PDF To TIFF (Conversion Tools)
Summary
Exports a .pdf file to Tagged Image File Format (TIFF).
Usage
  • If the Input PDF File parameter value includes georeference information, the Output TIFF File parameter value can be a GeoTIFF. A GeoTIFF can be used as a source for digitizing and viewing in ArcGIS Pro.
  • The tool supports both GeoPDF and ISO standards of georeferenced PDF documents.
  • If the Input PDF File parameter value consists of more than one page, the PDF Page Number parameter will display the pages in the .pdf file.
  • If the Input PDF File parameter value does not have a spatial reference, the PDF Map and Write GeoTIFF Tags parameters will be unavailable.
  • 3D GeoPDFs are not supported.
Parameters
Label Explanation Data type
Input PDF File
The input .pdf file to be exported to TIFF.
File
Output TIFF File
The output .tif file.
Raster Dataset
PDF Password
(Optional)
This parameter is unavailable at ArcGIS 3.6. It will be supported in a future release.
Encrypted String
PDF Page Number
(Optional)
The page number of the PDF document to export to TIFF.
Long
PDF Map
(Optional)
The map that will be exported.
In a .pdf file, a map is a defined container of graphics on the PDF page that has a spatial reference. A PDF map is equivalent to an ArcGIS Pro map in that it is the container for spatial data. A PDF document may have one or more maps. For example, a page may have a main map and an additional smaller overview or key map.
If the Write GeoTIFF Tags parameter value is specified, it will be used to set the output spatial reference of the .tif file.
If the Clip Output to Map parameter value is specified, it will be used to define the extent of the output .tif file.
If the page contains more than one map, each unique map on the PDF page will be listed by name. You can also use the LARGEST option to use the largest map in the PDF. This is the default.
For .pdf files that use the OGC GeoPDF standard, the only supported option is LARGEST.
If the page contains only one map, this parameter will be blank.
String
Clip Output to Map
(Optional)
Specifies whether the entire page or only the map will be exported.
  • Checked—Only the map specified in the PDF Map parameter will be exported to TIFF.
  • Unchecked—The entire page will be exported to TIFF. This is the default.
Boolean
Resolution in dpi
(Optional)
The resolution of the output .tif file in dots per inch (DPI). The default is 250.
Long
Color Mode
(Optional)
Specifies the number of bits that will be used to describe color.
Additional options will be supported in a future release.
  • RGB true color—32-bit RGBA color will be used. If the Compression parameter is set to Jpeg, 24-bit RGB color will be used. This is the default.
String
Compression
(Optional)
Specifies the compression scheme for the output .tif file.
  • LZW—Lempel-Ziv-Welch, a lossless data compression, will be used. This is the default.
  • Deflate—A lossless data compression will be used.
  • Jpeg—JPEG lossy compression will be used. The compression quality will be automatically set to 100 and cannot be changed.
  • None—Compression will not be applied.
  • PackBits—PackBits lossless compression will be used.
String
Write GeoTIFF Tags
(Optional)
Specifies whether GeoTIFF tags will be added to the output. This parameter is only supported if the Input PDF File parameter value has a spatial reference.
  • Checked—GeoTIFF tags will be added to the output. This is the default.
  • Unchecked—GeoTIFF tags will not be added to the output.
Boolean
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
