Update Feature Z (3D Analyst Tools)
Summary
Updates the z-coordinates of 3D feature vertices using a surface.
Usage
  • Only features that entirely overlap the input surface will have their vertices updated. Features that do not overlap the surface will be skipped.
    If the z-value obtained for a given vertex is outside of a geodatabase feature's spatial reference z-domain, the vertex's z-value will not be updated. Create a copy of the input features and specify an appropriate z-domain to process the affected features.
Parameters
Label Explanation Data type
Input Features
The 3D features whose vertex z-values will be modified.
Feature Layer
Input Surface
The surface that will be used to determine the new z-value for the 3D feature vertices.
LAS Dataset Layer; Mosaic Layer; Raster Layer; TIN Layer
Interpolation Method
(Optional)
Interpolation method used in determining information about the surface. The available options depend on the data type of the input surface:
  • BilinearAn interpolation method exclusive to the raster surface, which determines cell values from the four nearest cells. This is the only option available for a raster surface.
  • LinearDefault interpolation method for a TIN, terrain, and LAS dataset. Obtains elevation from the plane defined by the triangle that contains the XY location of a query point.
  • Natural NeighborsObtains elevation by applying area-based weights to the natural neighbors of a query point.
  • Conflate Minimum ZObtains elevation from the smallest z-value found among the natural neighbors of a query point.
  • Conflate Maximum ZObtains elevation from the largest z-value found among the natural neighbors of a query point.
  • Conflate Nearest ZObtains elevation from the nearest value among the natural neighbors of a query point.
  • Conflate Z Closest To MeanObtains elevation from the z-value that is closest to the average of all the natural neighbors of a query point.
String
Status Field
(Optional)
An existing numeric field that will be populated with values to reflect whether the feature's vertices were successfully updated. A value of 1 would be specified for updated features and 0 for features that were not updated. Features that partially overlap the surface will not be updated.
Field
Derived output
Updated Input Features
The updated 3D features whose vertex z-values have been modified.
Feature Layer
Environments
Current Workspace, Extent
Licensing information
  • Basic: Requires 3D Analyst
  • Standard: Requires 3D Analyst
  • Advanced: Requires 3D Analyst
