Terrain To Points (3D Analyst Tools)
Summary
Converts a terrain dataset into a new point or multipoint feature class.
Illustration
Terrain to Points Example
Usage
  • Points are extracted for the specified pyramid level resolution and area of interest.
  • If an embedded feature class is specified, the output points will only come from the embedded features. Otherwise, the output points will be derived from all points contributing to the terrain surface.
  • If an embedded feature contains lidar attributes, such as RGB, classification, or return values, the attributes will be written to the output feature class. However, the way the attributes are written will depend on the geometry type that is specified:
    • MULTIPOINT—Attributes will be stored in BLOB field.
    • POINT—Attributes will be stored in numeric fields.
Parameters
Label Explanation Data type
Input Terrain
The terrain dataset that will be processed.
Terrain Layer
Output Feature Class
The feature class that will be produced.
Feature Class
Pyramid Level Resolution
(Optional)
The z-tolerance or window-size resolution of the terrain pyramid level that will be used. The default is 0, or full resolution.
Double
Input Embedded Feature Class
(Optional)
The name of the terrain dataset's embedded points to be exported. If an embedded feature is specified, only the points from the feature will be written to the output. Otherwise, all points from all data sources in the terrain will be exported.
String
Output Feature Class Type
(Optional)
The geometry of the output feature class.
  • Multipoint—The output point features will be written to a multipoint feature class. This is the default.
  • Point—The output point features will be written to a point feature class.
String
Environments
Current Workspace, Extent, Output Coordinate System, Geographic Transformations, XY Resolution, XY Tolerance, Z Resolution, Z Tolerance, Output CONFIG Keyword, Auto Commit
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
