Build Terrain (3D Analyst Tools)
Summary
Performs tasks required for analyzing and displaying a terrain dataset.
Usage
  • This tool will need to be used after initially defining the features that participate in a terrain, making subsequent modifications to the features that participate in the terrain, or modifying the terrain pyramid definition.
  • It is more efficient to make a collection of edits followed by one build rather than running a build after each individual edit.
Parameters
Label Explanation Data type
Input Terrain
The terrain dataset that will be processed.
Terrain Layer
Update Extent
(Optional)
Recalculates the data extent of a window-size-based terrain dataset when the data area has been reduced through editing. It is not needed if the data extent has increased or if the terrain dataset is z-tolerance based. It will scan through all the terrain data to determine the new extent.
  • Maintain Extent—The extent of the terrain dataset will not be recalculated. This is the default.
  • Update Extent—The extent of the terrain dataset will be recalculated.
String
Derived output
Updated Input Terrain
The updated terrain.
Terrain Layer
Environments
Current Workspace, Extent, Auto Commit
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
