ProSnippets Topology
Language:              C#
Subject:               Topology
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Open topology and process definition
static void OpenTopologyAndProcessDefinition()
    // Open a geodatabase topology from a file geodatabase and process the topology definition.
    using (Geodatabase geodatabase = new Geodatabase(new FileGeodatabaseConnectionPath(new Uri(@"C:\TestData\GrandTeton.gdb"))))
    using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>("Backcountry_Topology"))
      ProcessDefinition(geodatabase, topology);
    // Open a feature service topology and process the topology definition.
    const string TOPOLOGY_LAYER_ID = "0";
    using (Geodatabase geodatabase = new Geodatabase(new ServiceConnectionProperties(new Uri("https://sdkexamples.esri.com/server/rest/services/GrandTeton/FeatureServer"))))
    using (ArcGIS.Core.Data.Topology.Topology topology = geodatabase.OpenDataset<ArcGIS.Core.Data.Topology.Topology>(TOPOLOGY_LAYER_ID))
    static void ProcessDefinition(Geodatabase geodatabase, ArcGIS.Core.Data.Topology.Topology topology)
      // Similar to the rest of the Definition objects in the Core.Data API, there are two ways to open a dataset's
      // definition -- via the Topology dataset itself or via the Geodatabase.
      using (TopologyDefinition definitionViaTopology = topology.GetDefinition())
        OutputDefinition(geodatabase, definitionViaTopology);
      using (TopologyDefinition definitionViaGeodatabase = geodatabase.GetDefinition<TopologyDefinition>("Backcountry_Topology"))
        OutputDefinition(geodatabase, definitionViaGeodatabase);
    static void OutputDefinition(Geodatabase geodatabase, TopologyDefinition topologyDefinition)
      Console.WriteLine($"Topology cluster tolerance => {topologyDefinition.GetClusterTolerance()}");
      Console.WriteLine($"Topology Z cluster tolerance => {topologyDefinition.GetZClusterTolerance()}");
      IReadOnlyList<string> featureClassNames = topologyDefinition.GetFeatureClassNames();
      Console.WriteLine($"There are {featureClassNames.Count} feature classes that are participating in the topology:");
      foreach (string name in featureClassNames)
        // Open each feature class that participates in the topology.
        using (FeatureClass featureClass = geodatabase.OpenDataset<FeatureClass>(name))
        using (FeatureClassDefinition featureClassDefinition = featureClass.GetDefinition())
          Console.WriteLine($"\t{featureClass.GetName()} ({featureClassDefinition.GetShapeType()})");
Get topology rules
static void GetTopologyRules()
      using (TopologyDefinition topologyDefinition = topology.GetDefinition())
        IReadOnlyList<TopologyRule> rules = topologyDefinition.GetRules();
        Console.WriteLine($"There are {rules.Count} topology rules defined for the topology:");
        Console.WriteLine("ID \t Origin Class \t Origin Subtype \t Destination Class \t Destination Subtype \t Rule Type");
        foreach (TopologyRule rule in rules)
          Console.Write($"{rule.ID}");
          Console.Write(!String.IsNullOrEmpty(rule.OriginClass) ? $"\t{rule.OriginClass}" : "\t\"\"");
          Console.Write(rule.OriginSubtype != null ? $"\t{rule.OriginSubtype.GetName()}" : "\t\"\"");
          Console.Write(!String.IsNullOrEmpty(rule.DestinationClass) ? $"\t{rule.DestinationClass}" : "\t\"\"");
          Console.Write(rule.DestinationSubtype != null ? $"\t{rule.DestinationSubtype.GetName()}" : "\t\"\"");
          Console.Write($"\t{rule.RuleType}");
          Console.WriteLine();
Validate topology
static void ValidateTopology()
      // If the topology currently does not have dirty areas, calling Validate() returns an empty envelope.
      ValidationResult result = topology.Validate(new ValidationDescription(topology.GetExtent()));
      Console.WriteLine($"'AffectedArea' after validating a topology that has not been edited => {result.AffectedArea.ToJson()}");
      // Now create a feature that purposely violates the "PointProperlyInsideArea" topology rule.  This action will
      // create dirty areas.
      Feature newFeature = null;
      try
        // Fetch the feature in the Campsites feature class whose objectID is 2.  Then create a new geometry slightly
        // altered from this and use it to create a new feature.
        using (Feature featureViaCampsites2 = GetFeature(geodatabase, "Campsites", 2))
          Geometry currentGeometry = featureViaCampsites2.GetShape();
          Geometry newGeometry = GeometryEngine.Instance.Move(currentGeometry, (currentGeometry.Extent.XMax / 8), (currentGeometry.Extent.YMax / 8));
          using (FeatureClass campsitesFeatureClass = featureViaCampsites2.GetTable())
          using (FeatureClassDefinition definition = campsitesFeatureClass.GetDefinition())
          using (RowBuffer rowBuffer = campsitesFeatureClass.CreateRowBuffer())
            rowBuffer[definition.GetShapeField()] = newGeometry;
            geodatabase.ApplyEdits(() => { newFeature = campsitesFeatureClass.CreateRow(rowBuffer); });
        // After creating a new feature in the 'Campsites' participating feature class, the topology's state should be
        // "Unanalyzed" because it has not been validated.
        Console.WriteLine($"The topology state after an edit has been applied => {topology.GetState()}");
        // Now validate the topology.  The result envelope corresponds to the dirty areas.
        Console.WriteLine($"'AffectedArea' after validating a topology that has just been edited => {result.AffectedArea.ToJson()}");
        // After Validate(), the topology's state should be "AnalyzedWithErrors" because the topology currently has errors.
        Console.WriteLine($"The topology state after validate topology => {topology.GetState()}");
        // If there are no dirty areas, the result envelope should be empty.
        Console.WriteLine($"'AffectedArea' after validating a topology that has just been validated => {result.AffectedArea.ToJson()}");
      finally
        if (newFeature != null)
          geodatabase.ApplyEdits(() => { newFeature.Delete(); });
          newFeature.Dispose();
      // Validate again after deleting the newly-created feature.
Process topology errors
static void ProcessTopologyErrors()
      // Get all the errors and exceptions currently associated with the topology.
      IReadOnlyList<TopologyError> allErrorsAndExceptions = topology.GetErrors(new ErrorDescription(topology.GetExtent()));
      Console.WriteLine($"errors and exceptions count => {allErrorsAndExceptions.Count}");
      Console.WriteLine("OriginClassName \t OriginObjectID \t DestinationClassName \t DestinationObjectID \t RuleType \t IsException \t Shape type \t Shape width & height \t  Rule ID \t");
      foreach (TopologyError error in allErrorsAndExceptions)
        Console.WriteLine(
          $"'{error.OriginClassName}' \t {error.OriginObjectID} \t '{error.DestinationClassName}' \t " +
          $"{error.DestinationObjectID} \t {error.RuleType} \t {error.IsException} \t {error.Shape.GeometryType} \t " +
          $"{error.Shape.Extent.Width},{error.Shape.Extent.Height} \t {error.RuleID}");
Mark and unmark errors or exceptions
static void MarkAndUnmarkAsErrors(ArcGIS.Core.Data.Topology.Topology topology)
    // Get all the errors due to features violating the "PointProperlyInsideArea" topology rule.
      TopologyRule pointProperlyInsideAreaRule = topologyDefinition.GetRules().First(rule => rule.RuleType == TopologyRuleType.PointProperlyInsideArea);
      ErrorDescription errorDescription = new ErrorDescription(topology.GetExtent())
        TopologyRule = pointProperlyInsideAreaRule
      IReadOnlyList<TopologyError> errorsDueToViolatingPointProperlyInsideAreaRule = topology.GetErrors(errorDescription);
      Console.WriteLine($"There are {errorsDueToViolatingPointProperlyInsideAreaRule.Count} feature violating the 'PointProperlyInsideArea' topology rule.");
      // Mark all errors from features violating the 'PointProperlyInsideArea' topology rule as exceptions.
      foreach (TopologyError error in errorsDueToViolatingPointProperlyInsideAreaRule)
        topology.MarkAsException(error);
      // Now verify all the errors from features violating the 'PointProperlyInsideArea' topology rule have indeed been
      // marked as exceptions.
      // By default, ErrorDescription is initialized to ErrorType.ErrorAndException.  Here we want ErrorType.ErrorOnly.
        ErrorType = ErrorType.ErrorOnly,
      IReadOnlyList<TopologyError> errorsAfterMarkedAsExceptions = topology.GetErrors(errorDescription);
      Console.WriteLine($"There are {errorsAfterMarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the errors have been marked as exceptions.");
      // Finally, reset all the exceptions as errors by unmarking them as exceptions.
        topology.UnmarkAsException(error);
      IReadOnlyList<TopologyError> errorsAfterUnmarkedAsExceptions = topology.GetErrors(errorDescription);
      Console.WriteLine($"There are {errorsAfterUnmarkedAsExceptions.Count} feature violating the 'PointProperlyInsideArea' topology rule after all the exceptions have been reset as errors.");
Explore topology graph
static void ExploreTopologyGraph()
      // Build a topology graph using the extent of the topology dataset.
      topology.BuildGraph(topology.GetExtent(), (topologyGraph) =>
        using (Feature campsites12 = GetFeature(geodatabase, "Campsites", 12))
          IReadOnlyList<TopologyNode> topologyNodesViaCampsites12 = topologyGraph.GetNodes(campsites12);
          TopologyNode topologyNodeViaCampsites12 = topologyNodesViaCampsites12[0];
          IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12 = topologyNodeViaCampsites12.GetEdges();
          IReadOnlyList<TopologyEdge> allEdgesConnectedToNodeViaCampsites12CounterClockwise = topologyNodeViaCampsites12.GetEdges(false);
          foreach (TopologyEdge edgeConnectedToNodeViaCampsites12 in allEdgesConnectedToNodeViaCampsites12)
            TopologyNode fromNode = edgeConnectedToNodeViaCampsites12.GetFromNode();
            TopologyNode toNode = edgeConnectedToNodeViaCampsites12.GetToNode();
            bool fromNodeIsTheSameAsTopologyNodeViaCampsites12 = (fromNode == topologyNodeViaCampsites12);
            bool toNodeIsTheSameAsTopologyNodeViaCampsites12 = (toNode == topologyNodeViaCampsites12);
            IReadOnlyList<FeatureInfo> leftParentFeaturesBoundedByEdge =
              edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures();
            foreach (FeatureInfo featureInfo in leftParentFeaturesBoundedByEdge)
              EnsureShapeIsNotEmpty(featureInfo);
            IReadOnlyList<FeatureInfo> leftParentFeaturesNotBoundedByEdge =
              edgeConnectedToNodeViaCampsites12.GetLeftParentFeatures(false);
            foreach (FeatureInfo featureInfo in leftParentFeaturesNotBoundedByEdge)
            IReadOnlyList<FeatureInfo> rightParentFeaturesBoundedByEdge =
              edgeConnectedToNodeViaCampsites12.GetRightParentFeatures();
            foreach (FeatureInfo featureInfo in rightParentFeaturesBoundedByEdge)
            IReadOnlyList<FeatureInfo> rightParentFeaturesNotBoundedByEdge =
              edgeConnectedToNodeViaCampsites12.GetRightParentFeatures(false);
            foreach (FeatureInfo featureInfo in rightParentFeaturesNotBoundedByEdge)
    static void EnsureShapeIsNotEmpty(FeatureInfo featureInfo)
      using (Feature feature = featureInfo.GetFeature())
        // Process feature ...
Find closest element from a topology graph
static void FindClosestElement()
        MapPoint queryPointViaCampsites12 = null;
          queryPointViaCampsites12 = campsites12.GetShape() as MapPoint;
        double searchRadius = 1.0;
        TopologyElement topologyElementViaCampsites12 = topologyGraph.FindClosestElement<TopologyElement>(queryPointViaCampsites12, searchRadius);
        IReadOnlyList<FeatureInfo> parentFeatures = topologyElementViaCampsites12.GetParentFeatures();
        Console.WriteLine("The parent features that spawn 'topologyElementViaCampsites12' are:");
        foreach (FeatureInfo parentFeature in parentFeatures)
          Console.WriteLine($"\t{parentFeature.FeatureClassName}; OID: {parentFeature.ObjectID}");
        TopologyNode topologyNodeViaCampsites12 = topologyGraph.FindClosestElement<TopologyNode>(queryPointViaCampsites12, searchRadius);
        if (topologyNodeViaCampsites12 != null)
          // There exists a TopologyNode nearest to the query point within searchRadius units.
        TopologyEdge topologyEdgeViaCampsites12 = topologyGraph.FindClosestElement<TopologyEdge>(queryPointViaCampsites12, searchRadius);
        if (topologyEdgeViaCampsites12 != null)
          // There exists a TopologyEdge nearest to the query point within searchRadius units.
