ProSnippets Tasks
Language:              C#
Subject:               Tasks
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Retrieve all the Task Items in a Project
IEnumerable<TaskProjectItem> taskItems = Project.Current.GetItems<TaskProjectItem>();
foreach (var item in taskItems)
  // do something
Open a Task File - .esriTasks file
// Open a task file
try
  // TODO - substitute your own .esriTasks file to be opened
  string taskFile = @"c:\Tasks\Get Started.esriTasks";
  //At 2.x -
  //System.Guid guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
  System.Guid guid;
  if (TaskAssistantFactory.Instance.CanOpenTaskFile(taskFile))
    guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile);
  // TODO - retain the guid returned for use with CloseTaskItemAsync
catch (OpenTaskException e)
  // exception thrown if task file doesn't exist or has incorrect format
  ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(e.Message);
Open a Project Task Item
// get the first project task item
  var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault();
  // if there isn't a project task item, return
  if (taskItem == null)
    return;
  try
    // Open it
    //At 2.x -
    //System.Guid guid = await TaskAssistantModule.OpenTaskItemAsync(taskItem.TaskItemGuid);
    var guid = await TaskAssistantFactory.Instance.OpenTaskItemAsync(taskItem.TaskItemGuid);
Close a Task Item
// find the first project task item which is open
  var taskItem = Project.Current.GetItems<TaskProjectItem>().FirstOrDefault(t => t.IsOpen == true);
    return;
  if (taskItem.IsOpen)
    // close it
    // NOTE : The task item will also be removed from the project
    //At 2.x -
    //TaskAssistantModule.CloseTaskAsync(taskItem.TaskItemGuid);
    TaskAssistantFactory.Instance?.CloseTaskItemAsync(taskItem.TaskItemGuid);
Export a Task Item
    return;
  try
    // export the task item to the c:\Temp folder
    string exportFolder = @"c:\temp";
    //At 2.x -
    //string fileName = await TaskAssistantModule.ExportTaskAsync(taskItem.TaskItemGuid, exportFolder);
    string fileName = await TaskAssistantFactory.Instance.ExportTaskItemAsync(taskItem.TaskItemGuid, exportFolder);
    ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Task saved to " + fileName);
  catch (ExportTaskException e)
    ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show("Error saving task " + e.Message);
Get Task Information - from a TaskProjectItem
    return;
  string message = await QueuedTask.Run(async () =>
    bool isOpen = taskItem.IsOpen;
    Guid taskGuid = taskItem.TaskItemGuid;
    string msg = "";
    try
      TaskItemInfo taskItemInfo = await taskItem.GetTaskItemInfoAsync();
      msg = "Name : " + taskItemInfo.Name;
      msg += "\r\n" + "Description : " + taskItemInfo.Description;
      msg += "\r\n" + "Guid : " + taskItemInfo.Guid.ToString("B");
      msg += "\r\n" + "Task Count : " + taskItemInfo.GetTasks().Count();
      // iterate the tasks in the task item
      IEnumerable<TaskInfo> taskInfos = taskItemInfo.GetTasks();
      foreach (TaskInfo taskInfo in taskInfos)
        string name = taskInfo.Name;
        Guid guid = taskInfo.Guid;
        // do something
      msg = e.Message;
    catch (TaskFileVersionException e)
      // exception thrown if task file does not support returning task information
      msg = e.Message;
    return msg;
  ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show(message, "Task Information");
Get Task Information - from an .esriTasks file
    string msg = "";
    try
      // retrieve the task item information
      //At 2.x -
      //TaskItemInfo taskItemInfo = await TaskAssistantModule.GetTaskItemInfoAsync(taskFile);
      TaskItemInfo taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
      msg = e.Message;
      msg = e.Message;
    return msg;
Open a specific Task in a Task File - .esriTasks file
    try
      //At 2.x -
      var taskItemInfo = await TaskAssistantFactory.Instance.GetTaskItemInfoAsync(taskFile);
      // find the first task
      TaskInfo taskInfo = taskItemInfo.GetTasks().FirstOrDefault();
      Guid guid = Guid.Empty;
      if (taskInfo != null)
        // if a task exists, open it
        //At 2.x -
        //guid = await TaskAssistantModule.OpenTaskAsync(taskFile, taskInfo.Guid);
        guid = await TaskAssistantFactory.Instance.OpenTaskFileAsync(taskFile, taskInfo.Guid);
      else
        // else just open the task item
        //At 2.x -
        //guid = await TaskAssistantModule.OpenTaskAsync(taskFile);
Subscribe to Task Events
TaskStartedEvent.Subscribe(taskStartedEventArgs =>
    string userName = taskStartedEventArgs.UserID;    // ArcGIS Online signed in userName.  If not signed in to ArcGIS Online then returns the name of the user logged in to the Windows OS.
    string projectName = taskStartedEventArgs.ProjectName;
    Guid taskItemGuid = taskStartedEventArgs.TaskItemGuid;
    string taskItemName = taskStartedEventArgs.TaskItemName;
    string taskItemVersion = taskStartedEventArgs.TaskItemVersion;
    Guid taskGuid = taskStartedEventArgs.TaskGuid;
    string taskName = taskStartedEventArgs.TaskName;
    DateTime startTime = taskStartedEventArgs.StartTime;
  TaskEndedEvent.Subscribe(taskEndedEventArgs =>
          string userName = taskEndedEventArgs.UserID;    // ArcGIS Online signed in userName.  If not signed in to ArcGIS Online then returns the name of the user logged in to the Windows OS.
          string projectName = taskEndedEventArgs.ProjectName;
          Guid taskItemGuid = taskEndedEventArgs.TaskItemGuid;
          string taskItemName = taskEndedEventArgs.TaskItemName;
          string taskItemVersion = taskEndedEventArgs.TaskItemVersion;
          Guid taskGuid = taskEndedEventArgs.TaskGuid;
          string taskName = taskEndedEventArgs.TaskName;
          DateTime startTime = taskEndedEventArgs.StartTime;
          DateTime endTime = taskEndedEventArgs.EndTime;
          double duration = taskEndedEventArgs.Duration;
          bool completed = taskEndedEventArgs.Completed;    // completed or cancelled
