Mobile Geodatabase To File Geodatabase (Conversion Tools)
Summary
Copies the contents of a mobile geodatabase to a new file geodatabase.
Usage
A mobile geodatabase uses SQLite and can be used in disconnected workflows in ArcGIS Maps SDKs apps. This tool allows you to copy the data from a mobile geodatabase to a file geodatabase so that it can be used in any client that supports file geodatabases.
Parameters
Label
Explanation
Data type
Input Mobile Geodatabase
The mobile geodatabase with the contents that will be copied to a new file geodatabase.
File
Output File Geodatabase
The name and location of the output file geodatabase, for example, c:\temp\outputGeodatabases\copiedFGDB.gdb.
File
arcpy.conversion.MobileGdbToFileGdb(in_mobile_gdb, out_file_gdb)
Name
Explanation
Data type
in_mobile_gdb
File
out_file_gdb
File
Code sample
MobileGdbToFileGdb example 1 (Python window)
The following Python window script demonstrates how to use the MobileGdbToFileGdb function in immediate mode.
import arcpy
arcpy.conversion.MobileGdbToFileGdb('D:\\data\\MobileGDBs\\delta.geodatabase',
'D:\\data\\copiedGDBs\\deltaFGDB.gdb')
MobileGdbToFileGdb example 2 (stand-alone script)
The following Python window script demonstrates how to use the MobileGdbToFileGdb function in a stand-alone script using the workspace environment.
# Import system modules
import arcpy
# Set environment settings
arcpy.env.workspace = 'C:\\data'
# Run CopyRuntimeGdbToFileGdb
arcpy.conversion.MobileGdbToFileGdb('D:\\MobileData\\replica.geodatabase',
'replica_Copy.gdb')
Environments
Current Workspace
Licensing information
Basic: Yes
Standard: Yes
Advanced: Yes
