Generate Threshold Rings (Business Analyst Tools)
Summary
Creates a feature class of ring trade areas that expand around point features until the threshold value is reached.
Usage
  • The size of the output rings is determined by the Threshold Values parameter value provided for a selected Threshold Variable parameter value from the active Business Analyst dataset.
  • The Threshold Variable parameter accepts only variables of Count type. Median, Average, Percent, or Index cannot be used.
  • Multiple threshold rings can be created around each input by typing individual values into separate threshold value text boxes.
  • The ID Field parameter value uniquely identifies the point location around which threshold rings will be created.
Parameters
Label Explanation Data type
Input Features
The input point feature layer.
Feature Layer
Output Feature Class
The output feature class containing the threshold rings.
Feature Class
Threshold Variable
The selected Business Analyst dataset variable to which the threshold value will be applied.
Threshold variables must be numeric. No other statistic type is supported.
String
Threshold Values
The threshold variable value that will determine the size of the output rings. The rings will expand until they contain the threshold value of the selected variable.
Double
Distance Units
(Optional)
The distance units that will be used with the threshold values.
String
ID Field
(Optional)
The ID that uniquely identifies each input point and is included in the output as an attribute.
Field
Input Method
(Optional)
Specifies the type of value that will be used for each drive time.
  • Values—A constant value will be used (all trade areas will be the same size). This is the default.
  • Expression—The values from a field or an expression will be used (trade areas can be different sizes).
String
Expression
(Optional)
A fields-based expression that will be used to calculate the radii.
SQL Expression
Minimum Step
(Optional)
The minimum distance between one threshold area candidate and the next as the model approaches the threshold value to prevent infinite iterations.
Double
Threshold Percent Difference
(Optional)
The maximum percentage difference between the target value and threshold value that will be used when determining the threshold drive time, for example, 5 percent. The default value is 5.
Double
Environments
Current Workspace, Data Source, Geographic Transformations
Licensing information
  • Basic: Requires Business Analyst
  • Standard: Requires Business Analyst
  • Advanced: Requires Business Analyst
