LandXML To TIN (3D Analyst Tools)
Summary
This tool imports one or more triangulated irregular network (TIN) surfaces from a LandXML file to output Esri TINs.
Usage
  • When the LandXML file is selected, the TINs to Import parameter is populated with all the TIN surfaces found in the LandXML file. A constrained Delaunay TIN from the LandXML file is created as a constrained Delaunay TIN.
  • When scripting, the names inside the tinnames parameter can be specified in short form (only number or only name) for convenience. Instead of "1. Site0445; 2. <unnamed>; 3. <unnamed>; 4. Site_09" , you can specify "1;2;3;4" or "Site0445; Site_09;2;3". The <unnamed> keyword cannot be used by itself because the TIN must be uniquely identified.
Parameters
Label Explanation Data type
Input
The input LandXML file.
File
Output TIN Folder
The folder that the output TINs will be created in.
Folder
Output TIN Base Name
The basename of the resulting TIN. When several TINs will be exported from the LandXML file, the basename is used to define a unique name for each output TIN. If <basename> already exists, the tool will not write anything. If <basename> does not exist but <basename>2 exists, the tool will create <basename> and <basename>2_1, instead of <basename>2.
String
TINs to Import
(Optional)
The one or more LandXML TIN surfaces that will be exported to an Esri TIN.
String
Derived output
Updated Output TIN Folder
The folder containing the output TINs.
Folder
Environments
Scratch Workspace, Current Workspace, Default TIN Storage Version
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
