Change LAS Class Codes (3D Analyst Tools)
Summary
Reassigns the classification codes and flags of .las and .zlas files.
Usage
  • The American Society for Photogrammetry and Remote Sensing (ASPRS) defines how class codes should be used for LAS files. The ASPRS classification standard allows LAS files to be easily processed and interpreted between different applications. The ASPRS guidelines divide class codes into reserved classes and user-definable classes. Reserved classes are values whose meanings are or will be defined by the ASPRS. User-definable classes can be used to classify objects that are not already described by the reserved classes. While many reserved classes are already defined, such as class 2 for ground and class 6 for buildings, the undefined reserved classes will be used in the future as the LAS specification evolves. For this reason, use reserved classes only for the objects they are meant to describe, and assign custom class codes to a user-definable class code. Consider using this tool to remap the class code of any custom objects that use reserved classes to a user-definable class.
  • This tool does not honor layer filters. All points with the class codes specified in the Current Class column will be modified. The classification change can be limited to an edit of the class code or a particular class flag, or any combination of class codes and class flags, such as reassigning ground model key points that are assigned a value of 8 to class 2 with the model key class flag. Also, a value of -1 can be specified in the Current Class column to make a uniform change to all points irrespective of their class code. This can be useful if you need to reset the existing classification to evaluate different classification settings, or to make other uniform edits to classification flags. For example, the synthetic classification flag is meant to represent any point that was acquired from a source other than lidar. If the point cloud is derived from a photogrammetric process and you want to assign the synthetic flag to each point, specify a value of -1 in the Current Class column and specify the Synthetic column to Set.
  • The classification codes and flags that can be used vary on the LAS file version and point record format. Consider the limitations of the input .las and .zlas files for any potential change. To maximize the options for classifying a point cloud, you can convert older files to the LAS 1.4 format using the Convert LAS tool. If the files also need to be tiled or thinned to improve performance, you can use the Tile LAS and Thin LAS tools to convert the file version.
    LAS file version
    Class code range
    Classification flags
    1.0
    0 - 255
    None
    1.1
    0 - 31
    Synthetic, Key-point, Withheld
    1.2
    0 - 31
    1.3
    0 - 31
    1.4
    0 - 255
    Synthetic, Key-point, Withheld, Overlap
    Classification flags like key-point and overlap supersede the use of classification codes which defined those same concepts. This allows the points to have a classification code that describes the object they are representing while also retaining the functional value of being defined as a model key point or an overlap point. If your LAS file version supports these classification flags, considering modifying the points accordingly. Historically, when model key points were defined by class code 8, the points represented a subset of ground-classified points. Such points can now be modified to have the class code set to 2 with the Model Key classification flag.
  • ArcGIS applies the classification scheme specified in the LAS file version 1.4 as follows:
    Classification value
    Meaning
    Created, Never classified
    Unassigned
    Ground
    Low Vegetation
    Medium Vegetation
    High Vegetation
    6
    Building
    7
    Low Point
    8
    Model Key-Point
    9
    Water
    10
    Rail
    11
    Road Surface
    12
    Reserved
    13
    Wire - Guard (Shield)
    14
    Wire - Conductor (Phase)
    15
    Transmission Tower
    16
    Wire-Structure Connector (Insulator)
    17
    Bridge Deck
    18
    High Noise
    19
    Reserved
    20
    Ignored Ground
    21
    Snow
    22
    Temporal Exclusion
    23–63
    Reserved
    64–255
    User Definable
    • The most current LAS 1.4 classification system has these codes (code 8: Model Key/Reserved and code 12: Overlap/Reserved) reserved, and points with these characteristics should use the corresponding class flags instead.
    • LAS 1.1–1.3 only support classes 0–31.
Parameters
Label Explanation Data type
Input LAS Dataset
The LAS dataset that will be processed.
LAS Dataset Layer
Class Codes
The class codes that will be modified and the change that will be made to their classification code and classification flags. A value of -1 can be provided in the Current Class column to modify all class codes.
Value table columns:
  • Current Class—The current class code value.
  • New Class—The new class code value.
  • Synthetic—The synthetic flag defines a point that was created by a technique other than direct observation, such as digitized from a photogrammetric stereo model or by traversing a waveform.
    • No Change—The synthetic classification flag will not be changed.
    • Set—The synthetic classification flag will be assigned.
    • Clear—The synthetic classification flag will be removed.
  • Model Key—The model key flag defines a point that is critical to modeling an object and should always be present when processed by any point thinning solution.
    • No Change—The model key classification flag will not be changed.
    • Set—The model key classification flag will be assigned.
    • Clear—The model key classification flag will be removed.
  • Withheld—The withheld flag defines a point that should not be included in any analysis. This is typically assigned for points that contain erroneous measurements.
    • No Change—The withheld classification flag will not be changed.
    • Set—The withheld classification flag will be assigned.
    • Clear—The withheld classification flag will be removed.
  • Overlap—The overlap flag defines a point that was collected in a location with points collected from different flight lines or survey routes. The flight line or survey route is typically denoted by the point source ID. Regions with points from overlapping scans will have a higher point density than regions with points from only one scan. Identifying the overlapping points and assigning them to a classification flag can make it easy to filter them out so as to ensure a more consistent point density across the entire dataset.
    • No Change—The overlap classification flag will not be changed.
    • Set—The overlap classification flag will be assigned.
    • Clear—The overlap classification flag will be removed.
Value Table
Compute statistics
(Optional)
Specifies whether statistics will be computed for the .las files referenced by the LAS dataset. Computing statistics provides a spatial index for each .las file, which improves analysis and display performance. Statistics also enhance the filtering and symbology experience by limiting the display of LAS attributes, such as classification codes and return information, to values that are present in the .las file.
  • Checked—Statistics will be computed. This is the default.
  • Unchecked—Statistics will not be computed.
Boolean
Processing Extent
(Optional)
The extent of the data that will be evaluated.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Intersection of Inputs Intersect—The extent will be the intersecting extent of all inputs.
  • Union of Inputs Union—The extent will be the combined extent of all inputs.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Processing Boundary
The polygon feature or features that will define the area to be processed.
Feature Layer
Process entire LAS files that intersect extent
(Optional)
Specifies how the processing extent will be applied.
  • Checked—If any portion of a .las file intersects the area of interest, all the points in that file, including those outside the area of interest, will be processed.
  • Unchecked—Only LAS points that intersect the area of interest will be processed. This is the default.
Boolean
Update pyramid
(Optional)
Specifies whether the LAS dataset pyramid will be updated after the class codes are modified.
  • Checked—The LAS dataset pyramid will be updated. This is the default.
  • Unchecked—The LAS dataset pyramid will not be updated.
Boolean
Derived output
Output LAS Dataset
The updated LAS dataset.
LAS Dataset Layer
Environments
Current Workspace, Extent
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
