TIN Polygon Volume (3D Analyst Tools)
Summary
Calculates the volumetric and surface area between polygons of an input feature class and a TIN surface.
Legacy:
This is a deprecated tool. This functionality has been added to the Polygon Volume tool.
Usage
  • The input polygons and TIN need to overlap in horizontal extent in order for surface area or volume to be calculated.
Parameters
Label Explanation Data type
Input TIN
The input TIN.
TIN Layer
Input Feature Class
The input polygon feature class.
Feature Layer
Height Field
The name of the field containing polygon reference plane heights.
String
Reference Plane
(Optional)
The keyword used to indicate whether volume and surface area are calculated ABOVE the reference plane height of the polygons, or BELOW. The default is BELOW.
String
Volume Field
(Optional)
The name of the output field used to store the volume result. The default is Volume.
String
Surface Area Field
(Optional)
The name of the output field used to store the surface area result. The default is SArea.
String
Derived output
Output Feature Class
The updated feature class.
Feature Layer
Environments
Current Workspace, Scratch Workspace, Extent
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
