Compress File Geodatabase Data (Data Management Tools)
Summary
Compresses all the contents in a geodatabase, all the contents in a feature dataset, or an individual stand-alone feature class or table.
Usage
  • Once compressed, a feature class or table is read-only and cannot be edited. Compression is ideally suited to mature datasets that do not require further editing. However, if required, a compressed dataset can always be uncompressed to return it to its original, read-write format.
  • When you compress a geodatabase, all feature classes and tables in it are also compressed.
  • When you compress a feature dataset, all its feature classes are also compressed.
  • When you specify a geodatabase as input, this tool compresses all vector feature classes and tables in the geodatabase. It does not compress raster catalogs or raster datasets. If it encounters these in the specified geodatabase, it skips over them. You can compress a raster catalog or a raster dataset with this tool, but the data does not reduce in size. This support is provided strictly as a means to allow ArcGIS Publisher to package to compressed and locked file geodatabase raster catalogs and datasets.
    Caution:
    A dataset that contains any of the following field data types will not be compressed:
    Learn more about compressing file geodatabase data
  • You cannot compress or uncompress individual feature classes in a feature dataset to produce a mixed state in which some feature classes are compressed and others are not. Compressed feature datasets allow you to add an uncompressed feature class through operations such as creating a new, empty feature class, copying and pasting, and importing. However, you cannot edit the uncompressed feature class if there are compressed feature classes in the same feature dataset. Once you've finished adding one or more uncompressed feature classes, you can recompress or uncompress the feature dataset so all its feature classes are either compressed or uncompressed.
  • When you display compressed feature class records, they may not display in the same order as they did before you compressed the data. The records display in the order in which they are compressed and stored.
  • When using lossless compression, floating-point values will be preserved, but compression will not be as effective. With nonlossless compression, floating-point values will be changed, but not below the limit of adequate precision. For example, state boundaries do not usually need to be measured to nanometer precision. Nonlossless compression is up to 20 percent smaller than lossless.
Parameters
Label Explanation Data type
Input file geodatabase data
The geodatabase, feature dataset, feature class, or table that will be compressed.
Feature Dataset; Geometric Network; Raster Layer; Table View; Workspace
Lossless compression
Specifies whether lossless compression will be used.
This parameter is ignored for file geodatabases earlier than 10.0.
  • Checked—Lossless compression will be used. This is the default.
  • Unchecked—Lossless compression will not be used.
Boolean
Derived output
Compressed Input Data
The compressed input data.
Workpsace; Feature Dataset; Table View; Raster Layer; Geometric Network
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
