Converts a LAS dataset to either a point feature class or multipoint feature class.
Support all LAS dataset layer filters, including: class codes, class flags, return values, and z-range filter.
Support LAS dataset and individual LAS, ZLAS, and LAZ files.
The tool supports the spatial reference of the input point cloud.
The available attributes for an LAS dataset will be based on the attributes supported by the input LAS files, which depends on the file version and point record format.
The Attributes parameter will be disabled when Create single-point features parameter is unchecked, since the fields will be binary large object (BLOB) fields, and are not supported in shapefiles.
The average point spacing for the point cloud data.
Linear Unit
(Optional)
Specifies whether the output will be a multipoint or point feature class.
Checked—The output will be a point feature class.
Unchecked—The output will be a multipoint feature class. This is the default.
Boolean
Attributes
(Optional)
The LAS point attributes to preserve in the output feature. Each specified LAS attribute is stored in a corresponding field in the attribute table. When the output is a multipoint feature class, the attributes are stored in binary large object (BLOB) fields, which are supported by terrain datasets. When the output is a point feature class, each attribute is stored as a single value in a numeric field.
Value table columns:
Attribute—Specifies the point cloud attributes to preserve in the output attribute fields. The availability of these attributes depends on how the LAS data was collected and the LAS file version used, so some attributes may not be present.
Intensity—Represents the strength of the reflected laser signal recorded for the point.
Return Number—The return number recorded for the point from its originating laser pulse.
Number of Returns—Represents the number of returns recorded for the laser pulse from which the point was derived.
Scan Direction Flag—The flag indicates whether the scan was progressing in the forward or reverse direction when the point was collected.
Edge of Flightline—Identifies points located at the boundary of a flight line during data acquisition.
Classification Code—The classification assigned to the point, indicating the type of object or surface it represents.
Scan Angle Rank—The angle of the laser pulse from the sensor's nadir direction at the time of measurement.
File Marker—Value used to distinguish points originating from different LAS files.The file marker.
User Bit Field—A customizable attribute used to store point-specific information using an 8-bit unsigned integer value.
GPS Time—A GPS-based timestamp indicating when the point was captured.
Red Color—The red channel value of the point's RGB color.
Green Color—The green channel value of the point's RGB color.
Blue Color—The blue channel value of the point's RGB color.
Near Infrared—Represents the near-infrared (NIR) intensity value associated with the point.
Field Name—The corresponding field in which the specified LAS attribute will be stored.
Linear Unit
single_point
(Optional)
SINGLE_POINT—The output will be a point feature class.
NO_SINGLE_POINT—The output will be a multipoint feature class. This is the default.
Boolean
attribute[attribute,...]
(Optional)
INTENSITY—Represents the strength of the reflected laser signal recorded for the point.
RETURN_NUMBER—The return number recorded for the point from its originating laser pulse.
NUMBER_OF_RETURNS—Represents the number of returns recorded for the laser pulse from which the point was derived.
SCAN_DIRECTION_FLAG—The flag indicates whether the scan was progressing in the forward or reverse direction when the point was collected.
EDGE_OF_FLIGHTLINE—Identifies points located at the boundary of a flight line during data acquisition.
CLASSIFICATION—The classification assigned to the point, indicating the type of object or surface it represents.
SCAN_ANGLE_RANK—The angle of the laser pulse from the sensor's nadir direction at the time of measurement.
FILE_MARKER—Value used to distinguish points originating from different LAS files.The file marker.
USER_BIT_FIELD—A customizable attribute used to store point-specific information using an 8-bit unsigned integer value.
GPS_TIME—A GPS-based timestamp indicating when the point was captured.
COLOR_RED—The red channel value of the point's RGB color.
COLOR_GREEN—The green channel value of the point's RGB color.
COLOR_BLUE—The blue channel value of the point's RGB color.
COLOR_NIR—Represents the near-infrared (NIR) intensity value associated with the point.
Value Table
Code sample
LasToPoints example 1 (Python window)
The following sample demonstrates the use of this tool in the Python window.
