Calculate Polygon Main Angle (Cartography Tools)
Summary
Calculates the dominant angles of input polygon features and assigns the values to a field to use to orient symbology such as markers or hatch lines within the polygons.
Illustration
Calculate Polygon Main Angle tool illustration.
The dominant polygon angle as applied to interior symbology is demonstrated for the three rotation methods.
Usage
  • The dominant angle of a polygon is the angle of the longest collection of segments that have similar orientation. For the purpose of symbol rotation, polygons are considered to be oriented upright when the dominant angle is horizontal. The angle perpendicular to the dominant polygon angle is recorded because this results in the expected orientation when using the value for symbol rotation.
  • The angle perpendicular to the dominant angle of the polygon will be stored in the specified field in decimal degrees from the origin point of the rotation method.
  • This tool is primarily for orthogonal polygons rather than polygons that are organically shaped.
Parameters
Label Explanation Data type
Input Features
The input polygon features.
Feature Layer
Angle Field
The field that will be updated with the polygon main angle values.
Field
Rotation Method
(Optional)
Specifies the method and origin point of rotation that will be used..
  • Geographic—The angle will be calculated clockwise with 0 at the top (north).
  • Arithmetic—The angle will be calculated counterclockwise with 0 at the right (east).
  • Graphic—The angle will be calculated counterclockwise with 0 at the top (north). This is the default.
String
Derived output
Updated Input Features
The updated input polygon features.
Feature Layer
Environments
Cartographic Coordinate System
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
