ProSnippets Raster
Language:              C#
Subject:               Raster
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Open raster dataset in a folder
// Create a FileSystemConnectionPath using the folder path.
FileSystemConnectionPath connectionPath = new(new System.Uri(@"C:\Temp"), FileSystemDatastoreType.Raster);
// Create a new FileSystemDatastore using the FileSystemConnectionPath.
FileSystemDatastore dataStore = new(connectionPath);
// Open the raster dataset.
RasterDataset fileRasterDataset = dataStore.OpenDataset<RasterDataset>("Sample.tif");
Open raster dataset in a geodatabase
// Create a FileGeodatabaseConnectionPath using the path to the gdb. Note: This can be a path to a .sde file.
FileGeodatabaseConnectionPath geodatabaseConnectionPath = new(new Uri(@"C:\Temp\rasters.gdb"));
// Create a new Geodatabase object using the FileGeodatabaseConnectionPath.
Geodatabase geodatabase = new(geodatabaseConnectionPath);
RasterDataset gdbRasterDataset = geodatabase.OpenDataset<RasterDataset>("sample");
Get the raster dataset definition from a raster dataset
await QueuedTask.Run(() =>
  RasterDatasetDefinition rasterDatasetDefinition = rasterDataset.GetDefinition();
  // access the dataset definition properties
  rasterDatasetDefinition.GetBandCount();
Access the bands in a raster dataset
var count = rasterDataset.GetBandCount();
  RasterBand rasterBandByName = rasterDataset.GetBandByName(sBandName);
  var index = rasterDataset.GetBandIndex(sBandName);
  // Get a RasterBand from the raster dataset
  RasterBand rasterBand = rasterDataset.GetBand(0);
  // Get the RasterBandDefinition from the raster band.
  RasterBandDefinition rasterBandDefinition = rasterBand.GetDefinition();
  // Get the name of the raster band from the raster band.
  string bandName = rasterBandDefinition.GetName();
Access rows in a raster attribute table
var raster = MapView.Active.Map.GetLayersAsFlattenedList().OfType<RasterLayer>().FirstOrDefault();
  if (raster != null)
      var rasterTbl = raster.GetRaster().GetAttributeTable();
      var cursor = rasterTbl.Search();
      while (cursor.MoveNext())
        var row = cursor.Current;
Create a raster cursor to iterate through the raster data
  // Create a full raster from the raster dataset.
  ArcGIS.Core.Data.Raster.Raster raster = rasterDataset.CreateFullRaster();
  // Calculate size of pixel blocks to process. Use 1000 or height/width of the raster, whichever is smaller.
  var height = raster.GetHeight();
  var width = raster.GetWidth();
  int pixelBlockHeight = height > 1000 ? 1000 : height;
  int pixelBlockWidth = width > 1000 ? 1000 : width;
  // Create the raster cursor using the height and width calculated.
  RasterCursor rasterCursor = raster.CreateCursor(pixelBlockWidth, pixelBlockHeight);
  // Use a do-while loop to iterate through the pixel blocks of the raster using the raster cursor.
  do
    // Get the current pixel block from the cursor.
    using (PixelBlock currentPixelBlock = rasterCursor.Current)
      // Do something with the pixel block...
    // Once you are done, move to the next pixel block.
  while (rasterCursor.MoveNext());
Read and Write pixels from and to a raster dataset using pixel blocks
  // Calculate size of pixel block to create. Use 128 or height/width of the raster, whichever is smaller.
  int pixelBlockHeight = height > 128 ? 128 : height;
  int pixelBlockWidth = width > 128 ? 128 : width;
  // Create a new (blank) pixel block.
  PixelBlock currentPixelBlock = raster.CreatePixelBlock(pixelBlockWidth, pixelBlockHeight);
  // Read pixel values from the raster dataset into the pixel block starting from the given top left corner.
  raster.Read(0, 0, currentPixelBlock);
  // Write the pixel block to the raster dataset starting from the given top left corner.
  raster.Write(0, 0, currentPixelBlock);
Process pixels using a pixel block
  // For each plane (band) in the pixel block
  for (int plane = 0; plane < currentPixelBlock.GetPlaneCount(); plane++)
    // Get a copy of the array of pixels from the pixel block corresponding to the current plane.
    Array sourcePixels = currentPixelBlock.GetPixelData(plane, true);
    // Get the height and width of the pixel block.
    int pBHeight = currentPixelBlock.GetHeight();
    int pBWidth = currentPixelBlock.GetWidth();
    // Iterate through the pixels in the array.
    for (int i = 0; i < pBHeight; i++)
      for (int j = 0; j < pBWidth; j++)
        // Get the NoData mask value to see if the pixel is a valid pixel.
        if (Convert.ToByte(currentPixelBlock.GetNoDataMaskValue(plane, j, i)) == 1)
          // Get the pixel value from the array and process it (add 5 to the value).
          // Note: This is assuming the pixel type is Unisigned 8bit.
          int pixelValue = Convert.ToInt16(sourcePixels.GetValue(j, i)) + 5;
          // Make sure the pixel value does not go above the range of the pixel type.
          pixelValue = pixelValue > 254 ? 254 : pixelValue;
          // Set the new pixel value to the array.
          sourcePixels.SetValue(Convert.ToByte(pixelValue), j, i);
    // Set the modified array of pixels back to the pixel block.
    currentPixelBlock.SetPixelData(plane, sourcePixels);
Calculate Raster statistics
//If a raster dataset has statistics, you can create a raster layer and get these statistics by accessing the colorizer.
  //Accessing the raster layer
  var lyr = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BasicRasterLayer>().FirstOrDefault();
  //Getting the colorizer
  var colorizer = lyr.GetColorizer() as CIMRasterStretchColorizer;
  //Accessing the statistics
  var stats = colorizer.StretchStats;
  var max = stats.max;
  var min = stats.min;
Raster and Imagery Options
Get/Set Raster and Imagery Options
var ro = ApplicationOptions.RasterImageryOptions;
  var validCategories = ro.GetValidColorRampCategories();
  var validCategory = validCategories.FirstOrDefault();
  var colorRamps = ColorFactory.Instance.GetColorRampNames(validCategory);
  var newColorRampName = colorRamps.FirstOrDefault();
  var stretchedColorRamp = ro.GetStretchedColorRamp();
  var colorRampName = ro.GetStretchedColorRampName();
  ro.SetStretchedColorRampName(null);
  var classifyColorRamp = ro.GetClassifyColorRamp();
  colorRampName = ro.GetClassifyColorRampName();
  ro.SetClassifyColorRampName(newColorRampName);
  var discreteColorRamp = ro.GetDiscreteColorRamp();
  colorRampName = ro.GetDiscreteColorRampName();
  ro.SetDiscreteColorRampName(newColorRampName);
  var uniqueValueColorRamp = ro.GetUniqueValueColorRamp();
  colorRampName = ro.GetUniqueValueColorRampName();
  ro.SetUniqueValueColorRampName(newColorRampName);
  var customRendering = ro.GetEnableCustomRenderingDefaults();
  ro.SetEnableCustomRenderingDefaults(!customRendering);
  var sampleType = ro.GetResampleType();
  ro.SetResampleType(RasterResamplingType.CubicConvolution);
  var stretchType = ro.GetStretchType();
  ro.SetStretchType(RasterStretchType.PercentMinimumMaximum);
  var val = ro.GetNumberOfStandardDeviation();
  ro.SetNumberOfStandardDeviation(3);
  var (clipMin, clipMax) = ro.GetClipPercentage();
  ro.SetClipPercentage(12, 23);
  var red = ro.GetGammaStretchValueRed();
  var green = ro.GetGammaStretchValueGreen();
  var blue = ro.GetGammaStretchValueBlue();
  ro.SetGammaStretchValueRed(2);
  ro.SetGammaStretchValueGreen(20);
  ro.SetGammaStretchValueBlue(60);
  var displayBackground = ro.GetDisplayBackground();
  ro.SetDisplayBackground(!displayBackground);
  var (r, g, b) = ro.GetBackgroundValue();
  ro.SetBackgroundValue(4, 21, 61);
  var backColor = ro.GetBackgroundColor();
  ro.SetBackgroundColor(CIMColor.CreateRGBColor(255, 0, 0));
  var noData = ro.GetNoDataColor();
  ro.SetNoDataColor(CIMColor.CreateRGBColor(0, 255, 0));
  // cache
  var useCache = ro.GetUseImageServiceCache();
  ro.SetUseImageServiceCache(!useCache);
  //dataset
  var opt = ro.GetPyramidOption();
  ro.SetPyramidOption(ArcGIS.Desktop.Core.BuildPyramidOption.NeverBuild);
  var sample = ro.GetPyramidResampleMethod();
  ro.SetPyramidResampleMethod(PyramidResamplingMode.Bilinear);
  var compression = ro.GetPyramidCompressionMethod();
  ro.SetPyramidCompressionMethod(PyramidCompressionType.JPEG_YCbCr);
  var quality = ro.GetPyramidCompressionQuality();
  ro.SetPyramidCompressionQuality(32);
  var stats = ro.GetStatisticsOption();
  ro.SetStatisticsOption(CalculateStatisticOption.AlwaysCalculate);
  var x = ro.GetSkipFactorX();
  ro.SetSkipFactorX(3);
  var y = ro.GetSkipFactorY();
  ro.SetSkipFactorY(23);
  var useWorldFile = ro.GetUseWorldFile();
  ro.SetUseWorldFile(!useWorldFile);
  var createTiledTiff = ro.GetCreateTiledTiff();
  ro.SetCreateTiledTiff(!createTiledTiff);
  var maxUniqueValues = ro.GetMaximumUniqueValues();
  ro.SetMaximumUniqueValues(123456);
  var path = ro.GetProxyFileLocation();
  ro.SetProxyFileLocation("c:\\temp");
  var isExpanded = ro.GetIsMosaicLayerExpanded();
  ro.SetIsMosaicLayerExpanded(!isExpanded);
  var isVisible = ro.GetIsMosaicBoundaryVisible();
  ro.SetIsMosaicBoundaryVisible(!isVisible);
  isVisible = ro.GetIsMosaicFootprintVisible();
  ro.SetIsMosaicFootprintVisible(!isVisible);
  isVisible = ro.GetIsMosaicSeamlinesVisible();
  ro.SetIsMosaicSeamlinesVisible(!isVisible);
  isVisible = ro.GetIsMosaicPreviewVisible();
  ro.SetIsMosaicPreviewVisible(!isVisible);
  var (red_3band, green_3band, blue_3band) = ro.Get3BandColor();
  ro.Set3BandColor(2, 2, 2);
  var (ms_red, ms_green, ms_blue) = ro.GetMSColor();
  ro.SetMSColor(23, 24, 25);
  var enableCustomColorSchemes = ro.GetEnableCustomColorSchemes();
  ro.SetEnableCustomColorSchemes(!enableCustomColorSchemes);
  var useWavelengthInfo = ro.GetUseWavelengthInformation();
  ro.SetUseWavelengthInformation(!useWavelengthInfo);
