Change Dataset Schema (Data Management Tools)
Summary
Moves a dataset in an enterprise geodatabase to a new database schema.
Usage
  • Only enterprise geodatabases in SQL Server are supported.
  • The input dataset must be registered with the geodatabase.
  • The database connection must have privileges to alter the schema of the dataset and its associated database objects.
  • The dataset cannot contain or participate in objects that do not support schema changes.
  • Any external references or services that use the dataset must be reestablished after running the tool.
Parameters
Label Explanation Data type
Input Dataset
The dataset for which the schema will be changed.
Table View; Feature Dataset
New Schema
The database schema that will be used to qualify the input dataset.
String
Derived output
Output Dataset
The input dataset qualified by the new database schema.
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
