//Get all styles in the project
var ProjectStyles = Project.Current.GetItems<StyleProjectItem>();
//Get a specific style in the project by name
StyleProjectItem styleFound = ProjectStyles.First(x => x.Name == "NameOfTheStyle");
How to create a new style
//Full path for the new style file (.stylx) to be created
string styleToCreate = @"C:\Temp\NewStyle.stylx";
//Note: Needs QueuedTask to run
StyleHelper.CreateStyle(Project.Current, styleToCreate);
How to add a style to project
//For ArcGIS Pro system styles, just pass in the name of the style to add to the project
StyleHelper.AddStyle(Project.Current, "3D Vehicles");
//For custom styles, pass in the full path to the style file on disk
string customStyleToAdd = @"C:\Temp\CustomStyle.stylx";
StyleHelper.AddStyle(Project.Current, customStyleToAdd);
How to remove a style from project
//For ArcGIS Pro system styles, just pass in the name of the style to remove from the project
StyleHelper.RemoveStyle(Project.Current, "3D Vehicles");
StyleHelper.RemoveStyle(Project.Current, customStyleToAdd);
How to add a style item to a style
//Create a new style item
//You can generate a swatch for a text symbols also.
CIMSymbol symbolToAdd = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
SymbolStyleItem styleItemToAdd = new SymbolStyleItem()
Symbol = symbolToAdd,
PatchHeight = 64,
PatchWidth = 64
styleProjectItem.AddItem(styleItemToAdd);
How to remove a style item from a style
//Remove any item from style
//Note: symbolStyleItem was created above in the variable initialization section
styleProjectItem.RemoveItem(symbolStyleItem);
How to determine if a style can be upgraded
//Add the style to the current project
string stylePath = @"C:\MyStyles\OldStyle.stylx";
StyleHelper.AddStyle(Project.Current, stylePath);
StyleProjectItem styleToUpgrade = Project.Current.GetItems<StyleProjectItem>().First(x => x.Path == stylePath);
//returns true if style can be upgraded
bool canUpgrade = styleToUpgrade.CanUpgrade;
How to determine if a style is read-only
string stylePath = @"C:\MyStyles\MyStyle.stylx";
StyleProjectItem styleToCheck = Project.Current.GetItems<StyleProjectItem>().First(x => x.Path == stylePath);
//returns true if style is read-only
bool isReadOnly = styleToCheck.IsReadOnly;
How to determine if a style is current
//returns true if style matches the current Pro version
bool isCurrent = styleToCheck.IsCurrent;
How to upgrade a style
bool success = false;
//Verify that style can be upgraded
if (styleToUpgrade.CanUpgrade)
success = StyleHelper.UpgradeStyle(styleToUpgrade);
Symbols
How to construct a point symbol of a specific color and size
How to construct a point symbol from a file on disk
//The following file formats can be used to create the marker: DAE, 3DS, FLT, EMF, JPG, PNG, BMP, GIF
//Note: Run within QueuedTask.Run
CIMMarker markerFromFile = SymbolFactory.Instance.ConstructMarkerFromFile(@"C:\Temp\fileName.dae");
CIMPointSymbol pointSymbolFromFile = SymbolFactory.Instance.ConstructPointSymbol(markerFromFile);
How to construct a point symbol from a in memory graphic
//Create a stream for the image
//At 3.0 you need https://www.nuget.org/packages/Microsoft.Windows.Compatibility
//System.Drawing
System.Drawing.Image newImage = System.Drawing.Image.FromFile(@"C:\PathToImage\Image.png");
var stream = new System.IO.MemoryStream();
newImage.Save(stream, System.Drawing.Imaging.ImageFormat.Png);
stream.Position = 0;
//Create marker using the stream
CIMMarker markerFromStream = SymbolFactory.Instance.ConstructMarkerFromStream(stream);
//Create the point symbol from the marker
CIMPointSymbol pointSymbolFromStream = SymbolFactory.Instance.ConstructPointSymbol(markerFromStream);
How to construct a polygon symbol of specific color and fill style
How to construct a multilayer line symbol with circle markers on the line ends
var lineStrokeRed = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 4.0);
var markerCircle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Circle);
markerCircle.MarkerPlacement = new CIMMarkerPlacementOnVertices()
AngleToLine = true,
PlaceOnEndPoints = true,
Offset = 0
var lineSymbolWithCircles = new CIMLineSymbol()
SymbolLayers = new CIMSymbolLayer[2] { markerCircle, lineStrokeRed }
How to construct a multilayer line symbol with an arrow head on the end
var markerTriangle = SymbolFactory.Instance.ConstructMarker(ColorFactory.Instance.RedRGB, 12, SimpleMarkerStyle.Triangle);
markerTriangle.Rotation = -90; // or -90
markerTriangle.MarkerPlacement = new CIMMarkerPlacementOnLine() { AngleToLine = true, RelativeTo = PlacementOnLineRelativeTo.LineEnd };
var lineSymbolWithArrow = new CIMLineSymbol()
SymbolLayers = new CIMSymbolLayer[2] { markerTriangle,
SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.RedRGB, 2)
How to get symbol reference from a symbol
CIMPolygonSymbol polySymbol = SymbolFactory.Instance.ConstructPolygonSymbol(ColorFactory.Instance.RedRGB);
//Get symbol reference from the symbol
CIMSymbolReference symbolReference = polySymbol.MakeSymbolReference();
Modify a point symbol created from a character marker
//create marker from the Font, char index,size,color
var cimMarker = SymbolFactory.Instance.ConstructMarker(125, "Wingdings 3", "Regular", 6, ColorFactory.Instance.BlueRGB) as CIMCharacterMarker;
var polygonMarker = cimMarker.Symbol;
//modifying the polygon's outline and fill
//This is the outline
polygonMarker.SymbolLayers[0] = SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.GreenRGB, 2, SimpleLineStyle.Solid);
//This is the fill
polygonMarker.SymbolLayers[1] = SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.BlueRGB);
//create a symbol from the marker
//Note this overload of ConstructPointSymbol does not need to be run within QueuedTask.Run.
var pointSymbol = SymbolFactory.Instance.ConstructPointSymbol(cimMarker);
Get a List of Available Fonts
//returns a tuple per font: (string fontName, List<string> fontStyles)
var fonts = SymbolFactory.Instance.GetAvailableFonts();
foreach (var font in fonts)
var styles = string.Join(",", font.fontStyles);
System.Diagnostics.Debug.WriteLine($"{font.fontName}, styles: {styles}");
Get/Set Default Font
var def_font = SymbolFactory.Instance.DefaultFont;
System.Diagnostics.Debug.WriteLine($"{def_font.fontName}, styles: {def_font.styleName}");
//set default font - set through application options
//Note: Must use QueuedTask
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma");
ApplicationOptions.TextAndGraphicsElementsOptions.SetDefaultFont("tahoma", "bold");
Construct a Text Symbol With Options
//using the default font
var textSym1 = SymbolFactory.Instance.ConstructTextSymbol();
var textSym2 = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.BlueRGB, 14);
//using a specific font
var textSym3 = SymbolFactory.Instance.ConstructTextSymbol("Arial");
var textSym4 = SymbolFactory.Instance.ConstructTextSymbol(
"Arial", "Narrow Bold");
//or query available fonts to ensure the font is there
var all_fonts = SymbolFactory.Instance.GetAvailableFonts();
var font = all_fonts.FirstOrDefault(f => f.fontName == "Arial");
if (!string.IsNullOrEmpty(font.fontName))
var textSym5 = SymbolFactory.Instance.ConstructTextSymbol(font.fontName);
//or with a font+style
var textSym6 = SymbolFactory.Instance.ConstructTextSymbol(
font.fontName, font.fontStyles.First());
//overloads - font + color and size, etc
var textSym7 = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.BlueRGB, 14, "Times New Roman", "Italic");
//custom symbol - black stroke, red fill
var poly_symbol = SymbolFactory.Instance.ConstructPolygonSymbol(
SymbolFactory.Instance.ConstructSolidFill(ColorFactory.Instance.RedRGB),
SymbolFactory.Instance.ConstructStroke(ColorFactory.Instance.BlackRGB, 1));
var textSym8 = SymbolFactory.Instance.ConstructTextSymbol(
poly_symbol, 14, "Georgia", "Bold");
Create a Swatch for a given symbol
//Note: call within QueuedTask.Run()
CIMSymbol symbolForSwatch = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
var si = new SymbolStyleItem()
Symbol = symbolForSwatch,
PatchHeight = 64,
PatchWidth = 64
Convert Point Symbol to SVG
//Create a point symbol
ColorFactory.Instance.RedRGB, 24, SimpleMarkerStyle.RoundedSquare);
//Generate image returns a stream
//OutputImageFormat specified the format for the image - in this case
//we want SVG (an xml-based format)
//output fmt: SVG, scale factor x2, centerAnchorPoint = true
//dpi = 300, wd x ht: 100x100px, background: white
var mem_strm = SymbolFactory.Instance.GenerateImage(
pointSymbol, OutputImageFormat.SVG, 2.0, true, 300, 100, 100,
ColorFactory.Instance.WhiteRGB);
//Set the memory stream position to the beginning
mem_strm.Seek(0, SeekOrigin.Begin);
//File path and name for saving the SVG file
var fileName = "RoundedSquareSymbol.svg";
string path_svg = System.IO.Path.Combine(System.IO.Path.GetTempPath() + fileName);
//Write the memory stream to the file
System.IO.File.WriteAllBytes(path_svg, mem_strm.ToArray());
//Note: to convert SVG to image format, use a 3rd party
//e.g. Aspose.SVG for .NET, for example convert SVG to PNG
//using (var svg_doc = new Aspose.Svg.SVGDocument(path_svg))
// string path_png = Path.Combine(Path.GetTempPath() + "RoundedSquareSymbol.png");
// using (var img_png = new Aspose.Svg.Rendering.Image.ImageDevice(
// new ImageRenderingOptions(ImageFormat.Png), path_png))
// svg_doc.RenderTo(img_png);
// //also: https://docs.aspose.com/imaging/net/convert-svg-to-png/
Convert Point Symbol to PNG
//we want PNG
//output fmt: PNG, scale factor x2, centerAnchorPoint = true
pointSymbol, OutputImageFormat.PNG, 2.0, true, 300, 100, 100,
//Write the stream to a bit map
var bitmapImage = new System.Windows.Media.Imaging.BitmapImage();
bitmapImage.BeginInit();
bitmapImage.StreamSource = mem_strm;
bitmapImage.CacheOption = System.Windows.Media.Imaging.BitmapCacheOption.OnLoad;
bitmapImage.EndInit();
bitmapImage.Freeze();
//Write the bit map out to a file
//File path and name for saving the PNG file
var fileName = "RoundedSquareSymbol.png";
string path_png = System.IO.Path.Combine(System.IO.Path.GetTempPath() + fileName);
BitmapEncoder encoder = new PngBitmapEncoder();
encoder.Frames.Add(BitmapFrame.Create(bitmapImage));
using (var fileStream = new System.IO.FileStream(
path_png, System.IO.FileMode.Create))
encoder.Save(fileStream);
Lookup Symbol
//feature layer from the active map
var featureLayerLookUp = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>()
.FirstOrDefault();
//Get the selection
var selection = featureLayerLookUp.GetSelection();
//Get the first Object ID
var firstOID = selection.GetObjectIDs().FirstOrDefault();
//Determine whether the layer's renderer type supports symbol lookup.
if (featureLayerLookUp.CanLookupSymbol())
//Looks up the symbol for the corresponding feature identified by the object id.
var lookupSymbol = featureLayerLookUp.LookupSymbol(firstOID, MapView.Active);
var jSon = lookupSymbol.ToJson(); //Create a JSON encoding of the symbol
//Do something with symbol
Symbol Search
How to search for a specific item in a style
//Search for a specific point symbol in style
//Note: styleProjectItem was created above in the variable initialization section
string key = "Circle 1_Shapes_3";
SymbolStyleItem item = (SymbolStyleItem)styleProjectItem.LookupItem(StyleItemType.PointSymbol, key);
How to search for point symbols in a style
//Search for point symbols
styleProjectItem.SearchSymbols(StyleItemType.PointSymbol, "searchString");
How to search for line symbols in a style
//Search for line symbols
styleProjectItem.SearchSymbols(StyleItemType.LineSymbol, "searchString");
How to search for polygon symbols in a style
//Search for polygon symbols
styleProjectItem.SearchSymbols(StyleItemType.PolygonSymbol, "searchString");
How to search for colors in a style
//Search for colors
styleProjectItem.SearchColors("searchString");
How to search for color ramps in a style
//StyleProjectItem can be "ColorBrewer Schemes (RGB)", "ArcGIS 2D"...
//Search for color ramps
//Color Ramp searchString can be "Spectral (7 Classes)", "Pastel 1 (3 Classes)", "Red-Gray (10 Classes)"..
styleProjectItem.SearchColorRamps("searchString");
How to search for north arrows in a style
//Search for north arrows
styleProjectItem.SearchNorthArrows("searchString");
How to search for scale bars in a style
//Search for scale bars
styleProjectItem.SearchScaleBars("searchString");
How to search for label placements in a style
//Search for label placements
styleProjectItem.SearchLabelPlacements(StyleItemType.StandardLabelPlacement, "searchString");
How to search for legends in a style
//Search for legends
styleProjectItem.SearchLegends("searchString");
How to search for legend items in a style
//Search for legend items
styleProjectItem.SearchLegendItems("searchString");
How to search for grids in a style
//Search for grids
styleProjectItem.SearchGrids("searchString");
How to search for map surrounds in a style
//Search for map surrounds
styleProjectItem.SearchMapSurrounds("searchString");
How to search for table frames in a style
//Search for table frames
styleProjectItem.SearchTableFrames("searchString");
How to search for table frame fields in a style
//Search for table frame fields
styleProjectItem.SearchTableFrameFields("searchString");
Feature Layer Symbology
How to set symbol for a feature layer symbolized with simple renderer
//Get simple renderer from the feature layer
CIMSimpleRenderer currentRenderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
if (currentRenderer == null)
return;
//Set symbol's real world setting to be the same as that of the feature layer
symbol.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
//Update the symbol of the current simple renderer
currentRenderer.Symbol = symbol.MakeSymbolReference();
//Update the feature layer renderer
featureLayer.SetRenderer(currentRenderer);
How to apply a symbol from style to a feature layer
return;
//Get symbol from the SymbolStyleItem
CIMSymbol symbolToApply = symbolStyleItem.Symbol;
symbolToApply.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
currentRenderer.Symbol = symbolToApply.MakeSymbolReference();
How to apply a point symbol from a style to a feature layer
//Get the ArcGIS 2D System style from the Project
var arcGIS2DStyle =
Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS 2D");
//Search for the symbolName style items within the ArcGIS 2D style project item.
var items = arcGIS2DStyle.SearchSymbols(StyleItemType.PointSymbol, "Circle 1");
//Gets the CIMSymbol
CIMSymbol symbolToUse = items.FirstOrDefault().Symbol;
//Get the renderer of the point feature layer
CIMSimpleRenderer renderer = featureLayer.GetRenderer() as CIMSimpleRenderer;
symbolToUse.SetRealWorldUnits(featureLayer.UsesRealWorldSymbolSizes);
//Apply the symbol to the feature layer's current renderer
renderer.Symbol = symbolToUse.MakeSymbolReference();
//Apply the renderer to the feature layer
featureLayer.SetRenderer(renderer);
How to apply a color ramp from a style to a feature layer
List<string> fields = new List<string>() { "Field1" };
StyleProjectItem styleToUse =
.FirstOrDefault(s => s.Name == "ColorBrewer Schemes (RGB)");
if (style == null) return;
var colorRampListFound = styleToUse.SearchColorRamps("Red-Gray (10 Classes)");
if (colorRampListFound == null || colorRampListFound.Count == 0) return;
CIMColorRamp cimColorRamp = null;
CIMRenderer renderer = null;
cimColorRamp = colorRampListFound[0].ColorRamp;
var rendererDef = new UniqueValueRendererDefinition(fields, null, cimColorRamp);
renderer = featureLayer?.CreateRenderer(rendererDef);
featureLayer?.SetRenderer(renderer);
Maps
Get the active map
//This is how you get the active map
var mapToGet = MapView.Active?.Map;
Create a new map with a default basemap layer
MapFactory.Instance.CreateMap("The Map", ArcGIS.Core.CIM.MapType.Map, ArcGIS.Core.CIM.MapViewingMode.Map, Basemap.ProjectDefault);
Find a map within a project and open it
//Finding the first project item with name matches with mapName
MapProjectItem? mpi = Project.Current.GetItems<MapProjectItem>()
.FirstOrDefault(m => m.Name.Equals("The Map", StringComparison.CurrentCultureIgnoreCase));
var mapFromItem = mpi?.GetMap();
if (mapFromItem != null)
//Open the map in a new map pane
//Must be called from the UI thread
await ProApp.Panes.CreateMapPaneAsync(map);
Open a webmap
//Assume we get the selected webmap from the Project pane's Portal tab
if (Project.Current.SelectedItems.Count > 0)
if (MapFactory.Instance.CanCreateMapFrom(Project.Current.SelectedItems[0]))
map = MapFactory.Instance.CreateMapFromItem(Project.Current.SelectedItems[0]);
//Gets the unique list of Maps from all the MapPanes.
//Note: The list of maps retrieved from the MapPanes
//maybe less than the total number of Maps in the project.
//It depends on what maps the user has actually opened.
var mapPanes = ProApp.Panes.OfType<IMapPane>()
.GroupBy((mp) => mp.MapView.Map.URI).Select(grp => grp.FirstOrDefault());
List<Map> uniqueMaps = new List<Map>();
foreach (var pane in mapPanes)
uniqueMaps.Add(pane.MapView.Map);
Change the Map name and caption of the active pane
MapView.Active.Map.SetName("Test");
ProApp.Panes.ActivePane.Caption = "Caption";
Convert Map to Local Scene
//Note: Run within the context of QueuedTask.Run
bool canConvertMap = MapFactory.Instance.CanConvertMap(map, MapConversionType.SceneLocal);
if (canConvertMap)
MapFactory.Instance.ConvertMap(map, MapConversionType.SceneLocal, true);
Get Basemaps
//Basemaps stored locally in the project. This is usually an empty collection
string localBasemapTypeID = "cim_map_basemap";
var mapContainer = Project.Current.GetProjectItemContainer("Map");
mapContainer.GetItems().Where(i => i.TypeID == localBasemapTypeID).ToList();
//portal basemaps. If there is no current active portal, the usual default
//is arcgis online
var portal = ArcGISPortalManager.Current.GetActivePortal();
var portalBaseMaps = await portal.GetBasemapsAsync();
//use one of them...local or portal...
//var map = MapView.Active.Map;
//QueuedTask.Run(() => map?.SetBasemapLayers(portalBaseMaps[0]));
Save Map as MapX
map.SaveAsFile(@"C:\Data\MyMap.mapx", true);
Save 2D Map as WebMap on Disk
//2D maps only
//Must be on the QueuedTask.Run(...)
if (map.DefaultViewingMode == MapViewingMode.Map)
//Only webmap compatible layers will be saved out to the file
map.SaveAsWebMapFile(@"C:\Data\MyMap.json");
Clip Map to the provided clip polygon
var mapToClip = MapView.Active.Map;
//A layer to use for the clip extent
var lyrOfInterest = mapToClip.GetLayersAsFlattenedList().OfType<FeatureLayer>().Where(l => l.Name == "TestPoly").FirstOrDefault();
//Get the polygon to use to clip the map
var extent = lyrOfInterest.QueryExtent();
var polygonForClipping = PolygonBuilderEx.CreatePolygon(extent);
//Clip the map using the layer's extent
mapToClip.SetClipGeometry(polygonForClipping,
SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.BlueRGB, 2.0, SimpleLineStyle.Dash)));
Clear the current map clip geometry
var mapWithClip = MapView.Active.Map;
//Clear the Map clip.
//If no clipping is set then this is a no-op.
mapWithClip.ClearClipGeometry();
Get the map clipping geometry
//If clipping is set to ArcGIS.Core.CIM.ClippingMode.None or ArcGIS.Core.CIM.ClippingMode.MapSeries null is returned
//If clipping is set to ArcGIS.Core.CIM.ClippingMode.MapExtent the ArcGIS.Core.CIM.CIMMap.CustomFullExtent is returned.
//Otherwise, if clipping is set to ArcGIS.Core.CIM.ClippingMode.CustomShape the custom clip polygon is returned.
//Note: Must be on the QueuedTask.Run()
var poly = mapWithClip.GetClipGeometry();
//You can use the polygon returned
//For example: We make a polygon graphic element and add it to a Graphics Layer.
var gl = mapWithClip.GetLayersAsFlattenedList().OfType<GraphicsLayer>().FirstOrDefault();
if (gl == null) return;
var polygonSymbol = SymbolFactory.Instance.ConstructPolygonSymbol(CIMColor.CreateRGBColor(255, 255, 0));
var cimGraphicElement = new CIMPolygonGraphic
Polygon = poly,
Symbol = polygonSymbol.MakeSymbolReference()
gl.AddElement(cimGraphicElement);
Get the Current Map Location Unit
//Get the current location unit
var loc_unit = map.GetLocationUnitFormat();
var line = $"{loc_unit.DisplayName}, {loc_unit.UnitCode}";
System.Diagnostics.Debug.WriteLine(line);
Get the Available List of Map Location Units
//Linear location unit formats are not included if the map sr
//is geographic.
var loc_units = map.GetAvailableLocationUnitFormats();
Format a Location Using the Current Map Location Unit
//Get the current view camera location
var center_pt = new Coordinate2D(mapView.Camera.X, mapView.Camera.Y);
//Format the camera location
var str = loc_unit.FormatLocation(center_pt, map.SpatialReference);
System.Diagnostics.Debug.WriteLine($"Formatted location: {str}");
Set the Location Unit for the Current Map
//Get the list of available location unit formats
//for the current map
//arbitrarily use the last unit in the list
map.SetLocationUnitFormat(loc_units.Last());
Get the Current Map Elevation Unit
var elev_unit = map.GetElevationUnitFormat();
var line = $"{elev_unit.DisplayName}, {elev_unit.UnitCode}";
Get the Available List of Map Elevation Units
//If the map is not a scene, the list of current
//Project distance units will be returned
var elev_units = map.GetAvailableElevationUnitFormats();
Format an Elevation Using the Current Map Elevation Unit
//Get the current elevation unit. If the map is not
//a scene the default Project distance unit is returned
//Format the view camera elevation
var str = elev_unit.FormatValue(mapView.Camera.Z);
System.Diagnostics.Debug.WriteLine($"Formatted elevation: {str}");
Set the Elevation Unit for the Current Map
//Trying to set the elevation unit on a map other than
//a scene will throw an InvalidOperationException
if (map.IsScene)
//Get the list of available elevation unit formats
var loc_units = map.GetAvailableElevationUnitFormats();
map.SetElevationUnitFormat(loc_units.Last());
var gridOptions = GridOptionsEnvironment.Instance.DefaultGridOptions;
Get the Grid Options for a Map
//Does the 'map' currently have any options?
var hasOptions = GridOptionsEnvironment.Instance.HasGridOptions(map);
//If grid options have not been set for the map, then default grid options are added
//for the map otherwise the existing gridoptions are returned.
//NOTE: Grid options are returned by value meaning a copy is always returned. Any changes made to the
//grid options need to be -set- back on the map using SetGridOptions for the changes to persist.
var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(
MapView.Active.Map);
//Only return grid options if grid options have previously been set:
var gridOptions2 = GridOptionsEnvironment.Instance.GetGridOptions(
MapView.Active.Map, false);
Get and Set Grid Options for a Map
//assume
//for the map and returned otherwise the existing gridoptions are returned.
//NOTE: Grid options are by value meaning a copy is returned. Any changes made to the
var gridOptions = GridOptionsEnvironment.Instance.GetGridOptions(map);
//change some properties
gridOptions.RotateWithMap = !gridOptions.RotateWithMap;
gridOptions.GridLineColor = ColorFactory.Instance.RedRGB;
gridOptions.GridLineColor = ColorFactory.Instance.BlueRGB;
//To apply changes, the gridoptions must be set back on the map
GridOptionsEnvironment.Instance.SetGridOptions(map, gridOptions);
Set Grid Origin for Grid Options for a Map
//assume
var center_pt = MapView.Active.Extent.Center;
var width = MapView.Active.Extent.Width;
var height = MapView.Active.Extent.Height;
var qtr_width = width * 0.25;
var qtr_ht = height * 0.25;
//Set the grid origin
var x1 = center_pt.X + qtr_width;
var y1 = center_pt.Y + qtr_ht;
gridOptions.SetGridOrigin(new Coordinate2D(x1, y1));
//or use Coordinate3D
gridOptions.SetGridOrigin(new Coordinate3D(x1, y1, 0));
Set Various Grid Option parameters for GridOptions for a Map
//use defaults
//customize the options as needed
var gs_rotation = gridOptions.GetGridRotation();
gridOptions.SetGridRotation(gs_rotation * 1.5);
var gs_meters = gridOptions.GetGridSpacingMeters();
var gs_in_spacing_units = gridOptions.GetGridSpacing();
var gs_units = gridOptions.GridSpacingUnits;
//meters assumed
gridOptions.SetGridSpacingInMeters(gs_meters + 10);
//specify units explicitly
gridOptions.SetGridSpacing(1000, LinearUnit.Feet);//internally will be converted to meters
gridOptions.IsGridLines = true;//use lines (default)
var grid_interval = gridOptions.GridMajorInterval;
gridOptions.SnapToGridEnabled = true;
var x1 = center_pt.X - qtr_width;
Reset the Grid Options for a Map back to Defaults
if (GridOptionsEnvironment.Instance.HasGridOptions(map))
//set back to defaults - will overwrite existing
GridOptionsEnvironment.Instance.DefaultGridOptions);
Remove the Grid Options from a Map
GridOptionsEnvironment.Instance.RemoveGridOptions(map);
var hasSyncEnabledContent = GenerateOfflineMap.Instance.GetCanGenerateReplicas(map);
if (hasSyncEnabledContent)
//TODO - use status...
Generate Replicas for Sync-Enabled Content
//namespace ArcGIS.Desktop.Mapping.Offline
var extent = MapView.Active.Extent;
//Check map has sync-enabled content that can be taken offline
//Generate Replicas and take the content offline
//sync-enabled content gets copied local into a SQLite DB
var gen_params = new GenerateReplicaParams()
Extent = extent, //SR of extent must match map SR
//DestinationFolder can be left blank, if specified,
//it must exist. Defaults to project offline maps location
DestinationFolder = @"C:\Data\Offline"
//Sync-enabled layer content will be resourced to point to the
//local replica content.
GenerateOfflineMap.Instance.GenerateReplicas(map, gen_params);
Check Map Has Local Syncable Content
//Check map has local syncable content
var canSyncContent = GenerateOfflineMap.Instance.GetCanSynchronizeReplicas(map);
if (canSyncContent)
//TODO - use status
Synchronize Replicas for Syncable Content
if (canSyncContent)
//Sync Replicas - changes since last sync are pushed to the
//parent replica. Parent changes are pulled to the client.
//Unsaved edits are _not_ sync'd.
GenerateOfflineMap.Instance.SynchronizeReplicas(map);
Remove Replicas for Syncable Content
//Either..
//var canSyncContent = GenerateOfflineMap.Instance.GetCanSynchronizeReplicas(map);
//Or...both accomplish the same thing...
var canRemove = GenerateOfflineMap.Instance.GetCanRemoveReplicas(map);
if (canRemove)
//Remove Replicas - any unsync'd changes are lost
//Call sync _first_ to push any outstanding changes if
//needed. Local syncable content is re-sourced
//to point to the service
GenerateOfflineMap.Instance.RemoveReplicas(map);
Export Map Raster Tile Cache Content
//Does the map have any exportable raster content?
var canExport = GenerateOfflineMap.Instance.GetCanExportRasterTileCache(map);
var rasterTileExtent = MapView.Active.Extent;
if (canExport)
//Check the available LOD scale ranges
var scales = GenerateOfflineMap.Instance.GetExportRasterTileCacheScales(map, rasterTileExtent);
//Pick the desired LOD scale
var max_scale = scales[scales.Count() / 2];
//Configure the export parameters
var export_params = new ExportTileCacheParams()
Extent = rasterTileExtent,//Use same extent as was used to retrieve scales
MaximumUserDefinedScale = max_scale
//DestinationFolder = .... (optional)
//If DestinationFolder is not set, output defaults to project
//offline maps location set in the project properties. If that is
//not set, output defaults to the current project folder location.
//Do the export. Depending on the MaximumUserDefinedScale and the
//area of the extent requested, this can take minutes for tile packages
//over 1 GB or less if your network speed is slow...
GenerateOfflineMap.Instance.ExportRasterTileCache(map, export_params);
Export Map Vector Tile Cache Content
var mapVectorTileExtent = MapView.Active.Extent;
//Does the map have any exportable vector tile content?
var canExport = GenerateOfflineMap.Instance.GetCanExportVectorTileCache(map);
if (canExport)
var scales = GenerateOfflineMap.Instance.GetExportVectorTileCacheScales(map, mapVectorTileExtent);
Extent = mapVectorTileExtent,//Use same extent as was used to retrieve scales
MaximumUserDefinedScale = max_scale,
GenerateOfflineMap.Instance.ExportVectorTileCache(map, export_params);
Create Layer
Create and add a layer to the active map
//* string url = @"c:\data\project.gdb\DEM"; //Raster dataset from a FileGeodatabase
//* string url = @"c:\connections\mySDEConnection.sde\roads"; //FeatureClass of a SDE
//* string url = @"c:\connections\mySDEConnection.sde\States\roads"; //FeatureClass within a FeatureDataset from a SDE
//* string url = @"c:\data\roads.shp"; //Shapefile
//* string url = @"c:\data\imagery.tif"; //Image from a folder
//* string url = @"c:\data\mySDEConnection.sde\roads"; //.lyrx or .lpkx file
//* string url = @"c:\data\CAD\Charlottesville\N1W1.dwg\Polyline"; //FeatureClass in a CAD dwg file
//* string url = @"C:\data\CAD\UrbanHouse.rvt\Architectural\Windows"; //Features in a Revit file
//* string url = @"http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer"; //map service
//* string url = @"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0"; //FeatureLayer off a map service or feature service
string urlRoads = @"c:\data\project.gdb\roads"; //FeatureClass of a FileGeodatabase
Uri uri = new Uri(urlRoads);
var newLayer = LayerFactory.Instance.CreateLayer(uri, MapView.Active.Map);
Create layer with create-params
var flyrCreatnParam = new FeatureLayerCreationParams(new Uri(@"c:\data\world.gdb\cities"))
Name = "World Cities",
IsVisible = false,
MinimumScale = 1000000,
MaximumScale = 5000,
DefinitionQuery = new DefinitionQuery(whereClause: "Population > 100000", name: "More than 100k"),
RendererDefinition = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var featureLayerWithParams = LayerFactory.Instance.CreateLayer<FeatureLayer>(flyrCreatnParam, map);
Create FeatureLayer and add to Map using LayerCreationParams
//Get the LayerDocument from a lyrx file
var layerDoc = new LayerDocument(@"E:\Data\SDK\Default2DPointSymbols.lyrx");
//Get the CIMLayerDocument from the LayerDocument and use it to create LayerCreationParams
var createParams = new LayerCreationParams(layerDoc.GetCIMLayerDocument());
//Create a FeatureLayer using the LayerCreationParams
LayerFactory.Instance.CreateLayer<FeatureLayer>(createParams, MapView.Active.Map);
Create FeatureLayer and set to not display in Map.
//The catalog path of the feature layer to add to the map
var featureClassUriVisibility = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
//Define the Feature Layer's parameters.
var layerParamsVisibility = new FeatureLayerCreationParams(featureClassUriVisibility)
//Set visibility
IsVisible = false,
//Create the layer with the feature layer parameters and add it to the active map
var createdFC = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsVisibility, MapView.Active.Map);
Create FeatureLayer with a Renderer
//Define a simple renderer to draw the Point US Cities feature class.
var simpleRender = new SimpleRendererDefinition
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 4.0, SimpleMarkerStyle.Circle).MakeSymbolReference()
var featureClassUri = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
var layerParams = new FeatureLayerCreationParams(featureClassUri)
//Set visibility
IsVisible = true,
//Set Renderer
RendererDefinition = simpleRender,
var createdFCWithRenderer = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
Create FeatureLayer with a Query Definition
var featureClassUriDefinition = new Uri(@"C:\Data\Admin\AdminData.gdb\USA\cities");
var layerParamsQueryDefn = new FeatureLayerCreationParams(featureClassUriDefinition)
IsVisible = true,
DefinitionQuery = new DefinitionQuery(whereClause: "STATE_NAME = 'California'", name: "CACities")
var createdFCWithQueryDefn = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParamsQueryDefn, MapView.Active.Map);
Create multiple layers
//Define a list of dataset URIs for the layers to be created
var uriShp = new Uri(@"c:\data\roads.shp");
var uriSde = new Uri(@"c:\MyDataConnections\MySDE.sde\Census");
var uri = new Uri(@"http://sampleserver6.arcgisonline.com/arcgis/rest/services/NapervilleShelters/FeatureServer/0");
// Create a list of URIs to be used for creating multiple layers
var uris = new List<Uri>() { uriShp, uriSde, uri };
// Create multiple layers using the LayerFactory
var layers = LayerFactory.Instance.CreateLayers(uris, MapView.Active.Map);
Create multiple layers in bulk - simple
Create multiple layers with BulkLayerCreationParams 1
//Uris to the datasets for the layers to be created
var uris = new List<Uri>() { uriShp, uriSde, uri }; ;
// set the index and visibility
var blkParams = new BulkLayerCreationParams(uris);
blkParams.MapMemberPosition = MapMemberPosition.Index;
blkParams.MapMemberIndex = 2;
blkParams.IsVisible = false;
// Create multiple layers using the BulkLayerCreationParams
var layers = LayerFactory.Instance.CreateLayers(blkParams, MapView.Active.Map);
Create multiple layers with BulkLayerCreationParams 2 - invalid
// get a feature class that is selected in the catalog pane
Item item = Project.GetCatalogPane().SelectedItems.FirstOrDefault();
var lcpShp = new FeatureLayerCreationParams(uriShp);
lcpShp.Name = "Roads";
lcpShp.IsVisible = false;
lcpShp.DefinitionQuery = new DefinitionQuery("shpQuery", "OBJECTID > 10");
var lcpItem = new FeatureLayerCreationParams(item);
lcpItem.Name = "Census Polygons";
lcpItem.IsVisible = true;
// list contains a Uri data source and an Item data source
// LayerFactory.Instance.CreateLayers will throw an ArgumentException
var lcps = new List<FeatureLayerCreationParams>();
lcps.Add(lcpShp);
lcps.Add(lcpItem);
var blkParams = new BulkLayerCreationParams(lcps);
// LayerFactory.Instance.CreateLayers will thrown an ArgumentException
// because the LayerCreationParams are created using different
// types of data sources (1 Uri and 1 Item)
Create multiple layers with BulkLayerCreationParams 2 - Valid
var lcpSde = new FeatureLayerCreationParams(uriSde);
lcpSde.Name = "Census Polygons";
lcpSde.IsVisible = true;
var lcpService = new FeatureLayerCreationParams(uri);
lcpService.Name = "Shelters";
lcpService.IsVisible = true;
// set some renderer here ...
//lcpService.RendererDefinition = ...
lcps.Add(lcpShp);
lcps.Add(lcpSde);
lcps.Add(lcpService);
// set the positioning on the BulkLayerCreationParams
blkParams.MapMemberIndex = 0;
Create multiple layers with BulkLayerCreationParams - Using RollbackBehavior
lcps.Add(lcpShp);
lcps.Add(lcpSde);
// set the rollback behavior
// - rollback if one or more layers cannot be created due to an invalid data source
blkParams.RollbackBehavior = LayerCreationRollbackBehavior.RollbackOnMissingLayers;
Add a GeoPackage to the Map
string pathToGeoPackage = @"C:\Data\Geopackage\flooding.gpkg";
//Create lists to hold the URIs of the layers and tables in the geopackage
var layerUris = new List<Uri>();
var tableUris = new List<Uri>();
//Create an item from the geopackage
var item = ItemFactory.Instance.Create(pathToGeoPackage, ItemFactory.ItemType.PathItem);
var children = item.GetItems();
//Collect the table and spatial data in the geopackage
foreach (var child in children)
var childPath = child.Path;
if (child.TypeID == "sqlite_table")
tableUris.Add(new Uri(childPath));
else
layerUris.Add(new Uri(childPath));
//Add the spatial data in the geopackage using the BulkLayerCreationParams
if (layerUris.Count > 0)
BulkLayerCreationParams bulklcp = new BulkLayerCreationParams(layerUris);
LayerFactory.Instance.CreateLayers(bulklcp, MapView.Active.Map);
// add the tables separately
foreach (var tableUri in tableUris)
StandaloneTableFactory.Instance.CreateStandaloneTable(tableUri, MapView.Active.Map);
Create TopologyLayer with an Uri pointing to a Topology dataset
var path = @"D:\Data\CommunitySamplesData\Topology\GrandTeton.gdb\BackCountry\Backcountry_Topology";
var lcp = new TopologyLayerCreationParams(new Uri(path));
lcp.Name = "GrandTeton_Backcountry";
lcp.AddAssociatedLayers = true;
var topoLayer = LayerFactory.Instance.CreateLayer<ArcGIS.Desktop.Mapping.TopologyLayer>(lcp, MapView.Active.Map);
Create Topology Layer using Topology dataset
//Get the Topology of another Topology layer
var existingTopology = MapView.Active.Map.GetLayersAsFlattenedList().OfType<TopologyLayer>().FirstOrDefault();
if (existingTopology != null)
var topology = existingTopology.GetTopology();
//Configure the settings for a new Catalog layer using the CatalogDataset of an existing layer
var topologyLyrParams = new TopologyLayerCreationParams(topology);
topologyLyrParams.Name = "NewTopologyLayerFromAnotherTopologyLayer";
topologyLyrParams.AddAssociatedLayers = true;
LayerFactory.Instance.CreateLayer<TopologyLayer>(topologyLyrParams, MapView.Active.Map);
Create Catalog Layer using Uri to a Catalog Feature Class
var createParams = new CatalogLayerCreationParams(new Uri(@"C:\CatalogLayer\CatalogDS.gdb\HurricaneCatalogDS"));
//Set the definition query
createParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'PuertoRico'");
//Set name of the new Catalog Layer
createParams.Name = "PuertoRico";
//Create Layer
var catalogLayer = LayerFactory.Instance.CreateLayer<CatalogLayer>(createParams, MapView.Active.Map);
Create Catalog Layer using CatalogDataset
//Get the CatalogDataset of another Catalog layer
var existingCatalogLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<CatalogLayer>().FirstOrDefault();
if (existingCatalogLayer != null)
var catalogDataset = existingCatalogLayer.GetCatalogDataset();
var catalogLyrParams = new CatalogLayerCreationParams(catalogDataset);
catalogLyrParams.Name = "NewCatalogLayerFromAnotherCatalogLayer";
catalogLyrParams.DefinitionQuery = new DefinitionQuery("Query1", "cd_itemname = 'Asia'");
LayerFactory.Instance.CreateLayer<CatalogLayer>(catalogLyrParams, MapView.Active.Map);
Add MapNotes to the active map
//Gets the collection of layer template packages installed with Pro for use with maps
var items = MapView.Active.Map.LayerTemplatePackages;
//Iterate through the collection of items to add each Map Note to the active map
foreach (var item in items)
//Create a parameter item for the map note
var layer_params = new LayerCreationParams(item);
layer_params.IsVisible = false;
//Create a feature layer for the map note
var layerCreated = LayerFactory.Instance.CreateLayer<Layer>(layer_params, MapView.Active.Map);
Apply Symbology from a Layer in the TOC
//Note: Call within QueuedTask.Run()
if (MapView.Active.Map == null) return;
//Get an existing Layer. This layer has a symbol you want to use in a new layer.
var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
.Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint).FirstOrDefault();
//This is the renderer to use in the new Layer
var renderer = lyr.GetRenderer() as CIMSimpleRenderer;
//Set the DataConnection for the new layer
Geodatabase geodatabase = new Geodatabase(
new FileGeodatabaseConnectionPath(new Uri(@"E:\Data\Admin\AdminData.gdb")));
FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>("Cities");
var dataConnection = featureClass.GetDataConnection();
//Create the definition for the new feature layer
var featureLayerParams = new FeatureLayerCreationParams(dataConnection)
RendererDefinition = new SimpleRendererDefinition(renderer.Symbol),
IsVisible = true,
//create the new layer
featureLayerParams, MapView.Active.Map);
Create a new SubTypeGroupLayer
var subtypeGroupLayerCreateParam = new SubtypeGroupLayerCreationParams
(new Uri(@"c:\data\SubtypeAndDomain.gdb\Fittings"));
// Define Subtype layers
var rendererDefn1 = new UniqueValueRendererDefinition(new List<string> { "type" });
var renderDefn2 = new SimpleRendererDefinition()
subtypeGroupLayerCreateParam.SubtypeLayers = new List<SubtypeFeatureLayerCreationParams>()
//define first subtype layer with unique value renderer
new SubtypeFeatureLayerCreationParams(new UniqueValueRendererDefinition(new List<string> { "type" }), 1),
//define second subtype layer with simple symbol renderer
new SubtypeFeatureLayerCreationParams(renderDefn2, 2)
// Define additional parameters
subtypeGroupLayerCreateParam.DefinitionQuery = new DefinitionQuery(whereClause: "Enabled = 1", name: "IsActive");
subtypeGroupLayerCreateParam.IsVisible = true;
subtypeGroupLayerCreateParam.MinimumScale = 50000;
SubtypeGroupLayer subtypeGroupLayer2 = LayerFactory.Instance.CreateLayer<SubtypeGroupLayer>(
subtypeGroupLayerCreateParam, MapView.Active.Map);
Create layer from a lyrx file
var lyrDocFromLyrxFile = new LayerDocument(@"d:\data\cities.lyrx");
var cimLyrDoc = lyrDocFromLyrxFile.GetCIMLayerDocument();
//modifying its renderer symbol to red
var cimSimpleRenderer = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMSimpleRenderer;
cimSimpleRenderer?.Symbol.Symbol.SetColor(new CIMRGBColor() { R = 255 });
//optionally save the updates out as a file
lyrDocFromLyrxFile.Save(@"c:\data\cities_red.lyrx");
//get a json representation of the layer document and you want store away...
var aJSONString = lyrDocFromLyrxFile.AsJson();
//... and load it back when needed
lyrDocFromLyrxFile.Load(aJSONString);
//create a layer and add it to a map
var lcp = new LayerCreationParams(cimLyrDoc);
var lyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
Apply Symbology to a layer from a Layer file
IEnumerable<FeatureLayer> featureLayers = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
.Where(l => l.ShapeType == esriGeometryType.esriGeometryPoint);
var layerFile = @"C:\Data\SDK\UniqueValuePointLayer.lyrx";
foreach (var featureLayerToSymbolize in featureLayers)
//Get the Layer Document from the lyrx file
var lyrDocFromLyrxFile = new LayerDocument(layerFile);
//Get the renderer from the layer file
var rendererFromLayerFile = ((CIMFeatureLayer)cimLyrDoc.LayerDefinitions[0]).Renderer as CIMUniqueValueRenderer;
//Note: If working with a raster layer, use the SetColorizer method.
featureLayerToSymbolize?.SetRenderer(rendererFromLayerFile);
Add a WMS service
// Create a connection to the WMS server
var serverConnection = new CIMInternetServerConnection { URL = "URL of the WMS service" };
var connection = new CIMWMSServiceConnection { ServerConnection = serverConnection };
// Add a new layer to the map
var layerParams = new LayerCreationParams(connection);
var layerCreated = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, MapView.Active.Map);
Add a WFS Service
CIMStandardDataConnection cIMStandardDataConnection = new CIMStandardDataConnection()
WorkspaceConnectionString = @"SWAPXY=TRUE;SWAPXYFILTER=FALSE;URL=http://sampleserver6.arcgisonline.com/arcgis/services/SampleWorldCities/MapServer/WFSServer;VERSION=2.0.0",
WorkspaceFactory = WorkspaceFactory.WFS,
Dataset = "Continent",
DatasetType = esriDatasetType.esriDTFeatureClass
var layerPamsDC = new LayerCreationParams(cIMStandardDataConnection);
Layer layerCreated = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerPamsDC, MapView.Active.Map);
Add a WMTS service
var serverConnection = new CIMProjectServerConnection
URL = "URL of the WMTS service.xml",
ServerType = ServerType.WMTS,
var service_connection = new CIMWMTSServiceConnection
ServerConnection = serverConnection,
LayerName = "AdminBoundaries", // Specify the layer name you want to add
var layerParams = new LayerCreationParams(service_connection);
layerParams.MapMemberPosition = MapMemberPosition.AddToBottom;
var layerCreated = LayerFactory.Instance.CreateLayer<FeatureLayer>(layerParams, map);
Connect to an AGS Service using a .ags File
//This workflow would work for
var agsFilePath = @"C:\Data\ServerConnectionFiles\AcmeSampleService.ags";
//ServerConnectionProjectItem supports .ags, .wms, .wmts, .wfs, and .wcs files
var server_conn_item = ItemFactory.Instance.Create(agsFilePath)
as ArcGIS.Desktop.Catalog.ServerConnectionProjectItem;
//Get the server connection - passwords are never returned
var serverConnection = server_conn_item.ServerConnection as CIMProjectServerConnection;
//Add to an AGS service connection
var service_connection = new CIMAGSServiceConnection()
URL = "URL to the AGS _service_ on the AGS _server_",
Connect to an AGS Service using ServiceConnectionProperties
//Connect to the AGS service. Note: the connection will persist for the
//duration of the Pro session.
var serverUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services";
var username = "user1";
var password = "user1";
//at any point before creating a layer, first make a connection to the server
//if one has not been already established for the current session
var uri = new Uri(serverUrl);
var props = new ServiceConnectionProperties(uri)
User = username
//It is preferred that you use the Windows Credential Manager to store the password
//However, it can be set as clear text if you so choose
props.Password = password; //not recommended
//Establish a connection to the server at any point in time _before_
//creating a layer from a service on the server
var gdb = new Geodatabase(props);
gdb.Dispose();//you do not need the geodatabase object after you have connected.
//later in the session, as needed...create a layer from one of the services
//on the server
var serviceUrl = "https://sampleserver6.arcgisonline.com/arcgis/rest/services/Wildfire_secure/MapServer";
var lc = new LayerCreationParams(new Uri(serviceUrl));
LayerFactory.Instance.CreateLayer<MapImageLayer>(lc, map);
Adding and changing styles for WMS Service Layer
var serverConnection = new CIMInternetServerConnection { URL = "https://spritle.esri.com/arcgis/services/sanfrancisco_sld/MapServer/WMSServer" };
LayerCreationParams parameters = new LayerCreationParams(connection);
parameters.MapMemberPosition = MapMemberPosition.AddToBottom;
var compositeLyr = LayerFactory.Instance.CreateLayer<WMSLayer>(parameters, MapView.Active.Map);
//wms layer in ArcGIS Pro always has a composite layer inside it
var wmsLayers = compositeLyr.Layers[0] as ServiceCompositeSubLayer;
//each wms sublayer belongs in that composite layer
var highwayLayerWMSSub = wmsLayers.Layers[1] as WMSSubLayer;
//toggling a sublayer's visibility
if ((highwayLayerWMSSub != null))
bool visibility = highwayLayerWMSSub.IsVisible;
highwayLayerWMSSub.SetVisibility(!visibility);
//applying an existing style to a wms sub layer
var pizzaLayerWMSSub = wmsLayers.Layers[0] as WMSSubLayer;
var currentStyles = pizzaLayerWMSSub.GetStyleNames();
pizzaLayerWMSSub.SetStyleName(currentStyles[1]);
Create a query layer
Geodatabase geodatabase = new Geodatabase(new DatabaseConnectionFile(new Uri(@"C:\Connections\mySDE.sde")));
CIMSqlQueryDataConnection sqldc = new CIMSqlQueryDataConnection()
WorkspaceConnectionString = geodatabase.GetConnectionString(),
GeometryType = esriGeometryType.esriGeometryPolygon,
OIDFields = "OBJECTID",
Srid = "102008",
SqlQuery = "select * from MySDE.dbo.STATES",
Dataset = "States"
var lcp = new LayerCreationParams(sqldc)
Name = "States"
FeatureLayer flyr = LayerFactory.Instance.CreateLayer<FeatureLayer>(lcp, map);
Create a feature layer with class breaks renderer with defaults
var featureLayerCreationParams = new FeatureLayerCreationParams(new Uri(@"c:\data\countydata.gdb\counties"))
Name = "Population Density (sq mi) Year 2010",
RendererDefinition = new GraduatedColorsRendererDefinition("POP10_SQMI")
featureLayerCreationParams,
MapView.Active.Map
Find a layer
//Finds layers by name and returns a read only list of Layers
IReadOnlyList<Layer> layers = map.FindLayers("cities", true);
//Finds a layer using a URI.
//The Layer URI you pass in helps you search for a specific layer in a map
var lyrFindLayer = MapView.Active.Map.FindLayer("CIMPATH=map/u_s__states__generalized_.xml");
//This returns a collection of layers of the "name" specified. You can use any Linq expression to query the collection.
var lyrExists = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().Any(f => f.Name == "U.S. States (Generalized)");
Find a standalone table
// these routines find a standalone table whether it is a child of the Map or a GroupLayer
var tblFind = map.FindStandaloneTable("CIMPATH=map/address_audit.xml");
IReadOnlyList<StandaloneTable> tables = map.FindStandaloneTables("addresses");
// this method finds a standalone table as a child of the map only
var table = map.StandaloneTables.FirstOrDefault(t => t.Name == "Addresses");
Find a layer using partial name search
IEnumerable<Layer> matches = map.GetLayersAsFlattenedList().Where(l => l.Name.Contains("partialLayerName", StringComparison.CurrentCultureIgnoreCase));
List<Layer> layers = new List<Layer>();
foreach (Layer l in matches)
layers.Add(l);
System.Diagnostics.Debug.WriteLine($"Found {layers.Count} layers with name containing '{"partialLayerName"}'");
if (!layer.IsVisible)
layer.SetVisibility(true);
if (layer is FeatureLayer featureLayerToChange)
if (!featureLayer.IsEditable)
featureLayer.SetEditable(true);
if (!featureLayer.IsSnappable)
featureLayer.SetSnappable(true);
Create a Lyrx file
LayerDocument layerDocument = new LayerDocument(layer);
layerDocument.Save(@"c:\Data\MyLayerDocument.lyrx");
Count the features selected on a layer
var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<FeatureLayer>().FirstOrDefault();
var noFeaturesSelected = lyr.SelectionCount;
Access the display field for a layer
// get the CIM definition from the layer
// Note: needs to be called on the MCT
var cimFeatureDefinition = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
// get the view of the source table underlying the layer
var cimDisplayTable = cimFeatureDefinition.FeatureTable;
// this field is used as the 'label' to represent the row
var displayField = cimDisplayTable.DisplayField;
Enable labeling on a layer
//Note: needs to be called on the MCT
// toggle the label visibility
featureLayer.SetLabelVisibility(!featureLayer.IsLabelVisible);
Set Elevation Mode for a layer
ElevationTypeDefinition elevationTypeDefinition = featureLayer.GetElevationTypeDefinition();
elevationTypeDefinition.ElevationType = LayerElevationType.OnGround;
//elevationTypeDefinition.ElevationType = LayerElevationType.RelativeToGround;
//elevationTypeDefinition.ElevationType = LayerElevationType.RelativeToScene;
//elevationTypeDefinition.ElevationType = LayerElevationType.AtAbsoluteHeight;
//..so on.
//Optional: Specify the cartographic offset
elevationTypeDefinition.CartographicOffset = 1000;
//Optional: Specify the VerticalExaggeration
elevationTypeDefinition.VerticalExaggeration = 2;
if (featureLayer.CanSetElevationTypeDefinition(elevationTypeDefinition))
featureLayer.SetElevationTypeDefinition(elevationTypeDefinition);
Move a layer in the 2D group to the 3D Group in a Local Scene
//The layer in the 2D group to move to the 3D Group in a Local Scene
//Get the layer's definition
var lyrDefn = featureLayer.GetDefinition() as CIMBasicFeatureLayer;
//setting this property moves the layer to 3D group in a scene
lyrDefn.IsFlattened = false;
//Set the definition back to the layer
featureLayer.SetDefinition(lyrDefn);
Reset the URL of a feature service layer
CIMStandardDataConnection dataConnection = featureLayer.GetDataConnection() as CIMStandardDataConnection;
dataConnection.WorkspaceConnectionString = @"DATABASE=C:\Data\USNationalParks\USNationalParks.gdb";
featureLayer.SetDataConnection(dataConnection);
Change the underlying data source of a feature layer - same workspace type
//This is the existing layer for which we want to switch the underlying datasource
var connectionStringToReplace = lyr.GetFeatureClass().GetDatastore().GetConnectionString();
string databaseConnectionPath = @"Path to the .sde connection file to replace with";
//If the new SDE connection did not have a dataset with the same name as in the feature layer,
//pass false for the validate parameter of the FindAndReplaceWorkspacePath method to achieve this.
//If validate is true and the SDE did not have a dataset with the same name,
//FindAndReplaceWorkspacePath will return failure
lyr.FindAndReplaceWorkspacePath(connectionStringToReplace, databaseConnectionPath, true);
Change Geodatabase Version of layers off a specified version in a map
//Getting the current version name from the first feature layer of the map
Datastore dataStore = featureLayer.GetFeatureClass().GetDatastore(); //getting datasource
Geodatabase geodatabase = dataStore as Geodatabase; //casting to Geodatabase
if (geodatabase == null)
return;
VersionManager versionManager = geodatabase.GetVersionManager();
ArcGIS.Core.Data.Version currentVersion = versionManager.GetCurrentVersion();
string currentVersionName = currentVersion.GetName();
//Getting all available versions except the current one
List<ArcGIS.Core.Data.Version> versions = [];
foreach (string versionName in versionManager.GetVersionNames())
if (versionName != currentVersionName)
break;
versions.Add(versionManager.GetVersion(versionName));
//Assuming there is at least one other version we pick the first one from the list
ArcGIS.Core.Data.Version toVersion = versions.FirstOrDefault();
if (toVersion != null)
//Changing version
MapView.Active.Map.ChangeVersion(currentVersion, toVersion);
Querying a feature layer
QueryFilter qf = new QueryFilter()
WhereClause = "Class = 'city'"
int count = 0;
using (RowCursor rows = selectedLayer.Search(qf)) //execute
//Looping through to count
while (rows.MoveNext()) count++;
System.Diagnostics.Debug.WriteLine(String.Format(
"Total features that matched the search criteria: {0}", count));
Querying a feature layer with a spatial filter
var layers = map.GetLayersAsFlattenedList().OfType<FeatureLayer>();
var layerToQuery = layers.FirstOrDefault(f => f.Name == "USNationalParks");
if (layerToQuery == null) return;
string whereClause = "RecreationVisitsTotal > 1000000"; //More than million visitors a year
var spatialDefnLayer = layers.FirstOrDefault(f => f.Name == "AllUSStates");
if (spatialDefnLayer == null) return;
try
if (MapView.Active == null) return;
// Set the spatial filter geometry
//Get the geometry from the selected features in the feature layer
var spatialClauseGeom = spatialDefnLayer.GetFeatureOutline(MapView.Active, FeatureOutlineType.Selected);
//Create the definition query
DefinitionQuery definitionQuery = new DefinitionQuery
WhereClause = whereClause,
Name = $"{layerToQuery.Name}"
//Setting the spatial filter to the Definition Query
if (definitionQuery.CanSetFilterGeometry(spatialClauseGeom))
definitionQuery.SetFilterGeometry(spatialClauseGeom);
layerToQuery.InsertDefinitionQuery(definitionQuery);
layerToQuery.SetActiveDefinitionQuery(definitionQuery.Name);
catch (Exception ex)
System.Diagnostics.Debug.WriteLine($"Error querying feature layer: {ex.Message}");
Apply A Definition Query Filter to a Feature Layer
var us_parks = map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().First(l => l.Name == "USNationalParks");
var def_query = new DefinitionQuery("CaliforniaParks",
"STATE_ABBR = 'CA'");
us_parks.InsertDefinitionQuery(def_query);
us_parks.SetDefinitionQuery("STATE_ABBR = 'CA'");
//Set it active
us_parks.SetActiveDefinitionQuery(def_query.Name);
//or....also - set it active when it is inserted
//us_parks.InsertDefinitionQuery(def_query, true);
Apply A Definition Query Filter With a Filter Geometry to a Feature Layer
var greatLakes = map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().First(l => l.Name == "Great Lakes");
var usa_states = map.GetLayersAsFlattenedList()
.OfType<FeatureLayer>().First(l => l.Name == "US_States");
//name must be unique
var def_query = new DefinitionQuery("GreatLakes",
"NAME in ('Huron','Michigan','Erie')");
//create a filter geometry - in this example we will use the outline geometry
//of all visible features from a us states layer...the filter geometry will be
//intersected with the layer feature geometry when added to the def query
var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Visible);
//other options...
//var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.All);
//var filter_geom = usa_states.GetFeatureOutline(mapView, FeatureOutlineType.Selected);
//Geometry must have a valid SR and be point, multi-point, line, or poly
if (def_query.CanSetFilterGeometry(filter_geom))
def_query.SetFilterGeometry(filter_geom);
//Apply the def query
greatLakes.InsertDefinitionQuery(def_query);
//Set it active
greatLakes.SetActiveDefinitionQuery(def_query.Name);
//greatLakes.InsertDefinitionQuery(def_query, true);
Apply A Definition Query Filter to a Feature Layer Option 2
//inserts a new definition query and makes it active
//it will be assigned a unique name
Retrieve the Definition Query Filters for a Feature Layer
//enumerate the layer's definition queries - if any
var def_queries = us_parks.DefinitionQueries;
foreach (var def_qry in def_queries)
var geom_uri = def_qry.GeometryUri ?? "null";
var sr_wkid = def_qry.SpatialReference?.Wkid.ToString() ?? "null";
var geom = def_qry.GetFilterGeometry();
var geom_type = geom?.GeometryType.ToString() ?? "null";
System.Diagnostics.Debug.WriteLine($" def_qry.Name: {def_qry.Name}");
System.Diagnostics.Debug.WriteLine($" def_qry.WhereClause: {def_qry.WhereClause}");
System.Diagnostics.Debug.WriteLine($" def_qry.GeometryUri: {geom_uri}");
System.Diagnostics.Debug.WriteLine($" def_qry.SpatialReference: {sr_wkid}");
System.Diagnostics.Debug.WriteLine($" def_qry.FilterGeometry: {geom_type}");
System.Diagnostics.Debug.WriteLine("");
Get Feature Outlines from a Feature Layer
var michigan = map.GetBookmarks().First(b => b.Name == "Michigan");
//get all features - multiple feature geometries are always returned as a
//single multi-part
var all_features_outline = greatLakes.GetFeatureOutline(mapView, FeatureOutlineType.All);
//or get just the outline of selected features
var qry = new QueryFilter()
SubFields = "*",
WhereClause = "NAME in ('Huron','Michigan','Erie')"
greatLakes.Select(qry);
var sel_features_outline = greatLakes.GetFeatureOutline(
greatLakes.ClearSelection();
//or just the visible features
mapView?.ZoomTo(michigan);
var visible_features_outline = greatLakes.GetFeatureOutline(
Get the attribute rotation field of a layer
var cimRenderer = featureLayer.GetRenderer() as CIMUniqueValueRenderer;
//Gets the visual variables from the renderer
var cimRotationVariable = cimRenderer.VisualVariables.OfType<CIMRotationVisualVariable>().FirstOrDefault();
//Gets the visual variable info for the z dimension
var rotationInfoZ = cimRotationVariable.VisualVariableInfoZ;
//The Arcade expression used to evaluate and return the field name for the rotation
var rotationExpression = rotationInfoZ.ValueExpressionInfo.Expression; // this expression stores the field name
Find connected attribute field for rotation
// get the CIM renderer from the layer
var cimRenderer = featureLayer.GetRenderer() as ArcGIS.Core.CIM.CIMSimpleRenderer;
// get the collection of connected attributes for rotation
var cimRotationVariable = cimRenderer.VisualVariables.OfType<ArcGIS.Core.CIM.CIMRotationVisualVariable>().FirstOrDefault();
// the z direction is describing the heading rotation
var rotationExpression = rotationInfoZ.Expression; // this expression stores the field name
Toggle "Scale layer symbols when reference scale is set"
// get the CIM layer definition
var cimFeatureLayer = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMFeatureLayer;
// turn on the option to scale the symbols in this layer based in the map's reference scale
cimFeatureLayer.ScaleSymbols = true;
Set the layer cache
// change from the default 5 min to 2 min
featureLayer.SetDisplayCacheMaxAge(TimeSpan.FromMinutes(2));
Change the layer selection color
// get the CIM definition of the layer
var layerDef = featureLayer.GetDefinition() as ArcGIS.Core.CIM.CIMBasicFeatureLayer;
// disable the default symbol
layerDef.UseSelectionSymbol = false;
// assign a new color
layerDef.SelectionColor = ColorFactory.Instance.RedRGB;
// apply the definition to the layer
featureLayer.SetDefinition(layerDef);
if (!featureLayer.IsVisible)
featureLayer.SetVisibility(true);
//Do a selection
MapView.Active.SelectFeatures(MapView.Active.Extent);
Removes all layers that are unchecked
//Get the group layers first
IReadOnlyList<GroupLayer> groupLayers = map.Layers.OfType<GroupLayer>().ToList();
//Iterate and remove the layers within the group layers that are unchecked.
//Note: Run within a QueuedTask
foreach (var groupLyr in groupLayers)
//Get layers that not visible within the group
var layers = groupLyr.Layers.Where(l => l.IsVisible == false).ToList();
//Remove all the layers that are not visible within the group
map.RemoveLayers(layers);
//Group Layers that are empty and are unchecked
foreach (var group in groupLayers)
if (group.Layers.Count == 0 && group.IsVisible == false) //No layers in the group
//remove the group
map.RemoveLayer(group);
//Get Layers that are NOT Group layers and are unchecked
var notAGroupAndUnCheckedLayers = map.Layers.Where(l => !(l is GroupLayer) && l.IsVisible == false).ToList();
//Remove all the non group layers that are not visible
map.RemoveLayers(notAGroupAndUnCheckedLayers);
Remove empty groups
if (group.Layers.Count == 0) //No layers in the group
//remove the group
Create Abbreviation Dictionary in the Map Definition to a layer
//Get the map's definition
var mapDefn = MapView.Active.Map.GetDefinition();
//Get the Map's Maplex labelling engine properties
var mapDefnPlacementProps = mapDefn.GeneralPlacementProperties as CIMMaplexGeneralPlacementProperties;
//Define the abbreviations we need in an array
List<CIMMaplexDictionaryEntry> abbreviationDictionary = new List<CIMMaplexDictionaryEntry>
new CIMMaplexDictionaryEntry {
Abbreviation = "Hts",
Text = "Heights",
MaplexAbbreviationType = MaplexAbbreviationType.Ending
Abbreviation = "Ct",
Text = "Text",
//etc
//The Maplex Dictionary - can hold multiple Abbreviation collections
var maplexDictionary = new List<CIMMaplexDictionary>
new CIMMaplexDictionary {
Name = "NameEndingsAbbreviations",
MaplexDictionary = abbreviationDictionary.ToArray()
//Set the Maplex Label Engine Dictionary property to the Maplex Dictionary collection created above.
mapDefnPlacementProps.Dictionaries = maplexDictionary.ToArray();
//Set the Map definition
MapView.Active.Map.SetDefinition(mapDefn);
Apply Abbreviation Dictionary in the Map Definition to a layer
//Creates Abbreviation dictionary and adds to Map Definition
//Refer to the " Create Abbreviation Dictionary in the Map Definition to a layer" snippet above
var lyrDefn = featureLayer.GetDefinition() as CIMFeatureLayer;
//Get the label classes - we need the first one
var listLabelClasses = lyrDefn.LabelClasses.ToList();
var theLabelClass = listLabelClasses.FirstOrDefault();
//Modify label Placement props to use abbreviation dictionary
CIMGeneralPlacementProperties labelEngine = MapView.Active.Map.GetDefinition().GeneralPlacementProperties;
//Get the dictionary from the map definition
theLabelClass.MaplexLabelPlacementProperties.DictionaryName = "NameEndingsAbbreviations";
theLabelClass.MaplexLabelPlacementProperties.CanAbbreviateLabel = true;
theLabelClass.MaplexLabelPlacementProperties.CanStackLabel = false;
//Set the labelClasses back
lyrDefn.LabelClasses = listLabelClasses.ToArray();
//set the layer's definition
Symbol Layer Drawing (SLD)
Add SLD
//check if it can be added to the layer
if (featureLayer.CanAddSymbolLayerDrawing())
featureLayer.AddSymbolLayerDrawing();
//ditto for a group layer...must have at least
//one child feature layer that can participate
if (groupLayer.CanAddSymbolLayerDrawing())
groupLayer.AddSymbolLayerDrawing();
Determine if a layer has SLD added
//SLD can be added to feature layers and group layers
//For a group layer, SLD controls all child feature layers
//that are participating in the SLD
//var featLayer = ...;//retrieve the feature layer
//var groupLayer = ...;//retrieve the group layer
//Check if the layer has SLD added -returns a tuple
var tuple = featureLayer.HasSymbolLayerDrawingAdded();
if (tuple.addedOnLayer)
//SLD is added on the layer
else if (tuple.addedOnParent)
//SLD is added on the parent (group layer) -
//check parent...this can be recursive
var parentLayer = GetParentLayerWithSLD(featureLayer.Parent as GroupLayer);
//Recursively get the parent with SLD
GroupLayer GetParentLayerWithSLD(GroupLayer groupLayer)
if (groupLayer == null)
return null;
//Must be on QueuedTask
var sld_added = groupLayer.HasSymbolLayerDrawingAdded();
if (sld_added.addedOnLayer)
return groupLayer;
else if (sld_added.addedOnParent)
return GetParentLayerWithSLD(groupLayer.Parent as GroupLayer);
return null;
Enable/Disable SLD
//A layer may have SLD added but is not using it
//HasSymbolLayerDrawingAdded returns a tuple - to check
//the layer has SLD (not its parent) check addedOnLayer
if (featureLayer.HasSymbolLayerDrawingAdded().addedOnLayer)
//the layer has SLD but is the layer currently using it?
//GetUseSymbolLayerDrawing returns a tuple - useOnLayer for
//the layer (and useOnParent for the parent layer)
if (!featureLayer.GetUseSymbolLayerDrawing().useOnLayer)
//enable it
featureLayer.SetUseSymbolLayerDrawing(true);
//Enable/Disable SLD on a layer parent
if (featureLayer.HasSymbolLayerDrawingAdded().addedOnParent)
var parent = GetParentLayerWithSLD(featureLayer.Parent as GroupLayer);
if (parent.GetUseSymbolLayerDrawing().useOnLayer)
parent.SetUseSymbolLayerDrawing(true);
return null;
return groupLayer;
return null;
Feature Drawing Order
Check Whether Feature Drawing Order is Supported
//Within QueuedTask.Run()
var supportsFeatureDrawOrder = featureLayer.GetIsFeatureDrawOrderSupported();
Set Feature Drawing Order
if (featureLayer.GetIsFeatureDrawOrderSupported())
//Provide the field name to use and the sort ordering
//The field must exist on the layer. Check the field can be used first
if (featureLayer.GetCanSetFeatureDrawOrder("Police_Precinct", SortOrderType.Ascending))
//Set the FDO to use the "Police_Precinct" field and ascending sort order
featureLayer.SetFeatureDrawOrder("Police_Precinct", SortOrderType.Ascending);
Set Feature Drawing Order 2
var listOfSortInfo = new List<CIMFeatureSortInfo>
//Draw features in the layer ordered by Police_Precinct field in ascending order
//and then by Crime_rate field in descending order
new CIMFeatureSortInfo
FieldName = "Police_Precinct",
SortDirection = SortOrderType.Ascending
FieldName = "Crime_rate",
SortDirection = SortOrderType.Descending
//Provide the list of FSOs to use and their sort ordering
//All fields must exist on the layer.
if (featureLayer.GetCanSetFeatureDrawOrder(listOfSortInfo))
//Set the FDO to use the list of FSOs
featureLayer.SetFeatureDrawOrder(listOfSortInfo);
Get the Current Feature Drawing Order
var cimFeatSortInfo = featureLayer.GetFeatureDrawOrder();
var c = 0;
System.Diagnostics.Debug.WriteLine("Feature Sort Info:");
foreach (var fs_info in cimFeatSortInfo)
$"fs_info[{c++}] {fs_info.FieldName}: {fs_info.SortDirection.ToString()}");
Clear the Current Feature Drawing Order
//will throw an InvalidOperation exception if the layer does
//not support FDO
featureLayer.ClearFeatureDrawOrder();
//Passing an empty or null list to 'SetFeatureDrawOrder()' will also clear the FDO
featureLayer.SetFeatureDrawOrder(new List<CIMFeatureSortInfo>());
//or
featureLayer.SetFeatureDrawOrder(null);
Elevation Surface Layers
Create a scene with a ground surface layer
var groundSourceUri = new Uri("https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer");
var scene = MapFactory.Instance.CreateScene("My scene", groundSourceUri, MapViewingMode.SceneGlobal);
Create a New Elevation Surface
//Define a ServiceConnection to use for the new Elevation surface
Anonymous = true,
HideUserProperty = true,
URL = "https://elevation.arcgis.com/arcgis/services"
CIMAGSServiceConnection serviceConnection = new CIMAGSServiceConnection
ObjectName = "WorldElevation/Terrain",
ObjectType = "ImageServer",
URL = "https://elevation.arcgis.com/arcgis/services/WorldElevation/Terrain/ImageServer",
//Defines a new elevation source set to the CIMAGSServiceConnection defined above
//Get the elevation surfaces defined in the map
var listOfElevationSurfaces = map.GetElevationSurfaceLayers();
//Add the new elevation surface
var elevationLyrCreationParams = new ElevationLayerCreationParams(serviceConnection);
var elevationSurface = LayerFactory.Instance.CreateLayer<ElevationSurfaceLayer>(
elevationLyrCreationParams, map);
Set a custom elevation surface to a Z-Aware layer
//Define the custom elevation surface to use
var layerElevationSurface = new CIMLayerElevationSurface
ElevationSurfaceLayerURI = "https://elevation3d.arcgis.com/arcgis/services/WorldElevation3D/Terrain3D/ImageServer"
//Set the layer's elevation surface
lyrDefn.LayerElevation = layerElevationSurface;
//Set the layer's definition
Add an elevation source to an existing elevation surface layer
ElevationSurfaceLayer surfaceLayer = null;
// surfaceLayer could also be the ground layer
string uri = "https://elevation3d.arcgis.com/arcgis/rest/services/WorldElevation3D/Terrain3D/ImageServer";
var createParams = new ElevationLayerCreationParams(new Uri(uri));
createParams.Name = "Terrain 3D";
var eleSourceLayer = LayerFactory.Instance.CreateLayer<Layer>(createParams, surfaceLayer);
Get the elevation surface layers and elevation source layers from a map
// retrieve the elevation surface layers in the map including the Ground
var surfaceLayers = map.GetElevationSurfaceLayers();
// retrieve the single ground elevation surface layer in the map
var groundSurfaceLayer = map.GetGroundElevationSurfaceLayer();
// determine the number of elevation sources in the ground elevation surface layer
int numberGroundSources = groundSurfaceLayer.Layers.Count;
// get the first elevation source layer from the ground elevation surface layer
var groundSourceLayer = groundSurfaceLayer.Layers.FirstOrDefault();
Find an elevation surface layer
// find a specific elevation surface layer by its URI
var surfaceLayer = surfaceLayers.FirstOrDefault(l => l.Name == "Surface2");
// or use the FindElevationSurfaceLayer method, passing the layer URI
surfaceLayer = map.FindElevationSurfaceLayer("layerUri");
Remove elevation surface layers
//Ground will not be removed
map.ClearElevationSurfaceLayers();
ElevationSurfaceLayer surfaceLayer = map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "Surface2");
//Cannot remove ground
map.RemoveLayer(surfaceLayer);
map.RemoveLayers(map.GetElevationSurfaceLayers());
Get Z values from the default ground surface
//Note: This method must be called on the MCT
// Get the center of the map's full extent
MapPoint mapPoint = MapView.Active.Map.CalculateFullExtent().Center;
//Pass any Geometry type to GetZsFromSurfaceAsync
var surfaceZResult = await MapView.Active.Map.GetZsFromSurfaceAsync(mapPoint);
if (surfaceZResult.Status == SurfaceZsResultStatus.Ok)
// cast to a mapPoint
var mapPointZ = surfaceZResult.Geometry as MapPoint;
var z = mapPointZ.Z;
Get Z values from a specific surface
var eleLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
//Ensure the feature layer is a line layer and is Z aware
var selectedFeatures = featureLayer.GetSelection();
var rowCursor = selectedFeatures.Search();
while (rowCursor.MoveNext())
var feature = rowCursor.Current as Feature;
var polyline = feature.GetShape() as Polyline;
var zResult = await MapView.Active.Map.GetZsFromSurfaceAsync(polyline, eleLayer);
if (zResult.Status == SurfaceZsResultStatus.Ok)
var polylineZ = zResult.Geometry as Polyline;
// process the polylineZ
// For example, you can iterate through the points and access their Z values
Get Z values from a layer
TinLayer tinLayer = map.GetLayersAsFlattenedList().OfType<TinLayer>().FirstOrDefault();
MapPoint mapPoint = MapView.Active.Map.CalculateFullExtent().Center; //Any Map Point
Polyline polyline = PolylineBuilderEx.CreatePolyline(mapView.Extent); //Any Polyline
if (tinLayer.CanGetZs())
// get z value for a mapPoint
var zResult = tinLayer.GetZs(mapPoint);
var mapPointZ = zResult.Geometry as MapPoint;
// get z values for a polyline
zResult = tinLayer.GetZs(polyline);
Raster Layers
Create a raster layer
string urlRatser = @"C:\Images\Italy.tif";
await QueuedTask.Run(() =>
// Create a raster layer using a path to an image.
// Note: You can create a raster layer from a url, project item, or data connection.
var rasterLayerToCreate = LayerFactory.Instance.CreateLayer(new Uri(urlRatser), map) as RasterLayer;
Update the raster colorizer on a raster layer
// Get the colorizer from the raster layer.
//Note: needs to be called on the QueuedTask
CIMRasterColorizer rasterColorizer = rasterLayer.GetColorizer();
// Update raster colorizer properties.
rasterColorizer.Brightness = 10;
rasterColorizer.Contrast = -5;
rasterColorizer.ResamplingType = RasterResamplingType.NearestNeighbor;
// Update the raster layer with the changed colorizer.
rasterLayer.SetColorizer(rasterColorizer);
Update the RGB colorizer on a raster layer
CIMRasterColorizer rColorizer = rasterLayer.GetColorizer();
// Check if the colorizer is an RGB colorizer.
if (rColorizer is CIMRasterRGBColorizer rasterRGBColorizer)
// Update RGB colorizer properties.
rasterRGBColorizer.StretchType = RasterStretchType.ESRI;
rasterLayer.SetColorizer(rasterRGBColorizer);
Check if a certain colorizer can be applied to a raster layer
// Get the list of colorizers that can be applied to the raster layer.
IEnumerable<RasterColorizerType> applicableColorizerList = rasterLayer.GetApplicableColorizers();
// Check if the RGB colorizer is part of the list.
bool isTrue_ContainTheColorizerType = applicableColorizerList.Contains(RasterColorizerType.RGBColorizer);
Create a new colorizer based on a default colorizer definition and apply it to the raster layer
// Check if the Stretch colorizer can be applied to the raster layer.
if (rasterLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
// Create a new Stretch Colorizer Definition using the default constructor.
StretchColorizerDefinition stretchColorizerDef_default = new StretchColorizerDefinition();
// Create a new Stretch colorizer using the colorizer definition created above.
CIMRasterStretchColorizer newStretchColorizer_default =
await rasterLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
// Set the new colorizer on the raster layer.
rasterLayer.SetColorizer(newStretchColorizer_default);
Create a new colorizer based on a custom colorizer definition and apply it to the raster layer
//Get a color ramp from a style
StyleProjectItem ArcGISColorsStyleItem =
Project.Current.GetItems<StyleProjectItem>().FirstOrDefault(s => s.Name == "ArcGIS Colors");
var colorRamps = ArcGISColorsStyleItem.SearchColorRamps("Heat Map 4 - Semitransparent");
CIMColorRamp colorRampToUse = colorRampList[0].ColorRamp;
// Create a new Stretch Colorizer Definition specifying parameters
// for band index, stretch type, gamma and color ramp.
StretchColorizerDefinition stretchColorizerDef_custom =
new StretchColorizerDefinition(1, RasterStretchType.ESRI, 2, colorRamp);
// Create a new stretch colorizer using the colorizer definition created above.
CIMRasterStretchColorizer newStretchColorizer_custom =
await rasterLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
rasterLayer.SetColorizer(newStretchColorizer_custom);
Create a raster layer with a new colorizer definition
// Create a new stretch colorizer definition using default constructor.
StretchColorizerDefinition stretchColorizerDef = new StretchColorizerDefinition();
// Create a raster layer creation parameters object with the raster file path.
var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("rasterPath"))
ColorizerDefinition = stretchColorizerDef,
Name = "rasterLayerName",
MapMemberIndex = 0
// Create a raster layer using the colorizer definition created above.
RasterLayer rasterLayerfromURL =
LayerFactory.Instance.CreateLayer<RasterLayer>(rasterLayerCreationParams, map);
Mosaic Layers
Create a mosaic layer
//Path to mosaic dataset
string urlItaly = @"C:\Images\countries.gdb\Italy";
// Create a mosaic layer using a path to a mosaic dataset.
// Note: You can create a mosaic layer from a url, project item, or data connection.
mosaicLayer = LayerFactory.Instance.CreateLayer(new Uri(urlItaly), map) as MosaicLayer;
Update the raster colorizer on a mosaic layer
// Get the image sub-layer from the mosaic layer.
ImageMosaicSubLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
// Get the colorizer from the image sub-layer.
CIMRasterColorizer rasterColorizer = mosaicImageSubLayer.GetColorizer();
// Update the image sub-layer with the changed colorizer.
mosaicImageSubLayer.SetColorizer(rasterColorizer);
Update the RGB colorizer on a mosaic layer
CIMRasterColorizer rColorizer = mosaicImageSubLayer.GetColorizer();
mosaicImageSubLayer.SetColorizer(rasterRGBColorizer);
Check if a certain colorizer can be applied to a mosaic layer
// Get the list of colorizers that can be applied to the image sub-layer.
mosaicImageSubLayer.GetApplicableColorizers();
Create a new colorizer based on a default colorizer definition and apply it to the mosaic layer
// Check if the Stretch colorizer can be applied to the image sub-layer.
if (mosaicImageSubLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
// Set the new colorizer on the image sub-layer.
mosaicImageSubLayer.SetColorizer(newStretchColorizer_default);
Create a new colorizer based on a custom colorizer definition and apply it to the mosaic layer
// Create a new Stretch colorizer definition specifying parameters
await mosaicImageSubLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
mosaicImageSubLayer.SetColorizer(newStretchColorizer_custom);
Create a mosaic layer with a new colorizer definition
// Create a new colorizer definition using default constructor.
var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri("url"))
Name = "layerRasterName",
MapMemberIndex = 0
// Create a mosaic layer using the colorizer definition created above.
MosaicLayer newMosaicLayer = LayerFactory.Instance.CreateLayer<MosaicLayer>(rasterLayerCreationParams, map);
Update the sort order - mosaic method on a mosaic layer
ImageServiceLayer mosaicImageSubLayer = mosaicLayer.GetImageLayer();
// Get the mosaic rule.
CIMMosaicRule mosaicingRule = mosaicImageSubLayer.GetMosaicRule();
// Set the Mosaic Method to Center.
mosaicingRule.MosaicMethod = RasterMosaicMethod.Center;
// Update the mosaic with the changed mosaic rule.
mosaicImageSubLayer.SetMosaicRule(mosaicingRule);
Update the resolve overlap - mosaic operator on a mosaic layer
ImageServiceLayer mosaicImageSublayerToUse = mosaicLayer.GetImageLayer();
CIMMosaicRule mosaicRule = mosaicImageSublayerToUse.GetMosaicRule();
// Set the Mosaic Operator to Mean.
mosaicRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
mosaicImageSublayerToUse.SetMosaicRule(mosaicRule);
Image Service Layers
Create an image service layer
string urlToUse =
@"http://imagery.arcgisonline.com/arcgis/services/LandsatGLS/GLS2010_Enhanced/ImageServer";
// Create an image service layer using the url for an image service.
var isLayer = LayerFactory.Instance.CreateLayer(new Uri(urlToUse), map) as ImageServiceLayer;
Update the raster colorizer on an image service layer
// Get the colorizer from the image service layer.
CIMRasterColorizer rasterColorizer = imageServiceLayer.GetColorizer();
// Update the colorizer properties.
// Update the image service layer with the changed colorizer.
imageServiceLayer.SetColorizer(rasterColorizer);
Update the RGB colorizer on an image service layer
CIMRasterColorizer rColorizer = imageServiceLayer.GetColorizer();
imageServiceLayer.SetColorizer((CIMRasterColorizer)rasterRGBColorizer);
Check if a certain colorizer can be applied to an image service layer
// Get the list of colorizers that can be applied to the imager service layer.
IEnumerable<RasterColorizerType> applicableColorizerList = imageServiceLayer.GetApplicableColorizers();
Create a new colorizer based on a default colorizer definition and apply it to the image service layer
// Check if the Stretch colorizer can be applied to the image service layer.
if (imageServiceLayer.GetApplicableColorizers().Contains(RasterColorizerType.StretchColorizer))
await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_default) as CIMRasterStretchColorizer;
// Set the new colorizer on the image service layer.
imageServiceLayer.SetColorizer(newStretchColorizer_default);
Create a new colorizer based on a custom colorizer definition and apply it to the image service layer
await imageServiceLayer.CreateColorizerAsync(stretchColorizerDef_custom) as CIMRasterStretchColorizer;
imageServiceLayer.SetColorizer(newStretchColorizer_custom);
Create an image service layer with a new colorizer definition
var rasterLayerCreationParams = new RasterLayerCreationParams(new Uri(url))
Name = "RasterLayer",
MapMemberIndex = 0
// Create an image service layer using the colorizer definition created above.
ImageServiceLayer imageServiceLayerWithColorizer =
LayerFactory.Instance.CreateLayer<ImageServiceLayer>(rasterLayerCreationParams, map);
Update the sort order - mosaic method on an image service layer
// Get the mosaic rule of the image service.
CIMMosaicRule mosaicRule = imageServiceLayer.GetMosaicRule();
mosaicRule.MosaicMethod = RasterMosaicMethod.Center;
// Update the image service with the changed mosaic rule.
imageServiceLayer.SetMosaicRule(mosaicRule);
Update the resolve overlap - mosaic operator on an image service layer
CIMMosaicRule mosaicingRule = imageServiceLayer.GetMosaicRule();
mosaicingRule.MosaicOperatorType = RasterMosaicOperatorType.Mean;
imageServiceLayer.SetMosaicRule(mosaicingRule);
Renderers
Set unique value renderer to the selected feature layer of the active map
//field to be used to retrieve unique values
var fields = new List<string> { "Type" };
//constructing a point symbol as a template symbol
CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Pushpin);
CIMSymbolReference symbolPointTemplate = pointSym.MakeSymbolReference();
//constructing renderer definition for unique value renderer
UniqueValueRendererDefinition uniqueValueRendererDef =
new UniqueValueRendererDefinition(fields, symbolPointTemplate);
//creating a unique value renderer
CIMUniqueValueRenderer uniqueValueRenderer = featureLayer.CreateRenderer(uniqueValueRendererDef) as CIMUniqueValueRenderer;
//setting the renderer to the feature layer
featureLayer.SetRenderer(uniqueValueRenderer);
Create a UniqueValueRenderer to specify symbols to values
//The goal is to construct the CIMUniqueValueRenderer which will be applied to the feature layer.
// To do this, the following are the objects we need to set the renderer up with the fields and symbols.
// As a reference, this is the USCities dataset. Snippet will create a unique value renderer that applies
// specific symbols to all the cities in California and Alabama. The rest of the cities will use a default symbol.
// First create a "CIMUniqueValueClass" for the cities in Alabama.
List<CIMUniqueValue> listUniqueValuesAlabama = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "Alabama" } } };
CIMUniqueValueClass alabamaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "Alabama",
Patch = PatchShape.Default,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuesAlabama.ToArray()
// Create a "CIMUniqueValueClass" for the cities in California.
List<CIMUniqueValue> listUniqueValuescalifornia = new List<CIMUniqueValue> { new CIMUniqueValue { FieldValues = new string[] { "California" } } };
CIMUniqueValueClass californiaUniqueValueClass = new CIMUniqueValueClass
Editable = true,
Label = "California",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.BlueRGB).MakeSymbolReference(),
Visible = true,
Values = listUniqueValuescalifornia.ToArray()
//Create a list of the above two CIMUniqueValueClasses
List<CIMUniqueValueClass> listUniqueValueClasses = new List<CIMUniqueValueClass>
alabamaUniqueValueClass, californiaUniqueValueClass
//Create a list of CIMUniqueValueGroup
CIMUniqueValueGroup uvg = new CIMUniqueValueGroup
Classes = listUniqueValueClasses.ToArray(),
List<CIMUniqueValueGroup> listUniqueValueGroups = new List<CIMUniqueValueGroup> { uvg };
//Create the CIMUniqueValueRenderer
CIMUniqueValueRenderer uvr = new CIMUniqueValueRenderer
UseDefaultSymbol = true,
DefaultLabel = "all other values",
DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreyRGB).MakeSymbolReference(),
Groups = listUniqueValueGroups.ToArray(),
Fields = new string[] { "STATE_NAME" }
//Set the feature layer's renderer.
featureLayer.SetRenderer(uvr);
Create a Heatmap Renderer
string colorBrewerSchemesName = "ArcGIS Colors";
//Get the style project item that contains the color ramps
//Refer to the Initialize region for an example of how to get a style item
//and the color ramp from it.
//defining a heatmap renderer that uses values from Population field as the weights
HeatMapRendererDefinition heatMapDef = new HeatMapRendererDefinition()
Radius = 20,
WeightField = "Population",
ColorRamp = colorRamp,
RendereringQuality = 8,
UpperLabel = "High Density",
LowerLabel = "Low Density"
CIMHeatMapRenderer heatMapRndr = featureLayer.CreateRenderer(heatMapDef) as CIMHeatMapRenderer;
featureLayer.SetRenderer(heatMapRndr);
Use Arcade expression to create Class Breaks
var usaStatesLayer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>()
.FirstOrDefault(fl => fl.Name == "USA States");
if (usaStatesLayer == null) return;
//Create a color ramp from red to blue
var colorRampForPopulation = ColorFactory.Instance.ConstructColorRamp(
ColorRampAlgorithm.LinearContinuous,
ColorFactory.Instance.RedRGB, ColorFactory.Instance.BlueRGB);
//This Arcade expression categorizes the POP2000 field in the usaStates layer
//into Low, Medium, and High values
var arcade = @"if ($feature.POP2000 < 1000000)
{return ""Low"";}" +
@"else if ($feature.POP2000 >= 100000 && $feature.POP2000 < 5000000)
{return ""Medium""; }" +
@"else if ($feature.POP2000 >= 5000000)
{return ""High"";}" +
@"else{return ""NA"";}";
//Create the Arcade expression info
CIMExpressionInfo arcadeExp = new CIMExpressionInfo();
arcadeExp.Expression = arcade;
arcadeExp.ReturnType = ExpressionReturnType.Default;
arcadeExp.Title = "State Population Categorized";
arcadeExp.Name = "USA States Population 2000";
//Each population category is assigned a color from the color ramp and symbolized on the map
// using a unique value renderer
var uvr_desc = new UniqueValueRendererDefinition()
//ValueFields = new List<string> { "STATION" },
ColorRamp = colorRampForPopulation,
ValuesLimit = 100,
ArcadeExpression = arcadeExp.Expression
//Create the renderer and assign it to the layer
var renderer = usaStatesLayer.CreateRenderer(uvr_desc);
usaStatesLayer.SetRenderer(renderer);
Create an unclassed Renderer
CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 16.0, SimpleMarkerStyle.Diamond);
//defining an unclassed renderer with custom upper and lower stops
//all features with value >= 5,000,000 will be drawn with the upper color from the color ramp
//all features with value <= 50,000 will be drawn with the lower color from the color ramp
UnclassedColorsRendererDefinition unclassRndrDef = new UnclassedColorsRendererDefinition
("Population", symbolPointTemplate, colorRamp, "Highest", "Lowest", 5000000, 50000)
//drawing features with null values with a different symbol
ShowNullValues = true,
NullValueLabel = "Unknown"
// Create a point symbol for null values
CIMPointSymbol nullSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.RedRGB, 16.0, SimpleMarkerStyle.Circle);
unclassRndrDef.NullValueSymbol = nullSym.MakeSymbolReference();
//Create the unclassed renderer using the definition
CIMClassBreaksRenderer cbRndr = featureLayer.CreateRenderer(unclassRndrDef) as CIMClassBreaksRenderer;
//Set the renderer to the feature layer
featureLayer.SetRenderer(cbRndr);
Create a Proportion Renderer with max and min symbol size capped
//Creating a point symbol to be used as a template symbol for the proportional renderer
CIMPointSymbol pointSym = SymbolFactory.Instance.ConstructPointSymbol(ColorFactory.Instance.GreenRGB, 1.0, SimpleMarkerStyle.Circle);
//minimum symbol size is capped to 4 point while the maximum symbol size is set to 50 point
//Creating a proportional renderer definition that uses the "Population" field
ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", symbolPointTemplate, 4, 50, true)
//setting upper and lower size stops to stop symbols growing or shrinking beyond those thresholds
UpperSizeStop = 5000000, //features with values >= 5,000,000 will be drawn with maximum symbol size
LowerSizeStop = 50000 //features with values <= 50,000 will be drawn with minimum symbol size
// Create a proportional renderer using the definition
CIMProportionalRenderer propRndr = featureLayer.CreateRenderer(prDef) as CIMProportionalRenderer;
// Set the renderer to the feature layer
featureLayer.SetRenderer(propRndr);
Create a True Proportion Renderer
//Defining proportional renderer where size of symbol will be same as its value in field used in the renderer.
ProportionalRendererDefinition prDef = new ProportionalRendererDefinition("POPULATION", esriUnits.esriMeters, symbolPointTemplate, SymbolShapes.Square, ValueRepresentations.Radius);
//Create a Proportional renderer using the definition
Attribute Table - ITablePane
Set zoom level for Attribute Table
//Check if the active pane is an ITablePane
if (FrameworkApplication.Panes.ActivePane is ITablePane tablePane)
//Get the current zoom level of the table pane
var currentZoomLevel = tablePane.ZoomLevel;
// Set a new zoom level, for example, increase it by 50
var newZoomLevel = currentZoomLevel + 50;
// Set the new zoom level to the table pane
tablePane.SetZoomLevel(newZoomLevel);
Retrieve the values of selected cell in the attribute table
var mapMember = tablePane.MapMember;
//Get the active row's object ID from the table pane
var oid = tablePane.ActiveObjectID;
if (oid.HasValue && oid.Value != -1 && mapMember != null)
//Get the field of the active column
var activeField = tablePane.ActiveColumn;
// TODO: Use core objects to retrieve record and get value
Move to a particular row
// Check if the active pane is an ITablePane
// move to first row
tablePane.BringIntoView(0);
// move to sixth row
tablePane.BringIntoView(5);
Working with Standalone Tables
Create a StandaloneTable
//container can be a map or group layer
var container = MapView.Active.Map;
//var container = MapView.Active.Map.GetLayersAsFlattenedList()
// .OfType<GroupLayer>().First();
//use a local path
var table = StandaloneTableFactory.Instance.CreateStandaloneTable(
new Uri(@"C:\Temp\Data\SDK.gdb\EarthquakeDamage", UriKind.Absolute), container);
//use a URI to a feature service table endpoint
var table2 = StandaloneTableFactory.Instance.CreateStandaloneTable(
new Uri(@"https://bexdog.esri.com/server/rest/services/FeatureServer" + "/2", UriKind.Absolute), container);
//Use an item
var item = ItemFactory.Instance.Create(@"C:\Temp\Data\SDK.gdb\ParcelOwners");
var tableCreationParams = new StandaloneTableCreationParams(item);
var table3 = StandaloneTableFactory.Instance.CreateStandaloneTable(tableCreationParams, container);
//use table creation params
var table_params = new StandaloneTableCreationParams(item)
DefinitionQuery = new DefinitionQuery(whereClause: "LAND_USE = 3", name: "Landuse")
var table4 = StandaloneTableFactory.Instance.CreateStandaloneTable(table_params, container);
Retrieve a table from its container
//the map standalone table collection
var table = container.GetStandaloneTablesAsFlattenedList()
.FirstOrDefault(tbl => tbl.Name == "EarthquakeDamage");
//or from a group layer
var grp_layer = MapView.Active.Map.FindLayers("GroupLayer1").First() as GroupLayer;
var table2 = grp_layer.FindStandaloneTables("EarthquakeDamage").First();
//or grp_layer.GetStandaloneTablesAsFlattenedList().First()
//or grp_layer.StandaloneTables.Where(...).First(), etc.
//show the table in a table view
//use FrameworkApplication.Current.Dispatcher.BeginInvoke if not on the UI thread
FrameworkApplication.Panes.OpenTablePane(table2);
Move a Standalone table
//get the first group layer that has at least one table
var grp_layer = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<GroupLayer>().First(g => g.StandaloneTables.Count > 0);
grp_layer.MoveStandaloneTable(grp_layer.StandaloneTables.First(), -1);
//move the last table in the map standalone tables to a group
//layer and place it at position 3. If 3 is invalid, the table
//will be placed at the bottom of the target container
//assumes the map has at least one standalone table...
var table = map.StandaloneTables.Last();
map.MoveStandaloneTable(table, grp_layer, 3);
//move a table from a group layer to the map standalone tables
//collection - assumes a table called 'Earthquakes' exists
var table2 = grp_layer.FindStandaloneTables("Earthquakes").First();
//move to the map container
map.MoveStandaloneTable(table2, 0);//will be placed at the top
Remove a Standalone table
//get the tables from the map container
var tables = map.GetStandaloneTablesAsFlattenedList();
//delete the first...
if (tables.Count() > 0)
map.RemoveStandaloneTable(tables.First());
//or delete all of them
map.RemoveStandaloneTables(tables);
//delete a table from a group layer
//assumes it has at least one table...
grp_layer.RemoveStandaloneTable(grp_layer.StandaloneTables.First());
Metadata
Get and Set Map Metadata
//Get map's metadata
var mapMetadata = map.GetMetadata();
//TODO:Make edits to metadata using the retrieved mapMetadata string.
//Set the modified metadata back to the map.
if (map.GetCanEditMetadata())
map.SetMetadata(mapMetadata);
Layer Metadata
//Search for only layers/tables here if needed.
MapMember mapMember = map.GetLayersAsFlattenedList().FirstOrDefault();
if (mapMember == null) return;
//Gets whether or not the MapMember stores its own metadata or uses metadata retrieved
//from its source. This method must be called on the MCT. Use QueuedTask.Run
bool doesUseSourceMetadata = mapMember.GetUseSourceMetadata();
//Sets whether or not the MapMember will use its own metadata or the metadata from
//its underlying source (if it has one). This method must be called on the MCT.
//Use QueuedTask.Run
mapMember.SetUseSourceMetadata(true);
//Does the MapMember supports metadata
var supportsMetadata = mapMember.SupportsMetadata;
//Get MapMember metadata
var metadatstring = mapMember.GetMetadata();
//Set the modified metadata back to the mapmember (layer, table..)
if (mapMember.GetCanEditMetadata())
mapMember.SetMetadata(metadatstring);
SelectionSet
Translate From Dictionary to SelectionSet
//Create a selection set from a list of object ids
//using FromDictionary
MapMember us_zips_layer = map.GetLayersAsFlattenedList().OfType<FeatureLayer>().First(s => s.Name == "USA zips layer");
var addToSelection = new Dictionary<MapMember, List<long>>();
addToSelection.Add(us_zips_layer, new List<long> { 1506, 2696, 2246, 1647, 948 });
//Create a SelectionSet object
var selSet = ArcGIS.Desktop.Mapping.SelectionSet.FromDictionary(addToSelection);
Translate from SelectionSet to Dictionary
var selSetDict = selSet.ToDictionary();
// convert to the dictionary and only include those that are of type FeatureLayer
var selSetDictFeatureLayer = selSet.ToDictionary<FeatureLayer>();
Get OIDS from a SelectionSet for a given MapMember
if (selSet.Contains(us_zips_layer))
var oids = selSet[us_zips_layer];
Get OIDS from a SelectionSet for a given MapMember by Name
var kvp = selSet.ToDictionary().Where(kvp => kvp.Key.Name == "LayerName").FirstOrDefault();
var oidList = kvp.Value;
Check SelectionSet Equality
// get map selection
var mapSelSet = MapView.Active.Map.GetSelection();
// create a selectionSet
var selDict = new Dictionary<MapMember, List<long>>();
selDict.Add(featureLayer, new List<long> { 1506, 2696, 2246, 1647, 948 });
var layerSelSet = ArcGIS.Desktop.Mapping.SelectionSet.FromDictionary(selDict);
// test for equality - use Equals method
var isEquals = mapSelSet.Equals(layerSelSet);
// test for equality - use operators
var equals = mapSelSet == layerSelSet;
var notEquals = mapSelSet != layerSelSet;
Selection Options
Get/Set Selection Options
var options = ApplicationOptions.SelectionOptions;
var defaultColor = options.DefaultSelectionColor;
//Set the selection color to red
var color = options.SelectionColor as CIMRGBColor;
options.SetSelectionColor(ColorFactory.Instance.CreateRGBColor(255, 0, 0));
//Set the selection fill color and fill hatch
var defaultFill = options.DefaultSelectionFillColor;
var fill = options.SelectionFillColor;
var isHatched = options.IsSelectionFillHatched;
options.SetSelectionFillColor(ColorFactory.Instance.CreateRGBColor(100, 100, 0));
if (!isHatched)
options.SetSelectionFillIsHatched(true);
//Toggle the selection Chip and Graphic
var showSelectionChip = options.ShowSelectionChip;
options.SetShowSelectionChip(!showSelectionChip);
var showSelectionGraphic = options.ShowSelectionGraphic;
options.SetShowSelectionGraphic(!showSelectionGraphic);
//Get the value indicating whether to save the layer and standalone table selection with the map.
var saveSelection = options.SaveSelection;
options.SetSaveSelection(!saveSelection);
//Get/Set the selection tolerance
var defaultTol = options.DefaultSelectionTolerance;
var tol = options.SelectionTolerance;
options.SetSelectionTolerance(2 * defaultTol);
// extension methods available for selection methods and combination methods
var selMethod = options.SelectionMethod;
options.SetSelectionMethod(SelectionMethod.Contains);
var combMethod = options.CombinationMethod;
options.SetCombinationMethod(SelectionCombinationMethod.Add);
// note that the following SelectionCombinationMethod is not supported
//options.SetCombinationMethod(SelectionCombinationMethod.XOR);
Elevation Profile
Get Elevation profile from the default ground surface
// get the elevation profile for a polyline / set of polylines
Polyline polyline = PolylineBuilderEx.CreatePolyline();
MapPoint mapPoint = MapPointBuilderEx.CreateMapPoint(34, -118, SpatialReferences.WGS84);
List<MapPoint> mapPoints = new List<MapPoint> { mapPoint };
var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline]);
if (result.Status == SurfaceZsResultStatus.Ok)
var polylineZ = result.Polyline;
// get the elevation profile for a set of points
result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints);
Get Elevation profile from a specific surface
// use the specific elevation surface layer
var zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync([polyline], eleLayer);
var polylineZ = zResult.Polyline;
zResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(mapPoints, eleLayer);
Interpolate a line between two points and calculate the elevation profile
int numPoints = 20;//Or any number of points you want to interpolate
// use a specific elevation surface
// use the default ground elevation surface
MapPoint startPt = MapPointBuilderEx.CreateMapPoint(-130, 20, SpatialReferences.WGS84);
MapPoint endPt = MapPointBuilderEx.CreateMapPoint(-100, 50, SpatialReferences.WGS84);
var result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints);
result = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, numPoints, eleLayer);
Show Elevation profile graph with the default ground surface
if (!MapView.Active.CanShowElevationProfileGraph())
return;
// show the elevation profile for a polyline
// use the default ground surface layer
MapView.Active.ShowElevationProfileGraph([polyline]);
// show the elevation profile for a set of points
//Some points
MapView.Active.ShowElevationProfileGraph(mapPoints);
Show Elevation profile graph with a specific surface
return;
// set up the parameters
var profileParams = new ElevationProfileParameters();
profileParams.SurfaceLayer = eleLayer;
profileParams.Densify = true;
// show the elevation profile for a polyline using the params
//Any line
MapView.Active.ShowElevationProfileGraph([polyline], profileParams);
// show the elevation profile for a set of points using the params
//Some points
MapView.Active.ShowElevationProfileGraph(mapPoints, profileParams);
Show Elevation profile graph between two points
int numPoints = 20;
return;
MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints);
var tinLayer = MapView.Active.Map.GetElevationSurfaceLayers().FirstOrDefault(l => l.Name == "TIN");
// set up the params
var elevProfileParams = new ElevationProfileParameters();
elevProfileParams.SurfaceLayer = tinLayer;
elevProfileParams.Densify = false;
// show the elevation profile using the params
MapView.Active.ShowElevationProfileGraph(startPt, endPt, numPoints, elevProfileParams);
Show Elevation profile graph using an ElevationProfileResult
var elevProfileResult = await MapView.Active.Map.GetElevationProfileFromSurfaceAsync(startPt, endPt, 10);
if (elevProfileResult.Status != SurfaceZsResultStatus.Ok)
return;
return;
// show the elevation profile using the result
MapView.Active.ShowElevationProfileGraph(elevProfileResult);
Access the ElevationProfileGraph when added
// subscribe to the Added, Removed events for the elevation profile graph
mapView.ElevationProfileGraphAdded += Mv_ElevationProfileGraphAdded;
mapView.ElevationProfileGraphRemoved += Mv_ElevationProfileGraphRemoved;
//Handles the event triggered when an elevation profile graph is removed.
void Mv_ElevationProfileGraphRemoved(object sender, EventArgs e)
//TODO: handle the removal of the elevation profile graph
//Handles the event triggered when an elevation profile graph is added to the active map view.
void Mv_ElevationProfileGraphAdded(object sender, EventArgs e)
// get the elevation profile graph from the view
// this will be non-null since we are in a ElevationProfileGraphAdded handler
var mv = MapView.Active;
var graph = mv.GetElevationProfileGraph();
// subscribe to the ContentLoaded event
graph.ContentLoaded += Graph_ContentLoaded;
// Handles the event triggered when the elevation profile graph content is loaded.
void Graph_ContentLoaded(object sender, EventArgs e)
var graph = sender as ArcGIS.Desktop.Mapping.ElevationProfileGraph;
// get the elevation profile geometry
var polyline = graph.Geometry;
// get the elevation profile statistics
var stats = graph.ElevationProfileStatistics;
var elevProfileGraph = MapView.Active.GetElevationProfileGraph();
// Elevation profile graph will be null if no profile graph is displayed
if (elevProfileGraph == null)
return;
// get the elevation profile geometry and stats
var polyline = elevProfileGraph.Geometry;
var stats = elevProfileGraph.ElevationProfileStatistics;
// reverse the graph
elevProfileGraph.IsReversed = !elevProfileGraph.IsReversed;
// collapse the graph
elevProfileGraph.IsExpanded = false;
Export Elevation Profile Graph
return;
if (elevProfileGraph.CanExport)
elevProfileGraph.ExportToImage("c:\\temp\\myprofileImage.png");
elevProfileGraph.ExportToCSV("c:\\temp\\myprofile.csv");
Customize Elevation Profile Graph Display
// customize the elevation profile graph options
var options = new ElevationProfileOptions()
LineColor = ColorFactory.Instance.CreateRGBColor(0, 0, 100),
ShowAverageSlope = false,
ShowMaximumSlope = false
var eaOptions = ApplicationOptions.ExploratoryAnalysisOptions;
if (eaOptions.CanSetElevationProfileOptions(options))
await eaOptions.SetElevationProfileOptionsAsync(options);
// or reset to default options
var defaultOptions = eaOptions.GetDefaultElevationProfileOptions();
if (eaOptions.CanSetElevationProfileOptions(defaultOptions))
await eaOptions.SetElevationProfileOptionsAsync(defaultOptions);
Device Location API, GPS/GNSS Devices
Connect to a Device Location Source
var newSrc = new SerialPortDeviceLocationSource();
//Specify the COM port the device is connected to
newSrc.ComPort = "Com3";
newSrc.BaudRate = 4800;
newSrc.AntennaHeight = 3; // meters
//fill in other properties as needed
var props = new DeviceLocationProperties();
props.AccuracyThreshold = 10; // meters
// jump to the background thread
//open the device
DeviceLocationService.Instance.Open(newSrc, props);
Get the Current Device Location Source
var source = DeviceLocationService.Instance.GetSource();
if (source == null)
//There is no current source
Close the Current Device Location Source
//Is there a current device source?
var src = DeviceLocationService.Instance.GetSource();
if (src == null)
return;//no current source
DeviceLocationService.Instance.Close();
Get Current Device Location Source and Properties
// Check if a device is connected
bool isConnected = DeviceLocationService.Instance.IsDeviceConnected();
if (!isConnected)
return; // no device connected
// Get the current device location source
// Check if the source is a SerialPortDeviceLocationSource
//Set values for the SerialPortDeviceLocationSource
if (src is SerialPortDeviceLocationSource serialPortSrc)
var port = serialPortSrc.ComPort;
var antennaHeight = serialPortSrc.AntennaHeight;
var dataBits = serialPortSrc.DataBits;
var baudRate = serialPortSrc.BaudRate;
var parity = serialPortSrc.Parity;
var stopBits = serialPortSrc.StopBits;
// retrieving spatial reference needs the MCT
var sr = await QueuedTask.Run(() =>
return serialPortSrc.GetSpatialReference();
//Get current device location properties being used.
var dlProps = DeviceLocationService.Instance.GetProperties();
var accuracy = dlProps.AccuracyThreshold;
Update Properties on the Current Device Location Source
//Note: Run within QueuedTask
// Get the current device location properties
//Change the accuracy threshold
dlProps.AccuracyThreshold = 22.5; // meters
// Update the properties on the device location source
DeviceLocationService.Instance.UpdateProperties(dlProps);
Subscribe to DeviceLocationPropertiesUpdated event
DeviceLocationPropertiesUpdatedEvent.Subscribe(OnDeviceLocationPropertiesUpdated);
// Event handler for DeviceLocationPropertiesUpdated event.
static void OnDeviceLocationPropertiesUpdated(DeviceLocationPropertiesUpdatedEventArgs args)
if (args == null)
return;
var properties = args.DeviceLocationProperties;
// TODO - something with the updated properties
Subscribe to DeviceLocationSourceChanged event
DeviceLocationSourceChangedEvent.Subscribe(OnDeviceLocationSourceChanged);
// Event handler for DeviceLocationSourceChanged event.
void OnDeviceLocationSourceChanged(DeviceLocationSourceChangedEventArgs args)
if (args == null)
return;
var source = args.DeviceLocationSource;
// TODO - something with the updated source properties
Map Device Location Options
Enable/Disable Current Device Location Source For the Map
//Gets the current device location options used by the MapDeviceLocationService
var options = MapDeviceLocationService.Instance.GetDeviceLocationOptions();
//Device location visibility on the map
var visibility = options.DeviceLocationVisibility;
//MappingDeviceLocationNavigationMode
var navMode = options.NavigationMode;
//Heading of the location from the device points to the top of the screen
var trackUp = options.TrackUpNavigation;
//Show accuracy buffer on the map
var showBuffer = options.ShowAccuracyBuffer;
Check if The Current Device Location Is Enabled On The Map
//Checks if the current device location source is enabled on the map
if (MapDeviceLocationService.Instance.IsDeviceLocationEnabled)
//The Device Location Source is Enabled
Set Current Map Device Location Options
//Check there is a source first...
if (DeviceLocationService.Instance.GetSource() == null)
//Setting DeviceLocationOptions w/ no Device Location Source
//Will throw an InvalidOperationException
return;
if (!MapDeviceLocationService.Instance.IsDeviceLocationEnabled)
//Setting DeviceLocationOptions w/ no Device Location Enabled
return;
MapDeviceLocationService.Instance.SetDeviceLocationOptions(
new MapDeviceLocationOptions()
DeviceLocationVisibility = true,
NavigationMode = MappingDeviceLocationNavigationMode.KeepAtCenter,
TrackUpNavigation = true
Zoom/Pan The Map To The Most Recent Location
//Calling ZoomOrPanToCurrentLocation w/ no Device Location Enabled
return;
// true for zoom, false for pan
MapDeviceLocationService.Instance.ZoomOrPanToCurrentLocation(true);
Add the Most Recent Location To A Graphics Layer
// get the last location
var pt = DeviceLocationService.Instance.GetCurrentSnapshot()?.GetPositionAsMapPoint();
if (pt != null)
//Create a point symbol
var ptSymbol = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(125, 125, 0), 10, SimpleMarkerStyle.Triangle);
//Add a graphic to the graphics layer
graphicsLayer.AddElement(pt, ptSymbol);
//unselect it
graphicsLayer.ClearSelection();
Set map view to always be centered on the device location
// Get the MapDeviceLocationOptions currently used by the MapDeviceLocationService
var currentOptions = MapDeviceLocationService.Instance.GetDeviceLocationOptions();
if (currentOptions == null)
return;
// Set the device location visibility on the map to true
currentOptions.DeviceLocationVisibility = true;
//Set the navigation mode to keep the device location at the center of the map
currentOptions.NavigationMode = MappingDeviceLocationNavigationMode.KeepAtCenter;
//Sets the MapDeviceLocationOptions to be updates with these values
MapDeviceLocationService.Instance.SetDeviceLocationOptions(currentOptions);
Subscribe to Location Snapshot event
SnapshotChangedEvent.Subscribe(OnSnapshotChanged);
/// Handles changes to a snapshot by processing the provided snapshot data.
void OnSnapshotChanged(SnapshotChangedEventArgs args)
if (args == null)
return;
var snapshot = args.Snapshot as NMEASnapshot;
if (snapshot == null)
return;
var pt = snapshot.GetPositionAsMapPoint();
if (pt?.IsEmpty ?? true)
return;
// access properties
var alt = snapshot.Altitude;
var dt = snapshot.DateTime;
var vdop = snapshot.VDOP;
var hdop = snapshot.HDOP;
// etc
//TODO: use the snapshot
Feature Masking
Get the Mask Geometry for a Feature
if (featureLayer == null)
return;
using (var table = featureLayer.GetTable())
using (var rc = table.Search())
//get the first feature...
//...assuming at least one feature gets retrieved
rc.MoveNext();
var oid = rc.Current.GetObjectID();
//Use DrawingOutlineType.BoundingEnvelope to retrieve a generalized
//mask geometry or "Box". The mask will be in the same SpatRef as the map
var mask_geom = featureLayer.GetDrawingOutline(oid, mv, DrawingOutlineType.Exact);
//TODO - use the mask geometry...
