
          var idx_attr = new AttributeIndexDescription(idx2, entity_table_desc);
          System.Diagnostics.Debug.WriteLine($"Delete index error: {err_msg}");
Create Domain and Field Definition on KG Schemas with SchemaBuilder
      var entity_name = "Fruit";
      //Domains are managed on the GDB objects...
      var fruit_fc = kg.OpenDataset<FeatureClass>(entity_name);
      var fruit_fc_def = fruit_fc.GetDefinition();
      var fieldFruitTypes = fruit_fc_def.GetFields()
            .FirstOrDefault(f => f.Name == "FruitTypes");
      var fieldShelfLife = fruit_fc_def.GetFields()
          .FirstOrDefault(f => f.Name == "ShelfLife");
      //Create a coded value domain and add it to a new field
      var fruit_cvd_desc = new CodedValueDomainDescription(
        "FruitTypes", FieldType.String,
        new SortedList<object, string> {
                    { "A", "Apple" },
                    { "B", "Banana" },
                    { "C", "Coconut" }
        SplitPolicy = SplitPolicy.Duplicate,
        MergePolicy = MergePolicy.DefaultValue
      //Create a Range Domain and add the domain to a new field description also
      var shelf_life_rd_desc = new RangeDomainDescription(
                                    "ShelfLife", FieldType.Integer, 0, 14);
      var sb = new SchemaBuilder(kg);
      sb.Create(fruit_cvd_desc);
      sb.Create(shelf_life_rd_desc);
      //Create the new field descriptions that will be associated with the
      //"new" FruitTypes coded value domain and the ShelfLife range domain
      var fruit_types_fld = new ArcGIS.Core.Data.DDL.FieldDescription(
                                    "FruitTypes", FieldType.String);
      fruit_types_fld.SetDomainDescription(fruit_cvd_desc);
      //ShelfLife will use the range domain
      var shelf_life_fld = new ArcGIS.Core.Data.DDL.FieldDescription(
    "ShelfLife", FieldType.Integer);
      shelf_life_fld.SetDomainDescription(shelf_life_rd_desc);
      //Add the descriptions to the list of field descriptions for the
      //fruit feature class - Modify schema needs _all_ fields to be included
      //in the schema, not just the new ones to be added.
      var fruit_fc_desc = new FeatureClassDescription(fruit_fc_def);
      var modified_fld_descs = new List<ArcGIS.Core.Data.DDL.FieldDescription>(
        fruit_fc_desc.FieldDescriptions);
      modified_fld_descs.Add(fruit_types_fld);
      modified_fld_descs.Add(shelf_life_fld);
      //Create a feature class description to modify the fruit entity
      //with the new fields and their associated domains
      var updated_fruit_fc =
        new FeatureClassDescription(entity_name, modified_fld_descs,
                                    fruit_fc_desc.ShapeDescription);
      //Add the modified fruit fc desc to the schema builder
      sb.Modify(updated_fruit_fc);
      try
          System.Diagnostics.Debug.WriteLine($"Create domains error: {err_msg}");
Delete Domain on KG Schemas with SchemaBuilder
      //Get all the domains in the KG
      var domains = kg.GetDomains();
      foreach (var domain in domains)
        //skip the special provenance domain
        var name = domain.GetName();
        if (string.Compare(name, "esri__provenanceSourceType", true) == 0)
          continue;//skip this one
        //Delete all other domains
        if (domain is ArcGIS.Core.Data.RangeDomain rd)
          sb.Delete(new RangeDomainDescription(rd));
        else if (domain is ArcGIS.Core.Data.CodedValueDomain cvd)
          sb.Delete(new CodedValueDomainDescription(cvd));
      try
        //note: will throw an InvalidOperationException if there are no operations
        //to run. Will also delete associated fields dependent on deleted domain(s)
          System.Diagnostics.Debug.WriteLine($"Delete domains error: {err_msg}");
KnowledgeGraph GetKnowledgeGraph(string url)
  var kg_props =
    new KnowledgeGraphConnectionProperties(new Uri(url));
  return new KnowledgeGraph(kg_props);
KnowledgeGraph Centrality
Compute Centrality Using Defaults
//using ArcGIS.Core.Data.Knowledge.Extensions;
    //using(var kg = ....) {
    //take default settings...
    //undirected relationship interpretation
    //use default relationship importance = 0
    //use default relationship cost = 0
    //use default Multiedge factor = 0
    //no normalization
    var kg_config = new CIMKnowledgeGraphCentralityConfiguration();
    //include all entities from the kg in the subgraph
    //(no filters)
    var kg_subgraph = new CIMKnowledgeGraphSubGraph();
    //include all centrality measures
    CentralityMeasure[] measures = [
      CentralityMeasure.Degree,
CentralityMeasure.InDegree,
CentralityMeasure.OutDegree,
CentralityMeasure.Coreness,//Coreness only wks w/ undirected relates
CentralityMeasure.Betweenness,
CentralityMeasure.Closeness,
CentralityMeasure.Harmonic,
CentralityMeasure.Eigenvector,
CentralityMeasure.PageRank
    //compute centrality
    var kg_centrality_results = kg.ComputeCentrality(
                                      kg_config, kg_subgraph, measures);
    //TODO - process results
Process Centrality Results
    //use defaults...
    //(no filters)
    //output results - results include measure scores for all entities
    //in all types in the subgraph
    System.Diagnostics.Debug.WriteLine("Centrality Results:");
    foreach (var named_type in kg_centrality_results.NamedTypes)
      System.Diagnostics.Debug.WriteLine($"Named type: {named_type}");
      foreach (var uid in kg_centrality_results.GetUidsForNamedType(named_type))
        //measure scores include one score per measure in the input measures array
        var scores = kg_centrality_results.Scores[uid];
        StringBuilder sb = new StringBuilder();
        var sep = "";
        //or use kg_centrality_results.Scores.Measures.Length
        //kg_centrality_results.Scores.Measures is there for convenience
        for (int m = 0; m < measures.Length; m++)
          sb.Append($"{sep}{measures[m].ToString()}: {scores[m]}");
          sep = ", ";
        System.Diagnostics.Debug.WriteLine($"  '{uid}' {sb.ToString()}");
Configure Centrality
    //configure centrality with custom settings
      RelationshipsInterpretation = CentralityRelationshipInterpretation.Directed,
      MultiedgeFactor = 1.0,//cumulative importance
      Normalization = CentralityScoresNormalization.None,
      DefaultRelationshipCost = 1.0,
      DefaultRelationshipImportance = 1.0,
      RelationshipCostProperty = string.Empty,
      RelationshipImportanceProperty = string.Empty
    //(no filters)
    //include the relevant centrality measures
    //Note: CentralityMeasure.Coreness cannot be calculated
    //with directed relationships, so it is not included here.
    //Specfying Coreness (with directed or reveresed relationships) will
    //throw an exception
    //TODO process results
Configure Centrality Entity SubGraph Filters
    //Assume KG contains Entity NamedTypes "A","B","C", and "D"
    //We can use either of a CIMKnowledgeGraphNamedTypeFilterByInstances
    //or CIMKnowledgeGraphNamedTypeFilterByType to filter instances for
    //_including_ in or _excluding_ from entities and relates wrt the subgraph.
    //Use CIMKnowledgeGraphNamedTypeFilterByInstances to filter by instance id
    //Use CIMKnowledgeGraphNamedTypeFilterByType to filter by type name and with
    //an optional property filter predicate to filter by property value(s)
    //Example 1.
    //Include all entities (and relates) from the kg in the subgraph
    //Leave kg_subgraph.EntityFilters null.
    //(kg_subgraph.RelationshipFilters is also null)
    //The collection of Entity and Relate filters are both empty
    //Everything is included
    //Example 2
    //Include a set of Entities from A (all of B, C, D will be implicitly excluded)
    var kg_filter2 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
      FilterType = KGFilterType.Include,
      NamedType = "A",
      InstancesIDs = list_of_ids.ToArray() //list_of_ids contains desired uids for "A"
                                           //note: -if list_of_ids is empty then -no-
                                           //instances of A will be included.
    var entity_filters2 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters2.Add(kg_filter2);
    //note: All relates are included as no RelationshipFilters are specified
    //var kg_subgraph = ...
    kg_subgraph.EntityFilters = entity_filters2.ToArray();
    //Example 3
    //Exclude a set of Entities from A (all of B, C, D will be implicitly included)
    var kg_filter3 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
      FilterType = KGFilterType.Exclude,
      NamedType = "A",
                                           //instances of A will be excluded.
    var entity_filters3 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters3.Add(kg_filter3);
    kg_subgraph.EntityFilters = entity_filters3.ToArray();
    //Example 4
    //Include all Entities from A via named type (all of B, C, D
    //will be implicitly excluded)
    var kg_filter4 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "A" //all of A will be included
                      //predicate is empty
    var entity_filters4 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters4.Add(kg_filter4);
    kg_subgraph.EntityFilters = entity_filters4.ToArray();
    //Example 5
    //Exclude all Entities from A via named type (all of B, C, D
    //will be implicitly included)
    var kg_filter5 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "A" //all of A will be excluded
    var entity_filters5 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters5.Add(kg_filter5);
    kg_subgraph.EntityFilters = entity_filters5.ToArray();
    //Example 6
    //Include all entities from B and C and
    //a subset from D via a set of ids (A is implicitly excluded)
    var kg_filter6_b = new CIMKnowledgeGraphNamedTypeFilterByType();
    var kg_filter6_c = new CIMKnowledgeGraphNamedTypeFilterByType();
    kg_filter6_b.NamedType = "B";//Include is default, predicate is empty
    kg_filter6_c.NamedType = "C";//Include is default, predicate is empty
    //TODO... populate list with uids from "D"...
    var kg_filter6_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
    kg_filter6_d.NamedType = "D";//Include is default
    kg_filter6_d.InstancesIDs = list_of_ids.ToArray();
    var entity_filters6 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters6.Add(kg_filter6_b);//order doesn't matter
    entity_filters6.Add(kg_filter6_c);
    entity_filters6.Add(kg_filter6_d);
    kg_subgraph.EntityFilters = entity_filters6.ToArray();
    //Example 7
    //Exclude all entities from B and C and
    //a subset from D (A is implicitly included)
    var kg_filter7_b = new CIMKnowledgeGraphNamedTypeFilterByType();
    var kg_filter7_c = new CIMKnowledgeGraphNamedTypeFilterByType();
    kg_filter7_b.NamedType = "B";//predicate is empty
    kg_filter7_c.NamedType = "C";//predicate is empty
    kg_filter7_b.FilterType = KGFilterType.Exclude;
    kg_filter7_c.FilterType = KGFilterType.Exclude;
    var kg_filter7_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
    kg_filter7_d.NamedType = "D";
    kg_filter7_d.FilterType = KGFilterType.Exclude;
    kg_filter7_d.InstancesIDs = list_of_ids.ToArray();//ids to be excluded
    var entity_filters7 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters7.Add(kg_filter7_b);//order doesn't matter
    entity_filters7.Add(kg_filter7_c);
    entity_filters7.Add(kg_filter7_d);
    kg_subgraph.EntityFilters = entity_filters7.ToArray();
    //Example 8
    //Include a subset of Entities from A using a property
    //filter predicate (all of B, C, D will be implicitly excluded)
    //we -must- use a predicate prefix in our expression
    //select instances of A w/ Material = 'Steel'
    var expr8 = $"a.Material = 'Steel'";//prefix can be anything - foo, bar, fred, etc.
    var kg_filter8 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "A",//Include is default
      PropertyFilterPredicate = expr8 //include ids w/Material='Steel'
    var entity_filters8 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters8.Add(kg_filter8);
    kg_subgraph.EntityFilters = entity_filters8.ToArray();
    //Example 9
    //Exclude a subset of Entities from A using a property
    //filter predicate (all of B, C, D will be implicitly included)
    //select instances of A with Material <> 'Steel'
    var expr9 = $"a.Material <> 'Steel'";//prefix can be anything - foo, bar, fred, etc.
    var kg_filter9 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "A",
      PropertyFilterPredicate = expr9 //exclude ids w/Material <> 'Steel'
    var entity_filters9 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters9.Add(kg_filter9);
    //Note: All relates are included as no RelationshipFilters are specified
    kg_subgraph.EntityFilters = entity_filters9.ToArray();
Configure Centrality Relationship SubGraph Filters
    //using(var kg = ...) {
    //Assume Relationship NamedTypes "R1","R2",and "R3"
    //Example 1.
    //Include all relates (and entities) from the kg in the subgraph
    //Leave kg_subgraph.RelationshipFilters null
    //(kg_subgraph.EntityFilters is also null)
    //note - relates can only be included if their corresponding entity end points
    //are also included in the subgraph.
    //Example 2
    //Include a set of Relates from R1 (all of R2, R3 will be implicitly excluded)
    var kg_filter_r2 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
      NamedType = "R1",
      InstancesIDs = list_of_ids.ToArray() //list_of_ids contains desired uids for "R1"
                                           //instances of R1 will be included.
    var relate_filters2 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters2.Add(kg_filter_r2);
    //note: All entities are included as no EntityFilters are specified
    kg_subgraph.RelationshipFilters = relate_filters2.ToArray();
    //Example 3
    //Exclude a set of Relates from R1 (all of R2, R3 will be implicitly included)
    var kg_filter_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances()
      NamedType = "R1",
                                           //instances of R1 will be excluded.
    var relate_filters3 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters3.Add(kg_filter_r3);
    kg_subgraph.RelationshipFilters = relate_filters3.ToArray();
    //Example 4
    //Include all Relates from R1 via named type (all of R2, R3
    var kg_filter_r4 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R1",//all of R1 will be included
    var relate_filters4 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters4.Add(kg_filter_r4);
    kg_subgraph.RelationshipFilters = relate_filters4.ToArray();
    //Example 5
    //Exclude all Relates from R1 via named type (all of R2, R3
    var kg_filter_r5 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R1" //all of R1 will be excluded
    var relate_filters5 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters5.Add(kg_filter_r5);
    kg_subgraph.RelationshipFilters = relate_filters5.ToArray();
    //Example 6
    //Include all relates from R2 and
    //a subset from R3 (R1 is implicitly excluded)
    var kg_filter_r6_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
    kg_filter_r6_r2.NamedType = "R2"; //Include is default, predicate is empty
    //TODO... populate list with uids from "R3"...
    var kg_filter_r6_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
    kg_filter_r6_r3.NamedType = "R3"; //Include is default
    kg_filter_r6_r3.InstancesIDs = list_of_ids.ToArray();
    var relate_filters6 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters6.Add(kg_filter_r6_r2);//order doesn't matter
    relate_filters6.Add(kg_filter_r6_r3);
    kg_subgraph.RelationshipFilters = relate_filters6.ToArray();
    //Example 7
    //Exclude all relates from R2 and
    //a subset from R3 (R1 is implicitly included)
    var kg_filter_r7_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
    kg_filter_r7_r2.NamedType = "R2";
    kg_filter_r7_r2.FilterType = KGFilterType.Exclude;
    var kg_filter_r7_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
    kg_filter_r7_r3.NamedType = "R3";
    kg_filter_r7_r3.FilterType = KGFilterType.Exclude;
    kg_filter_r7_r3.InstancesIDs = list_of_ids.ToArray();
    var relate_filters7 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters7.Add(kg_filter_r7_r2);//order doesn't matter
    relate_filters7.Add(kg_filter_r7_r3);
    //Example 8
    //Include a subset of Relates from R1 using a property
    //filter predicate (all of R2, R3 will be implicitly excluded)
    //select instances of R1 w/Distance = 2000
    var expr8 = $"r1.Distance = 2000";//prefix can be anything - foo, bar, fred, etc.
    var kg_filter_r8 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R1", //Include is default
    var relate_filters8 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters8.Add(kg_filter_r8);
    kg_subgraph.RelationshipFilters = relate_filters8.ToArray();
    //Example 9
    //Exclude a subset of Relates from R1 using a property
    //filter predicate (all of R2, R3 will be implicitly included)
    //select instances of R1 w/ Distance <> 2000
    var expr9 = $"r1.Distance <> 2000";//prefix can be anything - foo, bar, fred, etc.
    var kg_filter_r9 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R1",
      PropertyFilterPredicate = expr9 //exclude ids w/ Distance <> 2000
    var relate_filters9 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters9.Add(kg_filter_r9);
    //Note: All entities are included as no EntityFilters are specified
    kg_subgraph.RelationshipFilters = relate_filters9.ToArray();
Combine Centrality Entity and Relationship SubGraph Filters
    //Assume Entity NamedTypes "A","B","C", and "D"
    //Example 1
    //Include all Entities from A and B
    //Include all Relates from R1 and R2
    //(all of C, D, and R3 will be implicitly excluded)
    var kg_filter1_a = new CIMKnowledgeGraphNamedTypeFilterByType()
      FilterType = KGFilterType.Include,//default
      NamedType = "A"
    var kg_filter1_b = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "B"
    var kg_filter1_r1 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R1"
    var kg_filter1_r2 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R2"
    var entity_filters1 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    entity_filters1.Add(kg_filter1_a);
    entity_filters1.Add(kg_filter1_b);
    var relate_filters1 = new List<CIMKnowledgeGraphNamedTypeFilter>();
    relate_filters1.Add(kg_filter1_r1);
    relate_filters1.Add(kg_filter1_r2);
    //var kgSubgraph = ...
    kgSubgraph.EntityFilters = entity_filters1.ToArray();
    kgSubgraph.RelationshipFilters = relate_filters1.ToArray();
    //Example 2 -
    //Include a subset of Entities from A using a predicate,
    //and all of B, C, D and all of R1 and R3 (but not R2)
    var prefix2 = "a";//prefix can be anything - foo, bar, fred, etc.
    var expr2 = $"{prefix2}.Material = 'Steel' AND " +
                    $"{prefix2}.Role = 'Tier1'";
    var kg_filter2_a = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "A", //Include is default
      PropertyFilterPredicate = expr2
    var kg_filter2_b = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "B" //Include is default
    var kg_filter2_c = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "C" //Include is default
    var kg_filter2_d = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "D" //Include is default
    var kg_filter2_r1 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R1" //Include is default
    var kg_filter2_r3 = new CIMKnowledgeGraphNamedTypeFilterByType()
      NamedType = "R3" //Include is default
    entity_filters2.Add(kg_filter2_a);
    entity_filters2.Add(kg_filter2_b);
    entity_filters2.Add(kg_filter2_c);
    entity_filters2.Add(kg_filter2_d);
    relate_filters2.Add(kg_filter2_r1);
    relate_filters2.Add(kg_filter2_r3);
    kgSubgraph.EntityFilters = entity_filters2.ToArray();
    kgSubgraph.RelationshipFilters = relate_filters2.ToArray();
    //Example 3
    var kg_filter3_b = new CIMKnowledgeGraphNamedTypeFilterByType();
    var kg_filter3_c = new CIMKnowledgeGraphNamedTypeFilterByType();
    kg_filter3_b.NamedType = "B";
    kg_filter3_c.NamedType = "C";
    kg_filter3_b.FilterType = KGFilterType.Exclude;
    kg_filter3_c.FilterType = KGFilterType.Exclude;
    var kg_filter3_d = new CIMKnowledgeGraphNamedTypeFilterByInstances();
    kg_filter3_d.NamedType = "D";
    kg_filter3_d.FilterType = KGFilterType.Exclude;
    kg_filter3_d.InstancesIDs = list_of_ids.ToArray();
    var kg_filter3_r2 = new CIMKnowledgeGraphNamedTypeFilterByType();
    kg_filter3_r2.NamedType = "R2";//Include is default
    var kg_filter3_r3 = new CIMKnowledgeGraphNamedTypeFilterByInstances();
    kg_filter3_r3.NamedType = "R3";//Include is default
    kg_filter3_r3.InstancesIDs = list_of_ids2.ToArray();
    entity_filters3.Add(kg_filter3_b);//order doesn't matter
    entity_filters3.Add(kg_filter3_c);
    entity_filters3.Add(kg_filter3_d);
    relate_filters3.Add(kg_filter3_r2);//order doesn't matter
    relate_filters3.Add(kg_filter3_r3);
    kgSubgraph.EntityFilters = entity_filters3.ToArray();
    kgSubgraph.RelationshipFilters = relate_filters3.ToArray();
Output Centrality Results
    ///var kgConfig = ...;
    //var kgSubgraph = ...;
    //var measures = ...;
    var results = kg.ComputeCentrality(kgConfig, kgSubgraph, measures);
    //loop through each (entity) named type (relates are never included in results)
    foreach (var named_type in results.NamedTypes)
      //Get the entity uids for each named type
      foreach (var uid in results.GetUidsForNamedType(named_type))
        //Get the scores for each uid via the [] indexer on "Scores"
        var scores = results.Scores[uid];
        //There is one score per measure in the input measures array
        //Note: results.Scores.Measures is also provided for convenience...
        //for (int m = 0; m < results.Scores.Measures.Length; m++)
          var score = scores[m];//score for the given measure
                                //TODO - use measure score
Get Max and Min Centrality Result Scores No Sort or LINQ
    //var kgResults = kg.ComputeCentrality(...);
    var count_entities = kgResults.RawUids.Count();
    var score_len = kgResults.Scores.RawScores.Length;
    //Find the max and min score for each measure w/out
    //using LINQ or sorting
    for (int m = 0; m < kgResults.Scores.Measures.Length; m++)
      //index into the scores array for the current measure
      var start_idx = count_entities * m;
      var end_idx = start_idx + count_entities;
      double max_score = double.MinValue;
      double min_score = double.MaxValue;
      List<object> max_uids = new List<object>();
      List<object> min_uids = new List<object>();
      for (int i = 0, s = start_idx; s < end_idx; i++, s++)
        var score = kgResults.Scores.RawScores[s];
        //max
        if (score > max_score)
          max_score = score;
          max_uids.Clear();
          max_uids.Add(kgResults.RawUids[i]);
        else if (score == max_score)
          //Collect all uids with the max score
        //min
        if (score < min_score)
          min_score = score;
          min_uids.Clear();
          min_uids.Add(kgResults.RawUids[i]);
        else if (score == min_score)
          //Collect all uids with the min score
      //TODO - use the max and min scores and uids for
      //the current measure "measures[m]"
      //max_score, max_uids
      //min_score, min_uids
Get Max and Min Centrality Result Scores With Sort and Linq
    //Find the max and min score for each measure using LINQ
      //Get the scores for the specified measure
      var scores = Enumerable.Range(start_idx, count_entities)
        .Select(i => kgResults.Scores.RawScores[i]).ToArray();
      //max + min
      var max_score = scores.Max();
      var min_score = scores.Min();
      //uids with the max score
      var max_uids = Enumerable.Range(0, count_entities)
      .Where(i => scores[i] == max_score)
                       .Select(i => kgResults.RawUids[i])
                       .ToList();
      //uids with the min score
      var min_uids = Enumerable.Range(0, count_entities)
                       .Where(i => scores[i] == min_score)
                       .ToList();
Get Top or Bottom N Centrality Result Scores
  //Note: logic uses the following custom class:
  //public class KG_Score_Value {
  //   public KG_Score_Value(double score, int uid_idx) {
  //      Score = score;
  //      Uid_idx = uid_idx;
  //   public double Score { get; set; }
  //   public int Uid_idx { get; set; }
  int n = 100;
  //Find the top and bottom "n" scores for each measure
    //use "KG_Score_Value" to hold the score and uid index
    var uid_idx = 0;
    var kg_score_vals = Enumerable.Range(start_idx, count_entities)
           .Select(i => new KG_Score_Value(kgResults.Scores.RawScores[i], uid_idx++))
           .OrderByDescending(k => k.Score)
           .ToArray();
    //get up to the top or bottom N scores
    if (n > kg_score_vals.Length)
      n = kg_score_vals.Length;
    //get the top N scores and uids - largest first
    var top_n = kg_score_vals.Take(n).ToList();
    //get the bottom N scores and uids - smallest first
    var bottom_n = kg_score_vals.TakeLast(n)
                      .Reverse().ToList();
    foreach (var kg_score in top_n)
      //TODO - use top "n" scores
      var score = kg_score.Score;
      var uid1 = kgResults.RawUids[kg_score.Uid_idx];
      //...use it
    foreach (var kg_score in bottom_n)
      //TODO - use bottom "n" scores
      //...use it
Get The NamedType for a Given UID in Result Scores
//object uid = "{.... uid value ....}";
  //or
  //object uid = kgResults.RawUids[i]; e.g. in/from a loop
  var named_type = "";
  foreach (var nt in kgResults.NamedTypes)
    var uids = kgResults.GetUidsForNamedType(nt);
    if (uids.Contains(uid))
      named_type = nt;//found it
      break;
  if (string.IsNullOrEmpty(named_type))
    //uid not found in any named type
    //TODO - handle this case
  //TODO - use the named type for the uid
KnowledgeGraph FFP
Run FFP Using Defaults
    var ffp_config = new CIMFilteredFindPathsConfiguration();
    ffp_config.Name = "Run FFP Using Defaults";
    //Origin Entities
    var originEntities = new List<CIMFilteredFindPathsEntity>();
    var poi_entity = new CIMFilteredFindPathsEntity();
    poi_entity.EntityTypeName = "POI";//All entities of entity type "POI"
    poi_entity.PropertyFilterPredicate = "";
    originEntities.Add(poi_entity);
    //Add the CIMFilteredFindPathsEntity to the OriginEntities collection
    ffp_config.OriginEntities = originEntities.ToArray();
    //Destination Entities
    var destEntities = new List<CIMFilteredFindPathsEntity>();
    var supp_entity = new CIMFilteredFindPathsEntity();
    supp_entity.EntityTypeName = "Supplier";//All entities of entity type "Supplier"
    supp_entity.PropertyFilterPredicate = "";
    destEntities.Add(supp_entity);
    //Add the CIMFilteredFindPathsEntity to the DestinationEntities collection
    ffp_config.DestinationEntities = destEntities.ToArray();
    //Path Filters
    ffp_config.PathFilters = [];//Empty
                                //Traversal
    ffp_config.TraversalDirections = [];//Empty
    //Other
    ffp_config.RelationshipCostProperty = "";
    ffp_config.DefaultRelationshipCost = 1.0;
    ffp_config.DefaultTraversalDirectionType = KGTraversalDirectionType.Any;
    ffp_config.EntityUsage = FilteredFindPathsEntityUsage.AnyOriginAnyDestination;
    ffp_config.PathMode = KGPathMode.Shortest;
    ffp_config.MinPathLength = (int)1;//Min number of relationships in path
    ffp_config.MaxPathLength = (int)8;//Max number of relationships in path
    ffp_config.MaxCountPaths = (int)100000;//Total number of paths to return
    ffp_config.ClosedPathPolicy = KGClosedPathPolicy.Forbid;
    ffp_config.TimeFilter = null;
    var results = kg.RunFilteredFindPaths(ffp_config);
    //TODO process/analyze results
Run FFP Using Multiple Entities and Destinations
    ffp_config.Name = "Run FFP w Multiple Entities and Destinations";
    //Origin Entities
    foreach (var entity_name in new List<string> { "Person", "POI", "Supplier", "Plant" })
      var origin_entity = new CIMFilteredFindPathsEntity();
      origin_entity.EntityTypeName = entity_name;
      origin_entity.PropertyFilterPredicate = "";
      originEntities.Add(origin_entity);
    "Supplier", "Plant", "Part", "Customer" })
      var dest_entity = new CIMFilteredFindPathsEntity();
      dest_entity.EntityTypeName = entity_name;
      dest_entity.PropertyFilterPredicate = "";
      destEntities.Add(dest_entity);
    //Path Filters
                                //Traversal
    //Other
Run FFP Using Specific Entities and Destinations by ID
    ffp_config.Name = "Run FFP w Specific Entities and Destinations";
    //Origin Entities
    origin_entity.EntityTypeName = "POI";
    origin_entity.ID = "{EC2A2D91-B09C-4CF6-93A3-51D6527CF51E}";//upper case guid
    origin_entity.PropertyFilterPredicate = "";//Ignored
    var origin_entity2 = new CIMFilteredFindPathsEntity();
    origin_entity2.EntityTypeName = "POI";
    origin_entity2.ID = "{5008792F-3C67-4FCA-B1E9-756D6E389FDD}";//upper case guid
    origin_entity2.PropertyFilterPredicate = "";//Ignored
    originEntities.Add(origin_entity2);
    //etc.
    //Same thing, add specific entities using their Uids
    dest_entity.EntityTypeName = "Supplier";
    dest_entity.ID = "{A3F5C2E1-8D3B-4E2A-9F4B-1C2D3E4F5A6B}";//upper case guid
    var dest_entity2 = new CIMFilteredFindPathsEntity();
    dest_entity2.EntityTypeName = "Supplier";
    dest_entity2.ID = "{B1C2D3E4-F5A6-7B8C-9D0E-1F2A3B4C5D6E}";//upper case guid
    dest_entity2.PropertyFilterPredicate = "";
    destEntities.Add(dest_entity2);
    //etc.
    //TODO - use the config
    //var results = kg.RunFilteredFindPaths(ffp_config);
Run FFP Using PropertyFilterPredicates
    ffp_config.Name = "Run FFP w PropertyFilterPredicates";
    //Origin Entities
    //prefix can be anything - foo, bar, fred, n, x, etc.
    origin_entity.PropertyFilterPredicate = "n.name = 'Robert Johnston'";
    origin_entity2.EntityTypeName = "EnergySource";
    //prefix can be anything - foo, bar, fred, n, x, s, etc.
    origin_entity2.PropertyFilterPredicate = "s.Source_Name = 'natural gas'";
    //etc.
    //Same thing, add specific entities using a PropertyFilterPredicate as needed
    origin_entity.PropertyFilterPredicate = "x.Supplier_Name = 'Supplier 84'";
    //etc.
Run FFP Using Path Filters
    ffp_config.Name = "Run FFP w Path Filters";
    //set origin entities
    //set destination entities
    //set path filters
    var pathFilters = new List<CIMFilteredFindPathsPathFilter>();
    var path_filter = new CIMFilteredFindPathsPathFilter();
    path_filter.ItemTypeName = "POI";
    path_filter.ItemType = KGPathFilterItemType.Entity;
    //To select specific entities, set the ID property or provide a filter predicate
    //path_filter.ID = "{B1C2D3E4-F5A6-7B8C-9D0E-1F2A3B4C5D6E}";//set a specific id
    //...or...use a predicate
    //path_filter.PropertyFilterPredicate = "n.name = 'Robert Johnston'";
    //Use IncludeOnly to only consider entities of this type in the path
    path_filter.FilterType = KGPathFilterType.IncludeOnly;
    //Use Exclude to ignore paths that contain excluded types
    path_filter.FilterType = KGPathFilterType.Exclude;
    //Use MandatoryWaypoint if you have specific entities/entity types through
    //which all paths must pass through at least one entity of this type
    path_filter.FilterType = KGPathFilterType.MandatoryWaypoint;
    //Use OptionalWaypoint if you have specific entities/entity types through
    //which all paths must pass through at least one entity from any of the
    //optional waypoints
    path_filter.FilterType = KGPathFilterType.OptionalWaypoint;
    //Add the path filter(s) to the collection
    pathFilters.Add(path_filter);
    //Add more filters as needed
    //"Person", "Supplier", "Plant", etc.
    //Path Filters
    ffp_config.PathFilters = pathFilters.ToArray();
Run FFP Using Traversal Filters
    ffp_config.Name = "Run FFP w Traversal Filters";
    //set any path filters
    //Set traversal filters
    //A traversal filter is used to specify the traversal direction of a relationship (to be)
    //included in the result paths. By default, paths are evaluated without considering the
    //direction of relationships in the graph - i.e. KGTraversalDirectionType.Any.
    //Relationships can be evaluated in specific directions by changing the KGTraversalDirectionType
    //enum value of the traversal_filter.TraversalDirectionType.
    //For example, the traversal direction is being set for the following relationship types...
    var traversalFilters = new List<CIMKGTraversalDirection>();
    foreach (var relation in new List<string> { "near_poi", "near_facility", "near_facility2" })
      var traversal_filter = new CIMKGTraversalDirection();
      traversal_filter.RelationshipTypeName = relation;
      //All relationships of the specified type are considered (default)
      traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Any;
      //Relationship can only be traversed from origin to destination
      traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Forward;
      //Relationship can only be traversed from destination to origin
      traversal_filter.TraversalDirectionType = KGTraversalDirectionType.Backward;
      traversalFilters.Add(traversal_filter);
    ffp_config.TraversalDirections = traversalFilters.ToArray();
    //etc.
  await QueuedTask.Run(async () =>
    ffp_config.Name = "Create Link Chart from FFP Results";
    //set up config
    var pathsEntitiesAndRelationships = results.ExtractPathsEntitiesAndRelationships(null);
    //Create a KG layer id set
    var kgLayerIdSet = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
      pathsEntitiesAndRelationships.ToKnowledgeGraphIDSet(
        KGResultContentFromFFP.EntitiesAndRelationships));
    //Create a brand new link chart with the results and show it
    var linkChart = MapFactory.Instance.CreateLinkChart("KG Intro", kg, kgLayerIdSet);
    var mapPane = await FrameworkApplication.Panes.CreateMapPaneAsync(linkChart);
    var linkChartView = mapPane.MapView;
    //Change layout algo to match the default used by the UI after FFP
    await linkChartView.SetLinkChartLayoutAsync(
      KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom);
    //Set root nodes - they correspond to the origin nodes of the result paths
    var kgLayerIdSetForRootNodes = KnowledgeGraphLayerIDSet.FromKnowledgeGraphIDSet(
        KGResultContentFromFFP.OnlyPathsOriginEntities));
    //To correctly identify the ids in the link chart we must change the ids
    //from Geodatabase oids returned in the KnowledgeGraphLayerIDSet to the
    //temporary/synthetic oids used by layers in the link chart...
    var kg_layer = linkChart.GetLayersAsFlattenedList().OfType<KnowledgeGraphLayer>().First();
    var mapMembers = kg_layer.GetMapMembersAsFlattenedList();
    var oidDict = kgLayerIdSetForRootNodes.ToOIDDictionary();
    var mmDict = new Dictionary<MapMember, List<long>>();
    foreach (var kvp in oidDict)
      var named_type = kvp.Key;
      foreach (var mm in mapMembers)
        if (mm is LinkChartFeatureLayer fl_lc && fl_lc.IsEntity)
          if (fl_lc.GetTypeName().ToLower() == named_type.ToLower())
            var lc_oids = new List<long>();
            //these oids are from the geodatabase
            var oid_field = $"{fl_lc.GetTypeName()}.objectid";
            var id_list = string.Join(',', kvp.Value.ToArray());
            var where = $"{fl_lc.GetTypeName()}.objectid IN ({id_list})";
            var qf = new ArcGIS.Core.Data.QueryFilter()
              WhereClause = where,
              SubFields = $"LC.OID,{oid_field}"//the 'LC.OID' oids are the ones
                                               //we need for the mapmember id set
                                               //in the link chart
            var rc = fl_lc.Search(qf);
            var oid_idx = rc.FindField(oid_field);
            while (rc.MoveNext())
              var oid = (long)rc.Current[oid_idx];
              var lc_oid = rc.Current.GetObjectID();
              lc_oids.Add(lc_oid);
            rc.Dispose();
            mmDict[fl_lc] = lc_oids;
            break;
    var mmIdSet = MapMemberIDSet.FromDictionary(mmDict);
    linkChartView.SetRootNodes(mmIdSet);
  var linkChartView = MapView.Active;
    ffp_config.Name = "Append to Link Chart from FFP Results";
    //set up config
    var map = linkChartView.Map;
    if (!map.CanAppendToLinkChart(kgLayerIdSet))
      return;//not compatible
    map.AppendToLinkChart(kgLayerIdSet);
    //switch layout algo
    var algo = linkChartView.GetLinkChartLayout();
    if (algo != KnowledgeLinkChartLayoutAlgorithm.Hierarchical_TopToBottom)
    //To set link chart root nodes see 'Create Link Chart from FFP Results'
List out FFP Results by Path Length, Min Cost, Max Cost
    ffp_config.Name = "List out FFP Results by Path Length, Min Cost, Max Cost";
    //set up config
    if (results.CountPaths == 0)
      System.Diagnostics.Debug.WriteLine("FFP returned no paths");
      return;
    //print out paths by increasing length, min cost, max cost
    var path_by_len_indices = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingPathLength
                                .Select(idx => idx.index);
    var path_by_min_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMinPathCost
    var path_by_max_cost = (IEnumerable<long>)results.PathIndicesOrderedByIncreasingMaxPathCost
    var x = 0;
    foreach (var path_indeces in new List<IEnumerable<long>> {
    path_by_len_indices,
    path_by_min_cost,
    path_by_max_cost})
      if (x == 0)
        sb.AppendLine($"Paths by length: {path_by_len_indices.Count()}");
      else if (x == 1)
        sb.AppendLine($"Paths by min cost: {path_by_min_cost.Count()}");
      else if (x == 2)
        sb.AppendLine($"Paths by max cost: {path_by_max_cost.Count()}");
      x++;
      foreach (var path_idx in path_indeces)
        var path = (ResultPath)results.MaterializePath(path_idx);
        sb.AppendLine(
          $"Path[{path_idx}] length: {path.Length}, min: {path.MinCost} max: {path.MaxCost}");
        var g = 0;
        foreach (var rel_group in path.RelationshipGroups)
          var first_entity = $"({rel_group.FirstEntity.TypeName}:{rel_group.FirstEntity.Uid})";
          var second_entity = $"({rel_group.SecondEntity.TypeName}:{rel_group.SecondEntity.Uid})";
          foreach (var relation in rel_group.Relationships)
            sb.Append($"  [{g++}] ");
            var arrow = relation.SameDirectionAsPath ? "->" : "<-";
            var rel_uid = FormatUID(relation.Relationship.Uid.ToString());
            sb.Append($"{first_entity} '\r\n\t{relation.Relationship.TypeName}:{rel_uid}' {arrow}\r\n" +
              $"\t\t{second_entity}");
            sb.Append($" cost: {relation.Relationship.Cost}\r\n");
string FormatUID(string id)
  id = id.ToUpperInvariant();
  if (!id.StartsWith('{'))
    id = '{' + id;
  if (!id.EndsWith('}'))
    id += '}';
  return id;
List out FFP Results Origin, Destination, Other Entities
    ffp_config.Name = "List out FFP Results Origin, Destination, Other Entities";
    //set up config
      return;
    var x = 0;
    path_by_min_cost,
    path_by_max_cost})
      if (x == 0)
        sb.AppendLine($"Entities by length: {path_by_len_indices.Count()}");
      else if (x == 1)
        sb.AppendLine($"Entities by min cost: {path_by_min_cost.Count()}");
      else if (x == 2)
        sb.AppendLine($"Entities by max cost: {path_by_max_cost.Count()}");
      x++;
        sb.AppendLine(
        var sorted_set = new SortedSet<ulong>();
        sorted_set.Add((ulong)path_idx);
        var per = results.ExtractPathsEntitiesAndRelationships(sorted_set);
        var origin_dest_uids = new List<string>();
        var sep = "";
        sb.Append(" Origin EntitiesUIDs: ");
        foreach (var idx in per.PathsOriginEntitiesUIDsIndexes)
          //See 'List out FFP Results by Path Length, Min Cost, Max Cost' for
          //FormatID method above
          var uid = FormatID(per.EntitiesUIDs[idx].ToString());
          origin_dest_uids.Add(uid);
          var origin =
            $"{sep}{per.EntityTypeNames[per.EntityTypes[idx]]}:{uid}";
          sep = ", ";
          sb.Append($"{origin}");
        sb.AppendLine("");
        sep = "";
        sb.Append(" Destination EntitiesUIDs: ");
        foreach (var idx in per.PathsDestinationEntitiesUIDsIndexes)
          var dest =
          sep = ", ";
          sb.Append($"{dest}");
        sb.AppendLine("");
        sep = "";
        var idx2 = 0;
        sb.Append(" Other EntitiesUIDs: ");
        bool wereAnyOthers = false;
        foreach (var raw_uid in per.EntitiesUIDs)
          var uid = FormatID(raw_uid.ToString());
          if (!origin_dest_uids.Contains(uid))
            var other =
            $"{sep}{per.EntityTypeNames[per.EntityTypes[idx2]]}:{uid}";
            sep = ", ";
            sb.Append($"{other}");
            wereAnyOthers = true;
          idx2++;
        if (!wereAnyOthers)
          sb.Append(" <<none>>");
        //sb.AppendLine("");
        var entity_str = sb.ToString();
        System.Diagnostics.Debug.WriteLine(entity_str);
        sb.Clear();
        sep = "";
List out FFP Results Relationships
    ffp_config.Name = "List out FFP Results Relationships";
    //set up config
      return;
    var x = 0;
    path_by_min_cost,
    path_by_max_cost})
      if (x == 0)
        sb.AppendLine($"Relationships by length: {path_by_len_indices.Count()}");
      else if (x == 1)
        sb.AppendLine($"Relationships by min cost: {path_by_min_cost.Count()}");
      else if (x == 2)
        sb.AppendLine($"Relationships by max cost: {path_by_max_cost.Count()}");
      x++;
        sb.AppendLine(
        var idx = 0;
        foreach (var rel_uid in per.RelationshipsUIDs)
          sb.Append($" RelationshipsUIDs[{idx}]: ");
          var uid = FormatID(rel_uid.ToString());
          var rel_info =
            $"{per.RelationshipTypeNames[per.RelationshipTypes[idx]]}:{uid}";
          sb.Append($"{rel_info}\r\n");
          //From entity:
          var entity_idx = per.RelationshipsFrom[idx];
          var origin_uid = FormatID(per.EntitiesUIDs[entity_idx].ToString());
          var origin = $"{per.EntityTypeNames[per.EntityTypes[entity_idx]]}:{origin_uid}";
          sb.Append($"   RelationshipsFrom: {origin}\r\n");
          //To entity
          entity_idx = per.RelationshipsTo[idx];
          var dest_uid = FormatID(per.EntitiesUIDs[entity_idx].ToString());
          var dest = $"{per.EntityTypeNames[per.EntityTypes[entity_idx]]}:{dest_uid}";
          sb.Append($"   RelationshipsTo: {dest}\r\n");
          idx++;
        var rel_str = sb.ToString();
        System.Diagnostics.Debug.WriteLine(rel_str);
        sb.Clear();
string FormatID(string id)
    id = '{' + id;
    id += '}';
  return id;
