//Map must be a local scene
bool canCreateVoxel = (MapView.Active.ViewingMode == MapViewingMode.SceneLocal);
if (canCreateVoxel)
//TODO - use the voxel api methods
Create Voxel Layer
// Note: call within QueuedTask.Run()
//Must be a .NetCDF file for voxels
var url = @"C:\MyData\AirQuality_Redlands.nc";
var cim_connection = new CIMVoxelDataConnection()
URI = url
//Create a VoxelLayerCreationParams
var createParams = VoxelLayerCreationParams.Create(cim_connection);
createParams.IsVisible = true;
//Can also just use the path directly...
//var createParams = VoxelLayerCreationParams.Create(url);
//Use VoxelLayerCreationParams to enumerate the variables within
//the voxel
var variables = createParams.Variables;
foreach (var variable in variables)
var line = $"{variable.Variable}: {variable.DataType}, " +
$"{variable.Description}, {variable.IsDefault}, {variable.IsSelected}";
System.Diagnostics.Debug.WriteLine(line);
//Optional: set the default variable
createParams.SetDefaultVariable(variables.Last());
//Create the layer - map must be a local scene
voxelLayer = LayerFactory.Instance.CreateLayer<VoxelLayer>(createParams, map);
Voxel Layer settings and properties
Get a Voxel Layer from the TOC
//Get selected layer if a voxel layer is selected
voxelLayer = MapView.Active.GetSelectedLayers().OfType<VoxelLayer>().FirstOrDefault();
if (voxelLayer == null)
//just get the first voxel layer in the TOC
voxelLayer = MapView.Active.Map.GetLayersAsFlattenedList().OfType<VoxelLayer>().FirstOrDefault();
return;
Manipulate the Voxel Layer TOC Group
//Toggle containers and visibility in the TOC
voxelLayer.SetExpanded(!voxelLayer.IsExpanded);
voxelLayer.SetVisibility(!voxelLayer.IsVisible);
voxelLayer.SetIsosurfaceContainerExpanded(!voxelLayer.IsIsosurfaceContainerExpanded);
voxelLayer.SetIsosurfaceContainerVisibility(!voxelLayer.IsIsosurfaceContainerVisible);
voxelLayer.SetSliceContainerExpanded(voxelLayer.IsSliceContainerExpanded);
voxelLayer.SetSliceContainerVisibility(!voxelLayer.IsSliceContainerVisible);
voxelLayer.SetSectionContainerExpanded(!voxelLayer.IsSectionContainerExpanded);
voxelLayer.SetSectionContainerVisibility(!voxelLayer.IsSectionContainerVisible);
voxelLayer.SetLockedSectionContainerExpanded(!voxelLayer.IsLockedSectionContainerExpanded);
voxelLayer.SetLockedSectionContainerVisibility(!voxelLayer.IsLockedSectionContainerVisible);
Get/Set Selected Voxel Assets from the TOC
var surfaces = MapView.Active.GetSelectedIsosurfaces();
//set selected w/ MapView.Active.SelectVoxelIsosurface(isoSurface)
var slices = MapView.Active.GetSelectedSlices();
//set selected w/ MapView.Active.SelectVoxelSlice(slice)
var sections = MapView.Active.GetSelectedSections();
//set selected w/ MapView.Active.SelectVoxelSection(section)
var locked_sections = MapView.Active.GetSelectedLockedSections();
//set selected w/ MapView.Active.SelectVoxelLockedSection(locked_section)
Change the Voxel Visualization
//Change the visualization to Volume
//e.g. for creating slices
voxelLayer.SetVisualization(VoxelVisualization.Volume);
//Change the visualization to Surface
//e.g. to create isosurfaces and sections
voxelLayer.SetVisualization(VoxelVisualization.Surface);
//Offset
var offset = voxelLayer.CartographicOffset;
//apply an offset
voxelLayer.SetCartographicOffset(offset + 100.0);
//VerticalExaggeration
var exaggeration = voxelLayer.VerticalExaggeration;
//apply an exaggeration
voxelLayer.SetVerticalExaggeration(exaggeration + 100.0);
//Change the exaggeration mode to "ScaleZ" - corresponds to 'Z-coordinates'
//on the Layer properties UI - must use the CIM
var def = voxelLayer.GetDefinition() as CIMVoxelLayer;
def.Layer3DProperties.ExaggerationMode = ExaggerationMode.ScaleZ;
//can set vertical exaggeration via the CIM also
//def.Layer3DProperties.VerticalExaggeration = exaggeration + 100.0;
//apply the change
voxelLayer.SetDefinition(def);
//Diffuse Lighting
if (!voxelLayer.IsDiffuseLightingEnabled)
voxelLayer.SetDiffuseLightingEnabled(true);
var diffuse = voxelLayer.DiffuseLighting;
//set Diffuse lighting to a value between 0 and 1
voxelLayer.SetDiffuseLighting(0.5); //50%
//Specular Lighting
if (!voxelLayer.IsSpecularLightingEnabled)
voxelLayer.SetSpecularLightingEnabled(true);
var specular = voxelLayer.SpecularLighting;
voxelLayer.SetSpecularLighting(0.5); //50%
Get the Voxel Volume Dimensions
var x_max = voxelLayer.GetVolumes().Max(v => v.GetVolumeSize().X);
var y_max = voxelLayer.GetVolumes().Max(v => v.GetVolumeSize().Y);
var z_max = voxelLayer.GetVolumes().Max(v => v.GetVolumeSize().Z);
//Get the dimensions of just one volume
var dimensions = voxelLayer.GetVolumes().FirstOrDefault();
//Get the dimensions of the volume associated with the selected variable
var dimensions2 = voxelLayer.SelectedVariableProfile.Volume.GetVolumeSize();
Events
Subscribe for Changes to a Voxel Layer
MapMemberPropertiesChangedEvent.Subscribe((args) =>
var voxel = args.MapMembers.OfType<VoxelLayer>().FirstOrDefault();
if (voxel == null)
return;
//Anything changed on a voxel layer?
if (args.EventHints.Any(hint => hint == MapMemberEventHint.VoxelSelectedVariable))
//Voxel variable profile selection changed
var changed_variable_name = voxel.SelectedVariableProfile.Variable;
//TODO respond to change, use QueuedTask if needed
else if (args.EventHints.Any(hint => hint == MapMemberEventHint.Renderer))
//This can fire when a renderer becomes ready on a new layer; the selected variable profile
//is changed; visualization is changed, etc.
var renderer = voxel.SelectedVariableProfile.Renderer;
VoxelAssetChangedEvent.Subscribe((args) =>
//An asset changed on a voxel layer
System.Diagnostics.Debug.WriteLine("");
System.Diagnostics.Debug.WriteLine("VoxelAssetChangedEvent");
System.Diagnostics.Debug.WriteLine($" AssetType: {args.AssetType}, ChangeType: {args.ChangeType}");
if (args.ChangeType == VoxelAssetEventArgs.VoxelAssetChangeType.Remove)
return;
//Get "what"changed - add or update
//eg IsoSurface
VoxelLayer voxelLayer = null;
if (args.AssetType == VoxelAssetEventArgs.VoxelAssetType.Isosurface)
var surface = MapView.Active.GetSelectedIsosurfaces().FirstOrDefault();
//there will only be one selected...
if (surface != null)
voxelLayer = surface.Layer;
//Repeat for Slices, Sections, LockedSections...
//GetSelectedSlices(), GetSelectedSections(), GetSelectedLockedSections();
Variable Profiles + Renderer
Get the Selected Variable Profile
var sel_profile = voxelLayer.SelectedVariableProfile;
//Get the variable profile name
var profile_name = sel_profile.Variable;
Change the Selected Variable Profile
var profiles = voxelLayer.GetVariableProfiles();
//Select any profile as long as it is not the current selected variable
var not_selected = profiles.Where(p => p.Variable != sel_profile.Variable).ToList();
if (not_selected.Count() > 0)
voxelLayer.SetSelectedVariableProfile(not_selected.First());
Get the Variable Profiles
var variable_profiles = voxelLayer.GetVariableProfiles();
Get the Variable Renderer
var variable = voxelLayer.GetVariableProfiles().First();
var renderer = variable.Renderer;
if (variable.DataType == VoxelVariableDataType.Continuous)
//Renderer will be stretch
var stretchRenderer = renderer as CIMVoxelStretchRenderer;
//access the renderer
else //VoxelVariableDataType.Discrete
//Renderer will be unique value
var uvr = renderer as CIMVoxelUniqueValueRenderer;
Access Stats and Color Range for a Stretch Renderer
//Get the variable profile on which to access the data
var variable = voxelLayer.SelectedVariableProfile;
//or use ...voxelLayer.GetVariableProfiles()
//Data range
var min = variable.Statistics.MinimumValue;
var max = variable.Statistics.MaximumValue;
//Color range (Continuous only)
double color_min, color_max;
var renderer = variable.Renderer as CIMVoxelStretchRenderer;
color_min = renderer.ColorRangeMin;
color_max = renderer.ColorRangeMax;
Change Stretch Renderer Color Range
//Typically, the default color range covers the most
//commonly occurring voxel values. Usually, the data
//range is much broader than the color range
//Get the variable profile whose renderer will be changed
//Check DataType
if (variable.DataType != VoxelVariableDataType.Continuous)
//must be continuous to have a Stretch Renderer...
var color_min = renderer.ColorRangeMin;
var color_max = renderer.ColorRangeMax;
//increase range by 10% of the current difference
var dif = (color_max - color_min) * 0.05;
color_min -= dif;
color_max += dif;
//make sure we do not exceed data range
if (color_min < variable.Statistics.MinimumValue)
color_min = variable.Statistics.MinimumValue;
if (color_max > variable.Statistics.MaximumValue)
color_max = variable.Statistics.MaximumValue;
//variable.Statistics.MinimumValue
renderer.ColorRangeMin = color_min;
renderer.ColorRangeMax = color_max;
//apply changes
variable.SetRenderer(renderer);
Change The Visibility on a CIMVoxelColorUniqueValue class
//Check DataType
if (variable.DataType != VoxelVariableDataType.Discrete)
return;//must be Discrete to have a UV Renderer...
var renderer = variable.Renderer as CIMVoxelUniqueValueRenderer;
//A CIMVoxelUniqueValueRenderer consists of a collection of
//CIMVoxelColorUniqueValue classes - one per discrete value
//in the associated variable profile value array
//Get the first class
var classes = renderer.Classes.ToList();
var unique_value_class = classes.First();
//Set its visibility off
unique_value_class.Visible = false;
//Apply the change to the renderer
renderer.Classes = classes.ToArray();
//apply the changes
IsoSurfaces
Check the MaxNumberofIsoSurfaces for a Variable
var max = variable.MaxNumberOfIsosurfaces;
if (max >= variable.GetIsosurfaces().Count)
//no more surfaces can be created on this variable
Check a Variable's Datatype
//No iso surfaces
//Iso surface can only be created for VoxelVariableDataType.Continuous
Check CanCreateIsoSurface
//Visualization must be surface or CanCreateIsosurface will return
//false
if (voxelLayer.Visualization != VoxelVisualization.Surface)
//Get the variable profile on which to create the iso surface
//or use ...voxelLayer.GetVariableProfiles().First(....
// o Visualization must be Surface
// o Variable profile must be continuous
// o Variable MaxNumberofIsoSurfaces must not have been reached...
if (variable.CanCreateIsosurface)
//Do the create
Create Isosurface
//Note: calling create if variable.CanCreateIsosurface == false
//will trigger an InvalidOperationException
//Specify a voxel value for the iso surface
var mid = (max + min) / 2;
//color range (i.e. values that are being rendered)
//keep the surface within the current color range (or it
//won't render)
if (mid < color_min)
mid = renderer.ColorRangeMin;
else if (mid > color_max)
mid = renderer.ColorRangeMax;
//Create the iso surface
var suffix = Math.Truncate(mid * 100) / 100;
variable.CreateIsosurface(new IsosurfaceDefinition()
Name = $"Surface {suffix}",
Value = mid,
IsVisible = true
How to Change Value and Color on an Isosurface
//Change the color of the first surface for the given profile
var surface = variable.GetIsosurfaces().FirstOrDefault();
//Change the iso surface voxel value
surface.Value = surface.Value * 0.9;
//get a random color
var count = new Random().Next(0, 100);
var colors = ColorFactory.Instance.GenerateColorsFromColorRamp(
((CIMVoxelStretchRenderer)variable.Renderer).ColorRamp, count);
var idx = new Random().Next(0, count - 1);
surface.Color = colors[idx];
//set the custom color flag true to lock the color
//locking the color prevents it from being changed if the
//renderer color range or color theme is updated
surface.IsCustomColor = true;
//update the surface
variable.UpdateIsosurface(surface);
Change Isourface Color Back to Default
if (surface.IsCustomColor)
surface.Color = variable.GetIsosurfaceColor((double)surface.Value);
surface.IsCustomColor = false;
Delete Isosurfaces
//delete the last surface
var last_surface = variable.GetIsosurfaces().LastOrDefault();
if (last_surface != null)
variable.DeleteIsosurface(last_surface);
//delete all the surfaces
foreach (var surface in variable.GetIsosurfaces())
variable.DeleteIsosurface(surface);
//Optional - set visualization back to Volume
if (variable.GetIsosurfaces().Count() == 0)
Slices
Get the Collection of Slices
//Use the SelectedVariableProfile to get the slices currently in the TOC
//via its associated volume
var volume = voxelLayer.SelectedVariableProfile.Volume;
var slices = volume.GetSlices();
//Do something... e.g. make them visible
foreach (var slice in slices)
slice.IsVisible = true;
volume.UpdateSlice(slice);
//expand the slice container and make sure container visibility is true
voxelLayer.SetSliceContainerExpanded(true);
voxelLayer.SetSliceContainerVisibility(true);
Get a Slice
var slice = volume.GetSlices().FirstOrDefault();
var slice2 = volume.GetSlices().First(s => s.Id == my_slice_id);
Get Selected Slice in TOC
var slice = MapView.Active?.GetSelectedSlices()?.FirstOrDefault();
if (slice != null)
//Do something with the slice
Get Voxel Layer for the Selected Slice in TOC
voxelLayer = null;
if (slice != null)
voxelLayer = slice.Layer;
//TODO - use the layer
Create a Slice
if (voxelLayer.Visualization != VoxelVisualization.Volume)
//To stop the Voxel Exploration Dockpane activating use:
voxelLayer.AutoShowExploreDockPane = false;
//This is useful if u have your own dockpane currently activated...
var volumeSize = volume.GetVolumeSize();
//Orientation 90 degrees (West), Tilt 0.0 (vertical)
//Convert to a normal
var normal = voxelLayer.GetNormal(90, 0.0);
//Create the slice at the voxel mid-point. VoxelPosition
//is specified in voxel-space coordinates
//Create the slice on the respective volume
volume.CreateSlice(new SliceDefinition()
Name = "Middle Slice",
VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2),
Normal = normal,
IsVisible = true
//reset if needed...
voxelLayer.AutoShowExploreDockPane = true;
Change Tilt on a Slice
//Normally, it would be set in your dockpane
var slice = volume.GetSlices().First(s => s.Name == "Change Tilt Slice");
(double orientation, double tilt) = voxelLayer.GetOrientationAndTilt(slice.Normal);
//Convert orientation and tilt to a normal
slice.Normal = voxelLayer.GetNormal(orientation, 45.0);
//reset if needed...Normally this might be when your dockpane
//was de-activated (ie "closed")
Delete Slice
var last_slice = volume.GetSlices().LastOrDefault();
if (last_slice != null)
volume.DeleteSlice(last_slice);
//Delete all slices
volume.DeleteSlice(slice);
Sections
Get a Section
//Use the SelectedVariableProfile to get the sections currently in the TOC
var section = volume.GetSections().FirstOrDefault();
var section2 = volume.GetSections().First(sec => sec.ID == my_section_id);
Get the Current Collection of Sections
voxelLayer.SetSectionContainerExpanded(true);
voxelLayer.SetSectionContainerVisibility(true);
var sections = volume.GetSections();
Get the Selected Section in TOC
var section = MapView.Active?.GetSelectedSections()?.FirstOrDefault();
if (section != null)
//Do something with the section
Get Voxel Layer for the Selected Section in TOC
voxelLayer = null;
voxelLayer = section.Layer;
Create a Section at the Voxel MidPoint
//Create a section that cuts the volume in two on the vertical plane
//Orientation 90 degrees (due West), Tilt 0 degrees
//Position must be specified in voxel space
volume.CreateSection(new SectionDefinition()
Name = "Middle Section",
Normal = normal,
IsVisible = true
Create a Horizontal Section
//Create a section that cuts the volume in two on the horizontal plane
//Or use normal (0, 0, 1) or (0, 0, -1)...
var horz_section = SectionDefinition.CreateHorizontalSectionDefinition();
horz_section.Name = "Horizontal Section";
horz_section.IsVisible = true;
horz_section.VoxelPosition = new Coordinate3D(volumeSize.X / 2, volumeSize.Y / 2, volumeSize.Z / 2);
volume.CreateSection(horz_section);
Create Sections in a Circle Pattern
//180 degrees orientation is due South. 90 degrees orientation is due west.
var south = 180.0;
var num_sections = 12;
var spacing = 1 / (double)num_sections;
//Create a section every nth degree of orientation. Each section
//bisects the middle of the voxel
for (int s = 0; s < num_sections; s++)
var orientation = south * (s * spacing);
Name = $"Circle {s + 1}",
Normal = voxelLayer.GetNormal(orientation, 0.0),
IsVisible = true
Create Sections that Bisect the Voxel
//Make three Normals - each is a Unit Vector (x, y, z)
var north_south = new Coordinate3D(1, 0, 0);
var east_west = new Coordinate3D(0, 1, 0);
var horizontal = new Coordinate3D(0, 0, 1);
int n = 0;
//The two verticals bisect the x,y plane. The horizontal normal bisects
//the Z plane.
foreach (var normal in new List<Coordinate3D> { north_south, east_west, horizontal })
Name = $"Cross {++n}",
Normal = normal,
IsVisible = true
Create Sections Diagonally across the Voxel
//make a diagonal across the voxel
var voxel_pos = new Coordinate3D(0, 0, volumeSize.Z);
var voxel_pos_ur = new Coordinate3D(volumeSize.X, volumeSize.Y, volumeSize.Z);
var lineBuilder = new LineBuilderEx(voxel_pos, voxel_pos_ur, null);
var diagonal = PolylineBuilderEx.CreatePolyline(lineBuilder.ToSegment());
//change as needed
var orientation = 20.0; //(approx NNW)
var tilt = -15.0;
var normal = voxelLayer.GetNormal(orientation, tilt);
Coordinate2D end_pt = new Coordinate2D(0, 0);
if (s > 0)
//position each section evenly spaced along the diagonal
var segments = new List<Segment>() as ICollection<Segment>;
var part = GeometryEngine.Instance.GetSubCurve3D(
diagonal, 0.0, s * spacing, AsRatioOrLength.AsRatio);
part.GetAllSegments(ref segments);
end_pt = segments.First().EndCoordinate;
Name = $"Diagonal {s + 1}",
VoxelPosition = new Coordinate3D(end_pt.X, end_pt.Y, volumeSize.Z),
Normal = normal,
IsVisible = true
Update Section Orientation and Tilt
foreach (var section in volume.GetSections())
//set each normal to 45.0 orientation and tilt
section.Normal = voxelLayer.GetNormal(45.0, 45.0);
//apply the change
volume.UpdateSection(section);
Update Section Visibility
var sections = volume.GetSections().Where(s => !s.IsVisible);
//Make them all visible
foreach (var section in sections)
//apply the change
Delete Sections
volume.DeleteSection(section);
//optional...
Locked Sections
Get the Current Collection of Locked Sections
voxelLayer.SetLockedSectionContainerExpanded(true);
voxelLayer.SetLockedSectionContainerVisibility(true);
var locked_sections = voxelLayer.GetLockedSections();
Get a Locked Section
var my_locked_section_id = -1;
var locked_section = voxelLayer.GetLockedSections().FirstOrDefault();
var locked_section2 = voxelLayer.GetLockedSections()
.First(lsec => lsec.ID == my_locked_section_id);
Get Selected Locked Section in TOC
var locked_section = MapView.Active?.GetSelectedLockedSections()?.FirstOrDefault();
if (locked_section != null)
// Use the locked section
Get Voxel Layer for the Selected Locked Section in TOC
voxelLayer = locked_section.Layer;
Set the Variable Profile Active for Selected Locked Section
var variable = locked_section.Layer.GetVariableProfile(locked_section.VariableName);
locked_section.Layer.SetSelectedVariableProfile(variable);
Lock a Section/Create a Locked Section
//get the selected section
var section = MapView.Active.GetSelectedSections().FirstOrDefault();
if (section == null)
return;
//Lock the section (Creates a locked section, deletes
//the section)
//if (voxelLayer.CanLockSection(section))
// voxelLayer.LockSection(section);
if (volume.CanLockSection(section))
volume.LockSection(section);
Update Locked Section Visibility
var locked_sections = voxelLayer.GetLockedSections().Where(ls => !ls.IsVisible);
//Make them visible
foreach (var locked_section in locked_sections)
locked_section.IsVisible = true;
//apply change
voxelLayer.UpdateSection(locked_section);
Unlock a Locked Section
//get the selected locked section
var locked_section = MapView.Active.GetSelectedLockedSections().FirstOrDefault();
if (locked_section == null)
return;
//Unlock the locked section (Deletes the locked section, creates
//a section)
if (voxelLayer.CanUnlockSection(locked_section))
voxelLayer.UnlockSection(locked_section);
Delete a Locked Section
if (voxelLayer.GetLockedSections().Count() == 0)
return;
//Delete the last locked section from the collection of
//locked sections
voxelLayer.DeleteSection(voxelLayer.GetLockedSections().Last());
