ProSnippets UtilityNetwork
Language:              C#
Subject:               UtilityNetwork
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Obtaining Utility Networks
Get a Utility Network from a Table
static UtilityNetwork GetUtilityNetworkFromTable()
    UtilityNetwork utilityNetwork = null;
    Table table = MapView.Active.Map.GetStandaloneTablesAsFlattenedList().First().GetTable();
    // This routine obtains a utility network from a table
    if (table.IsControllerDatasetSupported())
      // Tables can belong to multiple controller datasets, but at most one of them will be a UtilityNetwork
      IReadOnlyList<Dataset> controllerDatasets = table.GetControllerDatasets();
      foreach (Dataset controllerDataset in controllerDatasets)
        if (controllerDataset is UtilityNetwork)
          utilityNetwork = controllerDataset as UtilityNetwork;
        else
          controllerDataset.Dispose();
    return utilityNetwork;
Get a Utility Network from a Layer
static UtilityNetwork GetUtilityNetworkFromLayer(Layer unLayer)
    Layer layer = MapView.Active.Map.GetLayersAsFlattenedList().First();
    // This routine obtains a utility network from a FeatureLayer, SubtypeGroupLayer, or UtilityNetworkLayer
    if (layer is UtilityNetworkLayer)
      UtilityNetworkLayer utilityNetworkLayer = layer as UtilityNetworkLayer;
      utilityNetwork = utilityNetworkLayer.GetUtilityNetwork();
    else if (layer is SubtypeGroupLayer)
      CompositeLayer compositeLayer = layer as CompositeLayer;
      utilityNetwork = GetUtilityNetworkFromLayer(compositeLayer.Layers.First());
    else if (layer is FeatureLayer)
      FeatureLayer featureLayer = layer as FeatureLayer;
      using (FeatureClass featureClass = featureLayer.GetFeatureClass())
        if (featureClass.IsControllerDatasetSupported())
          IReadOnlyList<Dataset> controllerDatasets = new List<Dataset>();
          controllerDatasets = featureClass.GetControllerDatasets();
            else
Elements
Fetching a Row from an Element
static Row FetchRowFromElement(UtilityNetwork utilityNetwork, Element element)
    // Get the table from the element
    using (Table unTable = utilityNetwork.GetTable(element.NetworkSource))
      // Create a query filter to fetch the appropriate row
      QueryFilter queryFilter = new QueryFilter()
        ObjectIDs = new List<long>() { element.ObjectID }
      // Fetch and return the row
      using (RowCursor rowCursor = unTable.Search(queryFilter))
        if (rowCursor.MoveNext())
          return rowCursor.Current;
        return null;
Get percentage along a polyline
static double GetPolylineStartingPercentage(Element startingPointElement, Geometry clickedPoint, FeatureLayer featureLayer)
    // Find feature
      ObjectIDs = new List<long>() { startingPointElement.ObjectID }
    using (RowCursor rowCursor = featureLayer.GetFeatureClass().Search(queryFilter, false))
      if (!rowCursor.MoveNext())
        return 0;
      using (Row row = rowCursor.Current)
        try
          Feature feature = row as Feature;
          Polyline polyline = feature.GetShape() as Polyline;
          ICollection<Segment> segments = new List<Segment>();
          polyline.GetAllSegments(ref segments);
          IList<Segment> segments2 = segments as IList<Segment>;
          MapPoint startPoint = segments2[0].StartPoint;
          MapPoint endPoint = segments2[segments2.Count - 1].EndPoint;
          MapPoint clickedMapPoint = clickedPoint as MapPoint;
          LineSegment line = LineBuilderEx.CreateLineSegment(startPoint, endPoint);
          MapPoint outPoint = GeometryEngine.Instance.QueryPointAndDistance(line,
            SegmentExtensionType.NoExtension,
            clickedMapPoint, AsRatioOrLength.AsRatio,
            out double distanceAlongCurve, out double distanceFromCurve, out LeftOrRightSide side);
          return distanceAlongCurve;
        catch (Exception e)
          // Handle exceptions
    return 0;
Editing Associations
Create a utility network association
// This routine creates a structural attachment association between a pole and a transformer bank
  static void CreateUNAssociation(UtilityNetwork utilityNetwork, AssetType poleAssetType, Guid poleGlobalID, AssetType transformerBankAssetType, Guid transformerBankGlobalID)
    // Create edit operation
    EditOperation editOperation = new EditOperation();
    editOperation.Name = "Create structural attachment association";
    // Create a RowHandle for the pole
    Element poleElement = utilityNetwork.CreateElement(poleAssetType, poleGlobalID);
    RowHandle poleRowHandle = new RowHandle(poleElement, utilityNetwork);
    // Create a RowHandle for the transformer bank
    Element transformerBankElement =
      utilityNetwork.CreateElement(transformerBankAssetType, transformerBankGlobalID);
    RowHandle transformerBankRowHandle = new RowHandle(transformerBankElement, utilityNetwork);
    // Attach the transformer bank to the pole
    AssociationDescription structuralAttachmentAssociationDescription =
      new AssociationDescription(AssociationType.Attachment, poleRowHandle, transformerBankRowHandle);
    editOperation.Create(structuralAttachmentAssociationDescription);
    editOperation.Execute();
Create utility network features and associations in a single edit operation
// This routine creates a pole and a transformer bank, and then creates a structural attachment association between them, all in a single edit operation
  static void CreateUNFeaturesAndAssociations(FeatureLayer transformerBankLayer,
  Dictionary<string, object> transformerBankAttributes, FeatureLayer poleLayer,
  Dictionary<string, object> poleAttributes)
    // Create an EditOperation
    editOperation.Name = "Create pole; create transformer bank; attach transformer bank to pole";
    // Create the transformer bank
    RowToken transformerBankToken = editOperation.Create(transformerBankLayer, transformerBankAttributes);
    // Create a pole
    RowToken poleToken = editOperation.Create(poleLayer, poleAttributes);
    // Create a structural attachment association between the pole and the transformer bank
    RowHandle poleHandle = new RowHandle(poleToken);
    RowHandle transformerBankHandle = new RowHandle(transformerBankToken);
    AssociationDescription poleAttachment =
      new AssociationDescription(AssociationType.Attachment, poleHandle, transformerBankHandle);
    editOperation.Create(poleAttachment);
    // Execute the EditOperation
Traverse Associations
Get traverse associations result from downward traversal
// This routine demonstrates how to get the associations involved in a downward traversal from a set of starting elements
  static void GetTraverseAssociationsResultFromDownwardTraversal(UtilityNetwork utilityNetwork, IReadOnlyList<Element> startingElements)
    // Set downward traversal with maximum depth
    TraverseAssociationsDescription traverseAssociationsDescription =
      new TraverseAssociationsDescription(TraversalDirection.Descending);
    // Get traverse associations result from the staring element up to maximum depth
    TraverseAssociationsResult traverseAssociationsResult =
      utilityNetwork.TraverseAssociations(startingElements, traverseAssociationsDescription);
    // Get associations participated in traversal
    IReadOnlyList<Association> associations = traverseAssociationsResult.Associations;
Get traverse associations result from upward traversal with depth limit
// This routine demonstrates how to get the associations involved in an upward traversal from a set of starting elements, up to a specified depth limit
  static void GetTraverseAssociationsResultFromUpwardTraversalWithDepthLimit(UtilityNetwork utilityNetwork, IReadOnlyList<Element> startingElements)
    // List of fields whose values will be fetched as name-values pairs during association traversal operation
    List<string> additionalFieldsToFetch =
      new List<string> { "ObjectId", "AssetName", "AssetGroup", "AssetType" };
    // Set downward traversal with maximum depth level of 3
      new TraverseAssociationsDescription(TraversalDirection.Ascending, 3)
        AdditionalFields = additionalFieldsToFetch
    // Get traverse associations result from the staring element up to depth level 3
    // List of associations participated in traversal
    // KeyValue mapping between involved elements and their field name-values
    IReadOnlyDictionary<Element, IReadOnlyList<FieldValue>> associationElementValuePairs =
      traverseAssociationsResult.AdditionalFieldValues;
    foreach (KeyValuePair<Element, IReadOnlyList<FieldValue>> keyValuePair in associationElementValuePairs)
      // Element
      Element element = keyValuePair.Key;
      // List of field names and their values
      IReadOnlyList<FieldValue> elementFieldValues = keyValuePair.Value;
Subnetworks and Tiers
Find a Tier given a Domain Network name and Tier name
static void FindATierFromDomainNetworkNameAndTierName(UtilityNetwork utilityNetwork, string domainNetworkName, string tierName)
    using UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition();
    DomainNetwork domainNetwork = utilityNetworkDefinition.GetDomainNetwork(domainNetworkName);
    Tier tier = domainNetwork.GetTier(tierName);
Update all dirty subnetworks in a tier
// This routine updates all dirty subnetworks in a given tier and refreshes the map view
  static void UpdateAllDirtySubnetworks(UtilityNetwork utilityNetwork, Tier tier, MapView mapView)
    using SubnetworkManager subnetworkManager = utilityNetwork.GetSubnetworkManager();
    subnetworkManager.UpdateAllSubnetworks(tier, true);
    mapView.Redraw(true);
Life cycle for a simple radial subnetwork with one controller
// This routine demonstrates the life cycle of a simple radial subnetwork with one controller
  static void RadialNetworkLifecycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR1)
    // Create a subnetwork named "Radial1" with a single controller
    // elementR1 represents the device that serves as the subnetwork controller (e.g., circuit breaker)
    Subnetwork subnetworkRadial1 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR1,
      "Radial1", "R1", "my description", "my notes");
    // Update the subnetwork and refresh the map
    subnetworkRadial1.Update();
    MapView.Active.Redraw(true);
    // At some point, a subnetwork will need to be deleted.
    // First step is to disable the controller
    subnetworkManager.DisableControllerInEditOperation(elementR1);
    // At this point, the subnetwork is deleted, but all of the rows that have been labeled with the subnetwork ID need to be updated
    // The final step is to notify external systems (if any) by exporting the subnetwork
    SubnetworkExportOptions subnetworkExportOptions = new SubnetworkExportOptions()
      SetAcknowledged = true,
      IncludeDomainDescriptions = true,
      IncludeGeometry = true,
      ServiceSynchronizationType = ServiceSynchronizationType.Asynchronous,
      SubnetworkExportResultTypes = new List<SubnetworkExportResultType>()
        SubnetworkExportResultType.Features
      // Set networks attributes and attribute fields to export
      //ResultNetworkAttributes = new List<NetworkAttribute>(networkAttributes),
      //ResultFieldsByNetworkSourceID = new Dictionary<int, List<string>>()
      //  { { electricDevice.ID, new List<string>() { "AssetID" } } }
    subnetworkRadial1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"),
      subnetworkExportOptions);
Life cycle for a mesh subnetwork with multiple controllers
// This routine demonstrates the life cycle of a mesh subnetwork with multiple controllers
  static void MeshNetworkLifeCycle(SubnetworkManager subnetworkManager, Tier lowVoltageMeshTier,
  Element elementM1, Element elementM2, Element elementM3)
    // Create a subnetwork named "Mesh1" from three controllers
    // elementM1, elementM2, and elementM3 represent the devices that serve as subnetwork controllers (e.g., network protectors)
    subnetworkManager.EnableController(lowVoltageMeshTier, elementM1, "Mesh1", "M1", "my description", "my notes");
    subnetworkManager.EnableController(lowVoltageMeshTier, elementM2, "Mesh1", "M2", "my description", "my notes");
    Subnetwork subnetworkMesh1 = subnetworkManager.EnableController(lowVoltageMeshTier, elementM3, "Mesh1", "M3",
    subnetworkMesh1.Update();
    // When deleting the subnetwork, each controller must be disabled before the subnetwork itself is deleted
    subnetworkManager.DisableControllerInEditOperation(elementM1);
    subnetworkManager.DisableControllerInEditOperation(elementM2);
    subnetworkManager.DisableControllerInEditOperation(elementM3);
    // After the subnetwork is deleted, all of the rows that have been labeled with the subnetwork ID need to be updated
    subnetworkMesh1.Export(new Uri($"{Path.GetTempPath()}SubnetworkExportResult.json"), subnetworkExportOptions);
Life cycle for a multifeed radial subnetwork with two controllers
// This routine demonstrates the life cycle of a multifeed radial subnetwork with two controllers
  static void MultifeedRadialLifeCycle(SubnetworkManager subnetworkManager, Tier mediumVoltageTier, Element elementR2, Element elementR3)
    // Create a subnetwork named "R2, R3" from two controllers
    // elementR2 and elementR3 represent the devices that serve as subnetwork controllers (e.g., circuit breakers)
    subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR2, "R2, R3", "R2",
    subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR3, "R2, R3", "R3",
    // If the tie switch between them is opened, the original subnetwork controllers must be disabled and re-enabled with different names
    // This will create two new subnetworks, named "R2" and "R3"
    subnetworkManager.DisableControllerInEditOperation(elementR2);
    subnetworkManager.DisableControllerInEditOperation(elementR3);
    Subnetwork subnetworkR2 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR2, "R2",
      "R2", "my description", "my notes");
    Subnetwork subnetworkR3 = subnetworkManager.EnableControllerInEditOperation(mediumVoltageTier, elementR3, "R3",
      "R3", "my description", "my notes");
    subnetworkR2.Update();
    subnetworkR3.Update();
Export Subnetwork
// This routine exports a subnetwork to a JSON file
  static void ExportSubnetwork(UtilityNetwork utilityNetwork, string subnetworkName, Uri exportResultJsonPath)
    Subnetwork subnetwork = subnetworkManager.GetSubnetwork(subnetworkName);
    IReadOnlyList<NetworkAttribute> networkAttributes = utilityNetworkDefinition.GetNetworkAttributes();
    IReadOnlyList<NetworkSource> networkSources = utilityNetworkDefinition.GetNetworkSources();
    NetworkSource electricDevice = networkSources.First(f => f.Name.Contains("ElectricDevice"));
    // Export options
    SubnetworkExportOptions subnetworkExportOptions = new()
      SetAcknowledged = false,
        SubnetworkExportResultType.Connectivity,
    subnetwork.Export(exportResultJsonPath, subnetworkExportOptions);
Tracing
Create a DownstreamTracer
// This routine creates a DownstreamTracer object from a UtilityNetwork
  static void CreateADownstreamTracerObject(UtilityNetwork utilityNetwork)
    using TraceManager traceManager = utilityNetwork.GetTraceManager();
    DownstreamTracer downstreamTracer = traceManager.GetTracer<DownstreamTracer>();
Create a Trace Argument
// This routine creates a TraceArgument object and assigns a TraceConfiguration to it
  static void CreateTraceArgument()
    IReadOnlyList<Element> startingPointList = new List<Element>();
    // Code to fill in list of starting points goes here...
    TraceArgument traceArgument = new TraceArgument(startingPointList);
    TraceConfiguration traceConfiguration = new TraceConfiguration();
    // Code to fill in trace configuration goes here...
    traceArgument.Configuration = traceConfiguration;
Create a Condition to compare a Network Attribute against a set of values
static void CreateNetworkAttributeComparison(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
    // This routine creates a NetworkAttributeComparison to compare the Lifecycle network attribute against two values: "In Design" and "In Service"
    const int InDesign = 4;
    const int InService = 8;
    // Create a NetworkAttribute object for the Lifecycle network attribute from the UtilityNetworkDefinition
    using NetworkAttribute lifecycleNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Lifecycle");
    // Create a NetworkAttributeComparison that stops traversal if Lifecycle <> "In Design" (represented by the constant InDesign)
    NetworkAttributeComparison inDesignNetworkAttributeComparison =
      new NetworkAttributeComparison(lifecycleNetworkAttribute, Operator.NotEqual, InDesign);
    // Create a NetworkAttributeComparison to stop traversal if Lifecycle <> "In Service" (represented by the constant InService)
    NetworkAttributeComparison inServiceNetworkAttributeComparison =
      new NetworkAttributeComparison(lifecycleNetworkAttribute, Operator.NotEqual, InService);
    // Combine these two comparisons together with "And"
    And lifecycleFilter = new And(inDesignNetworkAttributeComparison, inServiceNetworkAttributeComparison);
    // Final condition stops traversal if Lifecycle <> "In Design" and Lifecycle <> "In Service"
    traceConfiguration.Traversability.Barriers = lifecycleFilter;
Create a Function
// This routine creates an Add function to sum the Load network attribute during a trace
  static void ApplyFunction(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
    // Get a NetworkAttribute object for the Load network attribute from the UtilityNetworkDefinition
    using NetworkAttribute loadNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Load");
    // Create a function to sum the Load
    Add sumLoadFunction = new Add(loadNetworkAttribute);
    // Add this function to our trace configuration
    traceConfiguration.Functions = new List<Function>() { sumLoadFunction };
Create a FunctionBarrier
// This routine creates a FunctionBarrier that stops traversal when the total shape length exceeds 1000 feet
  static void CreateFunctionBarrier(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
    // Create a NetworkAttribute object for the Shape length network attribute from the UtilityNetworkDefinition
    using NetworkAttribute shapeLengthNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Shape length");
    // Create a function that adds up shape length
    Add lengthFunction = new Add(shapeLengthNetworkAttribute);
    // Create a function barrier that stops traversal after 1000 feet
    FunctionBarrier distanceBarrier = new FunctionBarrier(lengthFunction, Operator.GreaterThan, 1000.0);
    // Set this function barrier
    traceConfiguration.Traversability.FunctionBarriers = new List<FunctionBarrier>() { distanceBarrier };
Create an output condition
// This routine creates an output condition to filter trace results to only include features with the "Service Point" category assigned
  static void CreateOutputFilter(TraceConfiguration traceConfiguration)
    // Create an output category to filter the trace results to only include
    // features with the "Service Point" category assigned
    traceConfiguration.OutputCondition = new CategoryComparison(CategoryOperator.IsEqual, "Service Point");
Create a Propagator
// This routine creates a Propagator to propagate the Phases Normal network attribute downstream during a trace
  static void CreatePropagator(UtilityNetworkDefinition utilityNetworkDefinition, TraceConfiguration traceConfiguration)
    const int ABCPhase = 7;
    // Get a NetworkAttribute object for the Phases Normal attribute from the UtilityNetworkDefinition
    using NetworkAttribute normalPhaseAttribute = utilityNetworkDefinition.GetNetworkAttribute("Phases Normal");
    // Create a propagator to propagate the Phases Normal attribute downstream from the source, using a Bitwise And function
    // Allow traversal to continue as long as the Phases Normal value includes any of the ABC phases
    // (represented by the constant ABCPhase)
    Propagator phasePropagator = new Propagator(normalPhaseAttribute, PropagatorFunction.BitwiseAnd,
      Operator.IncludesAny, ABCPhase);
    // Assign this propagator to our trace configuration
    traceConfiguration.Propagators = new List<Propagator>() { phasePropagator };
Using Function Results
// This routine demonstrates how to extract function results from trace results
  static void UseFunctionResults(IReadOnlyList<Result> traceResults)
    // Get the FunctionOutputResult from the trace results
    FunctionOutputResult functionOutputResult = traceResults.OfType<FunctionOutputResult>().First();
    // First() can be used here if only one Function was included in the TraceConfiguration.Functions collection.
    // Otherwise you will have to search the list for the correct FunctionOutput object.
    FunctionOutput functionOutput = functionOutputResult.FunctionOutputs.First();
    // Extract the total load from the GlobalValue property
    double totalLoad = (double)functionOutput.Value;
Fetch a named trace configuration by name
// This routine fetches a named trace configuration by name from a utility network
  static NamedTraceConfiguration GetNamedTraceConfigurationsByName(UtilityNetwork utilityNetwork, string configurationName = "WaterNetwork")
    // Query to find named trace configurations
    NamedTraceConfigurationQuery namedTraceConfigurationQuery = new NamedTraceConfigurationQuery
    { Names = new List<string> { configurationName } };
    // Get the trace manager from the utility network
    using (TraceManager traceManager = utilityNetwork.GetTraceManager())
      // A set of named trace configurations specified by the named traced configuration query
      IReadOnlyList<NamedTraceConfiguration> namedTraceConfigurations =
        traceManager.GetNamedTraceConfigurations(namedTraceConfigurationQuery);
      NamedTraceConfiguration waterConfiguration =
        namedTraceConfigurations.First(f => f.Description.Equals(configurationName));
      return waterConfiguration;
Fetch named trace configurations from a utility network layer
// This routine fetches a named trace configuration by name from a utility network layer
  static NamedTraceConfiguration GetNamedTraceConfigurationsFromUtilityNetworkLayer(UtilityNetworkLayer utilityNetworkLayer, string configurationName = "WaterNetwork")
    // Get all named trace configurations in the utility network
    IReadOnlyList<NamedTraceConfiguration> namedTraceConfigurations = utilityNetworkLayer.GetNamedTraceConfigurations();
    foreach (NamedTraceConfiguration namedTraceConfiguration in namedTraceConfigurations)
      if (namedTraceConfiguration.Name == configurationName)
        return namedTraceConfiguration;
    return null;
Trace a utility network using a named trace configuration
// This routine demonstrates how to perform a trace using a named trace configuration from a utility network
  static void TraceUtilityNetworkUsingNamedTraceConfiguration(UtilityNetwork utilityNetwork, NamedTraceConfiguration namedTraceConfiguration, Element startElement)
      // Get a tracer from the trace manager using the named trace configuration
      Tracer upstreamTracer = traceManager.GetTracer(namedTraceConfiguration);
      // Trace argument holding the trace input parameters
      TraceArgument upstreamTraceArgument = new TraceArgument(namedTraceConfiguration, new List<Element> { startElement });
      // Trace results
      IReadOnlyList<Result> upstreamTraceResults = upstreamTracer.Trace(upstreamTraceArgument);
Trace a utility network with the digitized direction
// This routine demonstrates how to perform a trace using the digitized direction of features
  static void TraceWithDigitizedDirection(UtilityNetwork utilityNetwork, Element startElement)
    // Trace configuration with digitized direction
      IncludeIsolatedFeatures = true,
      IncludeBarriersWithResults = true,
      UseDigitizedDirection = true
    // Trace argument
    List<Element> startElements = new List<Element> { startElement };
    TraceArgument traceArgument = new TraceArgument(startElements);
    // Results
    IReadOnlyList<Result> traceResults = downstreamTracer.Trace(traceArgument);
    foreach (Result traceResult in traceResults)
      // Iterate trace results
Export a utility network trace as a JSON file
// This routine demonstrates how to perform a trace and export the results as a JSON file
  static void ExportUtilityNetworkTraceAsJSON(UtilityNetwork utilityNetwork)
    using (UtilityNetworkDefinition utilityNetworkDefinition = utilityNetwork.GetDefinition())
    using (NetworkSource deviceNetworkSource = GetNetworkSource(utilityNetworkDefinition, "GasDevice") as NetworkSource)
    using (FeatureClass distributionDeviceFeatureClass = utilityNetwork.GetTable(deviceNetworkSource) as FeatureClass)
    using (FeatureClassDefinition distributionDeviceDefinition = distributionDeviceFeatureClass.GetDefinition())
    using (AssetGroup deviceAssetGroup = deviceNetworkSource.GetAssetGroup("Regulator"))
    using (AssetType deviceAssetType = deviceAssetGroup.GetAssetType("Pressure Reducing"))
    using (NetworkAttribute deviceStatusNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("DeviceStatus"))
    using (NetworkAttribute accessibleNetworkAttribute = utilityNetworkDefinition.GetNetworkAttribute("Accessible"))
      // Domain and tier information
      DomainNetwork domainNetwork = utilityNetworkDefinition.GetDomainNetwork("Gas");
      Tier pipeDistributionSystemTier = domainNetwork.GetTier("Pipe Distribution");
      // Start elements
      Element startingPoint1 = utilityNetwork.CreateElement(deviceAssetType, Guid.Parse("{28CF437E-950C-41B7-B839-8BC45570DE40}"));
      Element startingPoint2 = utilityNetwork.CreateElement(deviceAssetType, Guid.Parse("{63C22828-7BC9-49ED-A14A-A596559B6CB3}"));
      startingPoint1.Terminal = startingPoint1.AssetType.GetTerminalConfiguration().Terminals
        .First(x => x.IsUpstreamTerminal);
      startingPoint2.Terminal = startingPoint2.AssetType.GetTerminalConfiguration().Terminals
      List<Element> startingPoints = [startingPoint1, startingPoint2];
      List<Element> barriers = [];
      // Set up trace filter: DeviceStatus = Open (1) AND Accessible = 1
      NetworkAttributeComparison statusNetworkAttributeComparison = new NetworkAttributeComparison(deviceStatusNetworkAttribute, Operator.Equal, 1);
      NetworkAttributeComparison networkAttributeComparison = new NetworkAttributeComparison(accessibleNetworkAttribute, Operator.Equal, 1);
      // Set trace configuration
        AllowIndeterminateFlow = true,
        IgnoreBarriersAtStartingPoints = false,
        IncludeContainers = true,
        IncludeContent = true,
        IncludeIsolatedFeatures = false,
        IncludeUpToFirstSpatialContainer = false
      traceConfiguration.Filter.Barriers = new And(statusNetworkAttributeComparison, networkAttributeComparison);
      traceConfiguration.DomainNetwork = domainNetwork;
      traceConfiguration.SourceTier = pipeDistributionSystemTier;
      // Attribute fields of a network source
      List<string> deviceFields = distributionDeviceDefinition.GetFields().Select(f => f.Name).ToList();
      // Network attributes
      List<string> networkattributeNames = new List<string>();
      foreach (NetworkAttribute networkAttribute in networkAttributes)
        networkattributeNames.Add(networkAttribute.Name);
      // Result Types
      List<ResultType> resultTypeList = new List<ResultType>() { ResultType.Feature };
      // Resutl Options
      ResultOptions resultOptions = new ResultOptions()
        NetworkAttributes = networkattributeNames,
        ResultFields = new Dictionary<NetworkSource, List<string>>() { { deviceNetworkSource, deviceFields } }
      // Trace Arguments
      TraceArgument traceArgument = new TraceArgument(startingPoints)
        Barriers = barriers,
        Configuration = traceConfiguration,
        ResultTypes = resultTypeList,
        ResultOptions = resultOptions
      ConnectedTracer connectedTracer = traceManager.GetTracer<ConnectedTracer>();
      // Set export options
      TraceExportOptions exportOptions = new TraceExportOptions()
      // Path to export JSON
      string jsonPath = $"{Path.GetTempPath()}TraceResults.json";
      Uri jsonUri = new Uri(jsonPath);
      // Export
      connectedTracer.Export(jsonUri, traceArgument, exportOptions);
      string jsonAbsolutePath = HttpUtility.UrlDecode(jsonUri.AbsolutePath);
      if (jsonUri.IsFile && File.Exists(jsonAbsolutePath))
        // Work with the JSON results
    NetworkSource GetNetworkSource(UtilityNetworkDefinition unDefinition, string name)
      IReadOnlyList<NetworkSource> allSources = unDefinition.GetNetworkSources();
      foreach (NetworkSource source in allSources)
        if (name.Contains("Partitioned Sink"))
          if (source.Name.Replace(" ", "").ToUpper().Contains(name.Replace(" ", "").ToUpper()) ||
                .Contains(name.Replace("Partitioned Sink", "Part_Sink").Replace(" ", "").ToUpper()))
            return source;
        if (name.Contains("Hierarchical Sink"))
                .Contains(name.Replace("Hierarchical Sink", "Hier_Sink").Replace(" ", "").ToUpper()))
            return source;
        if (source.Name.Replace(" ", "").ToUpper().Contains(name.Replace(" ", "").ToUpper()))
          return source;
      return null;
Fetch features and network attributes from a utility network during trace
// This routine demonstrates how to fetch features and network attributes from a utility network during a trace
  static void FetchFeaturesAndAttributes(UtilityNetwork utilityNetwork)
      // Start elements
      List<Element> startingPoints = new List<Element>() { startingPoint1, startingPoint2 };
      List<Element> barriers = new List<Element>();
      // Result Types
      // Resutl Options
      // Trace Arguments
      // Tracer
      // Async trace result
        connectedTracer.Trace(traceArgument, ServiceSynchronizationType.Asynchronous);
        if (traceResult is FeatureElementResult featureElementResult)
          IReadOnlyList<FeatureElement> featureElements = featureElementResult.FeatureElements;
    // Helper inline function
            return source;
            return source;
          return source;
      return null;
Get selected features from a list of elements
// This routine demonstrates how to get a list of feature selections from a list of elements
  static void FeatureSelectionsFromTrace(UtilityNetwork utilityNetwork, TraceArgument traceArgument)
    UpstreamTracer tracer = traceManager.GetTracer<UpstreamTracer>();
    IReadOnlyList<Result> tracerResults = tracer.Trace(traceArgument);
    foreach (Result traceResult in tracerResults)
      if (traceResult is ElementResult elementResult)
        IReadOnlyList<Element> elements = elementResult.Elements;
        // Feature selection from a list of elements
        IReadOnlyList<Selection> selections = utilityNetwork.GetFeaturesForElements(elements);
Network Diagrams
Get the Diagram Manager
static void GetDiagramManager(UtilityNetwork utilityNetwork)
    // Get the DiagramManager from the utility network
    using (DiagramManager diagramManager = utilityNetwork.GetDiagramManager())
      // Use the diagram manager...
Get Network Diagrams
static void GetDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
    Envelope extentOfInterest = MapView.Active.Map.GetDefaultExtent();
      // Get all the diagrams
      IReadOnlyList<NetworkDiagram> diagrams = diagramManager.GetNetworkDiagrams();
      // Get a diagram by name
      NetworkDiagram diagram = diagramManager.GetNetworkDiagram(_diagramName);
      // Get diagrams by extent
      diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest);
      // Get diagrams from a set of utility network feature GlobalIDs
      diagrams = diagramManager.GetNetworkDiagrams(globalIDs);
      // Get diagrams from a set of utility network feature GlobalIDs within an extent
      diagrams = diagramManager.GetNetworkDiagrams(extentOfInterest, globalIDs);
Get a list of Network Diagrams with inconsistent ConsistencyState
static List<NetworkDiagram> GetInconsistentDiagrams(UtilityNetwork utilityNetwork)
      List<NetworkDiagram> networkDiagrams = new List<NetworkDiagram>();
      // Loop through the network diagrams in the diagram manager
      foreach (NetworkDiagram diagram in diagramManager.GetNetworkDiagrams())
        NetworkDiagramInfo diagramInfo = diagram.GetDiagramInfo();
        // If the diagram is not a system diagram and is in an inconsistent state, add it to our list
        if (!diagramInfo.IsSystem &&
            diagram.GetConsistencyState() != NetworkDiagramConsistencyState.DiagramIsConsistent)
          networkDiagrams.Add(diagram);
        else
          diagram.Dispose(); // If we are not returning it we need to Dispose it
      return networkDiagrams;
Open a diagram pane from a Network Diagram
// Create a diagram layer from a NetworkDiagram
  static void CreateDiagramLayerFromNetworkDiagram(NetworkDiagram networkDiagram)
    // Create the diagram map
    Map newMap = MapFactory.Instance.CreateMap(networkDiagram.Name, MapType.NetworkDiagram, MapViewingMode.Map);
    // Open the diagram map
    Task<IMapPane> mapPane = ProApp.Panes.CreateMapPaneAsync(newMap, MapViewingMode.Map);
    //Add the diagram to the map
    DiagramLayer diagramLayer = newMap.AddDiagramLayer(networkDiagram);
Get Diagram from DiagramLayer
// Get the NetworkDiagram from a DiagramLayer and check its ConsistencyState
  static void GetDiagram(DiagramLayer diagramLayer)
    NetworkDiagram diagram = diagramLayer.GetNetworkDiagram();
    // Get the consistency state from the layer
    DiagramLayerConsistencyState diagramLayerConsistencyState = diagramLayer.ConsistencyState;
    // Or from the diagram
    NetworkDiagramConsistencyState diagramConsistencyState = diagram.GetConsistencyState();
Get Diagram Templates
// Get all the diagram templates or a template by name
  static void RetrieveDiagramTemplates(UtilityNetwork utilityNetwork)
    string templateName = "ElectricNetworkTemplate";
    using DiagramManager diagramManager = utilityNetwork.GetDiagramManager();
    // Get all templates
    IReadOnlyList<DiagramTemplate> templates = diagramManager.GetDiagramTemplates();
    // Get a template by name
    DiagramTemplate template = diagramManager.GetDiagramTemplate(templateName);
Get Network Diagrams from a Diagram Template
// Get all the network diagrams from a template or a diagram by name
  static void GetNetworkDiagramFromDiagramTemplates(UtilityNetwork utilityNetwork)
      // Get the first templates
      DiagramTemplate template = diagramManager.GetDiagramTemplates().FirstOrDefault();
      // Get the network diagrams fromt he template
      IEnumerable<NetworkDiagram> diagrams = template.GetNetworkDiagrams();
      // Get a network diagram by name
      NetworkDiagram diagram = template.GetNetworkDiagram(_diagramName);
Create a Network Diagram
// Create a network diagram from a template and a set of utility network feature GlobalIDs
  static void CreateNetworkDiagram(UtilityNetwork utilityNetwork, IEnumerable<Guid> globalIDs)
      // Get the template
      DiagramTemplate template = diagramManager.GetDiagramTemplate(TemplateName);
      NetworkDiagram diagram = diagramManager.CreateNetworkDiagram(template, globalIDs);
Get Network Diagram Information as JSON string
static void GetDiagramContent(UtilityNetwork utilityNetwork)
      NetworkDiagram diagram = diagramManager.GetNetworkDiagram(TemplateName);
      string jsonContent = diagram.GetContent(true, true, true, true);
Get Diagram Elements
// Get the diagram elements whose extent intersects the active map extent
  static void GetDiagramElements(MapView mapView, NetworkDiagram networkDiagram)
    // Create a DiagramElementQueryByExtent to retrieve diagram element junctions whose extent
    // intersects the active map extent
    DiagramElementQueryByExtent elementQuery = new DiagramElementQueryByExtent();
    elementQuery.ExtentOfInterest = MapView.Active.Extent;
    elementQuery.AddContents = false;
    elementQuery.QueryDiagramJunctionElement = true;
    elementQuery.QueryDiagramEdgeElement = false;
    elementQuery.QueryDiagramContainerElement = false;
    // Use this DiagramElementQueryByExtent as an argument to the QueryDiagramElements method
    DiagramElementQueryResult result = networkDiagram.QueryDiagramElements(elementQuery);
    // Get the container, junction, edge elements.
    IReadOnlyList<DiagramContainerElement> containerElements = result.DiagramContainerElements;
    // In this case result.DiagramJunctionElements and result.DiagramEdgeElements will be empty
    // because elementQuery.QueryDiagramEdgeElement and elementQuery.QueryDiagramContainerElement are set to 'false'
    IReadOnlyList<DiagramJunctionElement> junctionElements = result.DiagramJunctionElements;
    IReadOnlyList<DiagramEdgeElement> edgeElements = result.DiagramEdgeElements;
Get Diagram Aggregations
// Get the diagram aggregations
  static void GetDiagramAggregation(NetworkDiagram networkDiagram)
    IReadOnlyList<DiagramAggregation> aggregations = networkDiagram.GetAggregations();
    foreach (DiagramAggregation aggregation in aggregations)
      NetworkDiagramAggregationType type = aggregation.AggregationType;
Find Diagram Features for a set of utility network rows
// Given a list of utility network feature GlobalIDs, find the corresponding diagram features in a network diagram
  static void FindDiagramFeatures(NetworkDiagram diagram, List<Guid> globalIDs)
    FindDiagramFeatureQuery featureQuery = new FindDiagramFeatureQuery();
    featureQuery.NetworkRowGlobalIDs = globalIDs;
    featureQuery.AddAggregations = true;
    featureQuery.AddConnectivityAssociations = true;
    featureQuery.AddStructuralAttachments = true;
    IReadOnlyList<FindResultItem> features = diagram.FindDiagramFeatures(featureQuery);
    foreach (FindResultItem findFeature in features)
      long objectID = findFeature.ObjectID;
      Guid guid = findFeature.GlobalID;
      GeometryType geometryType = findFeature.GeometryType;
      int sourceID = findFeature.SourceID;
Find Utility Network Rows for a set of diagram features
// Given a list of diagram feature GlobalIDs, find the corresponding utility network rows in a network diagram
  static void FindDiagramRows(NetworkDiagram diagram, List<Guid> globalIDs)
    FindNetworkRowQuery rowQuery = new FindNetworkRowQuery();
    rowQuery.DiagramFeatureGlobalIDs = globalIDs;
    rowQuery.AddAggregations = true;
    IReadOnlyList<FindResultItem> rows = diagram.FindNetworkRows(rowQuery);
    foreach (FindResultItem findRow in rows)
      long objectID = findRow.ObjectID;
      Guid guid = findRow.GlobalID;
      GeometryType geometryType = findRow.GeometryType;
      int sourceID = findRow.SourceID;
Find Initial Network Rows Used to create a Network Diagram
// Find the utility network rows used to create a network diagram
  static void FindInitialNetworkRows(NetworkDiagram diagram)
    IReadOnlyList<FindResultItem> rows = diagram.FindInitialNetworkRows();
Change the Layout of a Network Diagram
// Change the layout of a network diagram by querying for all the diagram elements, editing their shapes,
  static void ChangeDiagramLayout(DiagramManager diagramManager, string diagramName)
    // Retrieve a diagram
    using (NetworkDiagram diagramTest = diagramManager.GetNetworkDiagram(diagramName))
      // Create a DiagramElementQueryByElementTypes query object to get the diagram elements we want to work with
      DiagramElementQueryByElementTypes query = new DiagramElementQueryByElementTypes();
      query.QueryDiagramJunctionElement = true;
      query.QueryDiagramEdgeElement = true;
      query.QueryDiagramContainerElement = true;
      // Retrieve those diagram elements
      DiagramElementQueryResult elements = diagramTest.QueryDiagramElements(query);
      // Create a NetworkDiagramSubset object to edit this set of diagram elements
      NetworkDiagramSubset subset = new NetworkDiagramSubset();
      subset.DiagramJunctionElements = elements.DiagramJunctionElements;
      subset.DiagramEdgeElements = elements.DiagramEdgeElements;
      subset.DiagramContainerElements = elements.DiagramContainerElements;
      // Save the new layout of the diagram elements
      diagramTest.SaveLayout(subset, true);
Editing Network Diagram
// Various editing operations on a network diagram
  static void EditDiagram(NetworkDiagram diagram, List<Guid> globalIDs)
    // These routines generate their own editing transaction, and therefore cannot be wrapped
    // in a separate transaction. Because the editing performed by these routines cannot
    // be undone, thise routines can also not be called within an editing session. All
    // edits in the current edit session must be saved or discarded before calling these
    // routines.
    // Refresh the diagram - synchronizes it based on the latest network topology
    diagram.Update();
    // Append features to the diagram
    diagram.Append(globalIDs);
    // Overwrite the diagram with a set of features
    diagram.Overwrite(globalIDs);
    NetworkDiagramInfo info = diagram.GetDiagramInfo();
    if (info.CanExtend)
      diagram.Extend(NetworkDiagramExtendType.ExtendByContainment);
      // or extend for only a set of utility network globalIDs
      diagram.Extend(NetworkDiagramExtendType.ExtendByContainment, globalIDs);
    // Delete a diagram
    diagram.Delete();
