Intersect 3D Line With Surface (3D Analyst Tools)
Summary
Computes the geometric intersection of 3D line features and one or more surfaces to return the intersection as segmented line features and points.
Illustration
Intersect 3D Line With Surface tool illustration
Usage
  • All of the input line features will be in the output line feature class even if they do not intersect a surface.
  • The following fields are included in the output line feature class:
    • OID_ORG—The OBJECTID value from the original 3D line feature
    • SURF_FROM—The surface where the 3D line segment began
    • SURF_TO—The surface where the 3D line segment was drawn
  • The following fields are included in the optional output point feature class:
    • OID_LINE—The OBJECTID value from the original 3D line feature
    • SURFACE—The surface name where the intersecting point was generated
    • DIST_ALONG—The distance from the beginning of the 3D line to the point of intersection
Parameters
Label Explanation Data type
Input Line Features
The input 3D line features.
Feature Layer
Input Surfaces
One or more surfaces that will be used to determine intersections. Supported inputs are raster and TIN datasets.
Mosaic Layer; Raster Layer; TIN Layer
Output Lines
The output line features that represent the input line features split at the points of intersection with the surface.
Feature Class
Output Points
(Optional)
The optional point features that represent the input line's intersection with a surface .
Feature Class
Environments
Current Workspace, Extent, Output Coordinate System, Geographic Transformations, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Output CONFIG Keyword, Auto Commit, Output XY Domain, Output Z Domain, Minimize memory use during analysis on terrains
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
