Remove Terrain Points (3D Analyst Tools)
Summary
Removes points within an area of interest from one or more embedded feature classes.
Legacy:
This is a deprecated tool. This functionality has been added to the Delete Terrain Points tool.
Usage
This tool functions only on feature classes embedded in a terrain. The terrain and at least one embedded feature class must already exist.
A rectangular area of interest (AOI) is required. This defines the area in the embedded feature class where multipoint vertices will be deleted. If a multipoint crosses the AOI boundary, only those vertices within the boundary will be deleted.
Remove Terrain Points looks for an existing edit session to piggyback on. This supports undo if the edit session was initialized to support undo (for example, using Editor inside ArcMap). If there's no edit session, it starts and stops one itself, in which case there is no chance for an undo.
To use this tool on a terrain inside an ArcSDE database, the terrain needs to be registered as versioned. You do this by registering the feature dataset the terrain resides in as versioned.
Removing points from an embedded feature class will invalidate the terrain. Run Build Terrain after adding points.
Parameters
| Label | Explanation | Data type |
Input Terrain |
The terrain dataset to be modified |
Terrain Layer |
Embedded Feature Class |
One or more embedded feature classes from which points will be removed |
String |
Area of Interest |
The XY extent defining the area from which points will be removed |
Extent |
Derived output
Output Terrain |
The updated terrain dataset. |
Terrain Layer |
Environments
Current Workspace, Scratch Workspace, Minimize memory use during analysis on terrains
Licensing information
- Basic: Requires 3D Analyst
- Standard: Requires 3D Analyst
- Advanced: Requires 3D Analyst
