// Note: call within QueuedTask.Run()
//Create with initial visibility set to false. Add to current scene
var createparams = new LayerCreationParams(new Uri(sceneLayerUrl, UriKind.Absolute))
IsVisible = false
//cast to specific type of scene layer being created - in this case FeatureSceneLayer
var sceneLayer = LayerFactory.Instance.CreateLayer<Layer>(
createparams, MapView.Active.Map) as FeatureSceneLayer;
//or...specify the cast directly
var sceneLayer2 = LayerFactory.Instance.CreateLayer<FeatureSceneLayer>(
createparams, MapView.Active.Map);
//ditto for BuildingSceneLayer, PointCloudSceneLayer, IntegratedMeshSceneLayer
Building Discipline Scene Layer
Get BuildingDisciplineSceneLayer Discipline
var bsl_discipline = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BuildingDisciplineSceneLayer>().FirstOrDefault(l => l.Name == "Architectural");
var disciplineName = bsl_discipline.GetDiscipline();
Enumerate the Discipline Layers from a Building SceneLayer
var bldgLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<BuildingSceneLayer>().First();
var disciplines = new Dictionary<string, BuildingDisciplineSceneLayer>();
//A Building layer has two children - Overview and FullModel
//Overview is a FeatureSceneLayer
//Full Model is a BuildingDisciplineSceneLayer that contains the disciplines
var fullModel = bldgLayer.FindLayers("Full Model").First()
as BuildingDisciplineSceneLayer;
//collect information on the disciplines
var name = fullModel.Name;
var discipline = fullModel.GetDiscipline();
//etc
//TODO - use collected information
disciplines.Add(discipline, fullModel);
//Discipline layers are composite layers too
foreach (var childDiscipline in fullModel.Layers
.OfType<BuildingDisciplineSceneLayer>())
//Discipline layers can also contain FeatureSceneLayers that render the
//individual full model contents
var content_names = string.Join(", ", childDiscipline.Layers
.OfType<FeatureSceneLayer>().Select(fl => fl.Name));
// Recursively call this "function" to go deeper
Building Scene Layer
Name of BuildingSceneLayer
bsl = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<BuildingSceneLayer>().FirstOrDefault();
var scenelayerName = bsl.Name;
Query Building Scene Layer for available Types and Values
var dict = bsl.GetAvailableFieldsAndValues();
//get a list of existing disciplines
var disciplines = dict.SingleOrDefault(
kvp => kvp.Key == "Discipline").Value ?? new List<string>();
//get a list of existing categories
var categories = dict.SingleOrDefault(
kvp => kvp.Key == "Category").Value ?? new List<string>();
//get a list of existing floors or "levels"
var floors = dict.SingleOrDefault(
kvp => kvp.Key == "BldgLevel").Value ?? new List<string>();
Create a Default Filter and Get Filter Count
var filter1 = bsl.CreateDefaultFilter();
var values = filter1.FilterBlockDefinitions[0].SelectedValues;
//values will be a single value for the type
//"CreatedPhase", value "New Construction"
//There will be at least one filter after "CreateDefaultFilter()" call
var filtersCount = bsl.GetFilters().Count;
Get all the Filters that Contain WireFrame Blocks
//Note: wire_frame_filters can be null in this example
var wire_frame_filters = bsl.GetFilters().Where(
f => f.FilterBlockDefinitions.Any(
fb => fb.FilterBlockMode == Object3DRenderingMode.Wireframe));
//substitute Object3DRenderingMode.None to get blocks with a solid mode (default)
//and...
//fb.FilterBlockMode == Object3DRenderingMode.Wireframe &&
//fb.FilterBlockMode == Object3DRenderingMode.None
//for blocks with both
Set and Clear Active Filter for BuildingSceneLayer
//Note: Use HasFilter to check if a given filter id exists in the layer
if (bsl.HasFilter(filter.ID))
bsl.SetActiveFilter(filter.ID);
var activeFilter = bsl.GetActiveFilter();
//Clear the active filter
bsl.ClearActiveFilter();
Get BuildingSceneLayer Filter ID and Filter
var filterDefinition = bsl.GetFilter(filterID);
//or via Linq
//var filter = bsl.GetFilters().FirstOrDefault(f => f.ID == filterID1);
Modify BuildingSceneLayer Filter Name and Description
//refer to "Query Building Scene Layer for available Types and Values
var categories = dict.SingleOrDefault(kvp => kvp.Key == "Category").Value;
var floors = dict.SingleOrDefault(kvp => kvp.Key == "BldgLevel").Value;
//Make a new filter definition
var fd = new FilterDefinition()
Name = "Floor and Category Filter",
Description = "Example filter",
//Set up the values for the filter
var filtervals = new Dictionary<string, List<string>>();
filtervals.Add("BldgLevel", new List<string>() { floors[0] });
var category_vals = categories.Where(v => v == "Walls" || v == "Stairs").ToList() ?? new List<string>();
if (category_vals.Count() > 0)
filtervals.Add("Category", category_vals);
//Create a solid block (other option is "Wireframe")
var fdef = new FilterBlockDefinition()
FilterBlockMode = Object3DRenderingMode.None,
Title = "Solid Filter",
SelectedValues = filtervals//Floor and Category
//Apply the block
fd.FilterBlockDefinitions = new List<FilterBlockDefinition>() { fdef };
//Add the filter definition to the layer
bsl.UpdateFilter(fd);
//Set it active. The ID is auto-generated
bsl.SetActiveFilter(fd.ID);
Modify BuildingSceneLayer Filter Block
var filterBlock = new FilterBlockDefinition();
filterBlock.FilterBlockMode = Object3DRenderingMode.Wireframe;
var selectedValues = new Dictionary<string, List<string>>();
//We assume QueryAvailableFieldsAndValues() contains "Walls" and "Doors"
//For 'Category'
selectedValues["Category"] = new List<string>() { "Walls", "Doors" };
filterBlock.SelectedValues = selectedValues;
//Overwrite
filter.FilterBlockDefinitions = new List<FilterBlockDefinition>() { filterBlock };
bsl.UpdateFilter(filter);
Remove BuildingSceneLayer Filter
bsl.RemoveFilter(filter.ID);
//Or remove all filters
bsl.RemoveAllFilters();
FeatureSceneLayer Editing
Determine if a FeatureSceneLayer supports editing
featSceneLayer = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<FeatureSceneLayer>().FirstOrDefault();
if (!featSceneLayer.HasAssociatedFeatureService ||
!featSceneLayer.IsEditable)
//not supported - exit the function
//TODO continue editing here...
Create a new Point feature in FeatureSceneLayer
//must support editing!
//Check geometry type...must be point in this example
var editOp = new EditOperation()
Name = "Create new 3d point feature",
SelectNewFeatures = true
var attributes = new Dictionary<string, object>();
//mapPoint contains the new 3d point location
attributes.Add("SHAPE", mapPoint);
attributes.Add("TreeID", "1");
editOp.Create(featSceneLayer, attributes);
editOp.ExecuteAsync();
Delete all the selected features in FeatureSceneLayer
return;
var delOp = new EditOperation()
Name = "Delete selected features"
//Assuming we have a selection on the layer...
delOp.Delete(featSceneLayer, featSceneLayer.GetSelection().GetObjectIDs());
delOp.ExecuteAsync();
Edit the attributes of a FeatureSceneLayer
return;
Name = "Edit FeatureSceneLayer Attributes",
SelectModifiedFeatures = true
//make an inspector
var inspector = new Inspector();
//get the attributes for the specified oid
inspector.Load(featSceneLayer, oid);
inspector["PermitNotes"] = "test";//modify
editOp.Modify(inspector);
editOp.Execute();//synchronous flavor
FeatureSceneLayer
Name of FeatureSceneLayer
var scenelayerName = featSceneLayer?.Name;
Get the Data Source type
var dataSourceType = featSceneLayer?.GetDataSourceType() ??
SceneLayerDataSourceType.Unknown;
if (dataSourceType == SceneLayerDataSourceType.SLPK)
//Uses SLPK - only cached attributes
else if (dataSourceType == SceneLayerDataSourceType.Service)
//Hosted service - can have live attributes - check HasAssociatedFeatureService
Get the Associated Feature class
if (featSceneLayer.HasAssociatedFeatureService)
using (var fc = featSceneLayer.GetFeatureClass())
//TODO query underlying feature class
Get Field Definitions
//Get only the readonly fields
var readOnlyFields = featSceneLayer.GetFieldDescriptions()
.Where(fdesc => fdesc.IsReadOnly);
//assume the geometry used in SelectFeaturesEx() is coming from a
//map tool...
//SketchType = SketchGeometryType.Rectangle;
//SketchOutputMode = SketchOutputMode.Screen;
var result = MapView.Active.SelectFeaturesEx(geometry);
//Get scene layers with selections
var scene_layers = result.ToDictionary<FeatureSceneLayer>();
foreach (var kvp in scene_layers)
var scene_layer = kvp.Key as FeatureSceneLayer;
var sel_oids = kvp.Value;
//If there are attributes then get them
if (scene_layer.HasAssociatedFeatureService)
var insp = new Inspector();
foreach (var objectid in sel_oids)
insp.Load(scene_layer, objectid);
//TODO something with retrieved attributes
Has Associated FeatureService
//Can Select and Search...possibly edit
Search Rows on the FeatureSceneLayer
if (!featSceneLayer.HasAssociatedFeatureService)
return;//Search and Select not supported
//Multipatch (Object3D) or point?
//var is3dObject = ((ISceneLayerInfo)featSceneLayer).SceneServiceLayerType
// == esriSceneServiceLayerType.Object3D;
var is3dObject = featSceneLayer.FeatureSceneLayerType == FeatureSceneLayerType.Object3D;
var queryFilter = new QueryFilter
WhereClause = "Name = 'Ponderosa Pine'",
SubFields = "*"
int rowCount = 0;
//or select... var select = featSceneLayer.Select(queryFilter)
using (RowCursor rowCursor = featSceneLayer.Search(queryFilter))
while (rowCursor.MoveNext())
using (var feature = rowCursor.Current as Feature)
oid = feature.GetObjectID();
var shape = feature.GetShape();
var attrib = feature["Name"];
if (is3dObject)
//shape is a multipatch
else
//shape is a point
rowCount += 1;
Hide Selected features and Show Hidden features
QueryFilter qf = new QueryFilter()
ObjectIDs = new List<long>() { 6069, 6070, 6071 },
SubFields = "*"
featSceneLayer.Select(qf, SelectionCombinationMethod.New);
featSceneLayer.HideSelectedFeatures();
var selectionCount = featSceneLayer.SelectionCount;
featSceneLayer.ShowHiddenFeatures();
Use MapView Selection SelectFeaturesEx or GetFeaturesEx
var sname = featSceneLayer.Name;
//Select all features within the current map view
var sz = MapView.Active.GetViewSize();
var c_ll = new Coordinate2D(0, 0);
var c_ur = new Coordinate2D(sz.Width, sz.Height);
//Use screen coordinates for 3D selection on MapView
var env = EnvelopeBuilderEx.CreateEnvelope(c_ll, c_ur);
//HasAssociatedFeatureService does not matter for SelectFeaturesEx
//or GetFeaturesEx
var result = MapView.Active.SelectFeaturesEx(env);
//var result = MapView.Active.GetFeaturesEx(env);
//The list of object ids from SelectFeaturesEx
var oids1 = result.ToDictionary().Where(kvp => kvp.Key.Name == sname).First().Value;
//TODO - use the object ids
MapView.Active.Map.ClearSelection();
Use Select or Search with a Spatial Query
return;//no search or select
var map_pt1 = MapView.Active.ClientToMap(new System.Windows.Point(0, sz.Height));
var map_pt2 = MapView.Active.ClientToMap(new System.Windows.Point(sz.Width, 0));
//Convert to an envelope
var temp_env = EnvelopeBuilderEx.CreateEnvelope(map_pt1, map_pt2, MapView.Active.Map.SpatialReference);
//Project if needed to the layer spatial ref
SpatialReference sr = null;
using (var fdef = fc.GetDefinition())
sr = fdef.GetSpatialReference();
var env = GeometryEngine.Instance.Project(temp_env, sr) as Envelope;
//Set up a query filter
var sf = new SpatialQueryFilter()
FilterGeometry = env,
SpatialRelationship = SpatialRelationship.Intersects,
SubFields = "*"
//Select against the feature service
var select = featSceneLayer.Select(sf);
if (select.GetCount() > 0)
//enumerate over the selected features
using (var rc = select.Search())
while (rc.MoveNext())
using (var feature = rc.Current as Feature)
//etc.
Name of PointCloudSceneLayer
var scenelayerName = pointCloudSceneLayer?.Name;
Get Data Source type for PointCloudSceneLayer
SceneLayerDataSourceType dataSourceType = pointCloudSceneLayer.GetDataSourceType();
//TODO...
else if (dataSourceType == SceneLayerDataSourceType.SLPK)
Query all class codes and labels in the PointCloudSceneLayer
//Retrieve the available classification codes
var dict = pointCloudSceneLayer.GetAvailableClassCodesAndLabels();
//Filter out low noise and unclassified (7 and 1 respectively)
//consult https://doc.esri.com/en/arcgis-pro/3.7/help/data/las-dataset/storing-lidar-data.htm
var filterDef = new PointCloudFilterDefinition()
ClassCodes = dict.Keys.Where(c => c != 7 && c != 1).ToList(),
ReturnValues = new List<PointCloudReturnType> {
PointCloudReturnType.FirstOfMany }
//apply the filter
pointCloudSceneLayer.SetFilters(filterDef.ToCIM());
Update the ClassFlags for PointCloudSceneLayer
var filters = pointCloudSceneLayer.GetFilters();
PointCloudFilterDefinition fdef = null;
if (filters.Count() == 0)
fdef = new PointCloudFilterDefinition()
//7 is "edge of flight line" - exclude
ClassFlags = new List<ClassFlag> {
new ClassFlag(7, ClassFlagOption.Exclude) }
else
fdef = PointCloudFilterDefinition.FromCIM(filters);
//keep any include or ignore class flags
var keep = fdef.ClassFlags.Where(
cf => cf.ClassFlagOption != ClassFlagOption.Exclude).ToList();
keep.Add(new ClassFlag(7, ClassFlagOption.Exclude));
fdef.ClassFlags = keep;
//apply
pointCloudSceneLayer.SetFilters(fdef.ToCIM());
Get the filters for PointCloudSceneLayer
IReadOnlyList<CIMPointCloudFilter> updatedFilter = pointCloudSceneLayer.GetFilters();
foreach (var f in updatedFilter)
//There is either 0 or 1 of each
if (f is CIMPointCloudReturnFilter returnFilter)
PointCloudFilterDefinition pcfl = PointCloudFilterDefinition.FromCIM(updatedFilter);
List<PointCloudReturnType> updatedReturnValues = pcfl.ReturnValues;
if (f is CIMPointCloudValueFilter classCodesFilter)
// do something
if (f is CIMPointCloudBitFieldFilter classFlagsFilter)
// do something
Clear filters in PointCloudSceneLayer
pointCloudSceneLayer.ClearFilters();
Get PointCloudSceneLayer Renderer and RendererType
CIMPointCloudRenderer cimGetPCLRenderer = pointCloudSceneLayer.GetRenderer();
//Can be one of Unknown, Stretch, ClassBreaks, UniqueValue, RGB
PointCloudRendererType pclRendererType = pointCloudSceneLayer.RendererType;
Query PointCloudSceneLayer Renderer fields
IReadOnlyList<string> flds = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
PointCloudRendererType.UniqueValueRenderer);
var fldCount = flds.Count;
Create and Set a Stretch Renderer
var fields = pointCloudSceneLayer.GetAvailablePointCloudRendererFields(
PointCloudRendererType.StretchRenderer);
var stretchDef = new PointCloudRendererDefinition(
//Will be either ELEVATION or INTENSITY
Field = fields[0]
//Create the CIM Renderer
var stretchRenderer = pointCloudSceneLayer.CreateRenderer(stretchDef)
as CIMPointCloudStretchRenderer;
//Apply a color ramp
var style = Project.Current.GetItems<StyleProjectItem>()
.First(s => s.Name == "ArcGIS Colors");
var colorRamp = style.SearchColorRamps("").First();
stretchRenderer.ColorRamp = colorRamp.ColorRamp;
//Apply modulation
stretchRenderer.ColorModulation = new CIMColorModulationInfo()
MinValue = 0,
MaxValue = 100
//apply the renderer
pointCloudSceneLayer.SetRenderer(stretchRenderer);
Create and Set a ClassBreaks Renderer
PointCloudRendererType.ClassBreaksRenderer);
var classBreakDef = new PointCloudRendererDefinition(
//ELEVATION or INTENSITY
Field = fields[0]
//create the renderer
var cbr = pointCloudSceneLayer.CreateRenderer(classBreakDef)
as CIMPointCloudClassBreaksRenderer;
//Set up a color scheme to use
var rampStyle = style.LookupItem(
StyleItemType.ColorRamp, "Spectrum By Wavelength-Full Bright_Multi-hue_2")
as ColorRampStyleItem;
var colorScheme = rampStyle.ColorRamp;
//Set up 6 manual class breaks
var breaks = 6;
var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
colorScheme, breaks);
var classBreaks = new List<CIMColorClassBreak>();
var min = cbr.Breaks[0].UpperBound;
var max = cbr.Breaks[cbr.Breaks.Count() - 1].UpperBound;
var step = (max - min) / (double)breaks;
//add in the class breaks
double upper = min;
for (int b = 1; b <= breaks; b++)
double lower = upper;
upper = b == breaks ? max : min + (b * step);
var cb = new CIMColorClassBreak()
UpperBound = upper,
Label = string.Format("{0:#0.0#} - {1:#0.0#}", lower, upper),
Color = colors[b - 1]
classBreaks.Add(cb);
cbr.Breaks = classBreaks.ToArray();
pointCloudSceneLayer.SetRenderer(cbr);
PointCloudSceneLayer Extended Properties
Edit Color Modulation
var def = pointCloudSceneLayer.GetDefinition() as CIMPointCloudLayer;
//Get the ColorModulation off the renderer
var modulation = def.Renderer.ColorModulation;
if (modulation == null)
modulation = new CIMColorModulationInfo();
//Set the minimum and maximum intensity as needed
modulation.MinValue = 0;
modulation.MaxValue = 100.0;
//apply back
def.Renderer.ColorModulation = modulation;
//Commit changes back to the CIM
pointCloudSceneLayer.SetDefinition(def);
Edit The Renderer to use Fixed Size
//Set the point shape and sizing on the renderer
def.Renderer.PointShape = PointCloudShapeType.DiskShaded;
var pointSize = new CIMPointCloudFixedSizeAlgorithm()
UseRealWorldSymbolSizes = false,
Size = 8
def.Renderer.PointSizeAlgorithm = pointSize;
Edit the Renderer to Scale Size
def.Renderer.PointShape = PointCloudShapeType.DiskFlat;//default
var scaleSize = new CIMPointCloudSplatAlgorithm()
MinSize = 8,
ScaleFactor = 1.0 //100%
def.Renderer.PointSizeAlgorithm = scaleSize;
Edit Density settings
//PointsBudget - corresponds to Display Limit on the UI
// - the absolute maximum # of points to display
def.PointsBudget = 1000000;
//PointsPerInch - corresponds to Density Min --- Max on the UI
// - the max number of points per display inch to renderer
def.PointsPerInch = 15;
