// Note: call within QueuedTask.Run()
var url = "https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
var createParam = new FeatureLayerCreationParams(new Uri(url))
IsVisible = false //turned off by default
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(createParam, map);
//or use "original" create layer (will be visible by default)
Uri uri = new Uri(url);
streamLayer = LayerFactory.Instance.CreateLayer(uri, map) as StreamLayer;
streamLayer.SetVisibility(false);//turn off
Create a stream layer with a definition query
//Must be on the QueuedTask
var lyrCreateParam = new FeatureLayerCreationParams(new Uri(url))
IsVisible = true,
DefinitionQuery = new DefinitionQuery(whereClause: "RWY = '29L'", name: "Runway")
streamLayer = LayerFactory.Instance.CreateLayer<StreamLayer>(lyrCreateParam, map);
Create a stream layer with a simple renderer
var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/LABus/StreamServer";
var uri = new Uri(url, UriKind.Absolute);
var createParams = new FeatureLayerCreationParams(uri)
RendererDefinition = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructPointSymbol(
ColorFactory.Instance.BlueRGB,
12,
SimpleMarkerStyle.Pushpin).MakeSymbolReference()
createParams, map);
Setting a unique value renderer for latest observations
var url = @"https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer";
IsVisible = false
createParams, map);
//Define the unique values by hand
var uvr = new CIMUniqueValueRenderer()
Fields = new string[] { "ACTYPE" },
UseDefaultSymbol = true,
DefaultLabel = "Others",
DefaultSymbol = SymbolFactory.Instance.ConstructPointSymbol(
CIMColor.CreateRGBColor(185, 185, 185), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
var classes = new List<CIMUniqueValueClass>
//add in classes - one for ACTYPE of 727, one for DC 9
new CIMUniqueValueClass()
Values = new CIMUniqueValue[] {
new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
Visible = true,
Label = "Boeing 727",
ColorFactory.Instance.RedRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
Visible = true,
Label = "DC 9",
ColorFactory.Instance.GreenRGB, 10, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//add the classes to a group
var groups = new List<CIMUniqueValueGroup>()
new CIMUniqueValueGroup() {
Classes = classes.ToArray()
//add the groups to the renderer
uvr.Groups = groups.ToArray();
//Apply the renderer (for current observations)
streamLayer.SetRenderer(uvr);
streamLayer.SetVisibility(true);//turn on the layer
Stream Layer settings and properties
Find all Stream Layers that are Track Aware
var trackAwareLayers = MapView.Active.Map.GetLayersAsFlattenedList()
.OfType<StreamLayer>().Where(sl => sl.IsTrackAware)?.ToList();
Determine the Stream Layer type
//spatial or non-spatial?
if (streamLayer.TrackType == TrackType.AttributeOnly)
//this is a non-spatial stream layer
else
//this must be a spatial stream layer
Check the Stream Layer connection state
if (!streamLayer.IsStreamingConnectionOpen)
streamLayer.StartStreaming();
//Must be called on the feature class
using var rfc = streamLayer.GetFeatureClass();
rfc.Truncate();
Get the Track Id Field
if (streamLayer.IsTrackAware)
var trackField = streamLayer.TrackIdFieldName;
//TODO use the field name
Get The Track Type
var trackType = streamLayer.TrackType;
switch (trackType)
//TODO deal with tracktype
case TrackType.None:
case TrackType.AttributeOnly:
case TrackType.Spatial:
break;
Set the Maximum Count of Previous Observations to be Stored in Memory
//Set Expiration Method and Max Expiration Count
if (streamLayer.GetExpirationMethod() != FeatureExpirationMethod.MaximumFeatureCount)
streamLayer.SetExpirationMethod(FeatureExpirationMethod.MaximumFeatureCount);
streamLayer.SetExpirationMaxCount(15);
//FYI
//MaxCount is per track! otherwise for the entire layer
Set the Maximum Age of Previous Observations to be Stored in Memory
//Set Expiration Method and Max Expiration Age
if (streamLayer.GetExpirationMethod() != FeatureExpirationMethod.MaximumFeatureAge)
streamLayer.SetExpirationMethod(FeatureExpirationMethod.MaximumFeatureAge);
//set to 12 hours (max is 24 hours)
streamLayer.SetExpirationMaxAge(new TimeSpan(12, 0, 0));
//FYI
//MaxAge is per track! otherwise for the entire layer
Set Stream Layer properties via the CIM
//The layer must be track aware and spatial
if (streamLayer.TrackType != TrackType.Spatial)
// not track aware and spatial
//get the CIM Definition
var def = streamLayer.GetDefinition() as CIMFeatureLayer;
//set the number of previous observations,
def.PreviousObservationsCount = (int)streamLayer.GetExpirationMaxCount() - 1;
//set show previous observations and track lines to true
def.ShowPreviousObservations = true;
def.ShowTracks = true;
//commit the changes
streamLayer.SetDefinition(def);
Rendering
Defining a unique value renderer definition
streamLayer = null;
//https://geoeventsample1.esri.com:6443/arcgis/rest/services/AirportTraffics/StreamServer
var uvrDef = new UniqueValueRendererDefinition()
ValueFields = new List<string> { "ACTYPE" },
.MakeSymbolReference(),
ValuesLimit = 5
//Note: CreateRenderer can only create value classes based on
//the current events it has received
streamLayer.SetRenderer(streamLayer.CreateRenderer(uvrDef));
Setting a unique value renderer for latest observations 2
//Define the classes by hand to avoid using CreateRenderer(...)
CIMUniqueValueClass uvcB727 = new CIMUniqueValueClass()
Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "B727" } } },
Visible = true,
Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(255, 0, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
CIMUniqueValueClass uvcD9 = new CIMUniqueValueClass()
Values = new CIMUniqueValue[] { new CIMUniqueValue() { FieldValues = new string[] { "DC9" } } },
Visible = true,
Label = "DC 9",
Symbol = SymbolFactory.Instance.ConstructPointSymbol(CIMColor.CreateRGBColor(0, 255, 0), 8, SimpleMarkerStyle.Hexagon).MakeSymbolReference()
//Assign the classes to a group
CIMUniqueValueGroup uvGrp = new CIMUniqueValueGroup()
Classes = new CIMUniqueValueClass[] { uvcB727, uvcD9 }
//assign the group to the renderer
var UVrndr = new CIMUniqueValueRenderer()
Groups = new CIMUniqueValueGroup[] { uvGrp },
//set the renderer. Depending on the current events received, the
//layer may or may not have events for each of the specified
//unique value classes
streamLayer.SetRenderer(UVrndr);
Setting a unique value renderer for previous observations
//Define unique value classes same as we do for current observations
//or use "CreateRenderer(...)" to assign them automatically
CIMUniqueValueClass uvcB727Prev = new CIMUniqueValueClass()
Visible = true,
CIMColor.CreateRGBColor(255, 0, 0), 4, SimpleMarkerStyle.Hexagon)
CIMUniqueValueClass uvcD9Prev = new CIMUniqueValueClass()
Visible = true,
Label = "DC 9",
CIMColor.CreateRGBColor(0, 255, 0), 4, SimpleMarkerStyle.Hexagon)
CIMUniqueValueGroup uvGrpPrev = new CIMUniqueValueGroup()
Classes = new CIMUniqueValueClass[] { uvcB727Prev, uvcD9Prev }
Groups = new CIMUniqueValueGroup[] { uvGrpPrev },
CIMColor.CreateRGBColor(185, 185, 185), 4, SimpleMarkerStyle.Hexagon)
streamLayer.SetRenderer(UVrndr, FeatureRendererTarget.PreviousObservations);
Setting a simple renderer to draw track lines
//Note: only a simple renderer with solid line symbol is supported for track
//line renderer
var trackRenderer = new SimpleRendererDefinition()
SymbolTemplate = SymbolFactory.Instance.ConstructLineSymbol(
ColorFactory.Instance.BlueRGB, 2, SimpleLineStyle.Solid)
streamLayer.CreateRenderer(trackRenderer),
FeatureRendererTarget.TrackLines);
Check Previous Observation and Track Line Visibility
//The layer must be track aware and spatial for these settings
//to have an effect
if (!streamLayer.AreTrackLinesVisible)
streamLayer.SetTrackLinesVisibility(true);
if (!streamLayer.ArePreviousObservationsVisible)
streamLayer.SetPreviousObservationsVisibility(true);
Make Track Lines and Previous Observations Visible
//to have an effect
//Note: Setting PreviousObservationsCount larger than the
//"SetExpirationMaxCount()" has no effect
streamLayer.SetPreviousObservationsCount(6);
Retrieve the current observation renderer
var renderer = streamLayer.GetRenderer();
Retrieve the previous observation renderer
var prev_renderer = streamLayer.GetRenderer(
Retrieve the track lines renderer
var track_renderer = streamLayer.GetRenderer(
Subscribe and SearchAndSubscribe
Search And Subscribe for Streaming Data
//query filter can be null to search and retrieve all rows
//true means recycling cursor
using (var rc = streamLayer.SearchAndSubscribe(qfilter, true))
//waiting for new features to be streamed
//default is no cancellation
while (rc.WaitForRowsAsync().Result)
while (rc.MoveNext())
using (var row = rc.Current)
//determine the origin of the row event
switch (row.GetRowSource())
case RealtimeRowSource.PreExisting:
//pre-existing row at the time of subscribe
continue;
case RealtimeRowSource.EventInsert:
//row was inserted after subscribe
continue;
case RealtimeRowSource.EventDelete:
//row was deleted after subscribe
continue;
}//row cursor is disposed. row cursor is unsubscribed
//....or....
//Use the feature class instead of the layer
//non-recycling cursor - 2nd param "false"
using (RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false))
//etc
Search And Subscribe With Cancellation
//Recycling cursor - 2nd param "true"
//or streamLayer.Subscribe(qfilter, true) to just subscribe
//auto-cancel after 20 seconds
var cancel = new CancellationTokenSource(new TimeSpan(0, 0, 20));
//catch TaskCanceledException
try
while (rc.WaitForRowsAsync(cancel.Token).Result)
//check for row events
using var row = rc.Current;
//etc
catch (TaskCanceledException)
//Handle cancellation as needed
cancel.Dispose();
Explicitly Cancel WaitForRowsAsync
RealtimeCursor rc = null;
bool SomeConditionForCancel = false;
//somewhere in our code we create a CancellationTokenSource
var cancel = new CancellationTokenSource();
//call cancel on the CancellationTokenSource anywhere in
//the add-in, assuming the CancellationTokenSource is in scope
if (SomeConditionForCancel)
cancel.Cancel();//<-- will cancel the token
//Within QueuedTask we are subscribed! streamLayer.Subscribe() or SearchAndSubscribe()
try
//TaskCanceledException will be thrown when the token is cancelled
//etc
cancel.Dispose();
Realtime FeatureClass
Connect to a real-time feature class from a real-time datastore
var realtimeServiceConProp = new RealtimeServiceConnectionProperties(
new Uri(url),
RealtimeDatastoreType.StreamService
using var realtimeDatastore = new RealtimeDatastore(realtimeServiceConProp);
//A Realtime data store only contains **one** Realtime feature class (or table)
var name = realtimeDatastore.GetTableNames().First();
using (RealtimeFeatureClass realtimeFeatureClass = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass)
//feature class, by default, is not streaming (opposite of the stream layer)
realtimeFeatureClass.StartStreaming();
//TODO use the feature class
Check the Realtime Feature Class is Track Aware
using var rfc_def = rfc.GetDefinition();
if (rfc_def.HasTrackIDField())
//Track aware
Get the Track Id Field from the Realtime Feature class
using (var rfc = streamLayer.GetFeatureClass())
using (var rfc_def = rfc.GetDefinition())
var fld_name = rfc_def.GetTrackIDField();
Subscribe to Streaming Data
//Note: with feature class we can also use a System Task to subscribe and
//process rows
// or var rfc = realtimeDatastore.OpenTable(name) as RealtimeFeatureClass
using RealtimeFeatureClass rfc = streamLayer.GetFeatureClass();
//subscribe, pre-existing rows are not searched
using RealtimeCursor rc = rfc.Subscribe(qfilter, false);
SpatialQueryFilter spatialFilter = new SpatialQueryFilter();
//getting geometry from new events as they arrive
Polygon poly = ((RealtimeFeature)row).GetShape() as Polygon;
//using the geometry to select features from another feature layer
spatialFilter.FilterGeometry = poly;//project poly if needed...
featureLayer.Select(spatialFilter);
continue;
default:
continue;
Search Existing Data and Subscribe for Streaming Data
//Note we can use System Task with the Realtime feature class
//for subscribe
using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, false);
//default is no cancellation - use await in async method
//pre-existing rows will be retrieved that were searched
using RealtimeRow row = rc.Current;
var row_source = row.GetRowSource();
switch (row_source)
//TODO - handle deletes
break;
//TODO handle inserts
break;
//TODO handle pre-existing rows
break;
Search And Subscribe With Cancellation 2
using RealtimeCursor rc = rfc.SearchAndSubscribe(qfilter, true);
try
// Use await in async method
using RealtimeRow record = rc.Current;
// Process the record
cancel.Dispose();
