Minimum Bounding Volume (3D Analyst Tools)
Summary
Creates multipatch features that represent the volume of space occupied by a set of 3D features.
Illustration
Usage
  • The Sphere or Envelope method (geometry_type="SPHERE" or geometry_type = "ENVELOPE" in Python) provides a quick representation of the volume of space occupied by a set of 3D features.
  • The Convex hull option (geometry_type="CONVEX_HULL" in Python) provides greater detail than the Sphere or Envelope method but will not capture local depressions in the input features.
  • The Concave hull option (geometry_type="CONCAVE_HULL" in Python) provides the greatest amount of detail about the shape of the bounding volume but is computationally heavy and should not be used with large collections of input data.
  • When the resulting minimum bounding volume represents groups of input features, the fields used to separate the input will be added to the resulting multipatch. If the geometry characteristics are included in the minimum bounding volume, the following fields will be added to the output features:
    • MBV_Area—The total surface area of the minimum bounding volume
    • MBV_Volume—The total volume of the space contained by the multipatch feature
Parameters
Label Explanation Data type
Input Features
The LAS dataset or 3D features whose minimum bounding volume will be evaluated.
LAS Dataset Layer; Feature Layer
Z Value
The source of z-values for the input data.
Field
Output Feature Class
The feature class that will be produced.
Feature Class
Output Feature Class Type
(Optional)
Specifies the method that will be used to determine the geometry of the minimum bounding volume.
  • Convex hull—The smallest convex region surrounding the input data.
  • Sphere—The smallest sphere enclosing the input data.
  • Envelope—The XYZ extent of the input data.
  • Concave hull—The concave hull that encloses the input data.
String
Group Options
(Optional)
Specifies how the input features will be grouped; each group will be enclosed with one output multipatch.
  • None—Input features will not be grouped. This is the default. This option is not available for point input.
  • All—All input features will be treated as one group.
  • List—Input features will be grouped based on their common values in the specified field or fields in the group field parameter.
String
Group Field(s)
(Optional)
The field or fields in the input features that will be used to group features when List is specified as Group Option. At least one group field is required for the List option. All features that have the same value in the specified field or fields will be treated as a group.
Field
Add geometry characteristics as attributes to output
(Optional)
Specifies whether geometric attributes will be added to the output multipatch feature class.
  • Checked—Geometric attributes will be added to the output feature.
  • Unchecked—No geometric attributes will be added to the output feature. This is the default.
Boolean
Environments
Current Workspace, Extent, Output Coordinate System, Geographic Transformations
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
