Calculate Adjacent Fields (Cartography Tools)
Summary
Creates fields and calculates values for the neighboring pages (polygon) of a grid polygon feature class.
The most common use case for this tool is to populate fields that can be used to label the adjacent pages in a map book. This tool appends eight new fields (each field representing one of the eight points of the compass: North, Northeast, East, Southeast, South, Southwest, West, and Northwest) to the input feature class and calculates values that identify the adjacent (neighboring) polygons, in each cardinal direction, for each feature in the input feature class.
Usage
This tool creates eight fields whose names are a combination of the Field Name value and direction. The direction is abbreviated. For example, if the Field Name value is PageName, the new field names created by the tool would be
PageName_N,PageName_NE,PageName_E,PageName_SE,PageName_S,PageName_SW,PageName_W, andPageName_NW. If the Field Name value is MyPoly, the new field names would beMyPoly_N,MyPoly_NE,MyPoly_E,MyPoly_SE,MyPoly_S,MyPoly_SW,MyPoly_W, andMyPoly_NW.The tool uses default names for new fields. The field names can be altered after the tool has run.
You can use fields from a joined table.
Parameters
| Label | Explanation | Data type |
Input Features |
The polygon grid index features that will be appended with adjacent field data. |
Feature Layer |
Field Name |
The field whose values will be used to populate adjacent field data. |
Field |
Derived output
Output Features |
The updated feature class with adjacent field data. |
Feature Layer |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
