Gets all the presentation items in the current project
var projectPresentations = Project.Current.GetItems<PresentationProjectItem>();
foreach (var projectItem in projectPresentations)
//Do Something with the presentation
Reference an existing presentation
//Reference a presentation associated with an active presentation view
PresentationView associatedPresentationView = PresentationView.Active;
if (activePresentationView != null)
Presentation presentationExisting = activePresentationView.Presentation;
//Open a presentation project item in a new view.
//A presentation project item may exist but it may not be open in a view.
//Reference a presentation project item by name
PresentationProjectItem presentationPrjItem = Project.Current.GetItems<PresentationProjectItem>().FirstOrDefault(item => item.Name.Equals(presentationName));
//Get the presentation associated with the presentation project item
//Note: Must be within QueuedTask.Run
Presentation presentationToOpen = presentationPrjItem.GetPresentation();
//Create the new pane
IPresentationPane iNewPresentationPane = await ProApp.Panes.CreatePresentationPaneAsync(presentationToOpen); //GUI thread
Create and export Presentation
Create presentation
//Note: Must be in QueuedTask.Run()
//Create a new presentation without parameters
var presentationNew = PresentationFactory.Instance.CreatePresentation();
// Use the new Presentation
// Create a presentation specifying the name of the new presentation
var presentationSpecifyName = PresentationFactory.Instance.CreatePresentation("New Presentation");
Export a presentation
//Note: Call within QueuedTask.Run()
//Create mp4 format with appropriate settings
MP4VideoFormat mp4Format = new MP4VideoFormat();
mp4Format.Width = 800;
mp4Format.Height = 600;
mp4Format.OutputFileName = @"my folder\presentation.mp4";
//Define Export Options
PresentationExportOptions options = new PresentationExportOptions
PageRangeOption = ExportPageOptions.ExportByPageRange,
CustomPages = "1,2,8"
//export as mp4
presentation.Export(mp4Format, options);
Presentation View
Activate a presentation view
//Assume we want to open a view for a particular presentation or activate a view if one is already open
//A presentation project item is an item that appears in the Presentation folder in the Catalog pane.
PresentationProjectItem presentationItem = Project.Current.GetItems<PresentationProjectItem>()
.FirstOrDefault(item => item.Name.Equals("Presentation Name"));
//Note: Must be on QueuedTask.Run
//Reference a presentation associated with a presentation project item
if (presentationItem != null)
//Get the presentation associated with the presentationItem
Presentation presentationToOpen = presentationItem.GetPresentation();
//Next check to see if a presentation view is already open that references the presentation
foreach (var pane in ProApp.Panes)
var prePane = pane as IPresentationPane;
if (prePane == null) // Not a presentation view, continue to the next pane
continue;
//if there is a match, activate the view
if (prePane.PresentationView.Presentation == presentationToOpen)
(prePane as Pane).Activate();
return;
//No pane found, activate a new one - must be called on UI
Presentation Page
Blank page
Presentation presentationActive = PresentationView.Active.Presentation;
// Note: Must be on QueuedTask
// add a blank page with with title and paragraph body text element
presentation.AddBlankPage(BlankPageTemplateType.TitleAndParagraph, -1);
Image page
// add a new image page in current active presentation
var imagePage = presentation.AddImagePage("my image source", -1);
// change the image source
imagePage.SetImageSource("new image source");
Video page
// add a new video page in current active presentation
var videoPage = presentation.AddVideoPage("my video file", -1);
videoPage.SetVideoSource("new video source");
// change the start time of video to 3s
videoPage.SetStartTime(3.0);
// change the end time of video to 10s
videoPage.SetEndTime(10.0);
Map page
// retrieve a map from the project based on the map name
MapProjectItem mpi = Project.Current.GetItems<MapProjectItem>()
.FirstOrDefault(m => m.Name.Equals("Your Map Name", StringComparison.CurrentCultureIgnoreCase));
Map map = mpi.GetMap();
//create a map page using map's default extent
presentation.AddMapPage(map, -1);
//create a page using map's bookmark
Bookmark bookmark = map.GetBookmarks().FirstOrDefault(
b => b.Name == "Your bookmark"); // get the bookmark based on the bookmark's name
presentation.AddMapPage(bookmark, -1);
Map Page
Change map page camera settings
//Note: Must be on the QueuedTask
//Reference a map page
var mpage = activePresentationView.Presentation.GetPage(4) as MapPresentationPage;
//Set the map frame extent based on the new camera's X,Y, Scale and heading values
Camera cam = new Camera(329997.6648, 6248553.1457, 2403605.8968, 24);
mpage.SetCamera(cam);
Zoom map page to extent of a single layer
//Reference map page
//Reference map and layer
MapProjectItem mp = Project.Current.FindItem("Page name") as MapProjectItem;
Map map = mp.GetMap();
FeatureLayer lyr = map.FindLayers("GreatLakes").First() as FeatureLayer;
//Set the map frame extent to all features in the layer
mpage.SetCamera(lyr);
Activate a map page
// Note: we are on the UI thread!
// A presentation view must be active
if (PresentationView.Active == null)
return;
PresentationPage currentActivePage = activePresentationView.ActivePage;
//check if the current page is a map page
if (activePage is MapPresentationPage)
await activePresentationView.ActivateMapPageAsync();
//move to the QueuedTask to do something
await QueuedTask.Run(() =>
// TODO
Presentation page design
// create customized margin and color
CIMMargin pMargin = new CIMMargin() { Left = 0.2, Right = 0.3, Top = 0.15, Bottom = 0.25 };
CIMRGBColor pColor = new CIMRGBColor() { R = 255, G = 255, B = 0, Alpha = 50 };
//Reference a page and its transition
var pageReference = activePresentationView.Presentation.GetPage(0);
CIMPresentationTransition transition = page.Transition;
// update the transition style
transition.TransitionType = PresentationTransitionType.Swipe;
transition.Duration = 2.0;
transition.SwipeDirection = SwipeDirection.Top;
//Must be on the QueuedTask
//Set the new margin, new background color and new transition effect
page.SetMargin(pMargin);
page.SetBackgroundColor(pColor);
page.SetTransition(transition);
Elements in presentations
Create elements on a presentation page
//create a picture element
var imgPath = @"https://www.esri.com/content/dam/esrisites/en-us/home/" +
"homepage-tile-podcast-business-resilience-climate-change.jpg";
//Build a geometry to place the picture
Coordinate2D ll = new Coordinate2D(3.5, 1);
Coordinate2D ur = new Coordinate2D(6, 5);
Envelope env = EnvelopeBuilderEx.CreateEnvelope(ll, ur);
//create a picture element on the page
var gElement = PresentationElementFactory.Instance.CreatePictureGraphicElement(page, env, imgPath);
//create a text element
//Set symbology, create and add element to a presentation page
CIMTextSymbol sym = SymbolFactory.Instance.ConstructTextSymbol(
ColorFactory.Instance.RedRGB, 15, "Arial", "Regular");
//use ElementInfo to set placement properties
var elemInfo = new ElementInfo()
Anchor = Anchor.CenterPoint,
Rotation = 45
string textString = "My text";
var textPos = new Coordinate2D(5, 3).ToMapPoint();
var tElement = PresentationElementFactory.Instance.CreateTextGraphicElement(page,
TextType.PointText, textPos, sym, textString, "telement", false, elemInfo);
//create a group element with elements created above
var elmList = new List<Element> { gElement, tElement };
GroupElement grp1 = PresentationElementFactory.Instance.CreateGroupElement(page, elmList, "My Group");
Element selection and navigation
// Find specific elements by name
var ge_rect = page.FindElement("Rectangle") as GraphicElement;
var elements = new List<string>();
elements.Add("Text");
elements.Add("Polygon");
var elems = page.FindElements(elements);
//Get elements retaining hierarchy
var top_level_elems = page.GetElements();
//Flatten hierarchy
var all_elems = page.GetFlattenedElements();
//Use LINQ with any of the collections
//Retrieve just those elements that are Visible
var some_elems = all_elems.Where(ge => ge.IsVisible).ToList();
Element selection manipulation
//Select/unselect some elements...
var elems = activePage.GetFlattenedElements();
//select any element not a group element
activePage.SelectElements(elems.Where(e => !e.Name.StartsWith("Group")));
activePage.UnSelectElements(elems.Where(e => !e.Name.StartsWith("Group")));
//Select/unselect all visible, graphic elements
var ge_elems = elems.Where(ge => ge.IsVisible).ToList();
activePage.SelectElements(ge_elems);
activePage.UnSelectElements(ge_elems);
//Select/unselect a specific element
var na = activePage.FindElement("My Text Element");
activePage.SelectElement(na);
activePage.UnSelectElement(na);
//Select everything
activePage.SelectElements(elems);
//enumerate the selected elements
foreach (var sel_elem in activePage.GetSelectedElements())
//TODO
Presentation events
Detect changes to the presentation
ArcGIS.Desktop.Presentations.Events.PresentationEvent.Subscribe((args) =>
var presentation = args.Presentation; //The presentation that was changed
//Check what triggered the event and take appropriate action
switch (args.Hint)
case PresentationEventHint.PropertyChanged:
//TODO handle presentation property changed
break;
case PresentationEventHint.PageAdded:
//TODO handle a new page added
break;
case PresentationEventHint.PageRemoved:
//TODO handle a page removed from the presentation
break;
case PresentationEventHint.PageSettingChanged:
//TODO handle page settings changed
break;
Detect changes to the presentation view
//For UI context changes associated with a presentation, subscribe to the PresentationView
//event - views activated/deactivated, views opened/closed
ArcGIS.Desktop.Presentations.Events.PresentationViewEvent.Subscribe((args) =>
//get the affected view and presentation
var view = args.PresentationView;
var presentation = args.PresentationView?.Presentation;
if (presentation == null)
//FYI presentationview and/or presentation can be null...
//eg closed, deactivation
switch (args.Hint)
case PresentationViewEventHint.Activated:
// Presentation view activated
break;
case PresentationViewEventHint.Opened:
//A PresentationView has been initialized and opened
break;
case PresentationViewEventHint.Deactivated:
// Presentation view deactivated
break;
case PresentationViewEventHint.Closing:
//Set args.Cancel = true to prevent closing
break;
case PresentationViewEventHint.ExtentChanged:
//presentation view extent has changed
break;
case PresentationViewEventHint.DrawingComplete:
break;
case PresentationViewEventHint.PauseDrawingChanged:
break;
