ProSnippets WorkflowManager
Language:              C#
Subject:               Prosnippets WorkflowManager
Contributor:           ArcGIS Pro SDK Team <arcgisprosdk@esri.com>
Organization:          Esri, http://www.esri.com
Date:                  4/30/2026
ArcGIS Pro:            3.7
Visual Studio:         2026
Determine if there is an active Workflow Manager connection
// determine if there is an active Workflow Manager connection
  var isConnected = WorkflowClientModule.IsConnected;
  // Use the value of isConnected to determine if you can proceed with Workflow Manager operations
Get the Workflow Manager item Id
// Get the Workflow Manager item Id
  var itemId = WorkflowClientModule.ItemId;
  // Use the itemId to identify the Workflow Manager item
Get the Workflow Manager server url
// Get the Workflow Manager server url
  var serverUrl = WorkflowClientModule.ServerUrl;
  // Use the serverUrl to identify the Workflow Manager server
Get the job Id associated with the active map view
// Get the job Id associated with the active map view
  var jobManager = WorkflowClientModule.JobsManager;
  jobId = jobManager.GetJobId();
  // Use the jobId to identify the job associated with the active map view
Get the job Id associated with a map
// Get the job Id associated with a map
  jobId = jobManager.GetJobId(mapUri);
  // Use the jobId to identify the job associated with the map
Get the job Id associated with a running OpenProProjectItems step
// Get the job Id associated with a running OpenProItems step for a Pro Add-In module
  // In the Add-In Module class, override the ExecuteCommandArgs(string id) method and return a Func<Object[], Task> object like the sample below
  // Refer to the Workflow Manager ProConcepts Sample Code link for an example
  Func<object[], Task> overrideFunction = (args) => QueuedTask.Run(() =>
    try
      // Get the jobId property from the OpenProProjectItemsStep arguments and store it.
      OpenProProjectItemsStepCommandArgs stepArgs = (OpenProProjectItemsStepCommandArgs)args[0];
      var jobId = stepArgs.JobId;
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show($"Got job id from ProMappingStep args: {jobId}", "Project Info");
      // Run the command specified by the id passed into ExecuteCommandArgs
      IPlugInWrapper wrapper = FrameworkApplication.GetPlugInWrapper(id);
      if (wrapper is ICommand command && command.CanExecute(null))
        command.Execute(null);
    catch (Exception e)
      ArcGIS.Desktop.Framework.Dialogs.MessageBox.Show($"ERROR: {e}", "Error running command");
  // Use overrideFunction to get the jobId from the step args when the command is executed
Get a job
// Note: QueuedTask is required to call Workflow Manager API methods
  // GetJob returns an existing job
  try
    var job = jobManager.GetJob(jobId);
    // Do something with the job
  catch (NotConnectedException)
    // Not connected to Workflow Manager server, do some error handling
  catch (Exception)
    // Some other exception occurred, do some error handling
  // Use the job object
Search for jobs using a detailed query
var search = new SearchQuery()
    // Search for all open high priority jobs assigned to users
    Q = "closed=0 AND assignedType='User' AND priority='High'",
    Fields = ["jobId", "jobName", "assignedTo", "dueDate"],
    // Sort by job assignment in ascending order and due date in descending order
    SortFields =
      new SortField() { FieldName = "assignedTo", SortOrder = SortOrder.Asc },
      new SortField() { FieldName = "dueDate", SortOrder = SortOrder.Desc }
  var searchResults = jobManager.SearchJobs(search);
  var fields = searchResults.Fields;
  var results = searchResults.Results;
Search for jobs using a detailed query with an arcade expression
    // Search for jobs assigned to the current user using the arcade expression '$currentUser'
    Q = "\"assignedType='User' AND closed=0 AND assignedTo='\" + $currentUser + \"' \"",
    // Sort by job name in ascending order
    SortFields = [new SortField() { FieldName = "jobName", SortOrder = SortOrder.Asc }]
Search for jobs using a simple string
var search = new SearchQuery() { Search = "My Search String" };
  // Use the fields and results collections
Get statistics for jobs
var query = new JobStatisticsQuery()
    // Search for open jobs assigned to users
    Q = "\"assignedType='User' AND closed=0 \""
  var results = jobManager.CalculateJobStatistics(query);
  var totalJobs = results.Total;
Run steps on a job
  jobManager.RunSteps(jobId);
Run specific steps on a job
  // Specify specific current steps in a job to run
  var stepIds = new List<string> { "step12345", "step67890" };
  jobManager.RunSteps(jobId, stepIds);
Stop running steps on a job
  // Stop the current steps in the job with the given id.
  jobManager.StopSteps(jobId);
Stop specific running steps on a job
  // Specify specific running steps in a job to stop
  List<string> stepIds = ["step12345", "step67890"];
  jobManager.StopSteps(jobId, stepIds);
Finish steps on a job
  // Finish the current steps in the job with the given id.
  jobManager.FinishSteps(jobId);
Finish specific steps on a job
  jobManager.FinishSteps(jobId, stepIds);
Subscribe to a workflow connection changed event.
subscriptionToken = WorkflowConnectionChangedEvent.Subscribe(e =>
    // The connection has changed
    // Do something relevant
    return Task.CompletedTask;
Unsubscribe from a workflow connection changed event.
WorkflowConnectionChangedEvent.Unsubscribe(subscriptionToken);
Subscribe to job notification messages
// Subscribe to the job message event to start receiving job and step notifications.
  // Use the subscription token to unsubscribe from the event.
  subscriptionToken = JobMessageEvent.Subscribe(e =>
    var jobId = e.Message.JobId;
    var msgType = e.MessageType;
    var message = e.Message;
    // Include logic to process the job / step messages
  // Subscribe to certain jobs. This will add these jobIds to the list of already subscribed jobs.
  var notifManager = WorkflowClientModule.NotificationManager;
  notifManager.SubscribeToJobs(jobIds);
Unsubscribe to messages for the given jobs
// Unsubscribe from the job message event using the subscription token
  JobMessageEvent.Unsubscribe(subscriptionToken);
  // Unsubscribe from jobs using the same instance of Notification Manager used to subscribe to jobs.
  // This will remove the jobs from the subscribed job list if no other clients are subscribed to those jobs.
  notifManager.UnsubscribeFromJobs(jobIds);
Send a response to Workflow Manager Server pertaining to a job's current step
// Send a step response to Workflow Manager Server with additional information required for the step to continue.
  // In this example, provide an answer response to a QuestionStepInfoRequiredMessage so that the Question step can complete.
  // The response must include the jobId, stepId, and other information pertinent to the step.
  var stepInfoResponseMessage = new QuestionStepInfoResponseMessage()
    JobId = jobId,
    StepId = stepId,
    QuestionResponse = 1,
    Comment = "Selected question response option 1"
  var stepResponse = new StepResponse()
    Message = stepInfoResponseMessage
  notifManager.SendStepResponse(stepResponse);
