Get the active map's labeling engine - Maplex or Standard labeling engine
// Note: call within QueuedTask.Run()
//Get the active map's definition - CIMMap.
var cimMap = MapView.Active.Map.GetDefinition();
//Get the labeling engine from the map definition
CIMGeneralPlacementProperties labelEngine = cimMap.GeneralPlacementProperties;
Change the active map's labeling engine from Standard to Maplex or vice versa
var cimGeneralPlacement = cimMap.GeneralPlacementProperties;
if (cimGeneralPlacement is CIMMaplexGeneralPlacementProperties)
//Current labeling engine is Maplex labeling engine
//Create a new standard label engine properties
var cimStandardPlacementProperties = new CIMStandardGeneralPlacementProperties();
//Set the CIMMap's GeneralPlacementProperties to the new label engine
cimMap.GeneralPlacementProperties = cimStandardPlacementProperties;
else
//Current labeling engine is Standard labeling engine
//Create a new Maplex label engine properties
var cimMaplexGeneralPlacementProperties = new CIMMaplexGeneralPlacementProperties();
cimMap.GeneralPlacementProperties = cimMaplexGeneralPlacementProperties;
//Set the map's definition
MapView.Active.Map.SetDefinition(cimMap);
Apply text symbol to a feature layer
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Set the label classes' symbol to the custom text symbol
//Refer to the ProSnippets-TextSymbols wiki page for help with creating custom text symbols.
//Example: var textSymbol = await CreateTextSymbolWithHaloAsync();
theLabelClass.TextSymbol.Symbol = textSymbol;
lyrDefn.LabelClasses = listLabelClasses.ToArray(); //Set the labelClasses back
featureLayer.SetDefinition(lyrDefn); //set the layer's definition
//set the label's visibility
featureLayer.SetLabelVisibility(true);
Enable labeling of a layer
if (!featureLayer.IsLabelVisible)
Modify the Placement/Position of labels - Point geometry
//Modify label Placement
//Check if the label engine is Maplex or standard.
MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
if (labelEngine is CIMStandardGeneralPlacementProperties) //Current labeling engine is Standard labeling engine
theLabelClass.StandardLabelPlacementProperties.PointPlacementMethod =
StandardPointPlacementMethod.OnTopPoint;
else //Current labeling engine is Maplex labeling engine
theLabelClass.MaplexLabelPlacementProperties.PointPlacementMethod =
MaplexPointPlacementMethod.CenteredOnPoint;
Modify the Placement/Position of labels - Line geometry
var lineLablePosition = new CIMStandardLineLabelPosition
Perpendicular = true,
Parallel = false,
ProduceCurvedLabels = false,
Horizontal = false,
OnTop = true
theLabelClass.StandardLabelPlacementProperties.LineLabelPosition =
lineLablePosition;
theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod =
MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
theLabelClass.MaplexLabelPlacementProperties.LineFeatureType =
MaplexLineFeatureType.General;
//theLabelClass.MaplexLabelPlacementProperties.LinePlacementMethod = MaplexLinePlacementMethod.CenteredPerpendicularOnLine;
Modify the Placement/Position of labels - Polygon geometry
CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
//Current labeling engine is Standard Labeling engine
theLabelClass.StandardLabelPlacementProperties.PolygonPlacementMethod =
StandardPolygonPlacementMethod.AlwaysHorizontal;
theLabelClass.StandardLabelPlacementProperties.PlaceOnlyInsidePolygon = true;
else
theLabelClass.MaplexLabelPlacementProperties.PolygonFeatureType =
MaplexPolygonFeatureType.LandParcel;
theLabelClass.MaplexLabelPlacementProperties.AvoidPolygonHoles = true;
theLabelClass.MaplexLabelPlacementProperties.PolygonPlacementMethod =
MaplexPolygonPlacementMethod.HorizontalInPolygon;
theLabelClass.MaplexLabelPlacementProperties.CanPlaceLabelOutsidePolygon = true;
//set the label's visiblity
Modify Orientation of a label using the MaplexEngine - Points and Polygon geometry
return;
//Modify label Orientation
theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignment = true;
theLabelClass.MaplexLabelPlacementProperties.GraticuleAlignmentType = MaplexGraticuleAlignmentType.Curved;
Modify Orientation of a label using the MaplexEngine - Line geometry
return;
theLabelClass.MaplexLabelPlacementProperties.AlignLabelToLineDirection = true;
Modify label Rotation - Point geometry
return;
//Modify label Rotation
CIMMaplexRotationProperties rotationProperties = new CIMMaplexRotationProperties
Enable = true, //Enable rotation
RotationField = "ELEVATION", //Field that is used to define rotation angle
AdditionalAngle = 15, //Additional rotation
RotationType = MaplexLabelRotationType.Arithmetic,
AlignmentType = MaplexRotationAlignmentType.Perpendicular,
AlignLabelToAngle = true
theLabelClass.MaplexLabelPlacementProperties.RotationProperties = rotationProperties;
Spread labels across Polygon geometry
return;
//Spread Labels (words and characters to fill feature)
// Spread words to fill feature
theLabelClass.MaplexLabelPlacementProperties.SpreadWords = true;
//Spread Characters to a fixed limit of 50%
theLabelClass.MaplexLabelPlacementProperties.SpreadCharacters = true;
theLabelClass.MaplexLabelPlacementProperties.MaximumCharacterSpacing = 50.0;
Modify label's Leader Line Anchor point properties - Polygon geometry
return;
//If TextSymbol is a call-out the leader line anchor point can be modified
theLabelClass.MaplexLabelPlacementProperties.PolygonAnchorPointType = MaplexAnchorPointType.Perimeter;
lyrDefn.LabelClasses = [.. listLabelClasses]; //Set the labelClasses back
