arcpy.3d.EncloseMultiPatch(in_features, out_feature_class, {grid_size})
Name
Explanation
Data type
in_features
The multipatch features that will be used to construct closed multipatches.
Feature Layer
out_feature_class
The output closed multipatch features.
Feature Class
grid_size
(Optional)
The resolution that will be used to construct the closed multipatch features. This value is defined using the linear units of the input feature's spatial reference.
Double
Code sample
EncloseMultiPatch example 1 (Python window)
The following sample demonstrates the use of this tool in the Python window:
arcpy.env.workspace = 'C:/data'
arcpy.ddd.EncloseMultiPatch('unclosed_features.shp',
'enclosed_features.shp', 0.5)
EncloseMultiPatch example 2 (stand-alone script)
The following sample demonstrates the use of this tool in a stand-alone Python script:
Name: Model Shadows For GeoVRML Models
Description: Creates a model of the shadows cast by GeoVRML models
imported to a multipatch feature class for a range of dates
and times. A range of times from the start time and end
time can also be specified by setting the EnforceTimes
Boolean to True. This sample is designed to be used in a
script tool.
# Import system modules
import arcpy
from datetime import datetime, time, timedelta
#************************* Script Variables **************************
inFiles = arcpy.GetParameterAsText(0) # list of input features
spatialRef = arcpy.GetParameterAsText(1) # list of GeoVRML files
outFC = arcpy.GetParameterAsText(2) # multipatch from 3D files
inTimeZone = arcpy.GetParameterAsText(3) # time zone
startDate = arcpy.GetParameter(4) # starting date as datetime
endDate = arcpy.GetParameter(5) # ending date as datetime
dayInterval = arcpy.GetParameter(6) # day interval as long (0-365)
minInterval = arcpy.GetParameter(7) # minute interval as long (0-60)
enforceTime = arcpy.GetParameter(8) # minute interval as Boolean
outShadows = arcpy.GetParameterAsText(9) # output shadow models
outIntersection = arcpy.GetParameterAsText(10) # shadow & bldg intersection
# Function to find all possible date/time intervals for shadow modelling
def time_list():
dt_result = [startDate]
if dayInterval:
if endDate: #Defines behavior when end date is supplied
while startDate < endDate:
startDate += timedelta(days=dayInterval)
dt_result.append(startDate)
dt_result.append(endDate)
else: # Behavior when end date is not given
daymonthyear = datetime.date(startDate)
while startDate <= datetime(daymonthyear.year, 12, 31, 23, 59):
return dt_result
importFC = arcpy.CreateUniqueName('geovrml_import', 'in_memory')
# Import GeoVRML files to in-memory feature
arcpy.ddd.Import3DFiles(inFiles, importFC, 'ONE_FILE_ONE_FEATURE',
spatialRef, 'Z_IS_UP', 'wrl')
# Ensure that building models are closed
arcpy.ddd.EncloseMultiPatch(importFC, outFC, 0.05)
# Discard in-memory feature
arcpy.management.Delete(importFC)
dt_result = time_list()
for dt in dt_result:
if dt == dt_result[0]:
shadows = outShadows
else:
shadows = arcpy.CreateUniqueName('shadow', 'in_memory')
arcpy.ddd.SunShadowVolume(outFC, dt, shadows, 'ADJUST_FOR_DST',
inTimeZone, '', minInterval, 'MINUTES')
if dt is not dt_result[0]:
arcpy.management.Append(shadows, outShadows)
arcpy.management.Delete(shadows)
arcpy.ddd.Intersect3D(outFC, outIntersection, outShadows, 'SOLID')
