Add GPS Metadata Fields (Data Management Tools)
Summary
Adds GNSS fields to a feature class in a geodatabase.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • The following fields will be added to an input polyline or polygon feature class. The geodatabase domains will also be created, if they do not already exist, and associated with the appropriate fields.
    Field alias
    Field name
    Data type
    Domain
    Average horizontal accuracy (m)
    ESRIGNSS_AVG_H_RMS
    Double
    Average vertical accuracy (m)
    ESRIGNSS_AVG_V_RMS
    Double
    Worst horizontal accuracy (m)
    ESRIGNSS_WORST_H_RMS
    Double
    Worst vertical accuracy (m)
    ESRIGNSS_WORST_V_RMS
    Double
    Worst fix type
    ESRIGNSS_WORST_FIXTYPE
    Short
    ESRI_FIX_TYPE_DOMAIN
    • 0—Fix not valid
    • 1—GPS
    • 2—Differential GPS
    • 4—RTK Fixed
    • 5—RTK Float
    Number of manual locations
    ESRIGNSS_MANUAL_LOCATIONS
    Long
  • The following fields will be added to an input point feature class. The geodatabase domains will also be created, if they do not already exist, and associated with the appropriate fields.
    Field alias
    Field name
    Field type
    Domain
    Position source type
    ESRIGNSS_POSITIONSOURCETYPE
    Short
    ESRI_POSITIONSOURCETYPE_DOMAIN
    • 0—Unknown
    • 1—User defined
    • 2—Integrated (System) Location Provider
    • 3—External GNSS Receiver
    • 4—Network Location Provider
    Receiver Name
    ESRIGNSS_RECEIVER
    String (50)
    Latitude
    ESRIGNSS_LATITUDE
    Double
    Longitude
    ESRIGNSS_LONGITUDE
    Double
    Altitude
    ESRIGNSS_ALTITUDE
    Double
    Horizontal Accuracy (m)
    ESRIGNSS_H_RMS
    Double
    Vertical Accuracy (m)
    ESRIGNSS_V_RMS
    Double
    Fix Time
    ESRIGNSS_FIXDATETIME
    Date
    Fix Type
    ESRIGNSS_FIXTYPE
    Short
    • 0—Fix not valid
    • 1—GPS
    • 4—RTK Fixed
    • 5—RTK Float
    Correction Age
    ESRIGNSS_CORRECTIONAGE
    Double
    Station ID
    ESRIGNSS_STATIONID
    Short
    Number of Satellites
    ESRIGNSS_NUMSATS
    Short
    ESRI_NUM_SATS_DOMAIN
    Range: 0-99
    PDOP
    ESRIGNSS_PDOP
    Double
    HDOP
    ESRIGNSS_HDOP
    Double
    VDOP
    ESRIGNSS_VDOP
    Double
    Direction of travel (°)
    ESRIGNSS_DIRECTION
    Double
    Speed (km/h)
    ESRIGNSS_SPEED
    Double
    Compass reading (°)
    ESRISNSR_AZIMUTH
    Double
    Average Horizontal Accuracy (m)
    ESRIGNSS_AVG_H_RMS
    Double
    Average Vertical Accuracy (m)
    ESRIGNSS_AVG_V_RMS
    Double
    Averaged Positions
    ESRIGNSS_AVG_POSITIONS
    Long
    Standard Deviation (m)
    ESRIGNSS_H_STDDEV
    Double
  • The following fields will also be added to an input point feature class when the Include offset metadata fields parameter is checked.
    Field alias
    Field name
    Data type
    Domain
    Offset method
    ESRISNSR_OFFSET_METHOD
    String
    ESRI_OFFSET_METHOD_DOMAIN
    • Azimuth-Azimuth
    • Distance-Angle
    • Distance-Azimuth
    • Distance-Distance
    • Azimuth-Azimuth-Backsight
    • Distance-Azimuth-Backsight
    • Distance-Distance-Backsight
    • User-Defined
    Rangefinder name
    ESRISNSR_OFFSET_DEVICE
    String
    GNSS Antenna height (m)
    ESRIGNSS_ANTENNA_HEIGHT
    Double
    Rangefinder height (m)
    ESRISNSR_OFFSET_LASER_HEIGHT
    Double
    Laser target height (m)
    ESRISNSR_OFFSET_LASER_TARGET_HT
    Double
    Rangefinder Magnetic variation (°)
    ESRISNSR_OFFSET_MAG_VAR
    Double
    CP1 Latitude
    ESRIGNSS_CP1_LATITUDE
    Double
    CP1 Longitude
    ESRIGNSS_CP1_LONGITUDE
    Double
    CP1 Ellipsoidal height (m)
    ESRIGNSS_CP1_ALTITUDE
    Double
    CP1 Horizontal accuracy (m)
    ESRIGNSS_CP1_H_RMS
    Double
    CP1 Vertical accuracy (m)
    ESRIGNSS_CP1_V_RMS
    Double
    CP1 Fix time
    ESRIGNSS_CP1_FIXDATETIME
    Date
    CP1 Fix type
    ESRIGNSS_CP1_FIXTYPE
    Short
    • 0—Fix not valid
    • 1—GPS
    • 4—RTK Fixed
    • 5—RTK Float
    CP1 Correction age
    ESRIGNSS_CP1_CORR_AGE
    Double
    CP1 Station ID
    ESRIGNSS_CP1_STATIONID
    Short
    CP1 Number of satellites
    ESRIGNSS_CP1_NUMSATS
    Double
    CP1 PDOP
    ESRIGNSS_CP1_PDOP
    Double
    CP1 HDOP
    ESRIGNSS_CP1_HDOP
    Double
    CP1 VDOP
    ESRIGNSS_CP1_VDOP
    Double
    CP1 Average horizontal accuracy (m)
    ESRIGNSS_CP1_AVG_H_RMS
    Double
    CP1 Average vertical accuracy (m)
    ESRIGNSS_CP1_AVG_V_RMS
    Double
    CP1 Averaged positions
    ESRIGNSS_CP1_AVG_POSITIONS
    Short
    CP1 Standard deviation (m)
    ESRIGNSS_CP1_H_STDDEV
    Double
    CP1 Laser slope distance (m)
    ESRISNSR_CP1_SLOPE_DIST
    Double
    CP1 Laser inclination (°)
    ESRISNSR_CP1_INCLINATION
    Double
    CP1 Laser azimuth (°)
    ESRISNSR_CP1_AZIMUTH
    Double
    CP2 Latitude
    ESRIGNSS_CP2_LATITUDE
    Double
    CP2 Longitude
    ESRIGNSS_CP2_LONGITUDE
    Double
    CP2 Ellipsoidal height (m)
    ESRIGNSS_CP2_ALTITUDE
    Double
    CP2 Horizontal accuracy (m)
    ESRIGNSS_CP2_H_RMS
    Double
    CP2 Vertical accuracy (m)
    ESRIGNSS_CP2_V_RMS
    Double
    CP2 Fix time
    ESRIGNSS_CP2_FIXDATETIME
    Date
    CP2 Fix type
    ESRIGNSS_CP2_FIXTYPE
    Short
    CP2 Correction age
    ESRIGNSS_CP2_CORR_AGE
    Double
    CP2 Station ID
    ESRIGNSS_CP2_STATIONID
    Short
    CP2 Number of satellites
    ESRIGNSS_CP2_NUMSATS
    Double
    CP2 PDOP
    ESRIGNSS_CP2_PDOP
    Double
    CP2 HDOP
    ESRIGNSS_CP2_HDOP
    Double
    CP2 VDOP
    ESRIGNSS_CP2_VDOP
    Double
    CP2 Average horizontal accuracy (m)
    ESRIGNSS_CP2_AVG_H_RMS
    Double
    CP2 Average vertical accuracy (m)
    ESRIGNSS_CP2_AVG_V_RMS
    Double
    CP2 Averaged positions
    ESRIGNSS_CP2_AVG_POSITIONS
    Short
    CP2 Standard deviation (m)
    ESRIGNSS_CP2_H_STDDEV
    Double
    CP2 Laser slope distance (m)
    ESRISNSR_CP2_SLOPE_DIST
    Double
    CP2 Laser inclination (°)
    ESRISNSR_CP2_INCLINATION
    Double
    CP2 Laser azimuth (°)
    ESRISNSR_CP2_AZIMUTH
    Double
Parameters
Label Explanation Data type
Input Features
The input feature class that will be updated. The input can be a point, polyline, or polygon feature class.
Feature Layer
(Optional)
Specifies whether offset metadata fields will be added to the input feature class. This parameter is only applicable to point feature classes.
  • Checked—Offset metadata fields will be added to the input feature class.
  • Unchecked—Offset metadata fields will not be added to the input feature class. This is the default.
Boolean
Derived output
Updated Features
The updated features.
Feature Layer
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
