var reportsInProject = Project.Current.GetItems<ReportProjectItem>();
foreach (var reportItem in reportsInProject)
//Do Something with the report
Get a specific report
ReportProjectItem reportProjItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals("Report Name"));
//Note: Needs QueuedTask to run
Report reportInProject = reportProjItem?.GetReport();
Open a Report project item in a new view
//Open a report project item in a new view.
//A report project item may exist but it may not be open in a view.
//Reference a report project item by name
ReportProjectItem reportPrjItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals("MyReport"));
//Get the report associated with the report project item
Report reportToOpen = reportPrjItem.GetReport();
//Create the new pane
IReportPane iNewReportPane = await ProApp.Panes.CreateReportPaneAsync(reportToOpen); //GUI thread
Activate an already open report view
Report reportToActivate = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault().GetReport();
var reportPane = FrameworkApplication.Panes.FindReportPanes(report).Last();
if (reportPane == null)
return;
//Activate the pane
(reportPane as ArcGIS.Desktop.Framework.Contracts.Pane).Activate();
//Get the "ReportView" associated with the Report Pane.
ReportView reportViewFromPane = reportPane.ReportView;
Reference the active report view
//Confirm if the current, active view is a report view. If it is, do something.
ReportView activeReportView = ReportView.Active;
if (activeReportView != null)
// do something
Refresh the report view
if (reportView == null)
return;
reportView.Refresh();
Zoom to whole page
reportView.ZoomToWholePage();
Zoom to specific location on Report view
//Note: On the QueuedTask
var detailsSection = report.Elements.OfType<ReportSection>().FirstOrDefault().Elements.OfType<ReportDetails>().FirstOrDefault();
var bounds = detailsSection.GetBounds();
ReportView.Active.ZoomTo(bounds);
Zoom to page width
//Process on worker thread
reportView.ZoomToPageWidth();
Create Report
Create report
//Note: Call within QueuedTask.Run()
//The fields in the datasource used for the report
//This uses a US Cities dataset
var listFields = new List<CIMReportField> {
//Grouping should be the first field
new CIMReportField{Name = "STATE_NAME", FieldOrder = 0, Group = true, SortInfo = FieldSortInfo.Desc}, //Group cities using STATES
new CIMReportField{Name = "CITY_NAME", FieldOrder = 1},
new CIMReportField{Name = "POP1990", FieldOrder = 2, },
//Definition query to use for the data source
var defQuery = "STATE_NAME LIKE 'C%'";
//Define the Datasource
var reportDataSource = new ReportDataSource(featureLayer, defQuery, listFields);
//The CIMPage defintion - page size, units, etc
var cimReportPage = new CIMPage
Height = 11,
StretchElements = false,
Width = 6.5,
ShowRulers = true,
ShowGuides = true,
Margin = new CIMMargin { Bottom = 1, Left = 1, Right = 1, Top = 1 },
Units = LinearUnit.Inches
//Report template
var reportTemplates = await ReportTemplateManager.GetTemplatesAsync();
var reportTemplate = reportTemplates.Where(r => r.Name == "Attribute List with Grouping").First();
//Report Styling
var reportStyles = await ReportStylingManager.GetStylingsAsync();
var reportStyle = reportStyles.Where(s => s == "Cool Tones").First();
//Field Statistics
var fieldStatisticsList = new List<ReportFieldStatistic> {
new ReportFieldStatistic{ Field = "POP1990", Statistic = FieldStatisticsFlag.Sum}
//Note: NoStatistics option for FieldStatisticsFlag is not supported.
var newReport = ReportFactory.Instance.CreateReport("USAReport", reportDataSource, cimReportPage, fieldStatisticsList, reportTemplate, reportStyle);
Create a report from a custom report template
//Note: Run within QueuedTask.Run()
// get the first map in the project
MapProjectItem item = Project.Current.GetItems<MapProjectItem>().FirstOrDefault(n => n.Name == "Cities");
if (item == null)
return;
Map map = item.GetMap();
if (map == null)
return;
Layer cityLayer = map.FindLayers("U.S. Cities")[0];
if (cityLayer == null)
return;
// load template information
var templatePath = System.IO.Path.Combine($@"{Project.Current.HomeFolderPath}\TemplateSimpleReportWithTokens.rptt");
ReportCustomTemplateDefinition templateDef = ReportTemplateManager.GetCustomTemplateDefinition(templatePath);
if (templateDef == null || templateDef.ReportTemplateDataSourceItems?.Count() < 1)
return;
// get template info of first data source (parent) and set its data source
ReportCustomTemplateDataSourceInfo parentDataSourceInfo = templateDef.ReportTemplateDataSourceItems.ElementAt(0);
parentDataSourceInfo.SetReportDataSource(cityLayer);
TemplateTokenFieldInfoValues templateTokenFieldInfoValues = parentDataSourceInfo.TokenInfoValues;
parentDataSourceInfo.DefinitionQuery = "STATE_NAME = 'Massachusetts'";
templateTokenFieldInfoValues["[text-field-value-0]"] = "CITY_NAME";
templateTokenFieldInfoValues["[text-field-name-0]"] = "City";
templateTokenFieldInfoValues["[numeric-field-value-0]"] = "POP1990";
templateTokenFieldInfoValues["[numeric-field-name-0]"] = "Population";
if (templateDef.CanCreateReport())
// create the report
report = ReportFactory.Instance.CreateReport("RelateSiblingsFromCode", templateDef);
//UI thread
if (report != null)
//open report
await FrameworkApplication.Panes.CreateReportPaneAsync(report);
Export report to pdf
//Define Export Options
var exportOptions = new ReportExportOptions
ExportPageOption = ExportPageOptions.ExportAllPages,
TotalPageNumberOverride = 0
//Create PDF format with appropriate settings
string path = $@"{Project.Current.HomeFolderPath}\ReportExport.pdf";
PDFFormat pdfFormat = new PDFFormat();
pdfFormat.Resolution = 300;
pdfFormat.OutputFileName = path;
report.ExportToPDF($"{report.Name}", pdfFormat, exportOptions, true);
Import a report file
var reportFilePath = @"c:\temp\Report.rptx";
Item reportToImport = ItemFactory.Instance.Create(reportFilePath);
Project.Current.AddItem(reportToImport as IProjectItem);
Delete a report
//Reference a ReportProjectItem in a project by name
ReportProjectItem reportItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(item => item.Name.Equals(reportName));
if (reportItem != null)
//Delete the report from the project
Project.Current.RemoveItem(reportItem);
//Remove Groups
// The fields in the datasource used for the report
var listFields = new List<string> {
"STATE_NAME"
report.RemoveGroups(listFields);
//Add Group
report.AddGroup("STATE_NAME", true, true, "");
//Modify the Definition Query
report.SetDefinitionQuery(defQuery);
Modify the report Page
Height = 12,
Width = 6.5,
ShowRulers = true,
ShowGuides = true,
report.SetPage(cimReportPage);
//Change only the report's page height
report.SetPageHeight(12);
Add SubReport
var mainReport = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(r => r.Name == "USAReports")?.GetReport();
if (mainReport == null) return;
//Add sub report
var vermontReportItem = Project.Current.GetItems<ReportProjectItem>().FirstOrDefault(r => r.Name == "Vermont");
if (vermontReportItem == null) return;
Report vermontReport = vermontReportItem.GetReport();
mainReport.AddSubReport(vermontReportItem, -1, true); // If -1, the subreport is added to the end of the report.
Report Design
Get a report template
//Report Template Styles:
//Attribute List
//Attribute List with Grouping
//Basic Summary
//Basic Summary with Grouping
//Page Per Feature
var reportTemplate = reportTemplates.Where(r => r.Name == "Report Template Name").First();
Get a report styling
//Report Styling:
//Black and White
//Cool Tones
//Warm Tones
var reportStyle = reportStyles.Where(s => s == "Report style name").First();
Report Elements
Get various Report sections
//Get the "ReportSection element"
//ReportSectionElement contains the ReportHeader, ReportPageHeader, ReportDetails. ReportPageFooter, ReportFooter sections.
var mainReportSection = report.Elements.OfType<ReportSection>().FirstOrDefault();
//Get the ReportHeader
var reportHeader = mainReportSection?.Elements.OfType<ReportHeader>().FirstOrDefault();
var reportPageHeader = mainReportSection?.Elements.OfType<ReportPageHeader>().FirstOrDefault();
//Get the "ReportDetails" within the ReportSectionElement. ReportDetails is where "fields" are.
var reportDetailsSection = mainReportSection?.Elements.OfType<ReportDetails>().FirstOrDefault();
//Get the ReportPageFooter
var reportPageFooter = mainReportSection?.Elements.OfType<ReportPageFooter>().FirstOrDefault();
//Get the ReportFooter
var reportFooter = mainReportSection?.Elements.OfType<ReportFooter>().FirstOrDefault();
Select elements
//ReportDetailsSection contains the "Fields"
var elements = reportDetailsSection.Elements;
reportDetailsSection.SelectElements(elements);
Select all elements
//Select all elements in the Report Footer.
ReportPageFooter pageFooterSection = report.Elements.OfType<ReportSection>().FirstOrDefault().Elements.OfType<ReportPageFooter>().FirstOrDefault();
pageFooterSection.SelectAllElements();
Get selected elements
IReadOnlyList<Element> selectedElements = report.GetSelectedElements();
//Can also use the active ReportView
IReadOnlyList<Element> selectedElementsFromView = ReportView.Active.GetSelectedElements();
Zoom to selected elements
reportView.ZoomToSelectedElements();
Clear element selection
reportView.ClearElementSelection();
Find specific elements in the report based on their Name.
var reportElementsToFind = new List<string> { "ReportText1", "ReportText2" };
var textReportElements = report.FindElements(reportElementsToFind);
Delete Elements
report.DeleteElements(textReportElements);
Create a new field in the report
//This is the gap between two fields
double fieldIncrement = 0.9388875113593206276389;
//On the QueuedTask
//New field to add.
var newReportField = new CIMReportField
Name = "POP1990",
FieldOrder = 2,
if (mainReportSection == null) return;
if (reportDetailsSection == null) return;
//Within ReportDetails find the envelope that encloses a field.
//We get the first CIMParagraphTextGraphic in the collection so that we can add the new field next to it.
var lastFieldGraphic = reportDetailsSection.Elements.FirstOrDefault((r) =>
var gr = r as GraphicElement;
if (gr == null) return false;
return (gr.GetGraphic() is CIMParagraphTextGraphic ? true : false);
//Get the Envelope of the last field
var graphicBounds = lastFieldGraphic.GetBounds();
//Min and Max values of the envelope
var xMinOfFieldEnvelope = graphicBounds.XMin;
var yMinOfFieldEnvelope = graphicBounds.YMin;
var xMaxOfFieldEnvelope = graphicBounds.XMax;
var YMaxOfFieldEnvelope = graphicBounds.YMax;
//create the new Envelope to be offset from the existing field
MapPoint newMinPoint = MapPointBuilderEx.CreateMapPoint(xMinOfFieldEnvelope + fieldIncrement, yMinOfFieldEnvelope);
MapPoint newMaxPoint = MapPointBuilderEx.CreateMapPoint(xMaxOfFieldEnvelope + fieldIncrement, YMaxOfFieldEnvelope);
Envelope newFieldEnvelope = EnvelopeBuilderEx.CreateEnvelope(newMinPoint, newMaxPoint);
//Create field
GraphicElement fieldGraphic = ReportElementFactory.Instance.CreateFieldValueTextElement(reportDetailsSection, newFieldEnvelope, newReportField);
