Extract Multipatch From Mesh (3D Analyst Tools)
Summary
Creates a multipatch feature from the portion of an integrated mesh that overlaps a polygon.
Usage
Each polygon from the footprint feature will result in a multipatch created from the overlapping portions of the integrated mesh.
Consider using this tool if you need to assign attributes for discrete objects captured in the integrated mesh. The attributes from the footprint polygon will transfer to the resulting multipatch.
Consider using this tool if you need to process the data captured in an integrated mesh using tools that analyze multipatch geometry.
Parameters
| Label | Explanation | Data type |
Source Integrated Mesh |
The integrated mesh that will be processed. |
File; Scene Layer |
Footprint Features |
The polygon features defining the area that will be clipped. |
Feature Layer |
Output Multipatch Feature Class |
The output multipatch feature class. |
Feature Class |
Environments
Extent, Output Coordinate System, Geographic Transformations
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
