Import Survey Profiles (Business Analyst Tools)
Summary
Imports segmentation profiles consisting of survey variable data.
Usage
Imported survey profiles contain count and percent values for the distribution of segments.
Multiple survey profiles can be selected to be imported simultaneously on the Add Data dialog box.
Survey profiles to be imported can only be selected from the active Business Analyst dataset. Manually constructed profiles cannot be imported with this tool.
When summed across all segments, survey profile values in the count column include all survey respondents in the country.
Parameters
| Label | Explanation | Data type |
Profiles |
The categories of survey variables that can be selected for importing as profiles. |
String |
Output Folder |
The folder that will contain the imported profiles. |
Folder |
Derived output
Output Profiles |
The output folder containing the segmentation profile project items. |
File |
Environments
Current Workspace, Data Source, Display Segment Names
Licensing information
- Basic: Requires Business Analyst
- Standard: Requires Business Analyst
- Advanced: Requires Business Analyst
