ProSnippets LinearReferencing
Language: C#
Subject: LinearReferencing
Contributor: ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization: Esri, http://www.esri.com
Date: 4/30/2026
ArcGIS Pro: 3.7
Visual Studio: 2026
Create a routes feature class using the DDL
static void CreateRoutes(SchemaBuilder schemaBuilder)
FieldDescription routeIdDescription = FieldDescription.CreateIntegerField("RouteID");
FieldDescription routeNameDescription = FieldDescription.CreateStringField("RouteName", 100);
ShapeDescription shapeDescription = new ShapeDescription(GeometryType.Polyline, SpatialReferences.WGS84)
{ HasM = true, HasZ = false };
FeatureClassDescription routeFeatureClassDescription = new FeatureClassDescription("Routes",
new List<FieldDescription>() { routeIdDescription, routeNameDescription }, shapeDescription);
//Create an M-enabled poly-line feature class
schemaBuilder.Create(routeFeatureClassDescription);
schemaBuilder.Build();
Create an events table using the DDL
static void CreateEvents(SchemaBuilder schemaBuilder)
FieldDescription routeIdDescription = FieldDescription.CreateIntegerField("RID");
FieldDescription measureFieldDescription = new FieldDescription("Measure", FieldType.Double);
FieldDescription offsetFieldDescription = FieldDescription.CreateIntegerField("OffsetValue");
TableDescription eventTableDescription = new TableDescription("LR_EventTable",
new List<FieldDescription>() { routeIdDescription, offsetFieldDescription, measureFieldDescription });
schemaBuilder.Create(eventTableDescription);
static void CreateRouteInfo(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string routeIdFieldName = "RouteID")
using (FeatureClass routeFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
using (FeatureClassDefinition routeFeatureClassDefinition = routeFeatureClass.GetDefinition())
if (routeFeatureClassDefinition.HasM())
RouteInfo routeInfo = new RouteInfo(routeFeatureClass, routeIdFieldName);
// Process the routeInfo as needed ...
static void CreateEventInfo(Geodatabase geodatabase, string eventTableName = "Accidents", string routeIdFieldName = "RID", string measureFieldName = "Measure", string offsetFieldName = "Offset")
using (Table eventTable = geodatabase.OpenDataset<Table>(eventTableName))
PointEventInfo eventInfo = new PointEventInfo(eventTable, routeIdFieldName, measureFieldName, offsetFieldName);
// Get event type: Point or Line type
EventType eventTableType = eventInfo.EventType;
Create a RouteEventSource via dynamic segmentation process for point events
static void CreatePointEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string measureFieldName = "Measure")
using (FeatureClass routesFeatureClass = geodatabase.OpenDataset<FeatureClass>(routeFeatureClassName))
using (Table eventsTable = geodatabase.OpenDataset<Table>(eventTableName))
RouteInfo routeInfo = new RouteInfo(routesFeatureClass, routeIdFieldName);
EventInfo eventInfo = new PointEventInfo(eventsTable, routeIdFieldName, measureFieldName);
RouteEventSourceOptions routeEventSourceOptions = new PointEventSourceOptions(AngleType.Tangent)
{ ComplementAngle = true };
using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, routeEventSourceOptions))
using (RouteEventSourceDefinition routeEventSourceDefinition = routeEventSource.GetDefinition())
// Locating errors
IReadOnlyList<RouteEventSourceError> errors = routeEventSource.GetErrors();
// Route event source fields
IReadOnlyList<Field> routeEventSourceFields = routeEventSourceDefinition.GetFields();
// Add RouteEventSource to the ArcGIS Pro map
FeatureLayerCreationParams layerParams = new FeatureLayerCreationParams(routeEventSource)
Name = "RoadAccidents"
LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
Create a RouteEventSource via dynamic segmentation process for line events
static void CreateLineEventSource(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string toMeasureFieldName = "toMeasure", string fromMeasureFieldName = "fromMeasure", string offsetFieldName = "Offset")
EventInfo eventInfo = new LineEventInfo(eventsTable, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName, offsetFieldName);
RouteEventSourceOptions routeEventSourceOptions = new LineEventSourceOptions() { IsPositiveOffsetOnRight = true };
// Locating errors
Name = "HighCrashAreas"
Locate features along routes
static void LocateLineFeaturesAlongRoutes(Geodatabase geodatabase, string routeFeatureClassName = "Roads", string eventTableName = "Accidents", string routeIdFieldName = "RID", string toMeasureFieldName = "toMeasure", string fromMeasureFieldName = "fromMeasure")
// Configure events table
EventTableConfiguration lineEventTableConfiguration = new LineEventTableConfiguration(eventTableName, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName) { KeepAllFields = true, MDirectionOffset = true };
using (FeatureClass highCrashAreaFeatureClass = geodatabase.OpenDataset<FeatureClass>("HighCrashRegion"))
// Creates an event table inside the geodatabase
routeInfo.LocateFeatures(highCrashAreaFeatureClass, 0.5, lineEventTableConfiguration);
// Open newly created event table
EventInfo eventInfo = new LineEventInfo(eventTable, routeIdFieldName, fromMeasureFieldName, toMeasureFieldName);
// Create RouteEventSource using new event table
using (RouteEventSource routeEventSource = new RouteEventSource(routeInfo, eventInfo, new LineEventSourceOptions()))
// Process the routeEventSource as needed ...
