Configure Geodatabase Log File Tables (Data Management Tools)
Summary
Alters the type of log file tables used by an earlier release enterprise geodatabase to maintain lists of records cached by ArcGIS.
Usage
  • This tool only functions with enterprise geodatabase version 10.9.0.2.7 or earlier in IBM Db2 or enterprise geodatabase version 10.7.0.2.3 or earlier in Oracle.
  • Only the geodatabase administrator can run the Configure Geodatabase Log File Tables tool.
Parameters
Label Explanation Data type
Input Database Connection
A database connection (.sde file) to the enterprise geodatabase where the log file table configuration will be changed. The connection must be made as the geodatabase administrator.
Workspace
Log File Type
Specifies the type of log file tables the geodatabase will use.
  • Session log file—Session-based log file tables for selection sets will be used. Session-based log file tables are dedicated to a single session and may contain multiple selection sets.
  • Shared log file—Shared log file tables for selection sets will be used. Shared log file tables are shared by all sessions that connect as the same user.
String
Number of pooled session-based log file tables to be owned by the administrator
(Optional)
The number of tables included in the pool that the geodatabase will use if a pool of session-based log file tables owned by the geodatabase administrator is used.
Long
Create session-based log file tables in the TempDB database (Microsoft SQL Server only)
(Optional)
This parameter is no longer applicable in any supported ArcGIS release.
Boolean
Derived output
Updated Input Workspace
The updated input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
