Add Incrementing ID Field (Data Management Tools)
Summary
Adds a database-maintained, incrementing ID field to an existing table or feature class in a Dameng, IBM Db2, Microsoft Azure SQL Database, Microsoft SQL Server, Oracle, or PostgreSQL database. A database-maintained ID field is required for all feature classes or tables you plan to edit through a feature service.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • You cannot run this tool on tables or feature classes that are registered with the geodatabase.
  • You must be the owner of the table or feature class to add an ID field to it.
  • If you do not specify a name for the field, ObjectID is used by default. If a field named ObjectID already exists, the tool will not run until you provide a different name.
  • If a database-maintained, incrementing ID field already exists, this tool will not add another one.
  • The following field types will be added:
    DBMS
    Data type
    Dameng
    int32 with identity property
    Db2
    integer as identity
    Oracle
    number with identity
    PostgreSQL
    serial
    SQL Server
    integer with identity property
Parameters
Label Explanation Data type
Input Table
The location and name of the table or feature class to which an ID field will be added.
Table View
Field Name
(Optional)
The name to be used for the ID field. If no input is provided, the default ObjectID will be used.
String
Derived output
Updated Input Table
The input table that is updated to include an incrementing ID field.
Table
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
