Create Overpass (Cartography Tools)
Summary
Creates bridge parapets and polygon masks at line intersections to indicate overpasses.
Illustration
Create Overpass tool illustration
A yellow polygon mask is created from margin dimensions to obscure a blue below line feature where it crosses a red above line feature. Gray bridge parapet decorations with angled wing ticks are also created.
Usage
  • Intersecting symbolized line features as inputs are required.
  • The same input can be used for the Input Above Features and the Input Below Features parameter values in the case of self-overlapping features. When the Input Above Features and Input Below Features parameter values are the same, an SQL expression is required for further refinement of feature selection. The tool will attempt to automatically identify which roads are above and below when this is not made clear with an SQL expression. Unexpected results can occur in this case, particularly at complex intersections with details that are smaller than the width of the road symbols.
  • This tool is identical to the Create Underpass tool except that the Expression parameter selects from the Input Above Features parameter value in this tool as well as from the Input Below Features parameter value in the Create Underpass tool.
Parameters
Label Explanation Data type
The input line feature layer containing lines that intersect—and will be symbolized as passing above—lines in the Input Below Features parameter value.
Layer
The input line feature layer containing lines that intersect—and will be symbolized as passing below—lines in the Input Above Features parameter value. These features will be masked by the polygons created in the Output Overpass Feature Class parameter value.
Layer
Margin Along
The length of the mask polygons along the Input Above Features parameter value, which is the distance in page units that the mask will extend beyond the width of the stroke symbol of the Input Below Features parameter value. This parameter value must be greater than or equal to zero. Choose a page unit (points, millimeters, and so on) for the margin; the default is points.
Linear Unit
Margin Across
The width of the mask polygons across the Input Above Features parameter value, which is the distance in page units that the mask will extend beyond the width of the stroke symbol of the Input Above Features parameter value. This parameter value must be greater than or equal to zero. Choose a page unit (points, millimeters, and so on) for the margin; the default is points.
Linear Unit
The output feature class that will be created to store polygons to mask the Input Below Features parameter value.
Feature Class
Output Mask Relationship Class
The output relationship class that will be created to store links between overpass mask polygons and the lines of the Input Below Features parameter value.
Relationship Class
Expression
(Optional)
An SQL expression that will be used to select a subset of features from the Input Above Features parameter value.
Use quotation marks for field names, for example, "MY_FIELD".
See SQL reference for query expressions used in ArcGIS for more information about SQL syntax.
SQL Expression
Output Decoration Feature Class
(Optional)
The output line feature class that will be created to store parapet features.
Feature Class
Wing Type
(Optional)
Specifies the wing style that will be used for the parapet features.
  • Wing ticks angled between above and below features—The wing tick of the parapet will be angled between the Input Above Features parameter value and the Input Below Features parameter value. This is the default.
  • Wing ticks parallel to below features—The wing tick of the overpass wing will be parallel to the Input Below Features parameter value.
  • No wing ticks created—No wing ticks will be created on the parapets.
String
Wing Tick Length
(Optional)
The length of the parapet wings in page units. The length must be greater than or equal to zero; the default length is 1. Choose a page unit (points, millimeters, and so on) for the length; the default is points. This parameter does not apply when the Wing Type parameter is set to No wing ticks created.
Linear Unit
Environments
Cartographic Coordinate System, Reference Scale
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
