string docFileName = "c:\\MyData\\MyDocument.pdf";
var pageCount = OCRManager.Instance.GetDocumentPageCount(docFileName);
Extract text from a document
var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName);
// or extract from a specific page
//int pageIdx = 1;
//var text = await OCRManager.Instance.ExtractTextFromDocumentAsync(deedFileName, pageIdx);
Extract text from a document using a CancellationTracker
var text = "";
bool canceled = false;
using (CancelableProgressorSource cps = new CancelableProgressorSource("Reading document", "Canceled"))
canceled = await QueuedTask.Run<bool>(async () =>
try
text = await ArcGIS.Core.OCR.OCRManager.Instance.ExtractTextFromDocumentAsync(docFileName, cps.Progressor.CancellationToken);
catch (OperationCanceledException cex)
return true;
catch (Exception ex)
return false;
}, cps.Progressor);
if (canceled)
// to do - some cancel action
else
// to do - something with text
Extract text from a document using OCROptions
string docFileName = "c:\\MyData\\MyDocument.tiff";
var ocrOptions = new OCROptions(docFileName);
ocrOptions.OutputType = OCROutputType.Text;
// set a specific page if necessary
// (if not set, then all pages are scanned)
// ocrOptions.Page = pageIdx;
// set the resolution if necessary
// ocrOptions.Resolution = 400;
var output = await OCRManager.Instance.ExtractFromDocumentAsync(ocrOptions);
var textOutput = output as OCRTextOutput;
var text = textOutput.Text;
Extract text from a document using a different model
string docFileName = "c:\\MyData\\MyDocument.jpg";
// set the language
// (de.traineddata should be installed at (arcgis_install_folder)\Resources\OCR)
// if file cannot be found an exception is thrown
ocrOptions.Model = "de";
try
catch (ArcGIS.Core.OCR.Exceptions.OCRException ex)
Extract TSV output from a document
string docFileName = "c:\\MyData\\MyDocument.bmp";
ocrOptions.OutputType = OCROutputType.TSV;
if (output is OCRTSVOutput ocr_tsvOutput)
// process the tsv output
foreach (var page in ocr_tsvOutput.Pages)
foreach (var block in page.Blocks)
foreach (var para in block.Paragraphs)
foreach (var line in para.Lines)
foreach (var word in line.Words)
var content = word.Content;
var confidence = word.Confidence;
// process content according to confidence
Get text from TSVOutput (simple)
string text = "";
var flowDocument = new FlowDocument();
foreach (var page in tsvOutput.Pages)
List<Paragraph> pageParagraphs = new();
foreach (var paragraph in block.Paragraphs)
foreach (var line in paragraph.Lines)
string lineWords = string.Join(" ", line.Words.Select(w => w.Content));
pageParagraphs.Add(new Paragraph(new Span(new Run(lineWords))));
flowDocument.Blocks.AddRange(pageParagraphs);
flowDocument.Blocks.Add(new Paragraph(new Span(new Run(Environment.NewLine))));
var startPointer = flowDocument?.ContentStart;
var endPointer = flowDocument?.ContentEnd;
if (startPointer != null && endPointer != null)
text = new TextRange(startPointer, endPointer).Text;
