Generate Target Group Layer (Business Analyst Tools)
Summary
Generates a layer that identifies geographies that contain selected segments and categorized groups based on targets.
Usage
If the Boundary Layer parameter is not specified, the Extent environment will be used.
Targets are a subclassification of a Target Group parameter value, for example, Core and Development targets. A target can contain one or more segments.
Parameters
| Label | Explanation | Data type |
Geography Level |
The geography level that will be used to define the target layer. |
String |
Segmentation Base |
The segmentation base for the profile being created. The available options are provided by the segmentation dataset in use. |
String |
Output Feature Class |
The output feature class for the target layer. |
Feature Class |
Target Group |
A user-created group of targets. This is used if the dataset supports target groups. |
File |
Boundary Layer (Optional) |
The boundary that will determine the layer extent. |
Feature Layer |
Environments
Current Workspace, Data Source, Display Segment Names, Extent
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
