ProSnippets Layouts
Language:              C#
Subject:               Layouts
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Layout Project Items
Create an IProjectItem from a layout template pagx file and add it to the project
var templateFileName = "Layout.pagx";
  // Get layout Template Path from the project's home folder and combine it with a file name
  var projectPath = CoreModule.CurrentProject.HomeFolderPath;
  var layoutTemplateFilePath = System.IO.Path.Combine(projectPath, templateFileName);
  // Create a new layout project item with the layout file path
  // Create an IProjectItem using a layout template pagx file
  IProjectItem pagx = ItemFactory.Instance.Create(layoutTemplateFilePath) as IProjectItem;
  // Add the IProjectItem to the current project
  //Note: Needs QueuedTask to run
  Project.Current.AddItem(pagx);
Get a Layout by name from the current project
LayoutProjectItem layoutItemByName = Project.Current.GetItems<LayoutProjectItem>()
    .FirstOrDefault((lpi) => lpi.Name == "MyLayout");
  Layout layoutByName = layoutItemByName.GetLayout();
Reference layout project items and their associated layout
//Reference layout project items and their associated layout.
  //A layout project item is an item that appears in the Layouts
  //folder in the Catalog pane.
  //Reference all the layout project items
  IEnumerable<LayoutProjectItem> layoutProjectItems =
                       Project.Current.GetItems<LayoutProjectItem>();
  //Or reference a specific layout project item by name
  LayoutProjectItem specificLayoutItem = Project.Current.GetItems<LayoutProjectItem>()
                             .FirstOrDefault(item => item.Name.Equals("MyLayoutItem"));
Open a layout project item in a new view
//Open a layout project item in a new view.
  //A layout project item may exist but it may not be open in a view.
  //Reference a layout project item by name
  //Get the layout associated with the layout project item
  Layout layoutFromItem = layoutItemByName.GetLayout();  //Worker thread
  //Create the new pane - call on UI
  ILayoutPane iNewLayoutPane = await ProApp.Panes.CreateLayoutPaneAsync(layout); //GUI thread
Activate an already open layout view
//Activate an already open layout view.
  //A layout view may be open but it may not be active.
  //Find the pane that references the layout and activate it.
  //Note - there can be multiple panes referencing the same layout.
  foreach (var pane in ProApp.Panes)
    var layoutPane = pane as ILayoutPane;
    if (layoutPane == null)  //if not a layout view, continue to the next pane
      continue;
    if (layoutPane.LayoutView.Layout == layout) //activate the view
      (layoutPane as Pane).Activate();
      return;
Reference the active layout view
//Reference the active layout view.
  //Confirm if the current, active view is a layout view.
  //If it is, do something.
  LayoutView activeLayoutView = LayoutView.Active;
  if (activeLayoutView != null)
    // do something
Import a pagx into a project
//Create a layout project item from importing a pagx file
                            @"C:\Temp\Layout.pagx") as IProjectItem;
Remove a layout project item
//Remove a layout project item.
  //Remove the layout from the project
  Project.Current.RemoveItem(layoutItem);
Create a new, basic layout and open it
//Create a new, basic layout and open it.
  //Create layout with minimum set of parameters on the worker thread
  var myNewLayout = LayoutFactory.Instance.CreateLayout(8.5, 11, LinearUnit.Inches);
  myNewLayout.SetName("New 8.5x11 Layout");
  //Open new layout on the GUI thread
  await ProApp.Panes.CreateLayoutPaneAsync(myNewLayout);
Create a new layout using a modified CIM and open it
//Create a new layout using a modified CIM and open it.
  //The CIM exposes additional members that may not be
  //available through the managed API.
  //In this example, optional guides are added.
  //Create a new CIMLayout on the worker thread
  //Set up a CIM page
  CIMPage newPage = new CIMPage
    //required parameters
    Width = 8.5,
    Height = 11,
    Units = LinearUnit.Inches,
    //optional rulers
    ShowRulers = true,
    SmallestRulerDivision = 0.5,
    //optional guides
    ShowGuides = true
  CIMGuide guide1 = new CIMGuide
    Position = 1,
    Orientation = Orientation.Vertical
  CIMGuide guide2 = new CIMGuide
    Position = 6.5,
  CIMGuide guide3 = new CIMGuide
    Position = 1,
    Orientation = Orientation.Horizontal
  CIMGuide guide4 = new CIMGuide
    Position = 10,
  List<CIMGuide> guideList = new List<CIMGuide>
    guide1,
    guide2,
    guide3,
    guide4
  newPage.Guides = guideList.ToArray();
  //Construct the new layout using the customized cim definitions
  var layout_local = LayoutFactory.Instance.CreateLayout(newPage);
  layout_local.SetName("New 8.5x11 Layout");
  await ProApp.Panes.CreateLayoutPaneAsync(layout_local);
Change the layout page size
//Change the layout page size.
  //Reference the layout project item
  LayoutProjectItem lytItem = Project.Current.GetItems<LayoutProjectItem>()
  if (layoutItem != null)
    //Get the layout
    Layout lyt = lytItem.GetLayout();
    if (lyt != null)
      //Change properties
      CIMPage page = lyt.GetPage();
      page.Width = 8.5;
      page.Height = 11;
      //Apply the changes to the layout
      lyt.SetPage(page);
CIM Graphics and GraphicFactory
Create Circle Graphic
//Note: Must be on QueuedTask.Run
  //Build geometry
  Coordinate2D center = new Coordinate2D(2, 4);
  EllipticArcSegment circle_seg = EllipticArcBuilderEx.CreateCircle(
    new Coordinate2D(2, 4), 0.5, ArcOrientation.ArcClockwise, null);
  var circle_poly = PolygonBuilderEx.CreatePolygon(PolylineBuilderEx.CreatePolyline(circle_seg));
  //PolylineBuilderEx.CreatePolyline(cir, AttributeFlags.AllAttributes));
  //Set symbology, create and add element to layout
  CIMStroke outline = SymbolFactory.Instance.ConstructStroke(
    ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Dash);
  CIMPolygonSymbol circleSym = SymbolFactory.Instance.ConstructPolygonSymbol(
    ColorFactory.Instance.RedRGB, SimpleFillStyle.Solid, outline);
  SymbolFactory.Instance.ConstructPolygonSymbol(null,
    SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2));
  var circleGraphic = GraphicFactory.Instance.CreateSimpleGraphic(circle_poly, circleSym);
  //Make an element to add to GraphicsLayer or Layout
  //var elemInfo = new ElementInfo() { Anchor = Anchor.CenterPoint };
  //GraphicElement cirElm = ElementFactory.Instance.CreateGraphicElement(
  //  layout, circleGraphic, "New Circle", true, elemInfo);
Create Circle Text Graphic
  //Build geometry
  Coordinate2D center = new Coordinate2D(4.5, 4);
  var eabCir = new EllipticArcBuilderEx(center, 0.5, ArcOrientation.ArcClockwise);
  var cir = eabCir.ToSegment();
  var poly = PolygonBuilderEx.CreatePolygon(
  CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
    ColorFactory.Instance.GreenRGB, 10, "Arial", "Regular");
  string text = "Circle, circle, circle";
  var graphic = GraphicFactory.Instance.CreateSimpleTextGraphic(
    TextType.CircleParagraph, poly, sym, text);
  //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic,
  //  "New Circle Text", true);
Create Bezier Graphic
  //Build geometry
  Coordinate2D pt1 = new Coordinate2D(3.5, 7.5);
  Coordinate2D pt2 = new Coordinate2D(4.16, 8);
  Coordinate2D pt3 = new Coordinate2D(4.83, 7.1);
  Coordinate2D pt4 = new Coordinate2D(5.5, 7.5);
  var bez = new CubicBezierBuilderEx(pt1, pt2, pt3, pt4);
  var bezSeg = bez.ToSegment();
  Polyline bezPl = PolylineBuilderEx.CreatePolyline(bezSeg, AttributeFlags.AllAttributes);
        ColorFactory.Instance.BlackRGB, 24, "Comic Sans MS", "Regular");
    TextType.SplinedText, bezPl, sym, "Splined text");
  //var ge = ElementFactory.Instance.CreateGraphicElement(layout, graphic);
Create Legend Patch Graphic
  //Build geometry
  List<Coordinate2D> plyCoords = new List<Coordinate2D>();
  plyCoords.Add(new Coordinate2D(1, 1));
  plyCoords.Add(new Coordinate2D(1.25, 2));
  plyCoords.Add(new Coordinate2D(1.5, 1.1));
  plyCoords.Add(new Coordinate2D(1.75, 2));
  plyCoords.Add(new Coordinate2D(2, 1.1));
  plyCoords.Add(new Coordinate2D(2.25, 2));
  plyCoords.Add(new Coordinate2D(2.5, 1.1));
  plyCoords.Add(new Coordinate2D(2.75, 2));
  plyCoords.Add(new Coordinate2D(3, 1));
  Polygon poly = PolygonBuilderEx.CreatePolygon(plyCoords);
            ColorFactory.Instance.BlackRGB, 2.0, SimpleLineStyle.Solid);
  CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
            ColorFactory.Instance.RedRGB, SimpleFillStyle.ForwardDiagonal, outline);
  var graphic = GraphicFactory.Instance.CreateLegendPatchGraphic(
              PatchShape.AreaBoundary, poly.Extent, polySym);
  //  CustomProperties = null,
  //  Anchor = Anchor.LeftMidPoint
  //  "New Legend Patch", true, elemInfo);
Create Arrow Graphic
  //Build geometry
  List<Coordinate2D> plCoords = new List<Coordinate2D>();
  plCoords.Add(new Coordinate2D(1, 8.5));
  plCoords.Add(new Coordinate2D(1.66, 9));
  plCoords.Add(new Coordinate2D(2.33, 8.1));
  plCoords.Add(new Coordinate2D(3, 8.5));
  Polyline linePl = PolylineBuilderEx.CreatePolyline(plCoords);
  //Set up the arrow info
  var arrowInfo = new ArrowInfo()
    ArrowHeadKey = ArrowInfo.DefaultArrowHeadKeys[1],
    ArrowOnBothEnds = true,
    ArrowSizePoints = 30,
    LineWidthPoints = 15
  var graphic = GraphicFactory.Instance.CreateArrowGraphic(linePl, arrowInfo);
  //  layout, graphic, "Arrow Line", false);
Create Picture Graphic
  //Build geometry
  Coordinate2D ll = new Coordinate2D(3.5, 1);
  Coordinate2D ur = new Coordinate2D(5.5, 2);
  Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
  string picPath = System.IO.Path.Combine(
  Environment.GetFolderPath(Environment.SpecialFolder.MyPictures), "SamplePicture.jpg");
  //Create and add element to layout
  var graphic = GraphicFactory.Instance.CreatePictureGraphic(env.Center, picPath);
Get Graphic Outline
//given a graphic, extract its outline geometry
  var graphic_outline = GraphicFactory.Instance.GetGraphicOutline(
                        layout, cimGraphic);
  //TODO - use the geometry - eg, make another graphic
  var outline_graphic = GraphicFactory.Instance.CreateSimpleGraphic(graphic_outline);
  //... etc.
Get Graphic Outline from Graphic Element
  var graphic_elem = layout.GetElementsAsFlattenedList().OfType<GraphicElement>()?.FirstOrDefault();
  if (graphic_elem != null)//can be point, line, poly, or text
    return;
  var outline = GraphicFactory.Instance.GetGraphicOutline(layout, graphic_elem.GetGraphic());
  //create an element using the outline
  var elem = ElementFactory.Instance.CreateGraphicElement(layout, outline);
  //... etc.
Create Layout Graphic Elements
Create Ellipse Graphic Element
  //Build geometry
  Coordinate2D center = new Coordinate2D(2, 2.75);
  var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45,
  var ellipse = eabElp.ToSegment();
                                  ColorFactory.Instance.GreenRGB, 2.0,
                          SimpleLineStyle.Dot);
  CIMPolygonSymbol ellipseSym = SymbolFactory.Instance.ConstructPolygonSymbol(
                            ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical,
                                                    outline);
    PolylineBuilderEx.CreatePolyline(ellipse, AttributeFlags.AllAttributes));
  var elpElm = ElementFactory.Instance.CreateGraphicElement(
    layout, poly, ellipseSym, "New Ellipse");
Create Lasso Line, Freehand Graphic Element
  //Build geometry
  plCoords.Add(new Coordinate2D(1.5, 10.5));
  plCoords.Add(new Coordinate2D(1.25, 9.5));
  plCoords.Add(new Coordinate2D(1, 10.5));
  plCoords.Add(new Coordinate2D(0.75, 9.5));
  plCoords.Add(new Coordinate2D(0.5, 10.5));
  plCoords.Add(new Coordinate2D(0.5, 1));
  plCoords.Add(new Coordinate2D(0.75, 2));
  plCoords.Add(new Coordinate2D(1, 1));
  CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(
  //var graphic = GraphicFactory.Instance.CreateShapeGraphic(linePl, lineSym);
                          layout, linePl, lineSym, "New Freehand");
Create Lasso Polygon, Freehand Element
    layout, poly, polySym, "New Lasso");
Create Line Element
  //Build geometry
  //Reference a line symbol in a style
  var ProjectStyles = Project.Current.GetItems<StyleProjectItem>();
  StyleProjectItem style = ProjectStyles.First(x => x.Name == "ArcGIS 2D");
  var symStyle = style.SearchSymbols(StyleItemType.LineSymbol, "Line with 2 Markers")[0];
  CIMLineSymbol lineSym = symStyle.Symbol as CIMLineSymbol;
  lineSym.SetSize(20);
  //CIMLineSymbol lineSym = SymbolFactory.Instance.ConstructLineSymbol(ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
    layout, linePl, lineSym, "New Line");
Create Point Element
//Note: Must be on QueuedTask.Run(() => { ...
  //Build geometry
  Coordinate2D coord2D = new Coordinate2D(2.0, 10.0);
  //Reference a point symbol in a style
  StyleProjectItem stylePrjItm = Project.Current.GetItems<StyleProjectItem>()
            .FirstOrDefault(item => item.Name == "ArcGIS 2D");
  SymbolStyleItem symStyleItm = stylePrjItm.SearchSymbols(
                        StyleItemType.PointSymbol, "City Hall")[0];
  CIMPointSymbol pointSym = symStyleItm.Symbol as CIMPointSymbol;
  pointSym.SetSize(50);
    CustomProperties = new List<CIMStringMap>() {
    new CIMStringMap() { Key = "Key1", Value = "Value1"},
    new CIMStringMap() { Key = "Key2", Value = "Value2"}
    Anchor = Anchor.TopRightCorner,
    Rotation = 45.0
  var graphic = GraphicFactory.Instance.CreateSimpleGraphic(
                                coord2D.ToMapPoint(), pointSym);
    layout, graphic, "New Point", true, elemInfo);
Create Polygon Element
  //Build geometry
  plyCoords.Add(new Coordinate2D(1, 7));
  plyCoords.Add(new Coordinate2D(2, 7));
  plyCoords.Add(new Coordinate2D(2, 6.7));
  plyCoords.Add(new Coordinate2D(3, 6.7));
  plyCoords.Add(new Coordinate2D(3, 6.1));
  plyCoords.Add(new Coordinate2D(1, 6.1));
    ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.DashDotDot);
    layout, poly, polySym, "New Polygon", false);
Create Rectangle Element
  //Build geometry
  Coordinate2D ll = new Coordinate2D(1.0, 4.75);
  Coordinate2D ur = new Coordinate2D(3.0, 5.75);
    ColorFactory.Instance.BlackRGB, 5.0, SimpleLineStyle.Solid);
    ColorFactory.Instance.GreenRGB, SimpleFillStyle.DiagonalCross, outline);
  var ge = GraphicFactory.Instance.CreateSimpleGraphic(env, polySym);
    Anchor = Anchor.CenterPoint,
    Rotation = 45.0,
    CornerRounding = 5.0
    layout, env, polySym, "New Rectangle", false, elemInfo);
Create Bezier Curve Element
  //Build geometry
  Coordinate2D pt1 = new Coordinate2D(1, 7.5);
  Coordinate2D pt2 = new Coordinate2D(1.66, 8);
  Coordinate2D pt3 = new Coordinate2D(2.33, 7.1);
  Coordinate2D pt4 = new Coordinate2D(3, 7.5);
    ColorFactory.Instance.RedRGB, 4.0, SimpleLineStyle.DashDot);
  ElementFactory.Instance.CreateGraphicElement(layout, bezPl, lineSym, "New Bezier");
Create Graphic Elements
//Note:Must be on QueuedTask.Run
  //Build geometry
  //Build geometry
  //Build geometry
  var g1 = GraphicFactory.Instance.CreateSimpleGraphic(poly);
  var g2 = GraphicFactory.Instance.CreateSimpleGraphic(env);
  var g3 = GraphicFactory.Instance.CreateSimpleGraphic(coord2D.ToMapPoint());
  var ge = ElementFactory.Instance.CreateGraphicElements(
    layout, new List<CIMGraphic>() { g1, g2, g3 },
    new List<string>() { "Poly", "Envelope", "MapPoint" },
    true);
Create Graphic Element using CIMGraphic
//Note: on the QueuedTask
  //Place symbol on the layout
  MapPoint location = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
  //specify a symbol
  var pt_symbol = SymbolFactory.Instance.ConstructPointSymbol(
                        ColorFactory.Instance.GreenRGB);
  //create a CIMGraphic
  var graphic = new CIMPointGraphic()
    Symbol = pt_symbol.MakeSymbolReference(),
    Location = location //center of map
  //Or use GraphicFactory
  var graphicFactory = GraphicFactory.Instance.CreateSimpleGraphic(location, pt_symbol);
  ElementFactory.Instance.CreateGraphicElement(layout, graphicFactory);
Create Graphic Element using CIMSymbol
  //specify a symbol
  ElementFactory.Instance.CreateGraphicElement(layout, location, pt_symbol);
Bulk Element creation
  //List of Point graphics
  var listGraphics = new List<CIMPointGraphic>();
  var listGraphicsFactory = new List<CIMPointGraphic>();
  //Symbol
  var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(
                                      ColorFactory.Instance.BlackRGB);
  //Define size of the array
  int dx = 5;
  int dy = 5;
  MapPoint point = null;
  //Create the List of graphics for the array
  for (int row = 0; row <= dx; ++row)
    for (int col = 0; col <= dy; ++col)
      point = MapPointBuilderEx.CreateMapPoint(col, row);
        Symbol = pointSymbol.MakeSymbolReference(),
        Location = point
      listGraphics.Add(graphic);
                                    point, pointSymbol) as CIMPointGraphic;
      listGraphicsFactory.Add(graphicFactory);
  //Draw the array of graphics
  var bulkgraphics = ElementFactory.Instance.CreateGraphicElements(
                                                     layout, listGraphics);
  var bulkgraphicsFactory = ElementFactory.Instance.CreateGraphicElements(
                                                     layout, listGraphicsFactory);
Create Element using a CIMGraphicElement
  MapPoint point = MapPointBuilderEx.CreateMapPoint(new Coordinate2D(9, 1));
  //specify a symbol
  var graphic = new CIMGraphicElement()
    Graphic = new CIMPointGraphic()
      Location = point //A point in the layout
  ElementFactory.Instance.CreateElement(layout, graphic);
Create point graphic with symbology
//Create a simple 2D point graphic and apply an existing point style item as the symbology.
  //Build 2D point geometry
  //(optionally) Reference a point symbol in a style
  StyleProjectItem ptStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
  SymbolStyleItem ptSymStyleItm = ptStylePrjItm.SearchSymbols(
  CIMPointSymbol pointSym = ptSymStyleItm.Symbol as CIMPointSymbol;
  //An alternative simple symbol is also commented out below.
  //This would eliminate the four optional lines of code above that
  //reference a style.
  //CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
  //                  ColorFactory.Instance.RedRGB, 25.0, SimpleMarkerStyle.Star);
  GraphicElement ptElm = ElementFactory.Instance.CreateGraphicElement(
                                 layout, coord2D.ToMapPoint(), pointSym);
  ptElm.SetName("New Point");
Create line graphic with symbology
//Create a simple 2D line graphic and apply an existing line
  //style item as the symbology.
  //Build 2d line geometry
  //(optionally) Reference a line symbol in a style
  StyleProjectItem lnStylePrjItm = Project.Current.GetItems<StyleProjectItem>()
  SymbolStyleItem lnSymStyleItm = lnStylePrjItm.SearchSymbols(
  CIMLineSymbol lineSym = lnSymStyleItm.Symbol as CIMLineSymbol;
  //         ColorFactory.Instance.BlueRGB, 4.0, SimpleLineStyle.Solid);
  GraphicElement lineElm = ElementFactory.Instance.CreateGraphicElement(
                                              layout, linePl, lineSym);
  lineElm.SetName("New Line");
Create rectangle graphic with simple symbology
//Create a simple 2D rectangle graphic and apply simple fill and
  //outline symbols.
  //Build 2D envelope geometry
  Coordinate2D rec_ll = new Coordinate2D(1.0, 4.75);
  Coordinate2D rec_ur = new Coordinate2D(3.0, 5.75);
  Envelope rec_env = EnvelopeBuilderEx.CreateEnvelope(rec_ll, rec_ur);
  GraphicElement recElm = ElementFactory.Instance.CreateGraphicElement(
    layout, rec_env, polySym, "New Rectangle");
  //Or use Predefined shape
  GraphicElement recElm2 = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                            layout, PredefinedShape.Rectangle, rec_env, polySym,
                            "New Rectangle2");
Create Text Graphic Elements
Create Point Text Element 1
//Create a simple point text element and assign basic symbology and text settings.
  Coordinate2D coord2D = new Coordinate2D(3.5, 10);
                ColorFactory.Instance.RedRGB, 32, "Arial", "Regular");
  string textString = "Point text";
  //use ElementInfo to set placement properties during create
    Rotation = 45
  var ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
    layout, TextType.PointText, coord2D.ToMapPoint(), sym, textString,
                       "New Point Text", true, elemInfo);
  //Change additional text properties
  ptTxtElm.SetX(4.5);
  ptTxtElm.SetY(9.5);
Create Rectangle Paragraph Text Element 1
  //Create rectangle text with background and border symbology.
  //Build 2D polygon geometry
  plyCoords.Add(new Coordinate2D(3.5, 7));
  plyCoords.Add(new Coordinate2D(4.5, 7));
  plyCoords.Add(new Coordinate2D(4.5, 6.7));
  plyCoords.Add(new Coordinate2D(5.5, 6.7));
  plyCoords.Add(new Coordinate2D(5.5, 6.1));
  plyCoords.Add(new Coordinate2D(3.5, 6.1));
  //Also notice how formatting tags are using within the text string.
                    ColorFactory.Instance.GreyRGB, 10, "Arial", "Regular");
  string text = "Some Text String that is really long and is " +
                "<BOL>forced to wrap to other lines</BOL> so that " +
                "we can see the effects." as String;
  GraphicElement polyTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
    layout, TextType.RectangleParagraph, poly, sym, text, "Polygon Paragraph");
  //(Optionally) Modify paragraph border
  CIMGraphic polyTxtGra = polyTxtElm.GetGraphic();
  CIMParagraphTextGraphic cimPolyTxtGra = polyTxtGra as CIMParagraphTextGraphic;
  cimPolyTxtGra.Frame.BorderSymbol = new CIMSymbolReference();
  cimPolyTxtGra.Frame.BorderSymbol.Symbol =
                          ColorFactory.Instance.GreyRGB, 1.0, SimpleLineStyle.Solid);
  polyTxtElm.SetGraphic(polyTxtGra);
Create a Dynamic Point Text Element
//Create a dynamic text element.
  //Set the string with tags and the location
  String title = @"<dyn type = ""page"" property = ""name"" />";
  Coordinate2D llTitle = new Coordinate2D(6, 2.5);
  //Create with default text properties
  TextElement titleGraphics = ElementFactory.Instance.CreateTextGraphicElement(
                  layout, TextType.PointText, llTitle.ToMapPoint(), null, title) as TextElement;
  //Modify the text properties
  titleGraphics.SetTextProperties(new TextProperties(title, "Arial", 24, "Bold"));
Create Point Text Element 2
  //Build geometry
  var elemInfo = new ElementInfo() { Anchor = Anchor.BottomLeftCorner };
  GraphicElement ptTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
Create Polygon Paragraph Text Element
  //Build geometry
  string text = "Some text string that is really long and " +
                "<BOL>wraps to other lines</BOL>" +
                " so that we can see the effects.";
  var ge = ElementFactory.Instance.CreateTextGraphicElement(
    layout, TextType.PolygonParagraph, poly, sym, text,
          "New Polygon Text", true);
Create Rectangle Paragraph Text Element 2
  //Build geometry
  Coordinate2D ll = new Coordinate2D(3.5, 4.75);
  Coordinate2D ur = new Coordinate2D(5.5, 5.75);
             ColorFactory.Instance.WhiteRGB, 10, "Arial", "Regular");
  //(Optionally) Modify border and background with 50% transparency
  //CIMGraphic recTxtGra = recTxtElm.Graphic;
  //CIMParagraphTextGraphic cimRecTxtGra = recTxtGra as CIMParagraphTextGraphic;
  //CIMSymbolReference cimRecTxtBorder = cimRecTxtGra.Frame.BorderSymbol;
  //                    ColorFactory.Instance.BlackRGB, 1.0, SimpleLineStyle.Solid);
  //cimRecTxtBorder.Symbol = lineSym;
  //CIMSymbolReference cimRecTxtBkgrd = cimRecTxtGra.Frame.BackgroundSymbol;
  //CIMPolygonSymbol polySym = SymbolFactory.Instance.ConstructPolygonSymbol(
  //                            ColorFactory.Instance.GreyRGB, SimpleFillStyle.Solid);
  //CIMColor symCol = polySym.GetColor(IElementContainer container);
  //symCol.SetAlphaValue(50);
  //cimRecTxtBkgrd.Symbol = polySym;
  //recTxtElm.SetGraphic(recTxtGra);
  var ge = ElementFactory.Instance.CreateTextGraphicElement(layout,
              TextType.RectangleParagraph, env, sym, text, "New Rectangle Text");
Create Circle Text Element
  //Build geometry
  GraphicElement cirTxtElm = ElementFactory.Instance.CreateTextGraphicElement(
    layout, TextType.CircleParagraph, poly, sym, text, "New Circle Text", false);
Create Bezier Text Element
  //Build geometry
    layout, TextType.SplinedText, bezPl, sym, "this is the bezier text",
          "New Bezier Text", true, new ElementInfo() { Anchor = Anchor.CenterPoint });
Create Ellipse Text Element
  //Build geometry
  Coordinate2D center = new Coordinate2D(4.5, 2.75);
  var eabElp = new EllipticArcBuilderEx(center, 0, 1, 0.45, ArcOrientation.ArcClockwise);
                        ColorFactory.Instance.BlueRGB, 10, "Arial", "Regular");
  string text = "Ellipse, ellipse, ellipse";
  GraphicElement ge = ElementFactory.Instance.CreateTextGraphicElement(
    layout, TextType.PolygonParagraph, poly, sym, text, "New Ellipse Text", false);
Create Predefined Shapes And Arrows
Create Predefined Shape Graphic Element
PredefinedShape shapeType = PredefinedShape.Circle;
  //PredefinedShape shapeType =
  //              PredefinedShape.Circle | Cloud | Cross |Circle | Triangle | ... ;
  //Build geometry
  Coordinate2D ll = new Coordinate2D(4, 2.5);
  Coordinate2D ur = new Coordinate2D(6, 4.5);
  var outline = SymbolFactory.Instance.ConstructStroke(
                  ColorFactory.Instance.BlueRGB, 2);
  var poly_sym = SymbolFactory.Instance.ConstructPolygonSymbol(
                   null, outline);
  var ge = ElementFactory.Instance.CreatePredefinedShapeGraphicElement(
                         layout, shapeType, env.Center, env.Width, env.Height,
                          poly_sym, shapeType.ToString(), true);
Create Predefined Shape Graphic Element 2
  //Build geometry
  Coordinate2D ll = new Coordinate2D(6.5, 7);
  Coordinate2D ur = new Coordinate2D(9, 9);
                  ColorFactory.Instance.GreenRGB, 2);
                   null, outline);
    layout, PredefinedShape.RoundedRectangle, env, poly_sym, "Rounded Rect", true);
Create Predefined Shape Graphic Element 3
  //Build geometry
                        ColorFactory.Instance.GreenRGB, 2.0, SimpleLineStyle.Dot);
                   ColorFactory.Instance.GreyRGB, SimpleFillStyle.Vertical, outline);
    layout, PredefinedShape.Ellipse, poly.Extent.Center, 0, 0, ellipseSym,
    "New Ellipse2", false, new ElementInfo() { Anchor = Anchor.TopRightCorner });
Create Line Arrow Element
  //Build geometry
    ArrowHeadKey = ArrowInfo.DefaultArrowHeadKeys[8],
    ArrowSizePoints = 24,
    LineWidthPoints = 12
  GraphicElement lineElm = ElementFactory.Instance.CreateArrowGraphicElement(
    layout, linePl, arrowInfo, "Arrow Line", true,
                              new ElementInfo() { Rotation = 15.0 });
  //lineElm.SetName("New Line");
Picture Elements
Create Picture Graphic Element using CIMSymbol
  //Build geometry
  Coordinate2D ll = new Coordinate2D(0.5, 1);
  Coordinate2D ur = new Coordinate2D(2.5, 2);
  string picPath = System.IO.Path.Combine(Environment.GetFolderPath(Environment.SpecialFolder.MyPictures),
  var pic_gr = ElementFactory.Instance.CreatePictureGraphicElement(
    layout, env.Center, picPath, "New Picture", true, new ElementInfo() { Anchor = Anchor.CenterPoint });
Create a new picture element with advanced symbol settings
//Create a picture element and also set background and border symbology.
  Coordinate2D pic_ll = new Coordinate2D(6, 1);
  Coordinate2D pic_ur = new Coordinate2D(8, 2);
  Envelope env = EnvelopeBuilderEx.CreateEnvelope(pic_ll, pic_ur);
  string picPath = @"C:\Temp\WhitePass.jpg";
  GraphicElement picElm = ElementFactory.Instance.CreatePictureGraphicElement(
                                       layout, env, picPath, "New Picture");
  //(Optionally) Modify the border and shadow
  CIMGraphic picGra = picElm.GetGraphic();
  CIMPictureGraphic cimPicGra = picGra as CIMPictureGraphic;
  cimPicGra.Frame.BorderSymbol = new CIMSymbolReference();
  cimPicGra.Frame.BorderSymbol.Symbol =
               ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Solid);
  cimPicGra.Frame.ShadowSymbol = new CIMSymbolReference();
  cimPicGra.Frame.ShadowSymbol.Symbol =
                    ColorFactory.Instance.BlackRGB, SimpleFillStyle.Solid);
  //Update the element
  picElm.SetGraphic(picGra);
Create MapFrame and Surrounds
Create Map Frame and Set Camera
//Create a map frame and set its camera by zooming to the extent of an existing bookmark.
  //Construct on the worker thread
  Coordinate2D mf_ll = new Coordinate2D(6.0, 8.5);
  Coordinate2D mf_ur = new Coordinate2D(8.0, 10.5);
  Envelope mf_env = EnvelopeBuilderEx.CreateEnvelope(mf_ll, mf_ur);
  //Reference map, create MF and add to layout
  MapProjectItem mapPrjItem = Project.Current.GetItems<MapProjectItem>()
                       .FirstOrDefault(item => item.Name.Equals("Map"));
  Map mfMap = mapPrjItem.GetMap();
  Bookmark bookmark = mfMap.GetBookmarks().FirstOrDefault(
                        b => b.Name == "Great Lakes");
  MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(
                       layout, mf_env, mfMap, "New Map Frame");
  //Zoom to bookmark
  mfElm.SetCamera(bookmark);
Create Legend
//Create a legend for an associated map frame.
  Coordinate2D leg_ll = new Coordinate2D(6, 2.5);
  Coordinate2D leg_ur = new Coordinate2D(8, 4.5);
  Envelope leg_env = EnvelopeBuilderEx.CreateEnvelope(leg_ll, leg_ur);
  //Reference MF, create legend and add to layout
  mapFrame = layout.FindElement("New Map Frame") as MapFrame;
  if (mapFrame == null)
    //TODO handle null map frame
    return;
  var legendInfo = new LegendInfo()
    MapFrameName = mapFrame.Name
  Legend legendElm = ElementFactory.Instance.CreateMapSurroundElement(
                      layout, leg_env, legendInfo, "New Legend") as Legend;
Create Scale Bar From StyleItem
//Create a scale bar using a style.
  //Search for a style project item by name
  StyleProjectItem arcgis_2dStyle = Project.Current.GetItems<StyleProjectItem>()
                              .First(si => si.Name == "ArcGIS 2D");
  //Reference the specific scale bar by name
  ScaleBarStyleItem scaleBarItem = arcgis_2dStyle.SearchScaleBars(
                      "Double Alternating Scale Bar").FirstOrDefault();
  //Reference the map frame and define the location
  MapFrame myMapFrame = layout.FindElement("Map Frame") as MapFrame;
  Coordinate2D coord2D = new Coordinate2D(10.0, 7.0);
  //Construct the scale bar
  var sbarInfo = new ScaleBarInfo()
    MapFrameName = myMapFrame.Name,
    ScaleBarStyleItem = scaleBarItem
          layout, coord2D.ToMapPoint(), sbarInfo);
Create North Arrow From StyleItem 1
//Create a north arrow using a style.
  StyleProjectItem arcgis2dStyles = Project.Current.GetItems<StyleProjectItem>()
  NorthArrowStyleItem naStyleItem = arcgis2dStyles.SearchNorthArrows(
                "ArcGIS North 13").FirstOrDefault();
  MapFrame newFrame = layout.FindElement("New Map Frame") as MapFrame;
  Coordinate2D nArrow = new Coordinate2D(6, 2.5);
  //Construct the north arrow
  var naInfo = new NorthArrowInfo()
    MapFrameName = newFrame.Name,
    NorthArrowStyleItem = naStyleItem
  var newNorthArrow = ElementFactory.Instance.CreateMapSurroundElement(
                          layout, nArrow.ToMapPoint(), naInfo);
Create Table Frame
//Create a table frame.
  Coordinate2D rec_ll = new Coordinate2D(1.0, 3.5);
  Coordinate2D rec_ur = new Coordinate2D(7.5, 4.5);
  //Reference map frame and layer
  MapFrame mf = layout.FindElement("Map Frame") as MapFrame;
  FeatureLayer lyr = mf.Map.FindLayers("GreatLakes").First() as FeatureLayer;
  //Build fields list
  var fields = new[] { "NAME", "Shape_Area", "Shape_Length" };
  //Construct the table frame
  var tableFrameInfo = new TableFrameInfo()
    FieldNames = fields,
    MapFrameName = mf.Name,
    MapMemberUri = lyr.URI
  var tabFrame = ElementFactory.Instance.CreateMapSurroundElement(
    layout, rec_env, tableFrameInfo) as TableFrame;
Create Map Frame 1
//Note: QueuedTask.Run
  //Build geometry
  Coordinate2D ll = new Coordinate2D(2.0, 4.5);
  Coordinate2D ur = new Coordinate2D(4.0, 6.5);
  MapFrame mfElm = ElementFactory.Instance.CreateMapFrameElement(layout, env, map);
Create Map Frame 2
  //Build geometry
  Coordinate2D ll = new Coordinate2D(4.0, 2.5);
  Coordinate2D ur = new Coordinate2D(7.0, 5.5);
  layout, env.Center, map);
Create Legend 2
  //Build geometry
  Coordinate2D ll = new Coordinate2D(6, 2.5);
  Coordinate2D ur = new Coordinate2D(8, 4.5);
  var surroundInfo = new LegendInfo()
  var legendElm = ElementFactory.Instance.CreateMapSurroundElement(
    layout, env.Center, surroundInfo) as Legend;
  legendElm.SetName("New Legend");
Create North Arrow From StyleItem 2
  //Build geometry
  Coordinate2D center = new Coordinate2D(7, 5.5);
  //Reference a North Arrow in a style
  NorthArrowStyleItem naStyleItm = stylePrjItm.SearchNorthArrows(
                                         "ArcGIS North 10")[0];
  //Reference MF, create north arrow and add to layout
  var mf = layout.FindElement("Map Frame") as MapFrame;
  var narrow_info = new NorthArrowInfo()
    NorthArrowStyleItem = naStyleItm
  var arrowElm = (NorthArrow)ElementFactory.Instance.CreateMapSurroundElement(
    layout, center.ToMapPoint(), narrow_info) as NorthArrow;
  arrowElm.SetName("New North Arrow");
  arrowElm.SetHeight(1.75);
  arrowElm.SetX(7);
  arrowElm.SetY(6);
Create Table Frame 2
  //Build geometry
  Coordinate2D ll = new Coordinate2D(1, 1);
  Coordinate2D ur = new Coordinate2D(4, 4);
    MapFrameName = "Map Frame",
    MapMemberUri = "CIMPATH=USNationalParks/NationalParks.json"
  var attribs = new List<CIMStringMap>();
  for (int i = 1; i < 6; i++)
    attribs.Add(new CIMStringMap
      Key = $"Key {i}",
      Value = $"Value {i}"
    CustomProperties = attribs
  var tableFrameElem = ElementFactory.Instance.CreateMapSurroundElement(
                                layout, env.Center, tableFrameInfo,
                                "New Table Frame", false, elemInfo) as TableFrame;
Create Scale Bar
  //Build geometry
  Coordinate2D ll = new Coordinate2D(5.0, 6);
  Coordinate2D ur = new Coordinate2D(6.0, 7);
  Envelope sbEnv = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
  //Reference a Scale Bar in a style
  ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
               "Alternating Scale Bar 1")[0];
  //ScaleBarStyleItem sbStyleItm = stylePrjItm.SearchScaleBars(
  //                                   "Double Alternating Scale Bar 1")[0];
  //                                    "Hollow Scale Bar 1")[0];
  //Create Scale Bar
  ScaleBarInfo sbInfo = new ScaleBarInfo()
    MapFrameName = mapFrame.Name,
  var sbElm = ElementFactory.Instance.CreateMapSurroundElement(
                                     layout, sbEnv, sbInfo) as ScaleBar;
Create Scale Line
  //Build geometry
  Coordinate2D ll = new Coordinate2D(5.0, 8);
  Coordinate2D ur = new Coordinate2D(6.0, 9);
                                "Scale Line 1")[0];
  //                                           "Stepped Scale Line")[0];
  //                                            "Scale Line 2")[0];
  //Create Scale Bar
    ScaleBarStyleItem = sbStyleItm
                    layout, sbEnv, sbInfo, "ScaleBar Line") as ScaleBar;
Group Elements
Creating empty group elements
//Create an empty group element at the root level of the contents pane
  //container is IElementContainer - GroupLayer or Layout
  GroupElement grp1 = ElementFactory.Instance.CreateGroupElement(
                        layout, null, "Group");
  // *** or ***
  //Create a group element inside another group element
  //Find an existing group element
  GroupElement existingGroup = layout.FindElement("Group") as GroupElement;
  //Create on worker thread
  GroupElement grp2 = ElementFactory.Instance.CreateGroupElement(
      existingGroup, null, "Group in Group");
Create a group element with elements
//Create a group with a list of elements at the root level of the contents pane.
  //Find an existing elements
  var elem1 = layout.FindElement("Polygon 1");
  var elem2 = layout.FindElement("Bezier Text");
  var elem3 = layout.FindElement("Cloud Shape 2");
  //Construct a list and add the elements
  var elmList = new List<Element>
    elem1,
    elem2,
    elem3
  GroupElement groupWithListOfElementsAtRoot =
                     layout, elmList, "Group with list of elements at root");
  // *** or ***
  //Create a group using a list of element names at the root level of the contents pane.
  //List of element names
  var elmNameList = new[] { "Para Text1", "Line 3" };
  var elemToGroup = layout.FindElements(elmNameList);
  GroupElement groupWithListOfElementNamesAtRoot =
             layout, elemToGroup, "Group with list of element names at root");
Layout Elements and Selection
Find an element on a layout
//Find an element on a layout.
  // Reference and load the layout associated with the layout item
  Layout mylayout = layoutItem.GetLayout();
  if (mylayout != null)
    //Find a single specific element
    Element rect = mylayout.FindElement("Rectangle") as Element;
    //Or use the Elements collection
    Element rect2 = mylayout.Elements.FirstOrDefault(item => item.Name.Equals("Rectangle"));
Find layout elements
  //Find elements by name
  var layoutElementsToFind = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
  //Get the collection of elements from the page layout. Nesting within GroupElement is preserved.
  var elementCollection = layout.GetElements();
  //Get the collection of Element from the page layout as a flattened list. Nested groups within GroupElement are not preserved.
  var elements = layout.GetElementsAsFlattenedList();
  //Convert collection of the elements to a collection of GraphicElements.
  var graphicElements = elements.ToList().ConvertAll(x => (GraphicElement)x);
  //Find elements by type
  //Find all point graphics in the Layout
  var pointGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMPointGraphic);
  //Find all line graphics in the Graphics Layer
  var lineGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMLineGraphic);
  ////Find all polygon graphics in the Graphics Layer
  var polyGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMPolygonGraphic);
  ////Find all text graphics in the Graphics Layer
  var textGraphics = graphicElements.Where(elem => elem.GetGraphic() is CIMTextGraphic);
  ////Find all picture graphics in the Graphics Layer
  var pictureGraphic = graphicElements.Where(elem => elem.GetGraphic() is CIMPictureGraphic);
Update element properties
//Update an element's properties.
  element = layout.FindElement("Rectangle") as Element;
  // update an element's name
  element.SetName("New Name");
  // update and element's visibility
  element.SetVisible(true);
Get element selection count
//Get element's selection count.
  //Count the number of selected elements on the active layout view
    var selectedElements = activeLayoutView.GetSelectedElements();
    ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show($@"Selected elements: {selectedElements.Count}");
Set element selection
//Set the active layout view's selection to include 2 rectangle elements.
  //Reference the active view
    Layout lyt = activeLayoutView.Layout;
    //Reference the two rectangle elements
    Element rec = lyt.FindElement("Rectangle");
    Element rec2 = lyt.FindElement("Rectangle 2");
    List<Element> elmList = new List<Element>
      rec,
      rec2
    //Set the selection
    activeLayoutView.SelectElements(elmList);
UnSelect elements on the Layout
//Unselect one element.
  var elementToUnSelect = layout.FindElements(new List<string>() { "MyPoint" }).FirstOrDefault();
  layout.UnSelectElement(elementToUnSelect);
  //Unselect multiple elements.
  var elementsToUnSelect = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
  layout.UnSelectElements(elementsToUnSelect);
UnSelect elements on the LayoutView
  var elementToUnSelectInView = layout.FindElements(new List<string>() { "MyPoint" }).FirstOrDefault();
  layoutView.UnSelectElement(elementToUnSelectInView);
  var elementsToUnSelectInView = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
  layoutView.UnSelectElements(elementsToUnSelectInView);
Clear the selection in a layout view
//If the a layout view is active, clear its selection
  activeLayoutView?.ClearElementSelection();
//Clear the layout selection.
  layout.ClearElementSelection();
Copy Layout Elements
  var elems = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
  var copiedElements = layout.CopyElements(elems);
Delete Layout Elements
  var elementsToRemove = layout.GetSelectedElements();
  layout.DeleteElements(elementsToRemove);
Delete an element or elements on a layout
//Delete an element or elements on a layout.
  //Delete a specific element on a layout
  Element rect = layout.FindElement("Rectangle") as Element;
  layout.DeleteElement(rect);
  //Or delete a group of elements using a filter
  layout.DeleteElements(item => item.Name.Contains("Clone"));
  //Or delete all elements on a layout
  layout.DeleteElements(item => true);
Zoom to elements
LayoutView lytView = LayoutView.Active;
  //Zoom to an element
  var elementToZoomTo = layout.FindElements(new List<string>() { "MyPoint" }).FirstOrDefault();
  lytView.ZoomToElement(elementToZoomTo);
  //Zoom to  multiple elements.
  var elementsToZoomTo = layout.FindElements(new List<string>() { "Point 1", "Line 3", "Text 1" });
  lytView.ZoomToElements(elementsToZoomTo);
Set halo property of north arrow
//Set the CIM halo properties of a north arrow.
  //Reference the first selected north arrow element
  var northArrow = LayoutView.Active.GetSelectedElements().OfType<NorthArrow>().First();
  //Get definition of north arrow...
  var cim = northArrow.GetDefinition() as CIMMarkerNorthArrow;
  //this halo symbol is 50% transparent, no outline (i.e. 0 width)
  //First construct a polygon symbol to use in the Halo
  //Polygon symbol will need a fill and a stroke
  var polyFill = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.CreateRGBColor(0, 0, 0, 50));
  var polyStroke = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 0);
  var haloPoly = SymbolFactory.Instance.ConstructPolygonSymbol(polyFill, polyStroke);
  //Set the north arrow definition of HaloSymbol and HaloSize
  ((CIMPointSymbol)cim.PointSymbol.Symbol).HaloSymbol = haloPoly;
  ((CIMPointSymbol)cim.PointSymbol.Symbol).HaloSize = 3;//size of the halo
  //Apply the CIM changes back to the element
  northArrow.SetDefinition(cim);
Grouping and Ordering Graphic Elements
Group Graphic Elements
  var elemsToGroup = layout.GetSelectedElements();
  //Note: run within the QueuedTask
  //group  elements
  var newGroupElement = layout.GroupElements(elemsToGroup);
Un-Group Graphic Elements
  var selectedElements = layout.GetSelectedElements().ToList();
  if (selectedElements?.Count == 0)//must be at least 1.
    return;
  var elementsToUnGroup = new List<GroupElement>();
  //All selected elements should be grouped elements.
  if (selectedElements.Count() == selectedElements.OfType<GroupElement>().Count())
    //Convert to a GroupElement list.
    elementsToUnGroup = selectedElements.ConvertAll(x => (GroupElement)x);
  if (elementsToUnGroup.Count() == 0)
    return;
  //UnGroup many grouped elements
  layout.UnGroupElements(elementsToUnGroup);
  //Ungroup one grouped element
  layout.UnGroupElement(elementsToUnGroup.FirstOrDefault());
Parent of GroupElement
//check the parent
  var parent = groupElement.Elements.First().GetParent();//will be the group element
                                                         //top-most parent
                                                         //will be a GraphicsLayer or Layout
  var top_most = groupElement.Elements.First().GetParent(true);
Children in a Group Element
// Nested groups within ArcGIS.Desktop.Layouts.GroupElement are not preserved.
  var children = groupElement.GetElementsAsFlattenedList();
Ordering: Send backward and Bring forward
  //get the current selection set
  var sel_elems = layout.GetSelectedElements();
  //can they be brought forward? This will also check that all elements have the same parent
  if (layout.CanBringForward(sel_elems))
    //bring forward
    layout.BringForward(sel_elems);
    //bring to front (of parent)
    //graphicsLayer.BringToFront(sel_elems);
  else if (layout.CanSendBackward(sel_elems))
    //send back
    layout.SendBackward(sel_elems);
    //send to the back (of parent)
    //graphicsLayer.SendToBack(sel_elems);
Get Z-Order
var selElementsZOrder = layout.GetSelectedElements();
  //list out the z order
  foreach (var elem in selElementsZOrder)
    System.Diagnostics.Debug.WriteLine($"{elem.Name}: z-order {elem.ZOrder}");
Update Layout Elements
Update text element properties
//Update text element properties for an existing text element.
  if (layout != null)
    // Reference a text element by name
    TextElement txtElm = layout.FindElement("MyTextElement") as TextElement;
    if (txtElm != null)
      double x = 2.0;
      double y = 3.0;
      // Change placement properties
      txtElm.SetAnchor(Anchor.CenterPoint);
      txtElm.SetX(x);
      txtElm.SetY(y);
      // Change TextProperties
      TextProperties txtProperties = new TextProperties(
                        "Hello world", "Times New Roman", 48, "Regular");
      txtElm.SetTextProperties(txtProperties);
Update a picture element
//Update a picture element.
  // Reference a picture element by name
  PictureElement picElm = layout.FindElement("MyPicture") as PictureElement;
  // Change the path to a new source
  picElm?.SetSourcePath(@"D:\MyData\Pics\somePic.jpg");
Apply a Background Color to a MapFrame
//Apply a background color to the map frame element using the CIM.
  //Get the map frame's definition in order to modify the background.
  var mapFrameDefn = mapFrame.GetDefinition() as CIMMapFrame;
  //Construct the polygon symbol to use to create a background
  var polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(
                  ColorFactory.Instance.BlueRGB, SimpleFillStyle.Solid);
  //Set the background
  mapFrameDefn.GraphicFrame.BackgroundSymbol =
                                    polySymbol.MakeSymbolReference();
  //Set the map frame definition
  mapFrame.SetDefinition(mapFrameDefn);
Update a map surround
//Update a map surround.
  // Reference a scale bar element by name
  MapSurround scaleBar = layout.FindElement("MyScaleBar") as MapSurround;
  // Reference a map frame element by name
  MapFrame mf = layout.FindElement("MyMapFrame") as MapFrame;
  if ((scaleBar != null) && (mf != null))
    //Set the scale bar to the newly referenced map frame
    scaleBar.SetMapFrame(mf);
Lock an element
// The Locked property is displayed in the TOC as a lock symbol next
  // to each element.  If locked the element can't be selected in the layout
  // using the graphic selection tools.
  //Reference an element
  if (element != null)
    // Modify the Locked property via the CIM
    CIMElement CIMElement = element.GetDefinition() as CIMElement;
    CIMElement.Locked = true;
    element.SetDefinition(CIMElement);
Update an elements transparency
//Update an element's transparency using the CIM.
  // Reference a element by name
  GraphicElement graphicElement = layout.FindElement("MyElement") as GraphicElement;
  if (graphicElement != null)
    // Modify the Transparency property that exists only in the CIMGraphic class.
    CIMGraphic CIMGraphic = graphicElement.GetGraphic() as CIMGraphic;
    CIMGraphic.Transparency = 50; // mark it 50% transparent
    graphicElement.SetGraphic(CIMGraphic);
Clone an element
//Clone a layout graphic element and apply an offset.
  // Reference a graphic element by name
    //Clone and set the new x,y
    GraphicElement cloneElement = graphicElement.Clone("Clone");
    double xOffset = 0;
    double yOffset = 0;
    cloneElement.SetX(cloneElement.GetX() + xOffset);
    cloneElement.SetY(cloneElement.GetY() + yOffset);
Style Layout Elements
Apply a style to a North Arrow
  //Get the Style project items in the project
  var styleProjectItems = Project.Current?.GetItems<StyleProjectItem>();
  //Get the ArcGIS 2D Style Project Item
  var styleProjectItem =
  styleProjectItems.FirstOrDefault(s => s.Name == "ArcGIS 2D");
  if (styleProjectItem == null) return;
  //Get the north arrow style item you need
  var northArrowStyleItem =
  styleProjectItem.SearchSymbols(StyleItemType.NorthArrow, "ArcGIS North 18").FirstOrDefault();
  if (northArrowStyleItem == null) return;
  //Select a North arrow layout element
  var northArrowElement = layout.GetSelectedElements().OfType<NorthArrow>().FirstOrDefault();
  if (northArrowElement != null)
    //Check if the input style can be applied to the element
    if (northArrowElement.CanApplyStyle(northArrowStyleItem))
      //Apply the style
      northArrowElement.ApplyStyle(northArrowStyleItem);
Apply a style to Grid and Graticules
  styleProjectItems.OfType<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
  //Get the grid style item you need
  var gridStyleItem =
  styleProjectItem.SearchSymbols(StyleItemType.Grid, "Blue Vertical Label Graticule").FirstOrDefault();
  if (gridStyleItem == null) return;
  var symbolItemName = gridStyleItem.Name;
  var girdGraticuleObject = gridStyleItem.GetObject() as CIMMapGrid;
  var cmf = mapFrame.GetDefinition() as CIMMapFrame;
  //note, if page units are _not_ inches then grid's gridline
  //lengths and offsets would need to be converted to the page units
  var mapGrids = new List<CIMMapGrid>();
  if (cmf.Grids != null)
    mapGrids.AddRange(cmf.Grids);
  switch (girdGraticuleObject)
    case CIMGraticule:
      var gridGraticule = girdGraticuleObject as CIMGraticule;
      gridGraticule.Name = symbolItemName;
      gridGraticule.SetGeographicCoordinateSystem(mapFrame.Map.SpatialReference);
      //assign grid to the frame
      mapGrids.Add(gridGraticule);
      break;
    case CIMMeasuredGrid:
      var gridMeasure = girdGraticuleObject as CIMMeasuredGrid;
      gridMeasure.Name = symbolItemName;
      gridMeasure.SetProjectedCoordinateSystem(mapFrame.Map.SpatialReference);
      mapGrids.Add(gridMeasure);
      break;
    case CIMReferenceGrid:
      var gridReference = girdGraticuleObject as CIMReferenceGrid;
      gridReference.Name = symbolItemName;
      mapGrids.Add(gridReference);
      break;
  cmf.Grids = mapGrids.ToArray();
  mapFrame.SetDefinition(cmf);
Apply a style to a Graphic Element
//Note: Run within QueuedTask context.
  var pointStyleItem =
  styleProjectItem.SearchSymbols(StyleItemType.PointSymbol, "Circle 3").FirstOrDefault();
  if (pointStyleItem == null) return;
  var layoutPointElement = layout.GetSelectedElements().FirstOrDefault();
  if (layoutPointElement != null && layoutPointElement is GraphicElement ge)
    if (layoutPointElement.CanApplyStyle(pointStyleItem))
      //The magic happens here
      //for Graphic Elements such as Point, Lines, Polys, text, preserve size.
      ge.ApplyStyle(pointStyleItem, true);
Layout Snapping
Configure Snapping - Turn Snapping on or off
//enable snapping
  ArcGIS.Desktop.Layouts.LayoutSnapping.IsEnabled = true;
  // disable snapping
  ArcGIS.Desktop.Layouts.LayoutSnapping.IsEnabled = false;
Configure Snapping - Application SnapModes
// sets only the Guide snapping mode
  ArcGIS.Desktop.Layouts.LayoutSnapping.SetSnapModes(new[] { LayoutSnapMode.Guide });
  // sets only Element and Page snapping modes
  ArcGIS.Desktop.Layouts.LayoutSnapping.SetSnapModes(new[] { LayoutSnapMode.Element, LayoutSnapMode.Page });
  // clear all snap modes
  ArcGIS.Desktop.Layouts.LayoutSnapping.SetSnapModes(null);
  // set snap modes one at a time
  ArcGIS.Desktop.Layouts.LayoutSnapping.SetSnapMode(LayoutSnapMode.Margins, true);
  ArcGIS.Desktop.Layouts.LayoutSnapping.SetSnapMode(LayoutSnapMode.Guide, true);
  /// LayoutSnapping.SetSnapModes(new[]{ LayoutSnapMode.Guide }); // sets only the Guide snapping mode
  // get current snap modes
  var snapModes = ArcGIS.Desktop.Layouts.LayoutSnapping.SnapModes;
  // get state of a specific snap mode
  bool isOn = ArcGIS.Desktop.Layouts.LayoutSnapping.GetSnapMode(LayoutSnapMode.Guide);
Layout Metadata
Layout Metadata
  //Gets the Layout metadata.
  var layout_xml = layout.GetMetadata();
  //Can metadata be edited?
  if (layout.GetCanEditMetadata())
    //Set the metadata back
    layout.SetMetadata(layout_xml);
Layout MapFrame
Change the map associated with a map frame
//Change the map associated with a map frame
  //Find a map frame element from a layout by the map frame's element name
  MapFrame mfrm = layout.FindElement("Map Frame") as MapFrame;
  //Reference map from the project item
  Map myMap = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name.Equals("Map1")).GetMap();
  //Set the map to the map frame
  mfrm.SetMap(map);
Change map frame camera settings
//Change a map frame's camera settings.
  //Reference MapFrame
  //Reference the camera associated with the map frame and change the scale
  Camera cam = mf.Camera;
  cam.Scale = 100000;
  //Set the map frame extent based on the new camera info
  mf.SetCamera(cam);
Zoom map frame to extent of a single layer
//Zoom map frame to the extent of a single layer.
  //Reference map and layer
  Map m = mapFrame.Map;
  FeatureLayer lyr = m.FindLayers("GreatLakes").First() as FeatureLayer;
  //Set the map frame extent to all features in the layer
  mapFrame.SetCamera(lyr, false);
Change map frame extent to selected features in multiple layers
//Change the extent of a map frame to the selected features multiple layers.
  //Reference map, layers and create layer list
  FeatureLayer fl_1 = m.FindLayers("GreatLakes").First() as FeatureLayer;
  FeatureLayer fl_2 = m.FindLayers("States_WithRegions").First() as FeatureLayer;
  var layers = new[] { fl_1, fl_2 };
  //IEnumerable<Layer> layers = m.Layers;  //This creates a list of ALL layers in map.
  //Set the map frame extent to the selected features in the list of layers
  mapFrame.SetCamera(layers, true);
Change map frame extent to single feature with 15 percent buffer
//Change map frame extent to single feature with 10 percent buffer
  //Reference the mapframe and its associated map
  //Reference a feature layer and build a query (to return a single feature)
  FeatureLayer fl = m.FindLayers("GreatLakes").First() as FeatureLayer;
  QueryFilter qf = new QueryFilter();
  string whereClause = "NAME = 'Lake Erie'";
  qf.WhereClause = whereClause;
  //Zoom to the feature
  using (ArcGIS.Core.Data.RowCursor rowCursor = fl.Search(qf))
    while (rowCursor.MoveNext())
      //Get the shape from the row and set extent
      using (var feature = rowCursor.Current as ArcGIS.Core.Data.Feature)
        Polygon polygon = feature.GetShape() as Polygon;
        Envelope env = polygon.Extent as Envelope;
        mapFrame.SetCamera(env);
        //Zoom out 15 percent
        Camera cam = mapFrame.Camera;
        cam.Scale = cam.Scale * 1.15;
        mapFrame.SetCamera(cam);
Activate Map Frame
//We can activate a map frame on the layout of the active view
  var map_frame = layout.GetElementsAsFlattenedList()
                      .OfType<MapFrame>().FirstOrDefault(mf => mf.Name == "Map 1");
  if (map_frame == null)
    return;
  //can we activate the map frame?
  if (layoutView.CanActivateMapFrame(map_frame))
    //activate it - Note: we are on the UI thread!
    layoutView.ActivateMapFrame(map_frame);
Deactivate Map Frame
//Deactivate any activated map frame
  //Note: we are on the UI thread!
  layoutView.DeactivateMapFrame();//no-op if nothing activated
  //or - check if a  map frame is activated first...
  if (layoutView.ActivatedMapFrame != null)
Get the Activated Map Frame and MapView
//The active view must be a layout view.
  var lv = LayoutView.Active;
  if (lv == null)
    return;
  var map_view = lv.ActivatedMapView;
  if (map_view != null)
    //TODO - use activated map view
  var map_frame = lv.ActivatedMapFrame;
  if (map_frame != null)
    //TODO - use activated map frame
Translates a point in page coordinates to a point in map coordinates.
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlackRGB, 8);
  var graphicsLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
  //Get a point in the center of the Map frame
  var mapFrameCenterPoint = mapFrame.GetBounds().CenterCoordinate;
  //Convert to MapPoint
  var pointInMapFrame = MapPointBuilderEx.CreateMapPoint(mapFrameCenterPoint);
  //Find the corresponding point in the MapView
  var pointOnMap = mapFrame.PageToMap(pointInMapFrame);
  //Create a point graphic on the MapView.
  var cimGraphicElement = new CIMPointGraphic
    Location = pointOnMap,
  graphicsLayer.AddElement(cimGraphicElement);
Translates a point in map coordinates to a point in page coordinates
  //Convert the clicked point in client coordinates to the corresponding map coordinates.
  //clicked point can be from a Map Tool's HandleMouseDownAsync callback.
  //MapViewMouseButtonEventArgs ClientPoint property.
  Point clickedPoint;
  var clickedMapPoint = MapView.Active.ClientToMap(clickedPoint);
  ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(string.Format("X: {0} Y: {1} Z: {2}",
      mapPoint.X, mapPoint.Y, mapPoint.Z), "Map Coordinates");
  //Get the corresponding layout point
  var pointOnLayoutFrame = mapFrame.MapToPage(mapPoint);
  //Create a point graphic on the Layout.
    Location = pointOnLayoutFrame,
  var cimGraphicElement2 = GraphicFactory.Instance.CreateSimpleGraphic(
          pointOnLayoutFrame, pointSymbol);
  ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement);
  ElementFactory.Instance.CreateGraphicElement(layout, cimGraphicElement2);
Layout MapSeries
Modify an existing map series
//Modify the currently active map series and changes its sort field and page number field.
  SpatialMapSeries SMS = layout.MapSeries as SpatialMapSeries; //cast as spatial map series for additional members
  SMS.SortField = "State_Name";
  SMS.SortAscending = true;
  SMS.PageNumberField = "PageNum";
  //Overwrite the current map series with these new settings
  layout.SetMapSeries(SMS);
Create a new spatial map series
// This example create a new spatial map series and then applies it to the active layout. This will automatically
  // overwrite an existing map series if one is already present.
  //Note: Must be on QueuedTask.Run;
  //SpatialMapSeries constructor - required parameters
  BasicFeatureLayer indexLyr = map.FindLayers("Countries").FirstOrDefault() as BasicFeatureLayer;
  SpatialMapSeries SMS = MapSeries.CreateSpatialMapSeries(layout, mapFrame, indexLyr, "Name");
  //Set optional, non-default values
  SMS.CategoryField = "Continent";
  SMS.SortField = "Population";
  SMS.ExtentOptions = ExtentFitType.BestFit;
  SMS.MarginType = ArcGIS.Core.CIM.UnitType.PageUnits;
  SMS.MarginUnits = ArcGIS.Core.Geometry.LinearUnit.Centimeters;
  SMS.Margin = 1;
  SMS.ScaleRounding = 1000;
  layout.SetMapSeries(SMS);  //Overwrite existing map series.
Layout Export
Export a layout to PDF
//Export a single page layout to PDF.
  //Create a PDF format with appropriate settings
  //BMP, EMF, EPS, GIF, JPEG, PNG, SVG, TGA, and TFF formats are also available for export
  string filePath = @"Path and file name for the output export file";
  PDFFormat PDF = new PDFFormat()
    OutputFileName = filePath,
    Resolution = 300,
    DoCompressVectorGraphics = true,
    DoEmbedFonts = true,
    HasGeoRefInfo = true,
    ImageCompression = ImageCompression.Adaptive,
    ImageQuality = ImageQuality.Best,
    LayersAndAttributes = LayersAndAttributes.LayersAndAttributes
  //Check to see if the path is valid and export
  if (PDF.ValidateOutputFilePath())
    layout.Export(PDF);  //Export the layout to PDF on the worker thread
Export a map frame to JPG
//Export a map frame to JPG.
  //Create JPEG format with appropriate settings
  //BMP, EMF, EPS, GIF, PDF, PNG, SVG, TGA, and TFF formats are also available for export
  JPEGFormat JPG = new JPEGFormat()
    HasWorldFile = true,
    Resolution = 300,
    ColorMode = JPEGColorMode.TwentyFourBitTrueColor,
    Height = 800,
    Width = 1200
  //Export on the worker thread
  //Note: Must be on QueuesTask.Run
  if (JPG.ValidateOutputFilePath())
    mf.Export(JPG);  //Export the map frame to JPG
Export the map view associated with a map frame to BMP
//Export the map view associated with a map frame to BMP.
  //Create BMP format with appropriate settings
  //EMF, EPS, GIF, JPEG, PDF, PNG, SVG, TGA, and TFF formats are also available for export
  BMPFormat BMP = new BMPFormat()
    Resolution = 300,
    Height = 500,
    Width = 800,
  await QueuedTask.Run(() =>
    MapView mv_bmp = mapFrame.GetMapView(layoutView);
    if (mv_bmp != null)
      if (BMP.ValidateOutputFilePath())
        mv_bmp.Export(BMP);  //Export to BMP
Export a map series to single PDF
//Export a map series with multiple pages to a single PDF.
  //Create PDF format with appropriate settings
  PDFFormat MS_PDF = new PDFFormat()
    Resolution = 300,
  //Set up map series export options
  MapSeriesExportOptions MS_ExportOptions = new MapSeriesExportOptions()
    ExportPages = ExportPages.Custom,  //Provide a specific list of pages
    CustomPages = "1-3, 5",  //Only used if ExportPages.Custom is set
    ExportFileOptions = ExportFileOptions.ExportAsSinglePDF,  //Export all pages to a single, multi-page PDF
    ShowSelectedSymbology = false  //Do no show selection symbology in the output
  if (MS_PDF.ValidateOutputFilePath())
    layout.Export(MS_PDF, MS_ExportOptions);  //Export to PDF
Export a map series to individual TIFF files
//Export each page of a map series to an individual TIFF file.
  //Create TIFF format with appropriate settings
  TIFFFormat TIFF = new TIFFFormat()
    Resolution = 300,
    ColorMode = TIFFColorMode.TwentyFourBitTrueColor,
    HasGeoTiffTags = true,
    ImageCompression = TIFFImageCompression.LZW
  MapSeriesExportOptions MSExportOptions_TIFF = new MapSeriesExportOptions()
    ExportPages = ExportPages.All,  //All pages
    ExportFileOptions = ExportFileOptions.ExportMultipleNames,  //Export each page to an individual file using page name as a suffix.
    ShowSelectedSymbology = true  //Include selection symbology in the output
  //Note: Must be on the QueuedTask.Run()
  if (TIFF.ValidateOutputFilePath())
    layout.Export(TIFF, MSExportOptions_TIFF);  //Export to TIFF
LayoutOptions
Get LayoutOptions
var lastToolActive = ApplicationOptions.LayoutOptions.KeepLastToolActive;
  var warnOnSurrounds = ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds;
  //eg <Install_Path>\Resources\LayoutTemplates\en-US
  var gallery_path = ApplicationOptions.LayoutOptions.LayoutTemplatePath;
  var defaultGuideColor = ApplicationOptions.LayoutOptions.DefaultGuideColor;
  //Note: Must be on QueuedTask.Run.
  var guideColor = ApplicationOptions.LayoutOptions.GetGuideColor();
Set LayoutOptions
//keep graphic element insert tool active
  ApplicationOptions.LayoutOptions.KeepLastToolActive = true;
  //no warning when deleting a map frame results in other elements being deleted
  ApplicationOptions.LayoutOptions.WarnAboutAssociatedSurrounds = false;
  //path to .pagx files used as templates
  ApplicationOptions.LayoutOptions.LayoutTemplatePath = @"D:\data\layout_templates";
  // set guide color
  ApplicationOptions.LayoutOptions.SetGuideColor(ColorFactory.Instance.RedRGB);
TextAndGraphicsElementsOptions
Get All Available Fonts
//Note: see also SymbolFactory.Instance.GetAvailableFonts() which returns the
  //same list. Use for TextAndGraphicsElementsOptions.GetAvailableFonts() convenience
  //A list of tuples of Font name + associated Font Styles, one tuple per
  //font, is returned
  var fonts = ApplicationOptions.TextAndGraphicsElementsOptions.GetAvailableFonts();
  StringBuilder sb = new StringBuilder();
  sb.AppendLine("Pro Fonts\r\n============================");
  foreach (var font in fonts)
    var styles = string.Join(",", font.fontStyles);
    sb.AppendLine($"{font.fontName}, [{styles}]");
  System.Diagnostics.Debug.WriteLine(sb.ToString());
Get TextAndGraphicsElementsOptions
  //Get the default font (see also 'SymbolFactory.Instance.DefaultFont')
  var def_font = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultFont();
    $"\r\ndefault font: {def_font.fontName}, {def_font.styleName}");
  //Get the default graphics element symbols - point, line, poly, text
  var ptSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPointSymbol();
  var lineSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultLineSymbol();
  var polySymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultPolygonSymbol();
  var textSymbol = ApplicationOptions.TextAndGraphicsElementsOptions.GetDefaultTextSymbol();
Set TextAndGraphicsElementsOptions
  //Set a default font. Use its default style
  ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
  //or specify an explicit style
  ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
  //Create symbols
  var ptSymbol2 = SymbolFactory.Instance.ConstructPointSymbol(
    ColorFactory.Instance.RedRGB, 14, SimpleMarkerStyle.Diamond);
  var lineSymbol2 = SymbolFactory.Instance.ConstructLineSymbol(
    ColorFactory.Instance.RedRGB, 2, SimpleLineStyle.Dash);
  var polySymbol2 = SymbolFactory.Instance.ConstructPolygonSymbol(
    ColorFactory.Instance.RedRGB, SimpleFillStyle.DiagonalCross);
  var textSymbol2 = SymbolFactory.Instance.ConstructTextSymbol(
    ColorFactory.Instance.RedRGB, 12);
  //Set default point, line, poly, text graphics element symbols
  ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPointSymbol(ptSymbol2);
  ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultLineSymbol(lineSymbol2);
  ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultPolygonSymbol(polySymbol2);
  ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultTextSymbol(textSymbol2);
MapFrame Display Constraints
SetAutoCameraNone
  var autoCamera = mapFrame.GetAutoCamera();
  autoCamera.Source = AutoCameraSource.None;
  if (mapFrame.ValidateAutoCamera(autoCamera) &&
    !mapFrame.IsMapSeriesMapFrame())
    mapFrame.SetAutoCamera(autoCamera);
SetAutoCameraFixedExtent
  autoCamera.Source = AutoCameraSource.Fixed;
  autoCamera.AutoCameraType = AutoCameraType.Extent;
  var mf_extent = mapFrame.GetViewExtent();
  var extent = EnvelopeBuilderEx.CreateEnvelope(
    400748.62, 800296.4, 1310669.05, 1424520.74, mapFrame.Map.SpatialReference);
  autoCamera.Extent = extent;
SetAutoCameraFixedCenter
  autoCamera.AutoCameraType = AutoCameraType.Center;
  var camera = mapFrame.GetMapView(LayoutView.Active).Camera;
  var center = mapFrame.GetViewCenter();
  //var extent = EnvelopeBuilderEx.CreateEnvelope(
  //    400748.62, 800296.4, 1310669.05, 1424520.74, mf.Map.SpatialReference);
  //autoCamera.Extent = extent;
  var camera2 = new CIMViewCamera()
    Heading = 0,
    Pitch = -90,
    Roll = 0,
    Scale = 21169571,
    X = 855708,
    Y = 1112409,
    Z = double.NaN
  autoCamera.Camera = camera2;
  var states = mapFrame.Map.GetLayersAsFlattenedList().First(l => l.Name == "State_Polygons");
  autoCamera.IntersectLayerPath = states.URI;
SetAutoCameraFixedCenterAndScale
  autoCamera.AutoCameraType = AutoCameraType.CenterAndScale;
    Heading = 0,
    Pitch = -90,
    Roll = 0,
    Scale = 21169571,
    X = 1310669.0 + ((400748.5 - 1310669.0) / 2.0),
    Y = 800296.4 + ((1424520.74 - 800296.4) / 2.0),
    Z = double.NaN
  //autoCamera.IntersectLayerPath = states.URI;
SetAutoCameraFixedScale
  autoCamera.AutoCameraType = AutoCameraType.Scale;
    Heading = 0,
    Pitch = -90,
    Roll = 0,
    Scale = 20000571,
    Z = double.NaN
SetAutoCameraLinkedExtent
  autoCamera.Source = AutoCameraSource.MapFrameLink;
  autoCamera.MapFrameLinkName = "mapFrameLink";
SetAutoCameraLinkedCenter
SetAutoCameraLinkedCenterAndScale
SetAutoCameraLinkedScale
SetAutoCameraLinkedMapSeriesShape
  autoCamera.Source = AutoCameraSource.MapSeriesLink;
  //autoCamera.MapFrameLinkName = mapFrameLink;
SetAutoCameraLinkedMapSeriesCenter
ProSnippets Group: Layer visibility overrides in MapFrames
Set Layer Visibility Overrides in MapFrames
//Note: Run this code within a QueuedTask
  //Get the USA States map from the project
  //This map has both States and Cities layers
  var usaMap = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(m => m.Name == "USA States")?.GetMap();
  //The layout has two map frames - one for States and one for Cities
  //We will set layer visibility overrides on each map frame, so that only the relevant layer is visible in each map frame
  // Get the States map frame in the layout
  var statesMapFrame = layout.Elements.OfType<MapFrame>().FirstOrDefault(n => n.Name == "States");
  //Get the map frame definition
  var mapFrameDefinition = statesMapFrame.GetDefinition() as CIMMapFrame;
  //Enable layer visibility overrides for the states map frame
  mapFrameDefinition.OverrideLayerVisibility = true;
  //Create layer override sets
  //Set States layer to visible and Cities layer to not visible
  var layerOverrideSets = new List<CIMLayerOverrideSet>
              new CIMLayerOverrideSet
                  LayerURI = usaMap.Layers.FirstOrDefault(l => l.Name == "States")?.URI,
                  Value = true
              new CIMLayerOverrideSet {
                  LayerURI = usaMap.Layers.FirstOrDefault(l => l.Name == "Cities")?.URI,
                  Value = false
  //Assign the layer override sets to the map frame definition
  mapFrameDefinition.LayerVisibilityOverrides = layerOverrideSets.ToArray();
  //Set the modified definition back to the map frame
  statesMapFrame.SetDefinition(mapFrameDefinition);
  //Next, get the cities map frame in the layout
  var citiesMapFrame = layout.Elements.OfType<MapFrame>().FirstOrDefault(n => n.Name == "Cities");
  //Get the map frame definition for the cities map frame
  var mapFrameDefinitionCities = citiesMapFrame.GetDefinition() as CIMMapFrame;
  //Enable layer visibility overrides for the cities map frame
  mapFrameDefinitionCities.OverrideLayerVisibility = true;
  //Create layer override sets for the cities map frame
  //Set Cities layer to visible and States layer to not visible
  var layerOverrideSetsCities = new List<CIMLayerOverrideSet>
                  Value = false
                  Value = true
  //Assign the layer override sets to the cities map frame definition
  mapFrameDefinitionCities.LayerVisibilityOverrides = layerOverrideSetsCities.ToArray();
  //Set the modified definition back to the cities map frame
  citiesMapFrame.SetDefinition(mapFrameDefinitionCities);
Remove Layer Visibility Overrides in MapFrames
  //Get all map frames in the layout
  var mapFrames = layout.Elements.OfType<MapFrame>();
  //Iterate through each map frame in the layout
  foreach (var mapFrameInLayout in mapFrames)
    var mapFrameDefinition = mapFrame.GetDefinition() as CIMMapFrame;
    //Remove all layer visibility overrides
    mapFrameDefinition.OverrideLayerVisibility = false;
    mapFrameDefinition.LayerVisibilityOverrides = null;
    mapFrame.SetDefinition(mapFrameDefinition);
