ProSnippets Telecom Domain Network
Language:              C#
Subject:               Telecom Domain Network
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Get the telecom domain network and network information from the utility network
await QueuedTask.Run(() =>
  if (!utilityNetwork.HasTelecomNetwork)
    Console.WriteLine("The utility network does not have a telecom domain network.");
  // Get the telecom domain network from the utility network definition.
  IReadOnlyList<DomainNetwork> domainNetworks = utilityNetwork.GetDefinition().GetDomainNetworks();
  foreach (DomainNetwork domainNetwork in domainNetworks)
    if (domainNetwork is TelecomDomainNetwork tdn)
      // The telecom domain network was found.
      telecomDomainNetwork = tdn;
      // Get information about circuit properties from the telecom domain network.
      CircuitProperties circuitProperties = telecomDomainNetwork.CircuitProperties;
      Console.WriteLine($"Maximum hops in a circuit: {circuitProperties.MaxHops}");
      Console.WriteLine($"Number of paths in a circuit: {circuitProperties.NumPaths}");
      // Get the circuit color scheme information
      IReadOnlyList<ColorScheme> colorSchemes = telecomDomainNetwork.ColorSchemes;
      foreach (ColorScheme colorScheme in colorSchemes)
        string colorSchemeName = colorScheme.Name;
        int colorSchemeID = colorScheme.ID;
        IReadOnlyList<ColorSchemeGroup> colorSchemeGroups = colorScheme.Groups;
        foreach (ColorSchemeGroup group in colorSchemeGroups)
          Console.WriteLine($"Color Scheme: {colorSchemeName}, Group: {group.Name}");
          // Color codes
          IReadOnlyList<ColorCode> colorCodes = group.ColorCodes;
          foreach (ColorCode colorCode in colorCodes)
            Console.WriteLine($"Color Code: {colorCode}");
          // Capacities
          IReadOnlyList<int> capacities = group.Capacity;
          foreach (int capacity in capacities)
            Console.WriteLine($"Capacity: {capacity}");
      // Use the telecom domain network to get additional information about the network.
      IReadOnlyList<WavelengthScheme> wavelengthSchemes = telecomDomainNetwork.WavelengthSchemes;
      IReadOnlyList<DividePolicy> dividePolicies = telecomDomainNetwork.DividePolicies;
      IReadOnlyList<CombinePolicy> combinePolicies = telecomDomainNetwork.CombinePolicies;
      IReadOnlyList<string> diagramTemplateNames = telecomDomainNetwork.DiagramTemplateNames;
Create a Telecom Element and Circuit Location in the utility network
  using (NetworkSource networkSource = telecomDomainNetwork.NetworkSources.FirstOrDefault(ns => ns.Name.Contains(assetGroupName)))
  using (AssetGroup assetGroup = networkSource.GetAssetGroup(assetTypeName))
  using (AssetType assetType = assetGroup.GetAssetType(assetTypeName))
    if (assetType == null)
      throw new Exception($"Asset type '{assetTypeName}' not found in group '{assetGroupName}'.");
    TelecomElement telecomElement = utilityNetwork.CreateElement(assetType, globalID) as TelecomElement;
    // Use the telecom element to create a circuit location.
    CircuitLocation circuitLocation = new CircuitLocation(telecomElement);
Create a physical circuit (non-sectioned) in the utility network with subcircuits
  using (CircuitManager circuitManager = utilityNetwork.GetCircuitManager(telecomDomainNetwork))
    // Create a non-sectioned circuit object
    Circuit circuit = new Circuit(circuitManager);
    circuit.SetName(circuitNames.First());
    circuit.SetSectioned(false);
    circuit.SetCircuitType(CircuitType.Physical);
    // Set a circuit user attribute
    IReadOnlyList<Field> circuitFields = circuitManager.GetCircuitUserFields();
    circuit[circuitFields.First().Name] = "My circuit description";
    // Add start and stop locations
    circuit.SetStartLocation(new CircuitLocation(startElement));
    circuit.SetStopLocation(new CircuitLocation(stopElement));
    Subcircuit subcircuit1 = new Subcircuit(circuitManager);
    subcircuit1.SetName("Subcircuit1");
    // Set a subcircuit user attribute
    IReadOnlyList<Field> subcircuitFields = circuitManager.GetSubcircuitUserFields();
    subcircuit1[subcircuitFields[0].Name] = "My subcircuit description";
    Subcircuit subcircuit2 = new Subcircuit(circuitManager);
    subcircuit2.SetName("Subcircuit2");
    subcircuit2.SetProviderID(new Guid("9B587BB4-FA30-4AC8-ACAC-4CB1BB087111")); // Example GUID
    // Add subcircuits to the circuit
    circuit.SetSubcircuits(new List<Subcircuit> {
                  subcircuit1,
                  subcircuit2
    // Create the circuit.
    circuitManager.Create(circuit);
Create a virtual sectioned circuit in the utility network
    // Create a sectioned virtual circuit object
    circuit.SetSectioned(true);
    circuit.SetCircuitType(CircuitType.Virtual);
    CircuitSection circuitSection1 = new CircuitSection(circuitManager);
    circuitSection1.SetSectionType(CircuitSectionType.Virtual);
    circuitSection1.SetStartLocation(new CircuitLocation(startElement));
    circuitSection1.SetStopLocation(new CircuitLocation(stopElement));
    CircuitSection circuitSection2 = new CircuitSection(circuitManager);
    circuitSection2.SetSectionType(CircuitSectionType.Physical);
    circuitSection2.SetStartLocation(new CircuitLocation(startElement));
    circuitSection2.SetStopLocation(new CircuitLocation(stopElement));
    // Add sections in parallel
    Dictionary<CircuitSection, List<CircuitSection>> circuitSections = new Dictionary<CircuitSection,
              List<CircuitSection>> {
                      circuitSection1,
                      new List < CircuitSection > ()
                      circuitSection2,
    circuit.SetCircuitSections(circuitSections);
Alter an existing circuit in the utility network
    // Get the existing circuit
    Circuit circuit = circuitManager.GetCircuits(new CircuitFilter(["circuitName"])).First();
    // Update circuit name
    // Update start and stop locations
    // Clear existing subcircuits
    circuit.SetSubcircuits(new List<Subcircuit>());
    // Apply the changes
    circuitManager.Alter(circuit);
Delete circuits from the telecom domain network
    // Delete circuits by name
    circuitManager.Delete(circuitNames);
Get all circuits at a specific location within the utility network
    // Define a location in the utility network.
    CircuitLocation location = new CircuitLocation(startElement);
    // Get circuit names from the start location
    CircuitFilter circuitFilter = new CircuitFilter([location], CircuitLocationTypeFilter.All) { Hierarchy = CircuitHierarchy.ConsumersAndProviders };
    IReadOnlyList<string> circuitNames = circuitManager.GetCircuitNames(circuitFilter);
    // Get circuits from the start location
    IReadOnlyList<Circuit> circuits = circuitManager.GetCircuits(circuitFilter);
    // Get circuits by names
    circuitFilter = new CircuitFilter(circuitNames);
    // Iterate through the circuits.
    foreach (Circuit circuit in circuits)
      Console.WriteLine($"Circuit name: {circuit.GetName()}");
Verify a circuit to check for inconsistencies in the utility network
    IReadOnlyList<CircuitVerifyResult> circuitVerifyResults = circuitManager.Verify(circuitNames, new CircuitVerifyOptions() { SynthesizeGeometries = true });
    // Iterate through the circuit verification results
    foreach (CircuitVerifyResult circuitVerifyResult in circuitVerifyResults)
      Console.WriteLine($"Circuit Name: {circuitVerifyResult.Name}, Geometry: {circuitVerifyResult.Geometry.ToJson()}, " +
                              $"HasError: {circuitVerifyResult.HasError}, Message: {circuitVerifyResult.Message}");
Query the contents of equipment containers in the utility network
  using (UnitIdentifierManager unitIdentifierManager = utilityNetwork.GetUnitIdentifierManager())
    var networkSource = utilityNetwork.GetDefinition().GetNetworkSource("TelecomDevice");
    // Container to query.
    UnitIdentifier containerUnitId = new UnitIdentifier(networkSource, globalID);
    // Query the unit identifiers in the container
    IReadOnlyList<UnitQueryResult> unitQueryResults = unitIdentifierManager.Query(new List<UnitIdentifier> { containerUnitId });
    // Iterate through the query results
    foreach (UnitQueryResult unitQueryResult in unitQueryResults)
      UnitIdentifier unitIdentifier = unitQueryResult.Container;
      IReadOnlyList<UnitRange> unitsInAContainer = unitQueryResult.UnitRanges;
      // Iterate through the unit ranges (contents) in the container
      foreach (UnitRange unitRange in unitsInAContainer)
        UnitIdentifier contentUnitId = unitRange.Content;
        bool isContentGap = unitRange.IsGap; // True if the content is a gap (empty space reserved for installing a larger piece of equipment).
        short? firstUnit = unitRange.FirstUnit;
        short? lastUnit = unitRange.LastUnit;
Reserve a gap in an equipment container in the utility network
    UnitIdentifier containerUnitIdentifier = new UnitIdentifier(networkSource, globalID);
    // Reserve a gap in the container for units 2 through 5.
    unitIdentifierManager.ReserveUnitIDs(containerUnitIdentifier, 2, 5);
Reset the contents of a container in the utility network to remove gaps and make the unit space contiguous
    // Reset the container to remove all gaps and make the unit space contiguous.
    unitIdentifierManager.Reset(new[] { containerUnitIdentifier });
Resize the content of a container in the utility network
    UnitIdentifier content = new UnitIdentifier(networkSource, globalID);
    // Update the number of units in an equipment container.
    unitIdentifierManager.Resize(content, 5);
Run a path trace in the telecom domain network
  using (TraceManager traceManager = utilityNetwork.GetTraceManager())
  using (NetworkSource deviceNetworkSource = telecomDomainNetwork.NetworkSources.First(f => f.Name.Contains("TelecomDevice")))
  using (AssetGroup assetGroup = deviceNetworkSource.GetAssetGroup("Port"))
  using (AssetType assetType = assetGroup.GetAssetType("Port"))
    Guid startGuid = new Guid("4BB4560A-34F3-4BBA-93D5-C5D6B26F2709");
    Guid stopGuid = new Guid("32203C76-E484-473A-AEA5-B1AB92A0C198");
    TelecomElement startElement = utilityNetwork.CreateElement(assetType, startGuid) as TelecomElement;
    TelecomElement stopElement = utilityNetwork.CreateElement(assetType, stopGuid) as TelecomElement;
    List<TelecomElement> startingLocations = new List<TelecomElement>() { startElement };
    List<TelecomElement> stoppingLocations = new List<TelecomElement>() { stopElement };
    TraceConfiguration traceConfiguration = new TraceConfiguration()
      MaxHops = 100,
      NumPaths = 2,
      DomainNetwork = telecomDomainNetwork,
      ValidateConsistency = true
    TraceArgument traceArgument = new TraceArgument(startingLocations)
      StoppingLocations = stoppingLocations,
      Configuration = traceConfiguration,
      ResultTypes = new List<ResultType>() { ResultType.Path },
      ResultOptions = new ResultOptions { IncludeGeometry = true }
    PathTracer pathTracer = traceManager.GetTracer<PathTracer>();
    IReadOnlyList<Result> results = pathTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous);
    // Iterate through the path trace results
    foreach (Result result in results)
      if (result is PathResult pathResult)
        IReadOnlyList<TracePath> paths = pathResult.Paths;
        foreach (TracePath path in paths)
          Element startLocation = path.StartLocation;
          Element stopLocation = path.StopLocation;
          Geometry pathGeometry = path.Geometry;
          IReadOnlyList<PathConnectivity> pathConnectivities = path.PathConnectivities;
          foreach (PathConnectivity pathConnectivity in pathConnectivities)
            Console.WriteLine($"Edge: {pathConnectivity.Edge.GlobalID}, Junction: {pathConnectivity.Junction.GlobalID}");
      else
        Console.WriteLine("Unexpected result type.");
Run a circuit trace in the telecom domain network
    Circuit circuitToTrace = circuitManager.GetCircuits(new CircuitFilter(circuitNames)).FirstOrDefault();
      MaxHops = 10,
      NumPaths = 5,
      InferConnectivity = true
    TraceArgument traceArgument = new TraceArgument(circuitToTrace)
      ResultTypes = new List<ResultType> { ResultType.Circuit },
      ResultOptions = new ResultOptions() { IncludeGeometry = true }
    CircuitTracer circuitTracer = traceManager.GetTracer<CircuitTracer>();
    IReadOnlyList<Result> results = circuitTracer.Trace(traceArgument);
    // Iterate through the circuit trace results
      if (result is CircuitResult circuitResult)
        IReadOnlyList<CircuitPath> circuitPaths = circuitResult.CircuitPaths;
        foreach (CircuitPath circuitPath in circuitPaths)
          Circuit circuit = circuitPath.Circuit;
          TracePath path = circuitPath.Path;
          Geometry geometry = circuitPath.Geometry;
          IReadOnlyDictionary<int, TracePath> sectionPaths = circuitPath.SectionPaths;
          foreach (KeyValuePair<int, TracePath> sectionPath in sectionPaths)
            int sectionID = sectionPath.Key;
            TracePath sectionGeometry = sectionPath.Value;
            Console.WriteLine($"Section ID: {sectionID}, Section Geometry: {sectionGeometry.Geometry.ToJson()}");
      else
Export circuits
  using (UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition())
    IReadOnlyList<NetworkSource> networkSources = utilityNetworkDefinition.GetNetworkSources();
    IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
    IEnumerable<string> networkAttributeNames = networkAttributes.Select(s => s.Name);
    NetworkSource telcoDeviceNWSource = networkSources.First(f => f.Name.Contains("TelcoDevice"));
    NetworkSource telcoCircuit = networkSources.First(f => f.Name.Contains("TelcoCircuit"));
      InferConnectivity = false,
      IncludeContainers = true,
      IncludeContent = true,
      SynthesizeGeometries = false
    ResultOptions resultOptions = new ResultOptions()
      IncludeGeometry = true,
      NetworkAttributes = networkAttributeNames.ToList(),
      ResultFields = new Dictionary<NetworkSource, List<string>>() { { telcoDeviceNWSource, ["NEXTUNITID", "PARTITIONID"] },
        { telcoCircuit, ["LongTestField", "TextTestField", "DateTestField"] }}
    CircuitExportOptions circuitExportOptions = new CircuitExportOptions()
      IncludeDomainDescriptions = true,
      ResultOptions = resultOptions,
      ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
      SetAcknowledged = false,
      TraceConfiguration = traceConfiguration
    circuitManager.Export(circuitNames, circuitExportOptions, circuitExportPath);
Add or delete an association between Telecom elements in the utility network
  using (NetworkSource junctionNetworkSource = telecomDomainNetwork.NetworkSources.FirstOrDefault(ns => ns.Name.Contains("TelcoDevice")))
  using (NetworkSource edgeNetworkSource = telecomDomainNetwork.NetworkSources.FirstOrDefault(ns => ns.Name.Contains("TelcoEdgeObject")))
    TelecomElement junction = utilityNetwork.CreateElement(junctionNetworkSource.GetAssetGroup("Fiber").GetAssetType("Fiber"),
              new Guid("CCFCF5DE-5B90-4FD9-A459-2F2E88107532")) as TelecomElement;
    TelecomElement edgeObject = utilityNetwork.CreateElement(edgeNetworkSource.GetAssetGroup("Fiber").GetAssetType("Fiber"),
              new Guid("838B4A2B-8531-499D-8DCF-8567901D43D9")) as TelecomElement;
    Association association = new Association(AssociationType.JunctionEdgeObjectConnectivityMidspan, junction, edgeObject, 0.3);
    // Create the association from the port to the fiber.
    geodatabase.ApplyEdits(() =>
            utilityNetwork.AddAssociation(association);
    // Delete the association
            utilityNetwork.DeleteAssociation(association);
